| This article is only applicable to M33-TD flavor |
This article gives some guidelines to support secure project on Arm®-Cortex®-M33 for M33-TD flavor
focuses on building secure firmware (Trusted Firmware-M) alongside nonsecure firmware, and provides guidance on how to debug both. It can be used on both Windows and Linux workstations. However, the screenshots in this article were taken on a Linux workstation.
The secure project relies on the StarterApp_M33TD project delivered in STM32CubeMP2 Package. This project offers a secure build configuration using Trusted Firmware-M (TF-M).
1.1. Hardware prerequisites[edit | edit source]
- Board must be connected to the workstation, refer to STM32MP215x-DKx_-_hardware_description for details.
- The ST-Link V3 cable must be connected to the PC USB port to display traces.
- 2 consoles on your workstation are needed : one for Arm®-Cortex®-M33 and one for Arm®-Cortex®-A35. For that, 2 "USB to TTL serial cables" are needed, see STM32MP215x-DKx_-_hardware_description#Connecting USB to TTL serial cables
1.2. Software prerequisites[edit | edit source]
- STM32CubeIDE must be installed.
- STM32CubeMX must be installed.
- STM32CubeProgrammer must be installed.
- Download the M33-TD Starter Package: STM32MP2-Ecosystem-v6-1-0_release_for_M33-TD_flavor
- Install build environment and python dependencies for TF-M as described in How_to_configure,_build_and_deploy_TF-M#Prerequisites chapter.
- Install sources of trusted-firmware-m as described in How_to_configure,_build_and_deploy_TF-M#Downloading_source chapter.
Trusted-firmware-m should be installed in STM32CubeMP2 Package, Middlewares/Third_Party/trusted-firmware-m.
- Go where you installed
trusted-firmware-m
cd <working directory path>/STM32Cube_FW_MP2_V1.2.0/Middlewares/Third_Party/trusted-firmware-m
- Install, on the workstation, python libraries, needed for TF-M signature python script.
pip install -r tools/requirements.txt
1.3. Import StarterApp_M33TD project into STM32CubeIDE[edit | edit source]
StarterApp_M33TD project is imported into STM32CubeIDE from STM32CubeMP2 Package using the menu File > Import....
Then, expand General, choose Existing Projects into Workspace.
A new window appears in Select root directory: click on Browse... and select in the STM32CubeMP2 firmware .../STM32Cube_FW_MP2_V1.2.0/Projects/STM32MP215F-DK/Demonstrations/StarterApp_M33TD/STM32CubeIDE.
Note that StarterApp_M33TD project is available from STM32CubeMPU package repository on local disk or from Projects/STM32MP215F-DK/Demonstrations/StarterApp_M33TD .
Resulting project structure contains two projects:
- StarterApp_M33TD_CM33_NonSecure, HAL-based project, addressing nonsecure part of application.
- StarterApp_M33TD_CM33_trusted-firmware-m, pre-set CMake STM32CubeIDE project for TF-M, with link to sources: trusted-firmware-M pointing inside STM32CubeMP2 Package Middlewares/Third_Party/trusted-firmware-m
1.4. Set up and configure the StarterApp_M33TD_CM33_trusted-firmware-m project[edit | edit source]
1.4.1. Configure trusted-firmware-m link[edit | edit source]
This section is normally not needed if you followed the #Software_prerequisites and installed the trusted-firmware-m sources in Middlewares/Third_Party/trusted-firmware-m. You should only follow it if your trusted-firmware-m is empty: |
To use the Trusted Firmware-M (TF-M) source files in your project, you need to specify the path to the TF-M repository.
As shown in the screenshot below, enter the correct path to the TF-M source folder in the STM32CubeIDE project settings to properly link the repository with your CMake-based project configuration.
Right click in trusted-firmware-m -> Properties -> Resources -> Edit and provide the path to trusted-firmware-m directory .
To get source code, follow the instructions in How_to_configure,_build_and_deploy_TF-M#Installing_sources. You can then refresh STM32CubeIDE project and view sources.
1.4.2. CMake configuration[edit | edit source]
In order to check CMake command
- right click on
StarterApp_M33TD_CM33_trusted-firmware-m->Properties->C/C++ build, click onCMake Settingstab, then inOther Optionsput your "CMake command"Apply>Apply and close
The trusted-firmware-M project is imported with pre-configured settings, but some of them can be customized.
Below an example of STM32MP215F-DK board - CMake project usage settings:
-DTFM_PLATFORM=stm/stm32mp215f_dk -DTFM_TOOLCHAIN_FILE=toolchain_GNUARM.cmake -DSTM32_BOOT_DEV=sdmmc1 # This option can be modified if you are not using the SD-CARD as boot memory. -DTFM_PROFILE=profile_medium -DSTM32_M33TDCID=ON -DCMAKE_BUILD_TYPE=Relwithdebinfo -DNS=OFF -DDTS_EXT_DIR=../../../../../../../../Utilities/dt-stm32mp -DDTS_BOARD_BL2=stm32mp2/m33-td/mcuboot/stm32mp215f-dk-cm33tdcid-ostl-sdcard-bl2.dts -DDTS_BOARD_S=stm32mp2/m33-td/tfm/stm32mp215f-dk-cm33tdcid-ostl-sdcard-s.dts -DDEBUG_AUTHENTICATION=FULL # Enabled for Debug Purpose, Default: this option is removed.
2. Set up embedded software[edit | edit source]
2.1. Populate the board with OpenSTLinux release for M33-TD flavor
Flash OpenSTLinux Starter Package ecosystem release v6.1.0
dedicated to M33-TD flavor
on your SD card, following instructions given in STM32MP21_Discovery_kits_-_Starter_Package#Downloading_the_image_and_flashing_it_on_the_board chapter.
2.2. Boot the board[edit | edit source]
2.2.1. Configure boot pins[edit | edit source]
Once the embedded software has been downloaded in the board, specific boot pins configuration is needed to boot on Arm®-Cortex®-M33 with the wished dual mass storage:
- Arm®-Cortex®-M33 from SD card,
- Arm®-Cortex®-A35 from SD card.
You must refer to STM32MP215x-DKx_-_hardware_description#Boot_switches to configure the boot pin correctly for M33-TD flavor
2.2.2. Create a second console[edit | edit source]
Two consoles are needed to check the dual boot.
See How_to_open_several_serial_consoles
To trace boot logs for Arm®-Cortex®-M33 and Arm®-Cortex®-A35, you must open two consoles on windows.
2.2.3. Start your board[edit | edit source]
To boot your board, you need to reset it by pressing on the Reset button on the board.
See dual boot steps, on the both consoles, in the screenshot below:
2.3. Configure StarterAppM33TD application with Device tree generated by STM32CubeMX[edit | edit source]
| This part is optional. It is needed if you want to use the device tree generated from CubeMX |
The StarterAppM33TD application can be configured to run with a device tree generated by STM32CubeMX project.
To create an M33-TD flavor
STM32CubeMX project, follow instructions given in How_to_create_STM32MPU_projects_with_STM32CubeMX#Create_an_STM32MP2_series_project
- Below an example of the device tree files generated by CubeMX
username@hostname:~/Downloads/MP2_TFM_TEST/MP21_board/CM33/DeviceTree$ tree
└── MP21_board
├── mcuboot
│ ├── stm32mp215f-mp21_board-mx.dts
│ ├── stm32mp215f-mp21_board-mx-rcc.dtsi
│ ├── stm32mp215f-mp21_board-mx-resmem.dtsi
│ ├── stm32mp215f-mp21_board-mx-rif.dtsi
│ └── stm32mp21-mx.dtsi
└── tf-m
└── stm32mp215f-mp21_board-mx-rif.dtsi
- In order to build with STM32CubeMX Device Tree user have to update CMake project usage settings.
- Only these ones should be updated :
-DDTS_EXT_DIR=/local/home/username/Downloads/MP2_TFM_TEST/MP21_board/CM33/DeviceTree
-DDTS_BOARD_BL2=MP21_board/mcuboot/stm32mp215f-mp21_board-mx.dts
-DDTS_BOARD_S=MP21_board/tf-m/stm32mp215f-mp21_board-mx.dts
3. Build updated project[edit | edit source]
3.1. Build the StarterApp_M33TD_CM33_trusted-firmware-m project[edit | edit source]
- StarterApp_M33TD_CM33_trusted-firmware-m project generates
bl2.stm32,ddr_phy_signed.bin,tfm_s.bin,tfm_s.elfandbl2.elf. - StarterApp_M33TD_CM33_NonSecure project generates
StarterApp_M33TD_CM33_NonSecure_tfm_s_ns_signed.bin
So when bl2 or tfm-s are rebuilt, you need to rebuild StarterApp_M33TD_CM33_NonSecure project in order to link and sign secure tfm_s.bin and StarterApp_M33TD_CM33_NonSecure.bin thanks to "postbuild" command, explained below in the article.
You can configure your project doing right click to your StarterApp_M33TD_CM33_trusted-firmware-m > CMake configure.
If you already made the CMake configuration in the past, you can override it by selecting Delete and Reconfigure.
Then run the build of StarterApp_M33TD_CM33_trusted-firmware-m by cliking on the hammer build icon from eclipse.
The generated ELF files tfm_s.elf and bl2.elf, are needed to debug. They can be found in:
- StarterApp_M33TD_CM33_trusted-firmware-m/trusted-firmware-m/config_default/api_ns/bin/ tfm_s.elf
- StarterApp_M33TD_CM33_trusted-firmware-m/trusted-firmware-m/config_default/api_ns/bin/ bl2.elf
3.2. Build the StarterApp_M33TD_CM33_NonSecure project[edit | edit source]
To generate the bin object StarterApp_M33TD_CM33_NonSecure_tfm_s_ns_signed.bin, you need to activate the generation of the .bin from
right click StarterApp_M33TD_CM33_NonSecure > Properties > C/C++ Build > Settings > MCU/MPU Post build outputs > select covert to binary file(-O binary ):
The StarterApp_M33TD_CM33_NonSecure project is used to get StarterApp_M33TD_CM33_NonSecure_tfm_s_ns_signed.bin object in order to link and sign secure tfm_s.bin, and non secure StarterApp_M33TD_CM33_NonSecure.bin
thanks to "postbuild" command visible in C/C++ Build > Settings and in tab Build Steps:
The default postbuild command of the project is made for Windows. On Linux Host, you should update it with the one below:
python ${workspace_loc:/StarterApp_M33TD_CM33_trusted-firmware-m/trusted-firmware-m/config_default/api_ns/image_signing/scripts/assemble.py} --layout ${workspace_loc:/StarterApp_M33TD_CM33_trusted-firmware-m/trusted-firmware-m/config_default/api_ns/image_signing/layout_files/signing_layout_s_ns.o} --secure ${workspace_loc:/StarterApp_M33TD_CM33_trusted-firmware-m/trusted-firmware-m/config_default/api_ns/bin/tfm_s.bin} --non_secure ${BuildArtifactFileBaseName}.bin --output ${BuildArtifactFileBaseName}_tfm_s_ns.bin; python ${workspace_loc:/StarterApp_M33TD_CM33_trusted-firmware-m/trusted-firmware-m/config_default/api_ns/image_signing/scripts/wrapper/wrapper.py} --version 2.1.0 --layout ${workspace_loc:/StarterApp_M33TD_CM33_trusted-firmware-m/trusted-firmware-m/config_default/api_ns/image_signing/layout_files/signing_layout_s_ns.o} --key ${workspace_loc:/StarterApp_M33TD_CM33_trusted-firmware-m/trusted-firmware-m/config_default/api_ns/image_signing/keys/image_s_signing_private_key.pem} --public-key-format full --align 1 --pad --pad-header -H 0x800 -s 1 -L 128 --measured-boot-record ${BuildArtifactFileBaseName}_tfm_s_ns.bin ${BuildArtifactFileBaseName}_tfm_s_ns_signed.bin;
Select StarterApp_M33TD_CM33_NonSecure project. This project has only one build configuration: CM33TDCID_m33_ns_tfm_s_sign.
Build can be done using standard eclipse Build icon, it generates StarterApp_M33TD_CM33_NonSecure_tfm_s_ns_signed.bin, visible after a project refresh.
4. Populate board with the created project[edit | edit source]
To flash your board, the recommended way is to take an existing tsv and update it with generated binaries :
- arm-trusted-firmware-m:
- bl2.stm32
- ddr_phy_signed.bin
- arm-trusted-firmware-m-cube
- StarterApp_M33TD_CM33_NonSecure_tfm_s_ns_signed.bin
You need first to configure the boot pin correctly, in Forced USB boot for flash memory programming for that refer to STM32MP215x-DKx_-_hardware_description#Boot_switches.
To modify the "tsv" file:
- Go inside
<working directory path>/Starter-Package/stm32mp2-m33td-openstlinux-6.6-yocto-scarthgap-mpu-v25.06.11/images/stm32mp2-m33td/flashlayout_st-image-weston/optee/. - Make a copy the tsv
FlashLayout_sdcard_stm32mp215f-dk-cm33tdcid-ostl-optee.tsvin the same directory. - And rename it by adding STM32CubeIDE Firmware project name. For example by adding
FW, the name becomesFlashLayout_sdcard_stm32mp215f-dk-cm33tdcid-ostl-optee_FW.tsv
- Open the new tsv and update all the Opt column of unmodified partitions to
PEin order to getting flashing quickly. (Yellow part of the picture below) - Update the paths to use the new binaries generated with STM32CubeIDE (Red part of the picture below):
- Replace fsblm1 and fsblm2 binary with
arm-trusted-firmware-m/bl2.stm32 - Replace m33ddr-a binary with
arm-trusted-firmware-m/ddr_phy_signed.bin - Replace m33fw-a binary with
arm-trusted-firmware-m-cube/StarterApp_M33TD_CM33_NonSecure_tfm_s_ns_signed.bin
Resulting image :
4.1. Populate board with the created project with STM32CubeIDE[edit | edit source]
STM32CubeIDE proposes Flash device memory menu, based onto STM32CubeProgrammer and its .tsv files. This menu allows to flash an on-board SD-Card.
- Select
StarterApp_M33TD_CM33project and right click to getProgram memory device.
- Go in Tab
Flash memories programmer:- Fill
Binaries Directorywith the path to the folder with binaries inside the Starter Package should be<working directory path>/Starter-Package/stm32mp2-m33td-openstlinux-6.6-yocto-scarthgap-mpu-v25.06.11/images/stm32mp2-m33td/ - Fill
TSV Filewith the updated .tsv file. - Click on
Downloadbutton.
- Fill
4.2. Populate board with the created project with STM32CubeProgrammer[edit | edit source]
- First step requires to copy the generated binaries from STM32CubeIDE in the folder indicated in the updated tsv.
Copy in arm-trusted-firmware-m folder the binaries:
bl2.stm32 ddr_phy_signed.bin
By default, they are generated in
STM32Cube_FW_MP2_V1.2.0/Middlewares/Third_Party/trusted-firmware-m/config_default/api_ns/bin/
Copy in arm-trusted-firmware-m-cube the binary:
By default, it is generated in
STM32Cube_FW_MP2_V1.2.0/Projects/STM32MP215F-DK/Demonstrations/StarterApp_M33TD/STM32CubeIDE/CM33/NonSecure/CM33TDCID_m33_ns_tfm_s_sign/
4.2.1. Flashing with STM32_Programmer_CLI[edit | edit source]
- Go inside the binaries folder of the Starter Package:
- Then use the STM32_Programmer_CLI with the new tsv generated. Below, an example of command to use:
PC>$ STM32_Programmer_CLI -c port=usb1 -w flashlayout_st-image-weston/optee/FlashLayout_sdcard_stm32mp215f-dk-cm33tdcid-ostl-optee_FW.tsv
4.2.2. Flashing with STM32CubeProgrammer GUI Application[edit | edit source]
- Run STM32CubeProgrammer GUI Application
- Fill
Binaries Directorywith the path to binaries inside OpenSTLinux images:<working directory path>/Starter-Package/stm32mp2-m33td-openstlinux-6.6-yocto-scarthgap-mpu-v25.06.11/images/stm32mp2-m33td/. - Fill
TSV Filewith the updated .tsv file. - Connect to the target through USB
- Click on
Downloadbutton.
5. How to debug[edit | edit source]
5.1. Prerequisites to debug[edit | edit source]
Once the download is completed, you must configure again the Boot Pin for M33-TD flavor
boot.
You must refer to STM32MP215x-DKx_-_hardware_description#Boot_switches.
5.2. Debug bl2[edit | edit source]
Open a console in STM32CubeIDE and reboot the board, you should see logs like this:
By default the code should be stuck in the bl2.
Select StarterApp_M33TD_CM33_trusted-firmware-m project and right click to get Debug As > Debug configurations....
Double click STM32 C/C++ Application and create debug configuration:
- In
maintabulation,Search Projectand selectbl2.elf. - In
Debuggertabulation:Load Modeand selectthru JTAG/SWD link (Engineering mode).
- In
Startuptabulation:- Remove all the
Initialization Commands - Disable in
Runtime OptionstheResumecheckbox. - Select the
Load Image and Symbolselement clickEditand disableDownload.
- Remove all the
And click on Apply.
Configuration file error
If you run the debug on STM32MP21, you will encounter an error.
This is due to an error in the generated cfg file.
In the project explorer, in the root of the project, click on StarterApp_M33TD_CM33_trusted-firmware-m config_default.cfg, copy it and paste it to duplicate it. You can call it StarterApp_M33TD_CM33_trusted-firmware-m config_default_user.cfg. Then open the new file and replace the last line with:
source [find target/stm32mp21x.cfg]
Then we need to modify again the debug configuration.
Click on the configuration created previously, by default it should be StarterApp_M33TD_CM33_trusted-firmware-m config_default
- In
Debuggertabulation:- In configuration Script area, select User Defined and point to your updated cfg file.
Debugger starting issue
On STM32MP21, a limitation prevent to make the debug start up in STM32CubeIDE, this should be done in two terminals.
- To get the command to run in the first one, you need to go in the debug configuration that you created previously.
- Click on the configuration created previously, by default it should be
StarterApp_M33TD_CM33_trusted-firmware-m config_default - In
Debuggertabulation:- In GDB Server Command Line Options: Click on
Show Command Line. - Then
Copy & Close
- Open two shell command line on your Linux Host.
- In the first one, paste the command and hit enter to run it.
- In the second one, type:
telnet localhost 4444
Once the connection is done, type:
targets STM32MP215FANx.m33 arp_examine
Once it is done, you can go back to STM32CubeIDE.
Click on Debug and you should see that you are in /StarterApp_M33TD_CM33_trusted-firmware-m/trusted-firmware-m/platform/ext/target/stm/common/stm32mp2xx/bl2/boot_hal.c.
You can just use the step into button to continue your debug in the BL2.
5.3. Debug TF-M secure[edit | edit source]
A way to control entry point of the TF-M debug session could be to add a debug loop. enum tfm_hal_status_t tfm_hal_platform_init(void)
// Debug loop entry
volatile int i=1;
while(i);
The debug session starts inside this debug loop.
In |
When debugging TF-M Secure and nonsecure firmware, please note that both run with cache enabled (D-Cache and I-Cache) by default. Because of this, standard breakpoints and variable modifications may not work as expected during debugging.
To avoid these limitations and to make easier the debug, you can disable the cache for debug purpose.
5.3.1. Disabling Cache[edit | edit source]
- You need to modify your CMake settings and add at the beginning:
-DSTM32_CACHE_ENABLED=OFF
The explanation to reach the CMake settings is available here: CMake_configuration
- Then run the CMake Configure and the build of the trusted-firmware-m Build_the_StarterApp_M33TD_CM33_trusted-firmware-m_project
- Build the NonSecure project Build_the_StarterApp_M33TD_CM33_NonSecure_project
- Flash the new binaries Populate_board_with_the_created_project
5.3.2. Create the TF-M debug configuration[edit | edit source]
Double click STM32 C/C++ Application and edit debug configuration:
- Rename it with
_tfmat the end of the name - In
Maintabulation:Search Projectand selecttfm_s.elf.
- In
- In
Startuptabulation:- Disable
Resume. - Remove
monitor halt&monitor reset - Select the
- Disable
Without disabling the cache, you will be limited and will have to use hardware breakpoints (limited to 8). To allow the Hardware breakpoint, it will be necessary to modify two fields in the debug configuration.
- In
Debuggertabulation:- In Openocd Options, add
-bc "gdb_breakpoint_override hard"
- In
Startuptabulation:- In
Initialization Commands, addmonitor gdb_breakpoint_override hard
- In
- Click on the configuration that you created.
- In
Debuggertabulation:- In configuration Script area, select User Defined and point to your updated cfg file created during the chapter Debug_bl2
Copy & Close
Apply and Debug.
Each time you want to debug the TF-M, you should first debug the BL2 to pass the __WFI(); in the code.
This Waiting for Interrupt is there to help to debug the BL2, but it can be commented for being able to load the TF-M directly.
Go inside __WFI();
with // __WFI();
5.4. Debug StarterApp_M33TD_CM33_NonSecure[edit | edit source]
Example of a way to control entry point of the CM33 Non Secure debug session.
Comment the waiting point (while) that we added in Debug_TF-M_secure and instead edit
#ifdef DEBUG with #ifndef DEBUG
In |
SelectStarterApp_M33TD_CM33_NonSecure project and right click to get Debug As > Debug configurations.
- In
maintabulation,Search Projectand selectStarterApp_M33TD_CM33_NonSecure.elf. - In
Debuggertabulation,Load Modeand selectthru JTAG/SWD link (Engineering mode).- In configuration Script select
User Definedand point to your updated cfg
- In
Resume. - Remove monitor halt & monitor reset
- Select the
- Disable
If you kept the cache when following Disabling_Cache, you will be limited and will have to use hardware breakpoints (limited to 8).
- In
- In
- In
- In
Copy & Close
Apply and Debug.
| Compiler Optimization settings
If you encounter an issue when starting a debug session, always confirm that the compiler optimization is set to Debug. In
