1. Overview[edit source]
This stage explains how to connect the Linux terminal of your board to your host computer through the ST-LINK/V2-1.
Then you can see how to execute basic commands with the Linux command line interface in order to be familiarized with the Linux console.
2. The serial terminal[edit source]
The serial terminal allows you to communicate with the board trough an UART serial interface.
  • Install minicom
PC $> sudo apt-get install minicom
  • Get the ttyACM device instance that needs to be used to access the ST-LINK/V2-1
PC $> ls /dev/ttyACM*
/dev/ttyACM0
PC $> minicom -D /dev/ttyACM0
Welcome to minicom 2.7
OPTIONS: I18n
Port /dev/ttyACM0, 15:56:03
Press CTRL-A Z for help on special keys
  • Press the reset button to reset the board. You should see logs displayed in the minicom window
For ecosystem release v2.1.0 More info.png :
NOTICE:  CPU: STM32MP157FAA Rev.Z
NOTICE:  Model: STMicroelectronics STM32MP157F eval daughter on eval mother
NOTICE:  Board: MB1263 Var4.0 Rev.C-03
INFO:    Reset reason (0x14):
INFO:    PMIC version = 0x20
INFO:    Using SDMMC
INFO:      Instance 1
NOTICE:  BL2: v2.2-r2.0(debug):v2.2-dirty
NOTICE:  BL2: Built : 13:36:23, Oct 22 2019
INFO:    Using crypto library 'stm32_crypto_lib'
INFO:    RAM: DDR3-DDR3L 32bits 533000Khz
INFO:    Memory size = 0x40000000 (1024 MB)
INFO:    BL2 runs SP_MIN setup
INFO:    Loading image id=4 at address 0x2ffeb000
INFO:    Image id=4 loaded: 0x2ffeb000 - 0x2ffff000
INFO:    STM32 Image size : 909210
INFO:    Image id=5 loaded: 0xc0100000 - 0xc01ddf9a
WARNING: Skip signature check (header option)
NOTICE:  ROTPK is not deployed on platform. Skipping ROTPK verification.
NOTICE:  BL2: Booting BL32
INFO:    Entry point address = 0x2ffeb000
INFO:    SPSR = 0x1d3
NOTICE:  SP_MIN: v2.2-r2.0(debug):v2.2-dirty
NOTICE:  SP_MIN: Built : 13:36:23, Oct 22 2019
INFO:    ARM GICv2 driver initialized
INFO:    Set calibration timer to 60 sec
INFO:    stm32mp IWDG1 (12): Secure
INFO:    SP_MIN: Initializing runtime services
INFO:    SP_MIN: Preparing exit to normal world
U-Boot 2020.01-stm32mp-r2 (Jan 06 2020 - 20:56:31 +0000)
Board: stm32mp1 in trusted mode (st,stm32mp157f-ev1)
DRAM:  1 GiB
Clocks:
- MPU : 800 MHz
- MCU : 208.878 MHz
- AXI : 266.500 MHz
- PER : 24 MHz
- DDR : 533 MHz
NAND:  1024 MiB
In:    serial
Out:   serial
Err:   serial
Boot over mmc0!
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:4...
Found /mmc0_extlinux/stm32mp157f-ev1_extlinux.conf
Retrieving file: /mmc0_extlinux/stm32mp157f-ev1_extlinux.conf
706 bytes read in 32 ms (21.5 KiB/s)
Retrieving file: /splash.bmp
18244 bytes read in 32 ms (556.6 KiB/s)
Select the boot mode
1:      OpenSTLinux
2:      stm32mp157f-ev1-a7-examples
3:      stm32mp157f-ev1-m4-examples
Retrieving file: /uInitrd
3632201 bytes read in 185 ms (18.7 MiB/s)
Retrieving file: /uImage
7341840 bytes read in 342 ms (20.5 MiB/s)
append: root=PARTUUID=e91c4e10-16e6-4c0e-bd0e-77becf4a3582 rootwait rw console=ttySTM0,115200
Retrieving file: /stm32mp157f-ev1.dtb
111905 bytes read in 36 ms (3 MiB/s)
   Image Name:   Linux-5.4.56
   Created:      2020-08-05   7:59:52 UTC
   Data Size:    7341776 Bytes = 7 MiB
   Load Address: c2000040
   Entry Point:  c2000040
   Verifying Checksum ... OK
   XIP Kernel Image
   Loading Ramdisk to cfc89000, end cffffc49 ... OK
   Loading Device Tree to cfc6a000, end cfc88520 ... OK
Starting kernel ...
[    0.000000] Linux version 5.4.56 (oe-user@oe-host) (gcc version 9.3.0 (GCC)) #1 SMP PREEMPT Wed Aug 5 07:59:52 UTC 2020
[    0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[    0.000000] CPU: div instructions available: patching division code
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] OF: fdt: Machine model: STMicroelectronics STM32MP157F eval daughter on eval mother
[    0.000000] Memory policy: Data cache writealloc
[    0.000000] Reserved memory: created DMA memory pool at 0x10000000, size 0 MiB
[    0.000000] OF: reserved mem: initialized node mcuram2@10000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x10040000, size 0 MiB
[    0.000000] OF: reserved mem: initialized node vdev0vring0@10040000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x10041000, size 0 MiB
[    0.000000] OF: reserved mem: initialized node vdev0vring1@10041000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x10042000, size 0 MiB
[    0.000000] OF: reserved mem: initialized node vdev0buffer@10042000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x30000000, size 0 MiB
[    0.000000] OF: reserved mem: initialized node mcuram@30000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x38000000, size 0 MiB
[    0.000000] OF: reserved mem: initialized node retram@38000000, compatible id shared-dma-pool
[    4.051696] asoc-audio-graph-card sound: dir-hifi <-> 4000d000.audio-controller mapping ok
[    4.058764] asoc-audio-graph-card sound: dmic-hifi <-> 4400d000.dfsdm:filter@0:dfsdm-d mapping ok
[    4.067948] asoc-audio-graph-card sound: dmic-hifi <-> 4400d000.dfsdm:filter@1:dfsdm-d mapping ok
[    4.076655] asoc-audio-graph-card sound: dmic-hifi <-> 4400d000.dfsdm:filter@2:dfsdm-d mapping ok
[    4.085961] asoc-audio-graph-card sound: dmic-hifi <-> 4400d000.dfsdm:filter@3:dfsdm-d mapping ok
[    4.094887] hub 2-1:1.0: USB hub found
[    4.097958] hub 2-1:1.0: 4 ports detected
[    4.133136] input: joystick as /devices/platform/joystick/input/input2
[    4.139783] stm32_rtc 5c004000.rtc: setting system clock to 2000-01-01T00:05:13 UTC (946685113)
[    4.149753] ALSA device list:
[    4.151270]   #0: STM32MP1-EV
[    4.159175] Freeing unused kernel memory: 1024K
[    4.163367] Run /init as init process
Starting version 244.3+
[    5.858706] EXT4-fs (mmcblk0p6): recovery complete
[    5.864217] EXT4-fs (mmcblk0p6): mounted filesystem with ordered data mode. Opts: (null)
[    6.284242] systemd[1]: System time before build time, advancing clock.
[    6.415692] NET: Registered protocol family 10
[    6.447816] Segment Routing with IPv6
[    6.482791] systemd[1]: systemd 244.3+ running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR -SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS -)
[    6.503966] systemd[1]: Detected architecture arm.
Welcome to ST OpenSTLinux - Weston - (A Yocto Project Based Distro) 3.1-openstlinux-5-4-dunfell-mp1-20-11-12 (dunfell)!
[    6.632901] systemd[1]: Set hostname to <stm32mp1>.
[    6.645159] systemd[1]: Hardware watchdog 'STM32 Independent Watchdog', version 0
[    6.652457] systemd[1]: Set hardware watchdog to 32s.
[    7.380195] systemd[1]: Unnecessary job for /dev/ttySTM0 was removed.
[    7.392493] systemd[1]: Created slice system-getty.slice.
[  OK  ] Created slice system-getty.slice.
[  OK  ] Started Serial Getty on ttySTM0.
[  OK  ] Reached target Login Prompts.
         Starting Weston Wayland Compositor (on tty7)...
[  OK  ] Started Weston Wayland Compositor (on tty7).
[  OK  ] Created slice User Slice of UID 0.
         Starting User Runtime Directory /run/user/0...
[  OK  ] Started User Runtime Directory /run/user/0.
         Starting User Manager for UID 0...
[  OK  ] Started Sound Service.
[  OK  ] Reached target Multi-User System.
         Starting Update UTMP about System Runlevel Changes...
[  OK  ] Started Update UTMP about System Runlevel Changes.
[  OK  ] Started User Manager for UID 0.
[  OK  ] Started Session c1 of user root.
ST OpenSTLinux - Weston - (A Yocto Project Based Distro) 3.1-openstlinux-5-4-dunfell-mp1-20-11-12 stm32mp1 ttySTM0
root@stm32mp1:~#
For ecosystem release v2.0.0 More info.png :
Board $> cat /etc/build
Build Configuration:  |
BB_VERSION = 1.46.0
BUILD_SYS = x86_64-linux
NATIVELSBSTRING = universal
MACHINE = stm32mp1
DISTRO = openstlinux-weston
DISTRO_VERSION = 3.1-openstlinux-5-4-dunfell-mp1-20-11-12
TARGET_FPU = hard
MANIFESTVERSION = ostl-20-11-12-rc10
DISTRO_CODENAME = dunfell
ACCEPT_EULA_stm32mp1 = 1
GCCVERSION = 9.%
Layer Revisions:      |
meta-python       = default.xml:144077083457ccb75700777d5e6b1da9aaff01aa
meta-oe           = default.xml:144077083457ccb75700777d5e6b1da9aaff01aa
meta-gnome        = default.xml:144077083457ccb75700777d5e6b1da9aaff01aa
meta-xfce         = default.xml:144077083457ccb75700777d5e6b1da9aaff01aa
meta-initramfs    = default.xml:144077083457ccb75700777d5e6b1da9aaff01aa
meta-multimedia   = default.xml:144077083457ccb75700777d5e6b1da9aaff01aa
meta-networking   = default.xml:144077083457ccb75700777d5e6b1da9aaff01aa
meta-webserver    = default.xml:144077083457ccb75700777d5e6b1da9aaff01aa
meta-filesystems  = default.xml:144077083457ccb75700777d5e6b1da9aaff01aa
meta-perl         = default.xml:144077083457ccb75700777d5e6b1da9aaff01aa
meta-st-stm32mp   = default.xml:e0168b92a0c00b1f6dff2411b8e2d5d0d406a05e
meta-qt5          = default.xml:fdd19517e17240b0b61765bd02fc483a1bde986f
meta-st-openstlinux = default.xml:aecec7a497fa7fc1abf05a8c376dd7e962da827c
meta              = default.xml:b39bda4cc62db12c0edfbe489d5a7f5988ede6a9 -- modified
Board $> uname -a
Linux stm32mp1 5.4.56 #1 SMP PREEMPT Wed Aug 5 07:59:52 UTC 2020 armv7l armv7l armv7l GNU/Linux
Board $> cat /proc/version
Board $> df -h
devtmpfs        370M     0  370M   0% /dev
/dev/mmcblk0p6  690M  416M  229M  65% /
tmpfs           436M   64K  436M   1% /dev/shm
tmpfs           436M  8.9M  427M   3% /run
tmpfs           436M     0  436M   0% /sys/fs/cgroup
tmpfs           436M  4.0K  436M   1% /tmp
/dev/mmcblk0p4   58M   14M   41M  25% /boot
/dev/mmcblk0p5   15M  6.7M  6.8M  50% /vendor
tmpfs           436M  144K  436M   1% /var/volatile
/dev/mmcblk0p7  1.1G   40M  956M   4% /usr/local
tmpfs            88M     0   88M   0% /run/user/0
3.5. ssh connection (only if Ethernet cable is connected)[edit source]
Board $> ip addr show eth0
  • On the host computer connect the terminal to the board using ssh
PC $> ssh root@xx.xx.xx.xx
root@stm32mp1:~#
