STM32MP13 RNG internal peripheral
1 Article purpose[edit]
  • briefly introduce the RNG peripheral and its main features
  • explain how to configure the RNG peripheral.
2 Peripheral overview[edit]
The RNG peripheral is used to provide 32-bit random numbers.
2.1 Features[edit]
Refer to STM32MP13 reference manuals for the complete list of features, and to the software components, introduced below, to know which features are really implemented.
2.2 Security support[edit]
RNG is a secure peripheral (under ETZPC control).
3 Peripheral usage and associated software[edit]
3.1 Boot time[edit]
RNG instance is used to seed the DPA peripherals which are connected over the interval RNG Bus: SAES and PKA. It is also used to generate random numbers required for secure boot processing such as key generation for DDRMCE encryption key.
3.2 Runtime[edit]
3.2.1 Overview[edit]
RNG instances can be allocated to:
Chapter #Peripheral assignment exposes which instance can be assigned to which context.
3.2.2 Software frameworks[edit]
OP-TEE Linux
Security RNG OP-TEE RNG driver Linux hardware random framework
3.2.3 Peripheral configuration[edit]
3.2.4 Peripheral assignment[edit]
non-secure
Security RNG RNG Assignment (single choice)
4 How to go further[edit]
Not applicable.
5 References[edit]
