How to configure, build and deploy TF-M
This section details the TF-M stage (Trusted Firmware-M). It explains how to configure and build TF-M in the STM32 MPU context, describes the build process from sources, and shows how to deploy it on the target device.
2. Build with a bare environment or STM32CubeIDE[edit | edit source]
2.1. Prerequisites[edit | edit source]
2.1.1. Linux® PC[edit | edit source]
2.1.1.1. Installing the build environment[edit | edit source]
Install the dependencies:
sudo apt-get install -y git curl wget build-essential libssl-dev python3 \
           python3-pip cmake make
Then add the CMake path to the environment:
export PATH=<CMake path>/bin:$PATH
2.1.1.2. Installing a toolchain[edit | edit source]
If using STM32CubeIDE to build TF-M, installing a toolchain is not necessary, since STM32CubeIDE comes with a built-in toolchain.
If using a command-line interface, download the toolchain and add the GNU Arm toolchain path to the environment:
export PATH=$PATH:<toolchain installation directory>/sysroots/x86_64-ostl_sdk-linux/usr/share/gcc-arm-none-eabi/bin
2.1.2. Windows® PC[edit | edit source]
2.1.2.1. Installing the build environment[edit | edit source]
Important
It is recommended to install GNU make in a path without any space characters. Avoid /c/Program Files/, for example.
set PATH=<CMake_Path>/bin;%PATH%
2.1.2.2. Installing a toolchain[edit | edit source]
If using a command-line interface, use the toolchain from STM32CubeIDE and update the path in .bashrc as follows:
PATH="/c/ST/<STM32 CubeIDE path>/STM32CubeIDE/plugins/com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.11.3.rel1.win32_1.1.2.202309201523/tools/bin":$PATH
Information
The plugin version may differ from one STM32CubeIDE version to another, so modify it accordingly.
2.2. Installing sources[edit | edit source]
2.2.1. Downloading source[edit | edit source]
For the full-featured software, go to the STMicroelectronics github:
 git clone https://github.com/STMicroelectronics/trusted-firmware-m.git
Warning
The STM32MP2 platform is not upstreamed.
For the record, the official Trusted Firmware-M git repository (without STM32MP2 support) can be downloaded there:
 git clone https://git.trustedfirmware.org/TF-M/trusted-firmware-m.git/
Warning
To run TF-M application with STM32CubeMP2 package, install the TF-M source inside STM32CubeMP2 Package Middlewares/Third_Party/.
2.3. Installing Python dependencies[edit | edit source]
From the TF-M source code installed on the PC:
pip3 install --upgrade pip \
           pip3 install -r tools/requirements.txt
2.4. Build process[edit | edit source]
Important
STMicroelectronics implementation uses the medium profile by default. See TF-M profile page for more information.
Only medium and large profile are supported for M33-TD flavor . Indeed, CONFIG_TFM_SPM_BACKEND set to IPC is mandatory for IPCC mailbox used by SCMI and PSA services. And by definition, CONFIG_TFM_SPM_BACKEND set to SFN is mandatory for small profile.
2.4.1. STM32CubeIDE[edit | edit source]
There is one Cortex®-M33 nonsecure STM32Cube firmware example that uses TF-M services and builds TF-M using STM32CubeIDE.
Refer to the How to build and debug secure project on Cortex-M33 coprocessor in STM32CubeIDE wiki page for a step-by-step build-and-load example with TF-M.
2.4.2. Build command lines[edit | edit source]
You can also use TF-M-tests for the tests and non-secure software example. Starting from ecosystem release v6.1.0 , TF-M is based on official release v2.1, for which build system has changed. You will need to fetch TF-M-tests:
 git clone https://github.com/STMicroelectronics/tf-m-tests.git ${TF-M-TESTS_DIRECTORY}
See the Github pages for compilation steps and the different possible build options for Unsupported domain! or Unsupported domain!
2.4.3. External device tree for the STM32MP2 series[edit | edit source]
STMicroelectronics provides device tree configurations for others boards in a dedicated git repository: stm32mp2/a35-td/tfm/ .
The repository can be used to store custom configurations. Use the following command to build with this external dt repository:
 git clone https://github.com/STMicroelectronics/dt-stm32mp.git ${DT_PATH}
Depending on your configuration, you will need to add build options for the external DT files.
For A35-TD flavor and M33-TD flavor , more information is also given on Github pages for Unsupported domain! or Unsupported domain!
2.4.3.1. Example for A35-TD flavor [edit | edit source]
DT_PATH can be set to any path, but it must not be a relative path.
       -DDTS_EXT_DIR=${DT_PATH}/stm32mp2/a35-td \
       -DDTS_BOARD_S=tfm/stm32mp257f-ev1-ca35tdcid-ostl-s.dts
And optionally, the nonsecure DT
       -DDTS_BOARD_NS=tfm/stm32mp257f-ev1-ca35tdcid-ostl-ns.dts
2.4.3.2. Example for M33-TD flavor [edit | edit source]
       -DDTS_EXT_DIR=${DT_PATH}/stm32mp2/m33-td \
       -DDTS_BOARD_S=tfm/stm32mp257f-ev1-cm33tdcid-ostl-sdcard-s.dts \
       -DDTS_BOARD_BL2=mcuboot/stm32mp257f-ev1-cm33tdcid-ostl-sdcard-bl2.dts
       -DDTS_BOARD_NS=tfm/stm32mp257f-ev1-cm33tdcid-ostl-sdcard-ns.dts
3. Build with Developer package[edit | edit source]
For the A35-TD flavor , only CubeIDE is supported to build TF-M
For the M33-TD flavor , TF-M is managed by Developper package. please refer to the following article to understand how to install & develop: STM32MPU Developer Package
4. Build with Distribution package[edit | edit source]
The Linux Yocto-based distribution package (STM32MPU distribution package) integrates the TF-M components source code in a dedicated recipe in the OpenSTLinux distribution.
To generate the three required binaries for M33TD flavor — **MCUBoot**, **DDR firmware** and **M33 firmware** — use the command:
bitbake m33fw-stm32mp2
If you need to build them individually, use the following commands:
bitbake tf-m-stm32mp
bitbake m33tdprojects-starter-stm32mp2
