STM32MP13 HASH internal peripheral
1 Article purpose[edit]
  • briefly introduce the HASH peripheral and its main features
  • explain, when necessary, how to configure the HASH peripheral.
2 Peripheral overview[edit]
The HASH peripheral is used to compute a message digest.
Digest algorithms could be:
  • SHA[1] (1, 224, 256, 384, 512)
  • Keccak-based functions[2]
    • SHA3 (224, 256, 384, 512)
    • Shake
    • RawShake
The HASH peripheral is also able to give the HMAC[3] used for authentication using the same algorithm support.
2.1 Features[edit]
Refer to the STM32MP13 reference manuals for the complete list of features, and to the software components, introduced below, to see which features are implemented.
2.2 Security support[edit]
HASH is a secure peripheral (under ETZPC control)
3 Peripheral usage and associated software[edit]
3.1 Boot time[edit]
HASH instance is used as boot device to support binary authentication.
3.2 Runtime[edit]
3.2.1 Overview[edit]
HASH instance can be allocated to:
3.2.2 Software frameworks[edit]
OP-TEE Linux
Security HASH OP-TEE HASH driver Linux Crypto framework
3.2.3 Peripheral configuration[edit]
3.2.4 Peripheral assignment[edit]
non-secure
Security HASH HASH Assignment (single choice)
4 References[edit]
