STM32MP13 SYSCFG internal peripheral
1 Article purpose[edit]
  • briefly introduce the SYSCFG peripheral and its main features
  • explain how it can be allocated to the three runtime contexts and linked to the corresponding software components
  • explain, when necessary, how to configure the SYSCFG peripheral.
2 Peripheral overview[edit]
The SYSCFG peripheral is used to configure various system aspects like IOs compensation, Ethernet clocking path, …
2.1 Features[edit]
Refer to the STM32MP13 reference manuals for the complete list of features, and to the software components, introduced below, to see which features are really implemented in ST software.
2.2 Security support[edit]
The SYSCFG is a non secure peripheral.
3 Peripheral usage and associated software[edit]
3.1 Boot time[edit]
The SYSCFG peripheral is configured by TF-A and U-Boot at boot time.
3.2 Runtime[edit]
3.2.1 Overview[edit]
Linux can directly change the SYSCFG at runtime from various drivers.
For instance, I2C fast mode plus (FM+) can be enabled for each instance in the SYSCFG so Linux I2C driver uses syscon [1] to enable this mode in the SYSCFG for the instances allocated to itself.
3.2.2 Software frameworks[edit]
OP-TEE Linux
Core SYSCFG Linux syscon framework[1]
3.2.3 Peripheral configuration[edit]
3.2.4 Peripheral assignment[edit]
non-secure
Core SYSCFG SYSCFG
4 References[edit]
