IKS01Ax MEMS expansion board
Revision as of 14:00, 13 June 2019 by Registered User (→‎Kernel configuration)
The purpose of this article is to explain how to integrate the IKS01A2 expansion board with STM32MP157C-DK2, managed by Linux on Cortex-A7.
The IKS01A2 board is an expansion board that includes several motion MEMS like HTS221 and LSM6DSL.
This article provides step-by-step instructions to:
  • configure Linux software to support IKS01A2 expansion board,
  • activate/use several motion MEMS such as HTS221 and LSM6DSL.
2. Prerequisites[edit source]
2.1. Hardware prerequisites[edit source]
  • STM32MP157C-DK2
STM32MP157C-DK2
For more information about the STM32 discovery board and how to start it up, jump to this section Getting_started/STM32MP1_boards/STM32MP157C-DK2
  • IKS01A2 expansion board
IKS01A2
2.2. Software prerequisites[edit source]
The STM32MP157C-DK2 board must be downloaded with appropriate software in order to support IKS01A2 expansion board. For proceeding, follow the step-by-step instructions provided at STM32MP157C-DK2 Let's start.
3. Software customization to support IKS01A2 expansion board[edit source]
The STM32MP157C-DK2 Linux software must be configured to activate the IKS01A2 board connected on top of the STM32MP157C-DK2 board.
The configuration consists in modifying the STM32MP157C-DK2 Linux kernel and managing some new device tree elements.
By default, the motion MEMS drivers present on IKS01A2 expansion board are enabled in STM32MP1 kernel configuration: hts221, pressure(lp22hb) and lsm6dsl. The device tree must be updated to declare and activate them.
To check whether associated drivers are enabled inside the kernel, type the commands provided here below :
  cat /proc/config.gz | gunzip | grep HTS221
CONFIG_HTS221=y
CONFIG_HTS221_I2C=y
CONFIG_HTS221_SPI=y
  cat /proc/config.gz | gunzip | grep ST_PRESS
CONFIG_IIO_ST_PRESS=m
CONFIG_IIO_ST_PRESS_I2C=m
CONFIG_IIO_ST_PRESS_SPI=m
  cat /proc/config.gz | gunzip |  grep ST_LSM6DS
CONFIG_IIO_ST_LSM6DSX=m
CONFIG_IIO_ST_LSM6DSX_I2C=m
CONFIG_IIO_ST_LSM6DSX_SPI=m
If the above configurations are not enabled, follow the indications given in Modify, rebuild and reload the Linux® kernel
3.2. Kernel device tree configuration[edit source]
3.2.1. Hardware / software interface[edit source]
The HTS221 and LSM6DSL motion MEMS present on IKS01A2 expansion board are involved in the following use case.
According to IKS01A2 user manual[1], both motion MEMS are controlled by ITemplate:SupC bus.
In schematics of IKS01A2 [2] and STM32MP157C-DK2[3] , presented below, are identified the pins which are connected together.
  • IKS01A2 schematic (Arduino connector) [2]
    • Pins 10 and 9 of CN5 are used for I2C Bus (SDA and SCL) (I2C1 and I2C2 bus instances are mixed via the jumper JP7 and JP8)
    • Pins 6 and 5 of CN9 are used to manage interruptions on LSM6DSL motion MEMS (indicated for information: not used on kernel configuration).
Screenshot iks01a2
IKS01A2 schematics extract
  • STM32MP157C-DK2 schematic (Arduino connector) [3]
    • Pins 10 and 9 of CN5 are used for I2C Bus (I2C5_SDA and I2C5_SCL)
    • Pins 6 and 5 of CN14 are used to manage interruptions on LSM6DSL motion MEMS (indicated for information: not used on kernel configuration)
Screenshot stm32mp157c-dk2
stm32mp157c-dk2 schematics extract
I2C5 bus instance MUST be enabled on software to access to motion MEMS present on IKS01A2
3.2.2. Kernel device tree configuration[edit source]
As seen in previous chapter, IKS01A2 expansion board is controlled via IC2 bus. On STM32MP157C-DK2, the associated I2C bus is I2C5.
I2C5 bus must be activated into STM32MP157C-DK2 device tree and a node for each hardware to support must be added (see entry on device tree like hts221, below, on the following device tree content).
For that, add following content into stm32mp157c-dk2.dts file:
 &i2c5 {
	pinctrl-0 = <&i2c5_pins_a>;
	pinctrl-1 = <&i2c5_pins_sleep_a>;
	i2c-scl-rising-time-ns = <124>;
	i2c-scl-falling-time-ns = <3>;
	/delete-property/dmas;
	/delete-property/dma-names;
	status = "okay";
	hts221@5f {
		compatible = "st,hts221";
		reg = <0x5f>;
	lsm6dsl@6b {
		compatible = "st,lsm6dsl";
		reg = <0x6b>;
To generate a new device tree, please follow the indications given in Modify, rebuild and reload the Linux® kernel
3.3. Activate the new configuration in the STM32MP157C-DK2 board[edit source]
  • Add the two generated files on file system of board, more accurately in bootfs partition (/boot directory)
 ls -1 /boot/stm32*dk2*
/boot/stm32mp157c-dk2-a7-examples.dtb
/boot/stm32mp157c-dk2-iks01a2.dtb
/boot/stm32mp157c-dk2-m4-examples.dtb
/boot/stm32mp157c-dk2.dtb
  • Add a new entry in extlinux.conf file, here located in /boot/mmc0_stm32mp157c-dk2_extlinux/. If no directory mmc0_<something> is available, add the new entry in /boot/extlinux/extlinux.conf.
 # Generic Distro Configuration file generated by OpenEmbedded
 menu title Select the boot mode
 MENU BACKGROUND ../splash.bmp
 TIMEOUT 20
 DEFAULT stm32mp157c-dk2-iks01a2
 LABEL stm32mp157c-dk2-sdcard
         KERNEL /uImage
         FDT /stm32mp157c-dk2.dtb
         APPEND root=/dev/mmcblk0p6 rootwait rw console=ttySTM0,115200
 LABEL stm32mp157c-dk2-a7-examples-sdcard
         KERNEL /uImage
         FDT /stm32mp157c-dk2-a7-examples.dtb
 LABEL stm32mp157c-dk2-m4-examples-sdcard
         KERNEL /uImage
         FDT /stm32mp157c-dk2-m4-examples.dtb
 LABEL stm32mp157c-dk2-iks01a2
        KERNEL /uImage
        FDT /stm32mp157c-dk2-iks01a2.dtb
Do not forget to synchronize the file system before rebooting the board
sync
  • Reboot the board
3.4. Verify the new configuration on board[edit source]
  • Verify if i2c5 is enabled:
  cat /proc/device-tree/soc/i2c\@40015000/status
okay
  • Verify if motion MEMS drivers are declared on device tree node:
 ls -l /proc/device-tree/soc/i2c\@40015000/
total 0
-r--r--r-- 1 root root  4 Dec 19 11:01 #address-cells
-r--r--r-- 1 root root  4 Dec 19 11:01 #size-cells
-r--r--r-- 1 root root  8 Dec 19 11:01 clocks
-r--r--r-- 1 root root 15 Dec 19 11:01 compatible
-r--r--r-- 1 root root  6 Dec 19 11:01 dma-names
-r--r--r-- 1 root root 32 Dec 19 11:01 dmas
drwxr-xr-x 2 root root  0 Dec 19 10:54 hts221@5f
-r--r--r-- 1 root root  4 Dec 19 11:01 i2c-scl-falling-time-ns
-r--r--r-- 1 root root  4 Dec 19 11:01 i2c-scl-rising-time-ns
-r--r--r-- 1 root root 19 Dec 19 11:01 interrupt-names
-r--r--r-- 1 root root 44 Dec 19 11:01 interrupts-extended
drwxr-xr-x 2 root root  0 Dec 19 10:54 lsm6dsl@6b
-r--r--r-- 1 root root  4 Dec 19 11:01 name
-r--r--r-- 1 root root  4 Dec 19 11:01 pinctrl-0
-r--r--r-- 1 root root  4 Dec 19 11:01 pinctrl-1
-r--r--r-- 1 root root 14 Dec 19 11:01 pinctrl-names
-r--r--r-- 1 root root  4 Dec 19 11:01 power-domains
-r--r--r-- 1 root root  8 Dec 19 11:01 reg
-r--r--r-- 1 root root  8 Dec 19 11:01 resets
-r--r--r-- 1 root root 12 Dec 19 11:01 st,syscfg-fmp
-r--r--r-- 1 root root  5 Dec 19 11:01 status
  • Verify if motion MEMS drivers are correctly probed and if the system provides access to the associated hardware:
  grep OF_NAME /sys/bus/iio/devices/iio\:device*/uevent
/sys/bus/iio/devices/iio:device0/uevent:OF_NAME=adc
/sys/bus/iio/devices/iio:device1/uevent:OF_NAME=adc
/sys/bus/iio/devices/iio:device2/uevent:OF_NAME=hts221
/sys/bus/iio/devices/iio:device3/uevent:OF_NAME=temp
/sys/bus/iio/devices/iio:device4/uevent:OF_NAME=lsm6dsl
/sys/bus/iio/devices/iio:device5/uevent:OF_NAME=lsm6dsl
If the results are different then check that
  1. the expansion board is correctly connected
  2. all steps, described above, were correctly done.
4. Read motion MEMS via bash script[edit source]
The goal of this section are to read the informations provided by Linux kernel interface and process it on a bash script.
4.1. List of sensors entry[edit source]
IKS01A2 expansion board provides several MEMS like HTS221, LSM6DSL, LPS22HB.
Hardware MEMS, detected by Linux via the IIO framework, can be listed by verifying the entries on sysfs.
This list of entries permits to know which entries are associated to a MEMS driver. In the rest of the article, this list is kept as reference list of entries.
4.2. HTS221: Temperature/Humidity[edit source]
HTS221 is a capacitive digital sensor for relative humidity and temperature.
In this example, hts221 entries are /sys/bus/iio/devices/iio:device2/, please adapt to your setup if it's not the case by changing the entry on the scripts described/explained in following chapters.
4.2.1. Temperature[edit source]
  • Read IIO entries associated to temperature for HTS221 driver
  cat /sys/bus/iio/devices/iio\:device2/in_temp_raw
  cat /sys/bus/iio/devices/iio\:device2/in_temp_offset
  cat /sys/bus/iio/devices/iio\:device2/in_temp_scale
  • Calculate real temperature according following formula
Temperature = ( Raw value + Offset value) * Scale value)
  • Calculate temperature by shell script : static IIO entries
Content of hts221_read_temperature_on_device2.sh:
#!/bin/sh
raw=`cat /sys/bus/iio/devices/iio\:device2/in_temp_raw`
offset=`cat /sys/bus/iio/devices/iio\:device2/in_temp_offset`
scale=`cat /sys/bus/iio/devices/iio\:device2/in_temp_scale`
printf "Value read: raw         %0f\n" $raw
printf "Value read: offset      %0f\n" $offset
printf "Value read: scale       %0f\n" $scale
temperature=`echo "scale=2;$raw*$scale + $offset*$scale" | bc`
echo "Temperature $temperature"
printf "Temperature %.01f\n" $temperature
  • Calculate temperature by shell script: auto detection of IIO entries
Content of hts221_read_temperature_with_entry_detection.sh:
#!/bin/sh
DRIVER_NAME=hts221
for d in `ls -d1 /sys/bus/iio/devices/*device*`;
do
    if grep -q $DRIVER_NAME $d/name ;
    then
        raw=`cat $d/in_temp_raw`
        offset=`cat $d/in_temp_offset`
        scale=`cat $d/in_temp_scale`
        break;
    fi
done
  • Test on board
  ./hts221_read_temperature_on_device2.sh
Value read: raw         563.000000
Value read: offset      1036.674817
Value read: scale       0.019172
Temperature 30.668765624
Temperature 30.7
4.2.2. Humidity[edit source]
  • Read IIO entries associated to humidity for HTS221 driver
 cat /sys/bus/iio/devices/iio\:device2/in_humidityrelative_raw
 cat /sys/bus/iio/devices/iio\:device2/in_humidityrelative_offset
 cat /sys/bus/iio/devices/iio\:device2/in_humidityrelative_scale
  • Calculate real humidity according following formula
Humidity = ( Raw value + Offset value) * Scale value)
  • Calculate humidity by shell script: static IIO entries
Content of hts221_read_humidity_on_device2.sh:
#!/bin/sh
raw=`cat /sys/bus/iio/devices/iio\:device2/in_humidityrelative_raw`
offset=`cat /sys/bus/iio/devices/iio\:device2/in_humidityrelative_offset`
scale=`cat /sys/bus/iio/devices/iio\:device2/in_humidityrelative_scale`
humidity=`echo "scale=2;$raw*$scale + $offset*$scale" | bc`
echo "Humidity $humidity"
printf "Humidity %.01f\n" $humidity
  • Calculate humidity by shell script: auto detection of IIO entries
Content of hts221_read_humidity_with_entry_detection.sh:
#!/bin/sh
DRIVER_NAME=hts221
do
    then
        raw=`cat $d/in_humidityrelative_raw`
        offset=`cat $d/in_humidityrelative_offset`
        scale=`cat $d/in_humidityrelative_scale`
        break;
    fi
done
  • Test on board
 ./hts221_read_humidity_on_device2.sh
Value read: raw         2669.000000
Value read: offset      -10661.500000
Value read: scale       -0.003000
Humidity 23.977500000
Humidity 24.0
4.3. LSM6DSL: accelerometer/gyroscope[edit source]
LSM6DSL is an inertial measurement unit (IMU), for smartphones and battery operating IoT, gaming, wearable and consumer electronics, ultra-low power and high accuracy.
In this example, lsm6dsl entries are /sys/bus/iio/devices/iio:device4/ and /sys/bus/iio/devices/iio:device4/.
Device4 entry is dedicated to accelerometer and device5 one to gyroscope.
4.3.1. Accelerometer[edit source]
  • Read IIO entries associated to accelerometer for LSM6DSL driver
 cat /sys/bus/iio/devices/iio\:device4/in_accel_x_raw
 cat /sys/bus/iio/devices/iio\:device4/in_accel_x_scale
 cat /sys/bus/iio/devices/iio\:device4/in_accel_y_raw
 cat /sys/bus/iio/devices/iio\:device4/in_accel_y_scale
 cat /sys/bus/iio/devices/iio\:device4/in_accel_z_raw
 cat /sys/bus/iio/devices/iio\:device4/in_accel_z_scale
  • Calculate accelerometer values according following formula
X = Raw value * scale value * (256.0 / 9.81)
Y = Raw value * scale value * (256.0 / 9.81)
Z = Raw value * scale value * (256.0 / 9.81)
  • Calculate accelerometer value by shell script: static IIO entries
Content of lsm6dsl_accel_read_on_device4.sh:
#!/bin/sh
xraw=`cat /sys/bus/iio/devices/iio\:device4/in_accel_x_raw`
xscale=`cat /sys/bus/iio/devices/iio\:device4/in_accel_x_scale`
yraw=`cat /sys/bus/iio/devices/iio\:device4/in_accel_y_raw`
yscale=`cat /sys/bus/iio/devices/iio\:device4/in_accel_y_scale`
zraw=`cat /sys/bus/iio/devices/iio\:device4/in_accel_z_raw`
zscale=`cat /sys/bus/iio/devices/iio\:device4/in_accel_z_scale`
printf "Value read: X (raw/scale)  %d / %.06f \n" $xraw $xscale
printf "Value read: Y (raw/scale)  %d / %.06f \n" $yraw $yscale
printf "Value read: Z (raw/scale)  %d / %.06f \n" $zraw $zscale
factor=`echo "scale=2;256.0 / 9.81" | bc`
xval=`echo "scale=2;$xraw*$xscale*$factor" | bc`
yval=`echo "scale=2;$yraw*$yscale*$factor" | bc`
zval=`echo "scale=2;$zraw*$zscale*$factor" | bc`
printf "Accelerometer value: [ %.02f, %.02f, %.02f ]\n" $xval $yval $zval
  • Calculate accelerometer value by shell script: auto detection of IIO entries
Content of lsm6dsl_accel_read_with_entry_detection.sh:
#!/bin/sh
DRIVER_NAME=lsm6dsl_accel
do
    then
        xraw=`cat $d/in_accel_x_raw`
        xscale=`cat $d/in_accel_x_scale`
        yraw=`cat $d/in_accel_y_raw`
        yscale=`cat $d/in_accel_y_scale`
        zraw=`cat $d/in_accel_z_raw`
        zscale=`cat $d/in_accel_z_scale`
        break;
    fi
done
  • Test on board
 ./lsm6dsl_accel_read_on_device4.sh
Value read: X (raw/scale)  104 / 0.000598
Value read: Y (raw/scale)  -16378 / 0.000598
Value read: Z (raw/scale)  -1117 / 0.000598
Accelerometer value: [ 1.62, -255.53, -17.43 ]
4.3.2. Gyroscope[edit source]
  • Read IIO entries associated to gyroscope for LSM6DSL driver
 cat /sys/bus/iio/devices/iio\:device5/in_anglvel_x_raw
 cat /sys/bus/iio/devices/iio\:device5/in_anglvel_x_scale
 cat /sys/bus/iio/devices/iio\:device5/in_anglvel_y_raw
 cat /sys/bus/iio/devices/iio\:device5/in_anglvel_y_scale
 cat /sys/bus/iio/devices/iio\:device5/in_anglvel_z_raw
 cat /sys/bus/iio/devices/iio\:device5/in_anglvel_z_scale
  • Calculate gyroscope values according following formula
  • Calculate gyroscope value by shell script: static IIO entries
Content of lsm6dsl_gyro_read_on_device5.sh:
#!/bin/sh
xraw=`cat /sys/bus/iio/devices/iio\:device5/in_anglvel_x_raw`
xscale=`cat /sys/bus/iio/devices/iio\:device5/in_anglvel_x_scale`
yraw=`cat /sys/bus/iio/devices/iio\:device5/in_anglvel_y_raw`
yscale=`cat /sys/bus/iio/devices/iio\:device5/in_anglvel_y_scale`
zraw=`cat /sys/bus/iio/devices/iio\:device5/in_anglvel_z_raw`
zscale=`cat /sys/bus/iio/devices/iio\:device5/in_anglvel_z_scale`
printf "Gyroscope value: [ %.02f, %.02f, %.02f ]\n" $xval $yval $zval
  • Calculate gyroscope value by shell script: auto detection of IIO entries
Content of lsm6dsl_gyro_read_with_entry_detection.sh:
#!/bin/sh
DRIVER_NAME=lsm6dsl_gyro
do
    then
        xraw=`cat $d/in_anglvel_x_raw`
        xscale=`cat $d/in_anglvel_x_scale`
        yraw=`cat $d/in_anglvel_y_raw`
        yscale=`cat $d/in_anglvel_y_scale`
        zraw=`cat $d/in_anglvel_z_raw`
        zscale=`cat $d/in_anglvel_z_scale`
        break;
    fi
done
  • Test on board
 ./lsm6dsl_gyro_read_on_device5.sh
Value read: X (raw/scale)  -2293 / 0.000153
Value read: Y (raw/scale)  150 / 0.000153
Value read: Z (raw/scale)  -111 / 0.000153
Gyroscope value: [ -9.15, 0.60, -0.44 ]
4.4. BASH: script with all the measurements[edit source]
  • Content of iks01a2.sh
#!/bin/sh
echo "============================="
echo "===       HTS221          ==="
echo "===    (temperature)      ==="
printf "Temperature %.02f\n" $temperature
echo "===    (humidity)         ==="
printf "Humidity %.02f\n" $humidity
echo "===      LSM6DSL          ==="
echo "===    (accelerometer)    ==="
echo "===    (gyroscope)        ==="
  • Content of iks01a2_with_auto_detection.sh
#!/bin/sh
do
    # for hts221: Temperature + Humidity
    if grep -q hts221 $d/name ;
    then
    fi
    # for lsm6dsl: accelerometer
    if grep -q lsm6dsl_accel $d/name ;
    then
    fi
    # for lsm6dsl: gyroscope
    if grep -q lsm6dsl_gyro $d/name ;
    then
    fi
done
5. Read motion MEMS via Python script[edit source]
The goal of this section isto read the informations provided by Linux kernel interface and process it on a python script.
The python will display the value calculated on a window UI.
5.1. Display a window with Python and weston/wayland[edit source]
#!/usr/bin/python3
import gi
gi.require_version('Gtk', '3.0')
from gi.repository import Gtk
from gi.repository import GObject
from gi.repository import Gdk
from gi.repository import GLib
from gi.repository import GdkPixbuf
import cairo
import random
import math
import os
from time import sleep, time
class MainUIWindow(Gtk.Window):
    def __init__(self):
        Gtk.Window.__init__(self, title="Sensor usage")
        #self.set_decorated(False)
        self.maximize()
        self.screen_width = self.get_screen().get_width()
        self.screen_height = self.get_screen().get_height()
        self.set_default_size(self.screen_width, self.screen_height)
        print("[DEBUG] screen size: %dx%d" % (self.screen_width, self.screen_height))
        self.set_position(Gtk.WindowPosition.CENTER)
        self.connect('destroy', Gtk.main_quit)
    def destroy(self, widget, data=None):
        Gtk.main_quit()
# Main
if __name__ == "__main__":
    # add signal to catch CRTL+C
    import signal
    signal.signal(signal.SIGINT, signal.SIG_DFL)
    win = MainUIWindow()
    win.connect("delete-event", Gtk.main_quit)
    win.show_all()
    Gtk.main()
5.2. Read temperature[edit source]
Part of code for reading temperature with HTS221 driver:
def found_iio_device_with_name(data, name):
    prefix = "/sys/bus/iio/devices/"
    of_name = 'OF_NAME=' + name
    try:
        for filefolder in os.listdir(prefix):
            with open(prefix + '/' + filefolder + '/uevent') as f:
                for line in f:
                    if line.split('\n')[0] == of_name:
                        ''' return directory which contains "data" '''
                        if os.path.exists(prefix + '/' + filefolder + '/' + data):
                            return (prefix + '/' + filefolder + '/')
    except OSError:
        pass
    except Exception as exc:
        pass
    return None
prefix_path = found_iio_device_with_name("in_temp_raw", "hts221")
try:
    with open(prefix_path + "in_temp_" + 'raw', 'r') as f:
        raw = float(f.read())
    print("[ERROR] read %s " % prefix_path + "in_temp_" + 'raw', exc)
    raw = 0.0
try:
    with open(prefix_path + "in_temp_" + 'scale', 'r') as f:
        scale = float(f.read())
    print("[ERROR] read %s " % prefix_path + "in_temp_" + 'scale', exc)
    scale = 0.0
try:
    with open(prefix_path + "in_temp_" + 'offset', 'r') as f:
        offset = float(f.read())
    print("[ERROR] read %s " % prefix_path + "in_temp_" + 'offset', exc)
    offset = 0.0
temp = (offset + raw) * scale
5.3. Read humidity[edit source]
Part of code for reading humidity with HTS221 driver:
    try:
                for line in f:
    except OSError:
        pass
        pass
    return None
prefix_path = found_iio_device_with_name("in_humidityrelative_raw", "hts221")
try:
    with open(prefix_path + "in_humidityrelative_" + 'raw', 'r') as f:
    print("[ERROR] read %s " % prefix_path + "in_humidityrelative_" + 'raw', exc)
    raw = 0.0
try:
    with open(prefix_path + "in_humidityrelative_" + 'scale', 'r') as f:
    print("[ERROR] read %s " % prefix_path + "in_humidityrelative_" + 'scale', exc)
    scale = 0.0
try:
    with open(prefix_path + "in_humidityrelative_" + 'offset', 'r') as f:
    print("[ERROR] read %s " % prefix_path + "in_humidityrelative_" + 'offset', exc)
    offset = 0.0
humidity = (offset + raw) * scale
5.4. Read accelerometer[edit source]
Part of code for reading accelerometer with LSM6DSL driver:
    try:
                for line in f:
    except OSError:
        pass
        pass
    return None
prefix_path = found_iio_device_with_name("in_accel_x_raw", "lsm6dsl")
try:
    with open(prefix_path + "in_accel_" + 'x_raw', 'r') as f:
        xraw = float(f.read())
    print("[ERROR] read %s " % prefix_path + "in_accel_" + 'x_raw', exc)
    xraw = 0.0
try:
    with open(prefix_path + "in_accel_" + 'x_scale', 'r') as f:
        xscale = float(f.read())
    print("[ERROR] read %s " % prefix_path + "in_accel_" + 'x_scale', exc)
    xscale = 0.0
accel_x = int(xraw * xscale * 256.0 / 9.81)
try:
    with open(prefix_path + "in_accel_" + 'y_raw', 'r') as f:
        yraw = float(f.read())
    print("[ERROR] read %s " % prefix_path + "in_accel_" + 'y_raw', exc)
    yraw = 0.0
try:
    with open(prefix_path + "in_accel_" + 'y_scale', 'r') as f:
        yscale = float(f.read())
    print("[ERROR] read %s " % prefix_path + "in_accel_" + 'y_scale', exc)
    yscale = 0.0
accel_y = int(yraw * yscale * 256.0 / 9.81)
try:
    with open(prefix_path + "in_accel_" + 'z_raw', 'r') as f:
        zraw = float(f.read())
    print("[ERROR] read %s " % prefix_path + "in_accel_" + 'z_raw', exc)
    zraw = 0.0
try:
    with open(prefix_path + "in_accel_" + 'z_scale', 'r') as f:
        zscale = float(f.read())
    print("[ERROR] read %s " % prefix_path + "in_accel_" + 'z_scale', exc)
    zscale = 0.0
accel_z = int(zraw * zscale * 256.0 / 9.81)
5.5. Read gyroscope[edit source]
Part of code for reading gyroscope with LSM6DSL driver:
    try:
                for line in f:
    except OSError:
        pass
        pass
    return None
prefix_path = found_iio_device_with_name("in_anglvel_x_raw", "lsm6dsl")
try:
    with open(prefix_path + "in_anglvel_" + 'x_raw', 'r') as f:
    print("[ERROR] read %s " % prefix_path + "in_anglvel_" + 'x_raw', exc)
    xraw = 0.0
try:
    with open(prefix_path + "in_anglvel_" + 'x_scale', 'r') as f:
    print("[ERROR] read %s " % prefix_path + "in_anglvel_" + 'x_scale', exc)
    xscale = 0.0
gyro_x = int(xraw * xscale * 256.0 / 9.81)
try:
    with open(prefix_path + "in_anglvel_" + 'y_raw', 'r') as f:
    print("[ERROR] read %s " % prefix_path + "in_anglvel_" + 'y_raw', exc)
    yraw = 0.0
try:
    with open(prefix_path + "in_anglvel_" + 'y_scale', 'r') as f:
    print("[ERROR] read %s " % prefix_path + "in_anglvel_" + 'y_scale', exc)
    yscale = 0.0
gyro_y = int(yraw * yscale * 256.0 / 9.81)
try:
    with open(prefix_path + "in_anglvel_" + 'z_raw', 'r') as f:
    print("[ERROR] read %s " % prefix_path + "in_anglvel_" + 'z_raw', exc)
    zraw = 0.0
try:
    with open(prefix_path + "in_anglvel_" + 'z_scale', 'r') as f:
    print("[ERROR] read %s " % prefix_path + "in_anglvel_" + 'z_scale', exc)
    zscale = 0.0
gyro_z = int(zraw * zscale * 256.0 / 9.81)
5.6. Full script with information displayed on a windows[edit source]
#!/usr/bin/python3
import gi
import cairo
import random
import math
import os
# time between each sensor mesearuement (1s)
TIME_UPATE = 2000
class Sensors():
    def __init__(self):
        self.sensor_dictionnary = {}
    def found_iio_device_with_name(self, data, name):
        try:
                    for line in f:
        except OSError:
            pass
            pass
        return None
    def found_all_sensor_path(self):
        self.sensor_dictionnary['temperature'] = self.found_iio_device_with_name("in_temp_raw", "hts221")
        self.sensor_dictionnary['humidity']    = self.found_iio_device_with_name("in_humidityrelative_raw", "hts221")
        self.sensor_dictionnary['accelerometer'] = self.found_iio_device_with_name("in_accel_x_raw", "lsm6dsl")
        self.sensor_dictionnary['gyroscope'] = self.found_iio_device_with_name("in_anglvel_x_raw", "lsm6dsl")
        print("[DEBUG] temperature   -> ", self.sensor_dictionnary['temperature'], "<")
        print("[DEBUG] humidity      -> ", self.sensor_dictionnary['humidity'], "<")
        print("[DEBUG] accelerometer -> ", self.sensor_dictionnary['accelerometer'], "<")
        print("[DEBUG] gyroscope     -> ", self.sensor_dictionnary['gyroscope'], "<")
    def temperature_read(self):
        prefix_path = self.sensor_dictionnary['temperature']
        try:
            raw = 0.0
        try:
            scale = 0.0
        try:
            offset = 0.0
        return (offset + raw) * scale
    def humidity_read(self):
        prefix_path = self.sensor_dictionnary['humidity']
        try:
            raw = 0.0
        try:
            scale = 0.0
        try:
            offset = 0.0
    def accelerometer_read(self):
        prefix_path = self.sensor_dictionnary['accelerometer']
        try:
            xraw = 0.0
        try:
            xscale = 0.0
        try:
            yraw = 0.0
        try:
            yscale = 0.0
        try:
            zraw = 0.0
        try:
            zscale = 0.0
        return [ accel_x, accel_y, accel_z]
    def gyroscope_read(self):
        prefix_path = self.sensor_dictionnary['gyroscope']
        try:
            xraw = 0.0
        try:
            xscale = 0.0
        try:
            yraw = 0.0
        try:
            yscale = 0.0
        try:
            zraw = 0.0
        try:
            zscale = 0.0
        return [ gyro_x, gyro_y, gyro_z]
    def __init__(self):
        self.maximize()
        # search sensor interface
        self.sensors = Sensors()
        self.sensors.found_all_sensor_path()
        sensor_box = Gtk.VBox(spacing=0)
        # temperature
        temp_label = Gtk.Label()
        temp_label.set_markup("<span font_desc='LiberationSans 25'>Temperature</span>")
        self.temp_value_label = Gtk.Label()
        self.temp_value_label.set_markup("<span font_desc='LiberationSans 25'>--.-- °C</span>")
        temp_box = Gtk.HBox(False, 0)
        temp_box.add(temp_label)
        temp_box.add(self.temp_value_label)
        sensor_box.add(temp_box)
        # humidity
        humidity_label = Gtk.Label()
        humidity_label.set_markup("<span font_desc='LiberationSans 25'>Humidity</span>")
        self.humidity_value_label = Gtk.Label()
        self.humidity_value_label.set_markup("<span font_desc='LiberationSans 25'>--.-- %c</span>" % '%')
        humidity_box = Gtk.HBox(False, 0)
        humidity_box.add(humidity_label)
        humidity_box.add(self.humidity_value_label)
        sensor_box.add(humidity_box)
        # Accel
        accel_label = Gtk.Label()
        accel_label.set_markup("<span font_desc='LiberationSans 25'>Accelerometer</span>")
        self.accel_value_label = Gtk.Label()
        self.accel_value_label.set_markup("<span font_desc='LiberationSans 25'> [ --.--, --.--, --.--]</span>")
        accel_box = Gtk.HBox(False, 0)
        accel_box.add(accel_label)
        accel_box.add(self.accel_value_label)
        sensor_box.add(accel_box)
        # Gyroscope
        gyro_label = Gtk.Label()
        gyro_label.set_markup("<span font_desc='LiberationSans 25'>Gyroscope</span>")
        self.gyro_value_label = Gtk.Label()
        self.gyro_value_label.set_markup("<span font_desc='LiberationSans 25'> [ --.--, --.--, --.--]</span>")
        gyro_box = Gtk.HBox(False, 0)
        gyro_box.add(gyro_label)
        gyro_box.add(self.gyro_value_label)
        sensor_box.add(gyro_box)
        self.add(sensor_box)
        # Add a timer callback to update
        # this takes 2 args: (how often to update in millisec, the method to run)
        self.timer = GObject.timeout_add(TIME_UPATE, self.update_ui, None)
        self.timer_enable = True
        Gtk.main_quit()
    def update_ui(self, user_data):
        if False == self.timer_enable:
            return False;
        # temperature
        temp = self.sensors.temperature_read()
        self.temp_value_label.set_markup("<span font_desc='LiberationSans 25'>%.02f °C</span>" % temp)
        # humidity
        hum = self.sensors.humidity_read()
        self.humidity_value_label.set_markup("<span font_desc='LiberationSans 25'>%.02f %c</span>" % (hum, '%'))
        # accel
        accel = self.sensors.accelerometer_read()
        self.accel_value_label.set_markup("<span font_desc='LiberationSans 25'>[ %.02f, %.02f, %.02f]</span>" % (accel[0], accel[1], accel[2]))
        # gyro
        gyro = self.sensors.gyroscope_read()
        self.gyro_value_label.set_markup("<span font_desc='LiberationSans 25'>[ %.02f, %.02f, %.02f]</span>" % (gyro[0], gyro[1], gyro[2]))
        # As this is a timeout function, return True so that it
        # continues to get called
        return True
# Main
    import signal
    win.show_all()
    Gtk.main()
  • Screenshot
Result of Python script
5.7. Example of screenshot for displaying information[edit source]
Example of interpreted IMU data
Example of raw IMU data
Example of sensors data presentation
  1. IKS01A2 User Manual [1]
  2. 2.0 2.1 IKS01A2 Schematics [2]
  3. 3.0 3.1 STM32MP157C-DK2 Schematics [3]
