X-LINUX-AZURE licenses
For licenses associated with earlier versions of X-LINUX-AZURE package, refer to the archives at the end of this page
The following licenses are applicable to the version v6.0.0 of the X-LINUX-AZURE Expansion Package.
1. Top software license agreement (SLA) and application licenses[edit | edit source]
1.1. Software license agreement[edit | edit source]
License
SLA0048 Rev4/March 2018
BY INSTALLING COPYING, DOWNLOADING, ACCESSING OR OTHERWISE USING THIS SOFTWARE PACKAGE OR ANY PART THEREOF (AND THE RELATED DOCUMENTATION) FROM STMICROELECTRONICS INTERNATIONAL N.V, SWISS BRANCH AND/OR ITS AFFILIATED COMPANIES (STMICROELECTRONICS), THE RECIPIENT, ON BEHALF OF HIMSELF OR HERSELF, OR ON BEHALF OF ANY ENTITY BY WHICH SUCH RECIPIENT IS EMPLOYED AND/OR ENGAGED AGREES TO BE BOUND BY THIS SOFTWARE PACKAGE LICENSE AGREEMENT.
Under STMicroelectronics’ intellectual property rights and subject to applicable licensing terms for any third-party software incorporated in this software package and applicable Open Source Terms (as defined here below), the redistribution, reproduction and use in source and binary forms of the software package or any part thereof, with or without modification, are permitted provided that the following conditions are met:
1. Redistribution of source code (modified or not) must retain any copyright notice, this list of conditions and the following disclaimer.
2. Redistributions in binary form, except as embedded into microcontroller or microprocessor device manufactured by or for STMicroelectronics or a software update for such device, must reproduce the above copyright notice, this list of conditions and the following disclaimer in the documentation and/or other materials provided with the distribution.
3. Neither the name of STMicroelectronics nor the names of other contributors to this software package may be used to endorse or promote products derived from this software package or part thereof without specific written permission.
4. This software package or any part thereof, including modifications and/or derivative works of this software package, must be used and execute solely and exclusively on or in combination with a microcontroller or a microprocessor devices manufactured by or for STMicroelectronics.
5. No use, reproduction or redistribution of this software package partially or totally may be done in any manner that would subject this software package to any Open Source Terms (as defined below).
6. Some portion of the software package may contain software subject to Open Source Terms (as defined below) applicable for each such portion (“Open Source Software”), as further specified in the software package. Such Open Source Software is supplied under the applicable Open Source Terms and is not subject to the terms and conditions of license hereunder. “Open Source Terms” shall mean any open source license which requires as part of distribution of software that the source code of such software is distributed therewith or otherwise made available, or open source license that substantially complies with the Open Source definition specified at www.opensource.org and any other comparable open source license such as for example GNU General Public License (GPL), Eclipse Public License (EPL), Apache Software License, BSD license and MIT license.
7. This software package may also include third party software as expressly specified in the software package subject to specific license terms from such third parties. Such third party software is supplied under such specific license terms and is not subject to the terms and conditions of license hereunder. By installing copying, downloading, accessing or otherwise using this software package, the recipient agrees to be bound by such license terms with regard to such third party software.
8. STMicroelectronics has no obligation to provide any maintenance, support or updates for the software package.
9. The software package is and will remain the exclusive property of STMicroelectronics and its licensors. The recipient will not take any action that jeopardizes STMicroelectronics and its licensors' proprietary rights or acquire any rights in the software package, except the limited rights specified hereunder.
10. The recipient shall comply with all applicable laws and regulations affecting the use of the software package or any part thereof including any applicable export control law or regulation.
11. Redistribution and use of this software package partially or any part thereof other than as permitted under this license is void and will automatically terminate your rights under this license.
THIS SOFTWARE PACKAGE IS PROVIDED BY STMICROELECTRONICS AND CONTRIBUTORS "AS IS" AND ANY EXPRESS, IMPLIED OR STATUTORY WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT OF THIRD PARTY INTELLECTUAL PROPERTY RIGHTS ARE DISCLAIMED TO THE FULLEST EXTENT PERMITTED BY LAW. IN NO EVENT SHALL STMICROELECTRONICS OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE PACKAGE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
EXCEPT AS EXPRESSLY PERMITTED HEREUNDER AND SUBJECT TO THE APPLICABLE LICENSING TERMS FOR ANY THIRD-PARTY SOFTWARE INCORPORATED IN THE SOFTWARE PACKAGE AND OPEN SOURCE TERMS AS APPLICABLE, NO LICENSE OR OTHER RIGHTS, WHETHER EXPRESS OR IMPLIED, ARE GRANTED UNDER ANY PATENT OR OTHER INTELLECTUAL PROPERTY RIGHTS OF STMICROELECTRONICS OR ANY THIRD PARTY.
2. Software bill of materials[edit | edit source]
List of software brought by X-LINUX-AZURE Expansion Package, installed on image st-image-azure in addition to image st-image-weston:
Recipe Name Package Name Version Copyright License Description
aziot-edged aziot-edged 1.5.5-r1 Microsoft Corporation. All rights reserved. MIT The aziot-edged is the main binary for the IoT edge daemon.
Customized by X-LINUX-AZURE.
aziot-keys aziot-keys 1.5.0 Microsoft Corporation. All rights reserved. MIT aziot-keys is the default implementation of cryptographic operations used by the Keys Service.
aziotctl aziotctl 1.5.0 Microsoft Corporation. All rights reserved. MIT aziotctl is used to manage the IoT Identity Service and related services.
aziotd aziotd 1.5.0 Microsoft Corporation. All rights reserved. MIT aziotd is the main binary for the IoT Identity Service and related services.
containerd-opencontainers containerd-opencontainers v2.0.0-beta.0+git0+b1624c3628 Docker, Inc Apache-2.0 containerd is a daemon to control runC
demo-application-azure demo-application-azure 6.0 STMicroelectronics BSD-3-Clause Add basic support of Azure IoT Edge on Demo Launcher
docker-moby docker-moby-cli
docker-moby
25.0.3+gitf417435e5f6216828dec57958c490c4f8bae4f980+f417435e5f_67e0588f1d Docker, Inc Apache-2.0 Linux container runtime
iotedge iotedge 1.5.5 Microsoft Corporation. All rights reserved. MIT The iotedge tool is used to manage the IoT Edge runtime.
libseccomp libseccomp 2.5.5 Red Hat <pmoore@redhat.com>
Red Hat <mjuszkiewicz@redhat.com>
Imagination Technologies Ltd.
Helge Deller <deller@gmx.de>
Freescale <bogdan.purcareata@freescale.com>
IBM
Microsoft Corporation. <paulmoore@microsoft.com>
Cisco Systems, Inc. <pmoore2@cisco.com>
LGPL-2.1 interface to seccomp filtering mechanism
pkcs11-provider pkcs11-provider 0.5-r1 simo@redhat.com Apache-2.0 An OpenSSL provider that allows direct interfacing with pkcs11 drivers
python3-tpm2-pytss python3-tpm2-pytss 2.1.0 Johannes Holland BSD-2-Clause python3-tpm2-pytss version 2.1.0-r0
runc-opencontainers runc-opencontainers 1.1.12+git0+a9833ff391 Docker, Inc Apache-2.0 runc container cli tools
tini tini 0.19.0 Thomas Orozco <thomas@orozco.fr> MIT Minimal init for containers
tpm2-abrmd tpm2-abrmd 3.0.0 Intel Corporation BSD-2-Clause TPM2 Access Broker & Resource Manager
tpm2-openssl tpm2-openssl 1.1.1 Fraunhofer SIT sponsored by Infineon Technologies AG
Wind River Systems
Petr Gotthard
BSD-3-Clause Provider for integration of TPM 2.0 to OpenSSL 3.0
tpm2-pkcs11 tpm2-pkcs11 1.9.0-r1 g10 Code GmbH
Andreas Jellinghaus
Red Hat, Inc.
BSD-2-Clause A PKCS#11 interface for TPM2 hardware
tpm2-tools tpm2-tools 5.7 Alibaba Group
Atom Software Studios, s.r.o.
Emmanuel Deloget <logout@free.fr>
Fraunhofer SIT
GlovePuppet
Intel Corporation
Massachusetts Institute of Technology
National Instruments
Red Hat, Inc.
Sebastien LE STUM
SUSE GmbH
Wind River Systems
BSD-3-Clause Tools for TPM2.
tpm2-totp tpm2-totp 0.3.0 Behdad Esfahbod
Fraunhofer SIT
Jonas Witschel
Linux TPM2 & TSS2 Software
Red Hat Inc.
BSD-3-Clause Attest the trustworthiness of a device against a human using time-based one-time passwords
tpm2-tss tpm2-tss
libtss2-tcti-device0
libtss2
libtss2-tcti-mssim0
libtss2-mu0
4.0.2 Andreas Droescher
Behdad Esfahbod
Facebook, Inc. and its affiliates
Fraunhofer SIT
Intel
Intel Corporation
Red Hat Inc.
Wind River Systems
BSD-2-Clause Software stack for TPM2.
tpm2-tss tpm2-tss
libtss2-tcti-mssim0
libtss2
libtss2-mu0
Behdad Esfahbod
Fraunhofer SIT
Intel
Intel Corporation
Red Hat Inc.
Wind River Systems
tpm2-tss-engine tpm2-tss-engine-engines
tpm2-tss-engine
1.1.0 Fraunhofer SIT sponsored by Infineon
Wind River Systems.
BSD-3-Clause The tpm2-tss-engine project implements a cryptographic engine for OpenSSL.
trousers trousers 0.3.15+git0+94144b0a1d Christian Kummer
TrouSerS Project
International Business Machines Corp
Intel Corporation
BSD-3-Clause TrouSerS - An open-source TCG Software Stack implementation.
List of software brought by OpenSTLinux, needed by X-LINUX-AZURE Expansion Package, installed on image st-image-azure, available on ST package repository:
Recipe Name Package Name Version License Description
ccid ccid 1.5.5 LGPL-2.1 Generic USB CCID smart card reader driver
connman connman
connman-client
1.42 GPL-2.0 A daemon for managing internet connections within embedded devices
glibc libc6-utils 2.39+git0+e8f5217097 LGPL-2.0 Miscellaneous utilities provided by glibc
libtasn1 libtasn1-6 4.19.0 LGPL-2.1 Library for ASN.1 and DER manipulation
opensc opensc 0.25.1 LGPL-2.1 Smart card library and applications
optee-client optee-client 4.0.0+git0+acb0885c11-r2 BSD-2-Clause OPTEE Client
optee-os-stm32mp optee-os-stm32mp-ta-pkcs11 4.0.0-stm32mp-r1-r1 BSD-2-Clause OPTEE TA development kit for stm32mp
p11-kit p11-kit 0.25.3 BSD-3-Clause Provides a way to load and enumerate PKCS#11 modules
pcsc-lite libpcsclite1
pcsc-lite
2.0.3 BSD-3-Clause PC/SC Lite smart card framework and applications
3. Archives Archive box.png[edit | edit source]
X-LINUX-AZURE release X-LINUX-AZURE licenses
X-LINUX-AZURE v5.1.0 X-LINUX-AZURE_licenses - v5.1.0
