1. Usage
The FlowCompatibility/Android template is used to indicate via a simple message, the last release for which the OpenSTdroid embedded software has been updated.
This template shall be added on top of all pages that deal with Android; if Android has not been ported yet on the last ecosystem release, then this template shall return the message; else, it shall return nothing; therefore, this template is always used for all Android pages and this template must be updated each time Android is ported on the last ecosystem release.
Usage: {{FlowCompatibility/Android}}
The returned value is a message informing reader about the most recent Flow version on which Android has been been ported.
The template must be set on top of the article, just below the ApplicableForm template.
2. Basic examples
You type | You get |
Compatibility message for Android
{{FlowCompatibility/Android}}<br> |
3. More examples
Check the spaces before and after the infobox
BEFORE{{FlowCompatibility/Android}}AFTER |
BEFORE AFTER |
4. Code
Example of message : OpenSTDroid is validated against the ecosystem release v5.1.0 . It has not been ported yet on ecosystem release v6.0.0 .
If Android has been ported on the last ecosystem release then the message should be empty.
