1. Open a terminal[edit | edit source]
Ubuntu terminal
  • Create your STM32MPU workspace directory on the host computer:
 cd $HOME/STM32MPU_workspace
2. Check the host computer Internet access[edit | edit source]
3. Install the tools[edit | edit source]
3.1. STM32CubeProgrammer[edit | edit source]
  • Create your STM32MPU tools directory on the host computer:
  • Create a temporary directory in your STM32MPU workspace:
STM32CubeProgrammer V2.11 is recommended for ecosystem release v4.0.0 More info.png
  • Execute the Linux® installer, which guides you through the installation process. Select "$HOME/STM32MPU-Tools/STM32CubeProgrammer-x.y.z" as installation directory when it is requested by the installer.
The screenshots below have been obtained with old STM32CubeProgrammer V2.7.0. They are provided as examples still valid for higher version :
Splash screen
  • Add the STM32CubeProgrammer binary path to your PATH environment variable:
  • Go inside the binary folder:
  • Check that the STM32CubeProgrammer tool is properly installed and accessible:
 STM32_Programmer_CLI --h
                       STM32CubeProgrammer vx.y.z
3.2. USB serial link[edit | edit source]
  • Install the libusb on your host computer:
  • To allow STM32CubeProgrammer to access the USB port through low-level commands, proceed as follows:
4. Download the image[edit | edit source]
  • Create your STM32MP1 Starter Package directory on the host computer:
 mkdir $HOME/STM32MPU_workspace/STM32MP1-Ecosystem-v4.0.0
 mkdir $HOME/STM32MPU_workspace/STM32MP1-Ecosystem-v4.0.0/Starter-Package
 cd $HOME/STM32MPU_workspace/STM32MP1-Ecosystem-v4.0.0/Starter-Package
  • Download the [unknown revision/unknown revision STM32MP1-Ecosystem-v4.0.0 Starter Package] to the following directory:
 tar xvf unknown revision
