STM32CubeRelease
1. Usage
The STM32CubeRelease template is used to indicate for which STM32Cube release revision(s), an article part (chapter, paragraph, table...) is valid. Per default (i.e. if this template is not used), any part of an article is valid for all STM32Cube release revisions for which the entire article is valid.
Usage: {{STM32CubeRelease| revision=<revision> | range =<range> | revision2=<revision2>}}
Where:
  • <revision> is the mandatory STM32Cube release revision for which the article part is valid.
    • The possible values for this parameter are available in the STM32CubeRelease/Revision template.
    • The optional <range> and <revision2> parameters allow to define a range of revisions.
  • <range> is the optional range of the STM32Cube release revisions for which the article part is valid. The possible values are:
    • and before: the article part is valid only for the revision(s) less than or equal to <revision>
    • and after: the article part is valid only for the revision(s) greater than or equal to <revision>
    • to: the article part is only valid from <revision> to <revision2>
  • <revision2> is the mandatory STM32Cube release upper revision for which the article part is valid, when <range> is set to "to"; in this case, <revision> becomes the lower revision for which the article part is valid.
    • This parameter is ignored if <range> is either not set, or set to another value than "to".
Warning DB.png Important
Use the value latest for <revision> or <revision2> with caution: be aware that the returned string will vary depending on the latest STM32Cube release.
If the mouse is left over a revision (or the More info.png icon), a popup window shows, for that revision:
  • the version of the STM32CubeMP1 Package
  • the version of the STM32CubeMP13 Package
  • the version of the STM32CubeIDE
  • the version of the STM32CubeMX
  • the version of the STM32CubeProgrammer
This information comes from the STM32CubeRelease/Components template.
2. Basic examples
You type You get
The latest revision
{{STM32CubeRelease| revision=latest}}
A specific revision (revision 1.17.0)
{{STM32CubeRelease| revision=1.17.0}}
A specific revision (revision 1.16.0)
{{STM32CubeRelease| revision=1.16.0}}
A specific revision (revision 1.15.0)
{{STM32CubeRelease| revision=1.15.0}}
Revisions that are lower than or equal to a revision
{{STM32CubeRelease| revision=x.1.0 | range=and before}}
{{STM32CubeRelease| revision=x.1.0 | range=and after}}
Range of revisions
{{STM32CubeRelease| revision=x.0.0 | range=to | revision2=x.1.0}}
Revisions that are lower than or equal to the latest one
{{STM32CubeRelease| revision=latest | range=and before}}
Revisions that are greater than or equal to the latest one
{{STM32CubeRelease| revision=latest | range=and after}}
Range of revisions
{{STM32CubeRelease| revision=x.0.0 | range=to | revision2=latest}}
3. More examples
You type You get
Revision x.2.0 (next)
{{STM32CubeRelease| revision=x.2.0}}
Revision x.1.0 (latest)
{{STM32CubeRelease| revision=x.1.0}}
Revision x.0.0 (legacy)
{{STM32CubeRelease| revision=x.0.0}}
Former revision that is part of a flow that is not the one associated with this wiki.
{{STM32CubeRelease| revision=0.y.0}}<br>
{{STM32CubeRelease| revision=0.y.0 | range=and before}}<br>
{{STM32CubeRelease| revision=0.y.0 | range=and after}}
STM32Cube release v0.y.0
STM32Cube release ≤ v0.y.0
STM32Cube release ≥ v0.y.0
Unspecified revision
{{STM32CubeRelease}}
Unknown revision
{{STM32CubeRelease| revision=10.20.30}}
Unspecified revision2
{{STM32CubeRelease| revision=x.1.0 | range=to}}
Unknown revision2
{{STM32CubeRelease| revision=x.1.0 | range=to | revision2=10.20.30}}
STM32Cube release vx.1.0 More info.png to unknown revision 10.20.30 Warning.png
Former revision2 that is part of a flow that is not the one associated with this wiki.
{{STM32CubeRelease| revision=x.0.0 | range=to | revision2=0.y.0}}<br>
{{STM32CubeRelease| revision=0.y.0 | range=to | revision2=0.y.0}}
STM32Cube release vx.0.0 More info.png to v0.y.0
STM32Cube release v0.y.0 to v0.y.0
Ignored revision2
{{STM32CubeRelease| revision=x.0.0 | range=and after  | revision2=x.1.0}}
Unknown range
{{STM32CubeRelease| revision=x.1.0 | range=error}}
BEFORE{{STM32CubeRelease| revision=x.0.0}}AFTER<br>
BEFORE{{STM32CubeRelease| revision=x.1.0 | range=and before}}AFTER<br>
BEFORE{{STM32CubeRelease| revision=x.1.0 | range=and after}}AFTER<br>
BEFORE{{STM32CubeRelease| revision=x.0.0 | range=to | revision2=x.1.0}}AFTER
BEFORESTM32Cube release vx.0.0 More info.png AFTER
BEFORESTM32Cube release ≤ vx.1.0 More info.png AFTER
BEFORESTM32Cube release ≥ vx.1.0 More info.png AFTER
BEFORESTM32Cube release vx.0.0 More info.png to vx.1.0 More info.pngAFTER
4. Code
No categories assignedEdit
