STM32MP13 ETZPC internal peripheral
1 Article purpose[edit]
  • briefly introduce the ETZPC peripheral and its main features
  • explain how it can be allocated to the three runtime contexts and linked to the corresponding software components
  • explain how to configure the ETZPC peripheral if necessary.
2 Peripheral overview[edit]
The ETZPC peripheral is used to configure TrustZone security in a STM32 MPU device. That STM32 MPU devicehas bus masters and slaves with programmable-security attributes (securable resources) such as:
  • on-chip RAM/ROM with programmable secure region size
  • AHB and APB peripherals to be made secure
  • AHB masters to be granted secure rights
The ETZPC peripheral also allows peripheral isolation. With MCU isolation, some peripherals can be assigned to Cortex-M4 context execution only. Those peripherals will not be accessible for Cortex-A7 contexts (secure and non-secure).
2.1 Features[edit]
Refer to the STM32MP13 reference manuals for the complete list of features, and to the software components, introduced below, to see which features are implemented.
2.2 Security support[edit]
The ETZPC is a secure peripheral.
3 Peripheral usage and associated software[edit]
3.1 Boot time[edit]
The ETZPC is configured at boot time to setup the platform security.
3.2 Runtime[edit]
3.2.1 Overview[edit]
The ETZPC is a system peripheral and is controlled by the Arm® Cortex®-A7 secure.
3.2.2 Software frameworks[edit]
OP-TEE Linux
Security ETZPC OP-TEE ETZPC driver Read/Write access U-Boot
Read only access
Resource Manager Utility
Read only access
Configuration made by A7 secure.
U-Boot updates the Linux
device tree.
3.2.3 Peripheral configuration[edit]
The configuration is applied by the firmware running in a secure context.
This configuration is done in OP-TEE, through device tree.
Refer to ETZPC device tree configuration.
3.2.4 Peripheral assignment[edit]
non-secure
Security ETZPC ETZPC
4 How to go further[edit]
The ETZPC is an STMicroelectronics extension of the Arm® peripheral: TrustZone Protection Controller[1]
5 References[edit]
