1. Top Software license agreement (SLA) and third-party licences[edit source]
Contents of Images SPDX License
MACHINE | stm32mp2 & stm32mp1 |
IMAGE | st-image-weston |
DISTRO | openstlinux-weston |
VERSION | 4.2.4-openstlinux-6.1-yocto-mickledore-mpu-v24.06.26 |
OE branch | mickledore |
1.1. Sofware license agreement[edit source]
License |
SLA0048 Rev4/March 2018
1.2. Vivante libraries OpenGL ES, OpenVG and EGL (multi backend), (Not applicable for STM32MP13)[edit source]
License |
Vivante End User Software License Terms
1.3. Firmware-cypress-bcm4343[edit source]
License |
CYPRESS WIRELESS CONNECTIVITY DEVICES |
1.4. Firmware-broadcom_bcm43xx[edit source]
License |
BROADCOM BCM43XX |
2. Boot partition:[edit source]
List of packages used during the different boot phases:
Recipe Name | Version | License |
fip-stm32mp | 5.1 | BSD-3-Clause |
linux-stm32mp | 6.1.82-stm32mp-r2 | GPL-2.0-only |
optee-os-stm32mp | 3.19.0-stm32mp-r2 | BSD-2-Clause & BSD-3-Clause |
st-initrd | 1.0 | MIT |
tf-a-stm32mp | v2.8.15-stm32mp-r2 | BSD-3-Clause |
tf-m-stm32mp | v1.7.0-stm32mp25 | BSD-3-Clause & Apache-2.0 |
u-boot-stm32mp | v2022.10-stm32mp-r2 | GPL-2.0-or-later |
3. Kernel partitions:[edit source]
3.1. bootfs partition:[edit source]
List of packages present on image:
Image | st-image-bootfs-openstlinux-weston-stm32mp25 |
Recipe Name | Package Name | Version | License | Description |
linux-stm32mp | kernel-imagebootfs | 6.1.82-stm32mp-r2 | GPL-2.0-only | Linux STM32MP Kernel |
st-initrd | st-initrd | 1.0 | MIT | ST InitRD installation package for st-image-resize-initrd image(s) |
stm32mp-extlinux | stm32mp-extlinux | 3.1.1 | MIT | Provide 'extlinux.conf' file for U-Boot |
u-boot-stm32mp-splash | u-boot-stm32mp-splash | 2018.11 | No license to ST trademark | Universal Boot Loader Splash Screen for stm32mp embedded devices |
3.2. rootfs partition:[edit source]
Image | st-image-weston-openstlinux-weston-stm32mp25 |
adwaita-icon-theme | adwaita-icon-theme-symbolic | 43 | CC-BY-SA-3.0 | GTK+ icon theme |
alsa-lib | alsa-conf | 1.2.8 | LGPL-2.1-only & GPL-2.0-or-later | ALSA sound library |
alsa-state | alsa-state | 0.2.0 | MIT & GPL-2.0-or-later | Alsa scenario files to enable alsa state restoration |
alsa-state-script | alsa-state-script | 1.0 | MIT | Alsa script file for alsa state restoration |
alsa-state-stm32mp2 | alsa-state-stm32mp2 | 1.0 | MIT | Alsa scenario files to enable alsa state restoration |
alsa-state | alsa-states | 0.2.0 | MIT & GPL-2.0-or-later | Alsa scenario files to enable alsa state restoration |
alsa-topology-conf | alsa-topology-conf | 1.2.5.1 | BSD-3-Clause | ALSA topology configuration files |
alsa-ucm-conf | alsa-ucm-conf | 1.2.8 | BSD-3-Clause | ALSA Use Case Manager configuration |
alsa-utils | alsa-utils-aconnect | 1.2.8 | GPL-2.0-only | ALSA sequencer connection manager |
alsa-utils | alsa-utils-alsabat | 1.2.8 | GPL-2.0-only | Command-line sound tester for ALSA sound card driver |
alsa-utils | alsa-utils-alsactl | 1.2.8 | GPL-2.0-only | Saves/restores ALSA-settings in /etc/asound.state |
alsa-utils | alsa-utils-alsaloop | 1.2.8 | GPL-2.0-only | ALSA PCM loopback utility |
alsa-utils | alsa-utils-alsamixer | 1.2.8 | GPL-2.0-only | ncurses-based control for ALSA mixer and settings |
alsa-utils | alsa-utils-alsatplg | 1.2.8 | GPL-2.0-only | Converts topology text files into binary format for kernel |
alsa-utils | alsa-utils-alsaucm | 1.2.8 | GPL-2.0-only | ALSA Use Case Manager |
alsa-utils | alsa-utils-amixer | 1.2.8 | GPL-2.0-only | Command-line control for ALSA mixer and settings |
alsa-utils | alsa-utils-aplay | 1.2.8 | GPL-2.0-only | Play (and record) sound files using ALSA |
alsa-utils | alsa-utils-aseqdump | 1.2.8 | GPL-2.0-only | Shows the events received at an ALSA sequencer port |
alsa-utils | alsa-utils-aseqnet | 1.2.8 | GPL-2.0-only | Network client/server for ALSA sequencer |
alsa-utils | alsa-utils-iecset | 1.2.8 | GPL-2.0-only | ALSA utility for setting/showing IEC958 (S/PDIF) status bits |
alsa-utils | alsa-utils-midi | 1.2.8 | GPL-2.0-only | Miscellaneous MIDI utilities for ALSA |
alsa-utils | alsa-utils-scripts | 1.2.8 | GPL-2.0-only | Shell scripts that show help info and create ALSA configuration files |
alsa-utils | alsa-utils-speakertest | 1.2.8 | GPL-2.0-only | ALSA surround speaker test utility |
apt | apt | 2.4.5 | GPL-2.0-or-later | Advanced front-end for dpkg |
apt-openstlinux | apt-openstlinux | 5.1 | MIT | Add apt configuration files for OpenSTLinux |
at-spi2-core | at-spi2-core | 2.46.0 | LGPL-2.1-or-later | Assistive Technology Service Provider Interface (dbus core) |
avahi | avahi-daemon | 0.8 | LGPL-2.1-or-later | Avahi IPv4LL network address configuration daemon |
babeltrace | babeltrace | 1.5.11 | MIT & GPL-2.0-only & LGPL-2.1-only | Babeltrace - Trace Format Babel Tower |
babeltrace2 | babeltrace2 | 2.0.5 | MIT & GPL-2.0-only & LGPL-2.1-only & BSD-2-Clause | Babeltrace2 - Trace Format Babel Tower |
base-files | base-files | 3.0.14 | GPL-2.0-only | Miscellaneous files for the base system |
bash | bash | 5.2.15 | GPL-3.0-or-later | An sh-compatible command language interpreter |
bc | bc | 1.07.1 | GPL-3.0-or-later | Arbitrary precision calculator language |
blktool | blktool | 4-7.1 | GPL-2.0-or-later | Tune low-level block device parameters |
blktrace | blktrace | 1.3.0+gitAUTOINC+366d30b9cd | GPL-2.0-only | Generates traces of I/O traffic on block devices |
bluetooth-suspend | bluetooth-suspend | 1.0 | MIT | Systemd service to suspend/resume correctly bluetooth |
bluez5 | bluez5 | 5.66 | GPL-2.0-or-later & LGPL-2.1-or-later | Linux Bluetooth Stack Userland V5 |
bridge-utils | bridge-utils | 1.7.1 | GPL-2.0-only | Tools for ethernet bridging |
build-info-openstlinux | build-info-openstlinux | 1.0 | MIT | Writes build information to target filesystem on /etc/build |
busybox | busybox | 1.36.1 | GPL-2.0-only & bzip2-1.0.4 | Tiny versions of many common UNIX utilities in a single small executable |
busybox | busybox-syslog | 1.36.1 | GPL-2.0-only & bzip2-1.0.4 | Tiny versions of many common UNIX utilities in a single small executable |
busybox | busybox-udhcpc | 1.36.1 | GPL-2.0-only & bzip2-1.0.4 | Tiny versions of many common UNIX utilities in a single small executable |
bzip2 | bzip2 | 1.0.8 | bzip2-1.0.6 | Very high-quality data compression program |
ca-certificates | ca-certificates | 20211016 | GPL-2.0-or-later & MPL-2.0 | Common CA certificates |
can-utils | can-utils | 2023.03 | GPL-2.0-only & BSD-3-Clause | Linux CAN network development utilities |
ckermit | ckermit | 302 | BSD-3-Clause | ckermit version 302-r0 |
coreutils | coreutils | 9.1 | GPL-3.0-or-later | The basic file, shell and text manipulation utilities |
coreutils | coreutils-stdbuf | 9.1 | GPL-3.0-or-later | The basic file, shell and text manipulation utilities |
cpufrequtils | cpufrequtils | 008 | GPL-2.0-only | cpufrequtils version 008-r5 |
cracklib | cracklib | 2.9.11 | LGPL-2.1-or-later | Password strength checker library |
curl | curl | 8.0.1 | curl | Command line tool and library for client-side URL transfers |
db | db | 5.3.28 | Sleepycat | Berkeley Database v5 |
dbus | dbus-1 | 1.14.10 | GPL-2.0-or-later | D-Bus message bus |
dbus | dbus-common | 1.14.10 | GPL-2.0-or-later | D-Bus message bus |
dbus | dbus-tools | 1.14.10 | GPL-2.0-or-later | D-Bus message bus |
desktop-file-utils | desktop-file-utils | 0.26 | GPL-2.0-or-later | Command line utilities for working with *.desktop files |
dosfstools | dosfstools | 4.2 | GPL-3.0-only | DOS FAT Filesystem Utilities |
dpkg | dpkg | 1.21.22 | GPL-2.0-or-later | Package maintenance system from Debian |
dpkg | dpkg-start-stop | 1.21.22 | GPL-2.0-or-later | Package maintenance system from Debian |
dropbear | dropbear | 2022.83 | MIT & BSD-3-Clause & BSD-2-Clause & PD | A lightweight SSH and SCP implementation |
e2fsprogs | e2fsprogs | 1.47.0 | GPL-2.0-only & LGPL-2.0-only & BSD-3-Clause & MIT | Ext2 Filesystem Utilities |
e2fsprogs | e2fsprogs-badblocks | 1.47.0 | GPL-2.0-only | Ext2 Filesystem Utilities |
e2fsprogs | e2fsprogs-dumpe2fs | 1.47.0 | GPL-2.0-only | Ext2 Filesystem Utilities |
e2fsprogs | e2fsprogs-e2fsck | 1.47.0 | GPL-2.0-only | Ext2 Filesystem Utilities |
e2fsprogs | e2fsprogs-mke2fs | 1.47.0 | GPL-2.0-only | Ext2 Filesystem Utilities |
e2fsprogs | e2fsprogs-resize2fs | 1.47.0 | GPL-2.0-only & LGPL-2.0-only & BSD-3-Clause & MIT | Ext2 Filesystem Utilities |
elfutils | elfutils | 0.188 | GPL-3.0-or-later | Utilities and libraries for handling compiled object files |
ethtool | ethtool | 6.2 | GPL-2.0-or-later | Display or change ethernet card settings |
evtest | evtest | 1.35 | GPL-2.0-only | Simple tool for input event debugging |
fb-test | fb-test | 1.1.0 | GPL-2.0-only | Test suite for Linux framebuffer |
file | file | 5.45 | BSD-2-Clause | File classification tool |
fontconfig | fontconfig-utils | 2.14.2 | MIT & MIT & PD | Generic font configuration library |
gcnano-userland-multi-binary-stm32mp | gcnano-ldconf | 6.4.15+20240517 | Proprietary | Vivante libraries OpenGL ES, OpenVG and EGL (multi backend) |
gdb | gdbserver | 13.2 | GPL-2.0-only & GPL-3.0-only & LGPL-2.0-only & LGPL-3.0-only | GNU debugger |
glib-networking | glib-networking | 2.74.0 | LGPL-2.1-only | GLib networking extensions |
glibc-locale | glibc-binary-localedata-en-us | 2.37 | GPL-2.0-only & LGPL-2.1-only | binary locale definition for en-us |
glibc-locale | glibc-gconv | 2.37 | GPL-2.0-only & LGPL-2.1-only | Locale data from glibc |
glibc-locale | glibc-gconv-iso8859-1 | 2.37 | GPL-2.0-only & LGPL-2.1-only | gconv module for character set iso8859-1 |
glmark2 | glmark2 | 2023.01 | GPL-3.0-or-later & SGI-1 | OpenGL (ES) 2.0 benchmark |
gnupg | gnupg | 2.4.3 | GPL-3.0-only & LGPL-3.0-only | GNU Privacy Guard - encryption and signing tools (2.x) |
gnupg | gnupg-gpg | 2.4.3 | GPL-3.0-only & LGPL-3.0-only | GNU Privacy Guard - encryption and signing tools (2.x) |
gobject-introspection | gobject-introspection | 1.74.0 | LGPL-2.0-or-later & GPL-2.0-or-later & MIT | Middleware layer between GObject-using C libraries and language bindings |
gpio-udev | gpio-udev | 1.0 | GPL-2.0-only | Add udev rules to set GPIO to dialout group |
gptfdisk | gptfdisk | 1.0.9 | GPL-2.0-only | Utility for modifying GPT disk partitioning |
grep | grep | 3.10 | GPL-3.0-only | GNU grep utility |
gstreamer1.0 | gstreamer1.0 | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 multimedia framework |
gstreamer1.0-libav | gstreamer1.0-libav | 1.22.6 | LGPL-2.1-or-later | Libav-based GStreamer 1.x plugin |
pipewire | gstreamer1.0-pipewire | 1.0.0 | MIT & LGPL-2.1-or-later & GPL-2.0-only | Multimedia processing server for Linux |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-accurip | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for accurip |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-adpcmdec | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for adpcmdec |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-adpcmenc | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for adpcmenc |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-aes | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for aes |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-aiff | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for aiff |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-apps | 1.22.6 | LGPL-2.1-or-later | 'Bad' GStreamer plugins and helper libraries |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-asfmux | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for asfmux |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-audiobuffersplit | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for audiobuffersplit |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-audiofxbad | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for audiofxbad |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-audiolatency | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for audiolatency |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-audiomixmatrix | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for audiomixmatrix |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-audiovisualizers | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for audiovisualizers |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-autoconvert | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for autoconvert |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-bayer | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for bayer |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-bluez | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for bluez |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-bz2 | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for bz2 |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-camerabin | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for camerabin |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-closedcaption | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for closedcaption |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-codecalpha | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for codecalpha |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-codectimestamper | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for codectimestamper |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-coloreffects | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for coloreffects |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-curl | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for curl |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-dash | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for dash |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-debugutilsbad | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for debugutilsbad |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-decklink | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for decklink |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-dtls | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for dtls |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-dvb | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for dvb |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-dvbsubenc | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for dvbsubenc |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-dvbsuboverlay | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for dvbsuboverlay |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-dvdspu | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for dvdspu |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-faac | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for faac |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-faceoverlay | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for faceoverlay |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-fbdevsink | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for fbdevsink |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-festival | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for festival |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-fieldanalysis | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for fieldanalysis |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-freeverb | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for freeverb |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-frei0r | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for frei0r |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-gaudieffects | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for gaudieffects |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-gdp | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for gdp |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-geometrictransform | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for geometrictransform |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-gtkwayland | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for gtkwayland |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-hls | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for hls |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-id3tag | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for id3tag |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-inter | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for inter |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-interlace | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for interlace |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-ipcpipeline | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for ipcpipeline |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-ivfparse | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for ivfparse |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-ivtc | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for ivtc |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-jp2kdecimator | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for jp2kdecimator |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-jpegformat | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for jpegformat |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-kms | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for kms |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-legacyrawparse | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for legacyrawparse |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-midi | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for midi |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-mpegpsdemux | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for mpegpsdemux |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-mpegpsmux | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for mpegpsmux |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-mpegtsdemux | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for mpegtsdemux |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-mpegtsmux | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for mpegtsmux |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-mxf | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for mxf |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-netsim | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for netsim |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-pcapparse | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for pcapparse |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-pnm | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for pnm |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-proxy | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for proxy |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-removesilence | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for removesilence |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-rfbsrc | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for rfbsrc |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-rist | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for rist |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-rsvg | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for rsvg |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-rtmp2 | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for rtmp2 |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-rtpmanagerbad | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for rtpmanagerbad |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-rtponvif | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for rtponvif |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-sbc | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for sbc |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-sdpelem | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for sdpelem |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-segmentclip | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for segmentclip |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-shm | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for shm |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-siren | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for siren |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-smooth | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for smooth |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-smoothstreaming | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for smoothstreaming |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-sndfile | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for sndfile |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-speed | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for speed |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-subenc | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for subenc |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-switchbin | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for switchbin |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-timecode | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for timecode |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-transcode | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for transcode |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-ttmlsubs | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for ttmlsubs |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-uvch264 | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for uvch264 |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-v4l2codecs | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for v4l2codecs |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-videofiltersbad | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for videofiltersbad |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-videoframe-audiolevel | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for videoframe-audiolevel |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-videoparsersbad | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for videoparsersbad |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-videosignal | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for videosignal |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-vmnc | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for vmnc |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-vulkan | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for vulkan |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-waylandsink | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for waylandsink |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-webp | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for webp |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-y4mdec | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for y4mdec |
gstreamer1.0-plugins-base | gstreamer1.0-plugins-base | 1.22.6 | LGPL-2.1-or-later | 'Base' GStreamer plugins and helper libraries |
gstreamer1.0-plugins-base | gstreamer1.0-plugins-base-adder | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for adder |
gstreamer1.0-plugins-base | gstreamer1.0-plugins-base-alsa | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for alsa |
gstreamer1.0-plugins-base | gstreamer1.0-plugins-base-app | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for app |
gstreamer1.0-plugins-base | gstreamer1.0-plugins-base-apps | 1.22.6 | LGPL-2.1-or-later | 'Base' GStreamer plugins and helper libraries |
gstreamer1.0-plugins-base | gstreamer1.0-plugins-base-audioconvert | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for audioconvert |
gstreamer1.0-plugins-base | gstreamer1.0-plugins-base-audiomixer | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for audiomixer |
gstreamer1.0-plugins-base | gstreamer1.0-plugins-base-audiorate | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for audiorate |
gstreamer1.0-plugins-base | gstreamer1.0-plugins-base-audioresample | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for audioresample |
gstreamer1.0-plugins-base | gstreamer1.0-plugins-base-audiotestsrc | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for audiotestsrc |
gstreamer1.0-plugins-base | gstreamer1.0-plugins-base-compositor | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for compositor |
gstreamer1.0-plugins-base | gstreamer1.0-plugins-base-encoding | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for encoding |
gstreamer1.0-plugins-base | gstreamer1.0-plugins-base-gio | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for gio |
gstreamer1.0-plugins-base | gstreamer1.0-plugins-base-ogg | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for ogg |
gstreamer1.0-plugins-base | gstreamer1.0-plugins-base-opengl | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for opengl |
gstreamer1.0-plugins-base | gstreamer1.0-plugins-base-overlaycomposition | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for overlaycomposition |
gstreamer1.0-plugins-base | gstreamer1.0-plugins-base-pango | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for pango |
gstreamer1.0-plugins-base | gstreamer1.0-plugins-base-pbtypes | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for pbtypes |
gstreamer1.0-plugins-base | gstreamer1.0-plugins-base-playback | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for playback |
gstreamer1.0-plugins-base | gstreamer1.0-plugins-base-rawparse | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for rawparse |
gstreamer1.0-plugins-base | gstreamer1.0-plugins-base-subparse | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for subparse |
gstreamer1.0-plugins-base | gstreamer1.0-plugins-base-tcp | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for tcp |
gstreamer1.0-plugins-base | gstreamer1.0-plugins-base-theora | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for theora |
gstreamer1.0-plugins-base | gstreamer1.0-plugins-base-typefindfunctions | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for typefindfunctions |
gstreamer1.0-plugins-base | gstreamer1.0-plugins-base-videoconvertscale | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for videoconvertscale |
gstreamer1.0-plugins-base | gstreamer1.0-plugins-base-videorate | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for videorate |
gstreamer1.0-plugins-base | gstreamer1.0-plugins-base-videotestsrc | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for videotestsrc |
gstreamer1.0-plugins-base | gstreamer1.0-plugins-base-volume | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for volume |
gstreamer1.0-plugins-base | gstreamer1.0-plugins-base-vorbis | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for vorbis |
gstreamer1.0-plugins-good | gstreamer1.0-plugins-good-adaptivedemux2 | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for adaptivedemux2 |
gstreamer1.0-plugins-good | gstreamer1.0-plugins-good-alaw | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for alaw |
gstreamer1.0-plugins-good | gstreamer1.0-plugins-good-alpha | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for alpha |
gstreamer1.0-plugins-good | gstreamer1.0-plugins-good-alphacolor | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for alphacolor |
gstreamer1.0-plugins-good | gstreamer1.0-plugins-good-apetag | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for apetag |
gstreamer1.0-plugins-good | gstreamer1.0-plugins-good-audiofx | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for audiofx |
gstreamer1.0-plugins-good | gstreamer1.0-plugins-good-audioparsers | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for audioparsers |
gstreamer1.0-plugins-good | gstreamer1.0-plugins-good-auparse | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for auparse |
gstreamer1.0-plugins-good | gstreamer1.0-plugins-good-autodetect | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for autodetect |
gstreamer1.0-plugins-good | gstreamer1.0-plugins-good-avi | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for avi |
gstreamer1.0-plugins-good | gstreamer1.0-plugins-good-cairo | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for cairo |
gstreamer1.0-plugins-good | gstreamer1.0-plugins-good-cutter | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for cutter |
gstreamer1.0-plugins-good | gstreamer1.0-plugins-good-debug | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for debug |
gstreamer1.0-plugins-good | gstreamer1.0-plugins-good-deinterlace | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for deinterlace |
gstreamer1.0-plugins-good | gstreamer1.0-plugins-good-dtmf | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for dtmf |
gstreamer1.0-plugins-good | gstreamer1.0-plugins-good-effectv | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for effectv |
gstreamer1.0-plugins-good | gstreamer1.0-plugins-good-equalizer | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for equalizer |
gstreamer1.0-plugins-good | gstreamer1.0-plugins-good-flac | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for flac |
gstreamer1.0-plugins-good | gstreamer1.0-plugins-good-flv | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for flv |
gstreamer1.0-plugins-good | gstreamer1.0-plugins-good-flxdec | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for flxdec |
gstreamer1.0-plugins-good | gstreamer1.0-plugins-good-gdkpixbuf | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for gdkpixbuf |
gstreamer1.0-plugins-good | gstreamer1.0-plugins-good-goom | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for goom |
gstreamer1.0-plugins-good | gstreamer1.0-plugins-good-goom2k1 | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for goom2k1 |
gstreamer1.0-plugins-good | gstreamer1.0-plugins-good-gtk | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for gtk |
gstreamer1.0-plugins-good | gstreamer1.0-plugins-good-icydemux | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for icydemux |
gstreamer1.0-plugins-good | gstreamer1.0-plugins-good-id3demux | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for id3demux |
gstreamer1.0-plugins-good | gstreamer1.0-plugins-good-imagefreeze | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for imagefreeze |
gstreamer1.0-plugins-good | gstreamer1.0-plugins-good-interleave | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for interleave |
gstreamer1.0-plugins-good | gstreamer1.0-plugins-good-isomp4 | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for isomp4 |
gstreamer1.0-plugins-good | gstreamer1.0-plugins-good-jpeg | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for jpeg |
gstreamer1.0-plugins-good | gstreamer1.0-plugins-good-lame | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for lame |
gstreamer1.0-plugins-good | gstreamer1.0-plugins-good-level | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for level |
gstreamer1.0-plugins-good | gstreamer1.0-plugins-good-matroska | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for matroska |
gstreamer1.0-plugins-good | gstreamer1.0-plugins-good-monoscope | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for monoscope |
gstreamer1.0-plugins-good | gstreamer1.0-plugins-good-mpg123 | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for mpg123 |
gstreamer1.0-plugins-good | gstreamer1.0-plugins-good-mulaw | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for mulaw |
gstreamer1.0-plugins-good | gstreamer1.0-plugins-good-multifile | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for multifile |
gstreamer1.0-plugins-good | gstreamer1.0-plugins-good-multipart | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for multipart |
gstreamer1.0-plugins-good | gstreamer1.0-plugins-good-navigationtest | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for navigationtest |
gstreamer1.0-plugins-good | gstreamer1.0-plugins-good-ossaudio | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for ossaudio |
gstreamer1.0-plugins-good | gstreamer1.0-plugins-good-png | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for png |
gstreamer1.0-plugins-good | gstreamer1.0-plugins-good-pulseaudio | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for pulseaudio |
gstreamer1.0-plugins-good | gstreamer1.0-plugins-good-replaygain | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for replaygain |
gstreamer1.0-plugins-good | gstreamer1.0-plugins-good-rtp | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for rtp |
gstreamer1.0-plugins-good | gstreamer1.0-plugins-good-rtpmanager | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for rtpmanager |
gstreamer1.0-plugins-good | gstreamer1.0-plugins-good-rtsp | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for rtsp |
gstreamer1.0-plugins-good | gstreamer1.0-plugins-good-shapewipe | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for shapewipe |
gstreamer1.0-plugins-good | gstreamer1.0-plugins-good-smpte | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for smpte |
gstreamer1.0-plugins-good | gstreamer1.0-plugins-good-soup | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for soup |
gstreamer1.0-plugins-good | gstreamer1.0-plugins-good-spectrum | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for spectrum |
gstreamer1.0-plugins-good | gstreamer1.0-plugins-good-speex | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for speex |
gstreamer1.0-plugins-good | gstreamer1.0-plugins-good-taglib | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for taglib |
gstreamer1.0-plugins-good | gstreamer1.0-plugins-good-udp | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for udp |
gstreamer1.0-plugins-good | gstreamer1.0-plugins-good-video4linux2 | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for video4linux2 |
gstreamer1.0-plugins-good | gstreamer1.0-plugins-good-videobox | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for videobox |
gstreamer1.0-plugins-good | gstreamer1.0-plugins-good-videocrop | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for videocrop |
gstreamer1.0-plugins-good | gstreamer1.0-plugins-good-videofilter | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for videofilter |
gstreamer1.0-plugins-good | gstreamer1.0-plugins-good-videomixer | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for videomixer |
gstreamer1.0-plugins-good | gstreamer1.0-plugins-good-wavenc | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for wavenc |
gstreamer1.0-plugins-good | gstreamer1.0-plugins-good-wavparse | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for wavparse |
gstreamer1.0-plugins-good | gstreamer1.0-plugins-good-xingmux | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for xingmux |
gstreamer1.0-plugins-good | gstreamer1.0-plugins-good-y4menc | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for y4menc |
gstreamer1.0-plugins-ugly | gstreamer1.0-plugins-ugly-a52dec | 1.22.6 | GPL-2.0-or-later | GStreamer 1.0 plugin for a52dec |
gstreamer1.0-plugins-ugly | gstreamer1.0-plugins-ugly-asf | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for asf |
gstreamer1.0-plugins-ugly | gstreamer1.0-plugins-ugly-dvdlpcmdec | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for dvdlpcmdec |
gstreamer1.0-plugins-ugly | gstreamer1.0-plugins-ugly-dvdsub | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for dvdsub |
gstreamer1.0-plugins-ugly | gstreamer1.0-plugins-ugly-mpeg2dec | 1.22.6 | GPL-2.0-or-later | GStreamer 1.0 plugin for mpeg2dec |
gstreamer1.0-plugins-ugly | gstreamer1.0-plugins-ugly-realmedia | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for realmedia |
gstreamer1.0-rtsp-server | gstreamer1.0-rtsp-server-rtspclientsink | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 plugin for rtspclientsink |
gtk+3 | gtk+3-demo | 3.24.36 | LGPL-2.0-only & LGPL-2.0-or-later & LGPL-2.1-or-later | Multi-platform toolkit for creating GUIs |
gtk+3 | gtk+3-locale-en | 3.24.36 | LGPL-2.0-only & LGPL-2.0-or-later & LGPL-2.1-or-later | Multi-platform toolkit for creating GUIs - en translations |
hdparm | hdparm | 9.65 | BSD-2-Clause & hdparm | Utility for viewing/manipulating IDE disk drive/driver parameters |
hicolor-icon-theme | hicolor-icon-theme | 0.17 | GPL-2.0-only | Default icon theme that all icon themes automatically inherit from |
hostapd | hostapd | 2.10 | BSD-3-Clause | User space daemon for extended IEEE 802.11 management |
i2c-tools | i2c-tools | 4.3 | GPL-2.0-or-later | Set of i2c tools for linux |
infos-openstlinux | infos-openstlinux | 1.1 | GPL-2.0-or-later | Information for support |
iproute2 | iproute2 | 6.2.0 | GPL-2.0-or-later | TCP / IP networking and traffic control utilities |
iproute2 | iproute2-ip | 6.2.0 | GPL-2.0-or-later | TCP / IP networking and traffic control utilities |
iptables | iptables | 1.8.9 | GPL-2.0-or-later | Tools for managing kernel packet filtering capabilities |
iptables | iptables-module-ip6t-ah | 1.8.9 | GPL-2.0-or-later | iptables module ip6t-ah |
iptables | iptables-module-ip6t-dnpt | 1.8.9 | GPL-2.0-or-later | iptables module ip6t-dnpt |
iptables | iptables-module-ip6t-dst | 1.8.9 | GPL-2.0-or-later | iptables module ip6t-dst |
iptables | iptables-module-ip6t-eui64 | 1.8.9 | GPL-2.0-or-later | iptables module ip6t-eui64 |
iptables | iptables-module-ip6t-frag | 1.8.9 | GPL-2.0-or-later | iptables module ip6t-frag |
iptables | iptables-module-ip6t-hbh | 1.8.9 | GPL-2.0-or-later | iptables module ip6t-hbh |
iptables | iptables-module-ip6t-hl | 1.8.9 | GPL-2.0-or-later | iptables module ip6t-hl |
iptables | iptables-module-ip6t-icmp6 | 1.8.9 | GPL-2.0-or-later | iptables module ip6t-icmp6 |
iptables | iptables-module-ip6t-ipv6header | 1.8.9 | GPL-2.0-or-later | iptables module ip6t-ipv6header |
iptables | iptables-module-ip6t-mh | 1.8.9 | GPL-2.0-or-later | iptables module ip6t-mh |
iptables | iptables-module-ip6t-netmap | 1.8.9 | GPL-2.0-or-later | iptables module ip6t-netmap |
iptables | iptables-module-ip6t-reject | 1.8.9 | GPL-2.0-or-later | iptables module ip6t-reject |
iptables | iptables-module-ip6t-rt | 1.8.9 | GPL-2.0-or-later | iptables module ip6t-rt |
iptables | iptables-module-ip6t-snpt | 1.8.9 | GPL-2.0-or-later | iptables module ip6t-snpt |
iptables | iptables-module-ip6t-srh | 1.8.9 | GPL-2.0-or-later | iptables module ip6t-srh |
iptables | iptables-module-ipt-ah | 1.8.9 | GPL-2.0-or-later | iptables module ipt-ah |
iptables | iptables-module-ipt-clusterip | 1.8.9 | GPL-2.0-or-later | iptables module ipt-clusterip |
iptables | iptables-module-ipt-ecn | 1.8.9 | GPL-2.0-or-later | iptables module ipt-ecn |
iptables | iptables-module-ipt-icmp | 1.8.9 | GPL-2.0-or-later | iptables module ipt-icmp |
iptables | iptables-module-ipt-netmap | 1.8.9 | GPL-2.0-or-later | iptables module ipt-netmap |
iptables | iptables-module-ipt-realm | 1.8.9 | GPL-2.0-or-later | iptables module ipt-realm |
iptables | iptables-module-ipt-reject | 1.8.9 | GPL-2.0-or-later | iptables module ipt-reject |
iptables | iptables-module-ipt-ttl | 1.8.9 | GPL-2.0-or-later | iptables module ipt-ttl |
iptables | iptables-module-ipt-ulog | 1.8.9 | GPL-2.0-or-later | iptables module ipt-ulog |
iptables | iptables-module-xt-addrtype | 1.8.9 | GPL-2.0-or-later | iptables module xt-addrtype |
iptables | iptables-module-xt-audit | 1.8.9 | GPL-2.0-or-later | iptables module xt-audit |
iptables | iptables-module-xt-bpf | 1.8.9 | GPL-2.0-or-later | iptables module xt-bpf |
iptables | iptables-module-xt-cgroup | 1.8.9 | GPL-2.0-or-later | iptables module xt-cgroup |
iptables | iptables-module-xt-checksum | 1.8.9 | GPL-2.0-or-later | iptables module xt-checksum |
iptables | iptables-module-xt-classify | 1.8.9 | GPL-2.0-or-later | iptables module xt-classify |
iptables | iptables-module-xt-cluster | 1.8.9 | GPL-2.0-or-later | iptables module xt-cluster |
iptables | iptables-module-xt-comment | 1.8.9 | GPL-2.0-or-later | iptables module xt-comment |
iptables | iptables-module-xt-connbytes | 1.8.9 | GPL-2.0-or-later | iptables module xt-connbytes |
iptables | iptables-module-xt-connlimit | 1.8.9 | GPL-2.0-or-later | iptables module xt-connlimit |
iptables | iptables-module-xt-connmark | 1.8.9 | GPL-2.0-or-later | iptables module xt-connmark |
iptables | iptables-module-xt-connsecmark | 1.8.9 | GPL-2.0-or-later | iptables module xt-connsecmark |
iptables | iptables-module-xt-conntrack | 1.8.9 | GPL-2.0-or-later | iptables module xt-conntrack |
iptables | iptables-module-xt-cpu | 1.8.9 | GPL-2.0-or-later | iptables module xt-cpu |
iptables | iptables-module-xt-ct | 1.8.9 | GPL-2.0-or-later | iptables module xt-ct |
iptables | iptables-module-xt-dccp | 1.8.9 | GPL-2.0-or-later | iptables module xt-dccp |
iptables | iptables-module-xt-devgroup | 1.8.9 | GPL-2.0-or-later | iptables module xt-devgroup |
iptables | iptables-module-xt-dscp | 1.8.9 | GPL-2.0-or-later | iptables module xt-dscp |
iptables | iptables-module-xt-ecn | 1.8.9 | GPL-2.0-or-later | iptables module xt-ecn |
iptables | iptables-module-xt-esp | 1.8.9 | GPL-2.0-or-later | iptables module xt-esp |
iptables | iptables-module-xt-hashlimit | 1.8.9 | GPL-2.0-or-later | iptables module xt-hashlimit |
iptables | iptables-module-xt-helper | 1.8.9 | GPL-2.0-or-later | iptables module xt-helper |
iptables | iptables-module-xt-hmark | 1.8.9 | GPL-2.0-or-later | iptables module xt-hmark |
iptables | iptables-module-xt-idletimer | 1.8.9 | GPL-2.0-or-later | iptables module xt-idletimer |
iptables | iptables-module-xt-ipcomp | 1.8.9 | GPL-2.0-or-later | iptables module xt-ipcomp |
iptables | iptables-module-xt-iprange | 1.8.9 | GPL-2.0-or-later | iptables module xt-iprange |
iptables | iptables-module-xt-ipvs | 1.8.9 | GPL-2.0-or-later | iptables module xt-ipvs |
iptables | iptables-module-xt-led | 1.8.9 | GPL-2.0-or-later | iptables module xt-led |
iptables | iptables-module-xt-length | 1.8.9 | GPL-2.0-or-later | iptables module xt-length |
iptables | iptables-module-xt-limit | 1.8.9 | GPL-2.0-or-later | iptables module xt-limit |
iptables | iptables-module-xt-log | 1.8.9 | GPL-2.0-or-later | iptables module xt-log |
iptables | iptables-module-xt-mac | 1.8.9 | GPL-2.0-or-later | iptables module xt-mac |
iptables | iptables-module-xt-mark | 1.8.9 | GPL-2.0-or-later | iptables module xt-mark |
iptables | iptables-module-xt-multiport | 1.8.9 | GPL-2.0-or-later | iptables module xt-multiport |
iptables | iptables-module-xt-nat | 1.8.9 | GPL-2.0-or-later | iptables module xt-nat |
iptables | iptables-module-xt-nfacct | 1.8.9 | GPL-2.0-or-later | iptables module xt-nfacct |
iptables | iptables-module-xt-nflog | 1.8.9 | GPL-2.0-or-later | iptables module xt-nflog |
iptables | iptables-module-xt-nfqueue | 1.8.9 | GPL-2.0-or-later | iptables module xt-nfqueue |
iptables | iptables-module-xt-osf | 1.8.9 | GPL-2.0-or-later | iptables module xt-osf |
iptables | iptables-module-xt-owner | 1.8.9 | GPL-2.0-or-later | iptables module xt-owner |
iptables | iptables-module-xt-physdev | 1.8.9 | GPL-2.0-or-later | iptables module xt-physdev |
iptables | iptables-module-xt-pkttype | 1.8.9 | GPL-2.0-or-later | iptables module xt-pkttype |
iptables | iptables-module-xt-policy | 1.8.9 | GPL-2.0-or-later | iptables module xt-policy |
iptables | iptables-module-xt-quota | 1.8.9 | GPL-2.0-or-later | iptables module xt-quota |
iptables | iptables-module-xt-rateest | 1.8.9 | GPL-2.0-or-later | iptables module xt-rateest |
iptables | iptables-module-xt-recent | 1.8.9 | GPL-2.0-or-later | iptables module xt-recent |
iptables | iptables-module-xt-rpfilter | 1.8.9 | GPL-2.0-or-later | iptables module xt-rpfilter |
iptables | iptables-module-xt-sctp | 1.8.9 | GPL-2.0-or-later | iptables module xt-sctp |
iptables | iptables-module-xt-secmark | 1.8.9 | GPL-2.0-or-later | iptables module xt-secmark |
iptables | iptables-module-xt-set | 1.8.9 | GPL-2.0-or-later | iptables module xt-set |
iptables | iptables-module-xt-socket | 1.8.9 | GPL-2.0-or-later | iptables module xt-socket |
iptables | iptables-module-xt-standard | 1.8.9 | GPL-2.0-or-later | iptables module xt-standard |
iptables | iptables-module-xt-statistic | 1.8.9 | GPL-2.0-or-later | iptables module xt-statistic |
iptables | iptables-module-xt-string | 1.8.9 | GPL-2.0-or-later | iptables module xt-string |
iptables | iptables-module-xt-synproxy | 1.8.9 | GPL-2.0-or-later | iptables module xt-synproxy |
iptables | iptables-module-xt-tcp | 1.8.9 | GPL-2.0-or-later | iptables module xt-tcp |
iptables | iptables-module-xt-tcpmss | 1.8.9 | GPL-2.0-or-later | iptables module xt-tcpmss |
iptables | iptables-module-xt-tcpoptstrip | 1.8.9 | GPL-2.0-or-later | iptables module xt-tcpoptstrip |
iptables | iptables-module-xt-tee | 1.8.9 | GPL-2.0-or-later | iptables module xt-tee |
iptables | iptables-module-xt-time | 1.8.9 | GPL-2.0-or-later | iptables module xt-time |
iptables | iptables-module-xt-tos | 1.8.9 | GPL-2.0-or-later | iptables module xt-tos |
iptables | iptables-module-xt-tproxy | 1.8.9 | GPL-2.0-or-later | iptables module xt-tproxy |
iptables | iptables-module-xt-trace | 1.8.9 | GPL-2.0-or-later | iptables module xt-trace |
iptables | iptables-module-xt-u32 | 1.8.9 | GPL-2.0-or-later | iptables module xt-u32 |
iptables | iptables-module-xt-udp | 1.8.9 | GPL-2.0-or-later | iptables module xt-udp |
iputils | iputils-arping | 20221126 | BSD-3-Clause & GPL-2.0-or-later | Network monitoring tools |
iputils | iputils-clockdiff | 20221126 | BSD-3-Clause & GPL-2.0-or-later | Network monitoring tools |
iputils | iputils-ping | 20221126 | BSD-3-Clause & GPL-2.0-or-later | Network monitoring tools |
iputils | iputils-tracepath | 20221126 | BSD-3-Clause & GPL-2.0-or-later | Network monitoring tools |
iw | iw | 5.19 | BSD-2-Clause | nl80211 based CLI configuration utility for wireless devices |
kbd | kbd | 2.5.1 | GPL-2.0-or-later | Keytable files and keyboard utilities |
kbd | kbd-consolefonts | 2.5.1 | GPL-2.0-or-later | Keytable files and keyboard utilities |
kbd | kbd-keymaps | 2.5.1 | GPL-2.0-or-later | Keytable files and keyboard utilities |
linux-stm32mp | kernel-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | Linux STM32MP Kernel |
linux-stm32mp | kernel-module-6lowpan-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | 6lowpan kernel module |
linux-stm32mp | kernel-module-8021q-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | 8021q kernel module |
linux-stm32mp | kernel-module-act-bpf-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | act-bpf kernel module |
linux-stm32mp | kernel-module-act-csum-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | act-csum kernel module |
linux-stm32mp | kernel-module-act-gact-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | act-gact kernel module |
linux-stm32mp | kernel-module-act-gate-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | act-gate kernel module |
linux-stm32mp | kernel-module-act-ife-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | act-ife kernel module |
linux-stm32mp | kernel-module-act-meta-mark-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | act-meta-mark kernel module |
linux-stm32mp | kernel-module-act-meta-skbprio-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | act-meta-skbprio kernel module |
linux-stm32mp | kernel-module-act-meta-skbtcindex-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | act-meta-skbtcindex kernel module |
linux-stm32mp | kernel-module-act-mirred-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | act-mirred kernel module |
linux-stm32mp | kernel-module-act-nat-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | act-nat kernel module |
linux-stm32mp | kernel-module-act-pedit-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | act-pedit kernel module |
linux-stm32mp | kernel-module-act-police-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | act-police kernel module |
linux-stm32mp | kernel-module-act-sample-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | act-sample kernel module |
linux-stm32mp | kernel-module-act-skbedit-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | act-skbedit kernel module |
linux-stm32mp | kernel-module-act-skbmod-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | act-skbmod kernel module |
linux-stm32mp | kernel-module-act-tunnel-key-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | act-tunnel-key kernel module |
linux-stm32mp | kernel-module-act-vlan-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | act-vlan kernel module |
linux-stm32mp | kernel-module-adc-keys-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | adc-keys kernel module |
linux-stm32mp | kernel-module-aes-neon-blk-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | aes-neon-blk kernel module |
linux-stm32mp | kernel-module-aes-neon-bs-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | aes-neon-bs kernel module |
linux-stm32mp | kernel-module-ah4-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | ah4 kernel module |
linux-stm32mp | kernel-module-algif-rng-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | algif-rng kernel module |
linux-stm32mp | kernel-module-algif-skcipher-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | algif-skcipher kernel module |
linux-stm32mp | kernel-module-altera-cvp-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | altera-cvp kernel module |
linux-stm32mp | kernel-module-altera-freeze-bridge-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | altera-freeze-bridge kernel module |
linux-stm32mp | kernel-module-amlogic-gxl-crypto-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | amlogic-gxl-crypto kernel module |
linux-stm32mp | kernel-module-arm-cci-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | arm-cci kernel module |
linux-stm32mp | kernel-module-arm-ccn-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | arm-ccn kernel module |
linux-stm32mp | kernel-module-arm-cmn-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | arm-cmn kernel module |
linux-stm32mp | kernel-module-arm-dmc620-pmu-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | arm-dmc620-pmu kernel module |
linux-stm32mp | kernel-module-arm-dsu-pmu-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | arm-dsu-pmu kernel module |
linux-stm32mp | kernel-module-arm-smccc-trng-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | arm-smccc-trng kernel module |
linux-stm32mp | kernel-module-arm-smmuv3-pmu-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | arm-smmuv3-pmu kernel module |
linux-stm32mp | kernel-module-arm-spe-pmu-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | arm-spe-pmu kernel module |
linux-stm32mp | kernel-module-arp-tables-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | arp-tables kernel module |
linux-stm32mp | kernel-module-arpt-mangle-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | arpt-mangle kernel module |
linux-stm32mp | kernel-module-arptable-filter-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | arptable-filter kernel module |
linux-stm32mp | kernel-module-asix-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | asix kernel module |
linux-stm32mp | kernel-module-at24-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | at24 kernel module |
linux-stm32mp | kernel-module-at25-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | at25 kernel module |
linux-stm32mp | kernel-module-ath-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | ath kernel module |
linux-stm32mp | kernel-module-ath10k-core-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | ath10k-core kernel module |
linux-stm32mp | kernel-module-ath10k-pci-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | ath10k-pci kernel module |
linux-stm32mp | kernel-module-ath11k-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | ath11k kernel module |
linux-stm32mp | kernel-module-ath11k-ahb-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | ath11k-ahb kernel module |
linux-stm32mp | kernel-module-ath11k-pci-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | ath11k-pci kernel module |
linux-stm32mp | kernel-module-atl1c-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | atl1c kernel module |
linux-stm32mp | kernel-module-atmel-mxt-ts-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | atmel-mxt-ts kernel module |
linux-stm32mp | kernel-module-authenc-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | authenc kernel module |
linux-stm32mp | kernel-module-authencesn-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | authencesn kernel module |
linux-stm32mp | kernel-module-ax88179-178a-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | ax88179-178a kernel module |
linux-stm32mp | kernel-module-ax88796b-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | ax88796b kernel module |
linux-stm32mp | kernel-module-b53-common-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | b53-common kernel module |
linux-stm32mp | kernel-module-b53-srab-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | b53-srab kernel module |
linux-stm32mp | kernel-module-batman-adv-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | batman-adv kernel module |
linux-stm32mp | kernel-module-bcm-phy-lib-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | bcm-phy-lib kernel module |
linux-stm32mp | kernel-module-bcm-phy-ptp-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | bcm-phy-ptp kernel module |
linux-stm32mp | kernel-module-bcm-sba-raid-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | bcm-sba-raid kernel module |
linux-stm32mp | kernel-module-bcm-sf2-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | bcm-sf2 kernel module |
linux-stm32mp | kernel-module-bcm54140-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | bcm54140 kernel module |
linux-stm32mp | kernel-module-bcm63138-nand-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | bcm63138-nand kernel module |
linux-stm32mp | kernel-module-bcm7xxx-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | bcm7xxx kernel module |
linux-stm32mp | kernel-module-bcmsysport-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | bcmsysport kernel module |
linux-stm32mp | kernel-module-blake2b-generic-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | blake2b-generic kernel module |
linux-stm32mp | kernel-module-blocklayoutdriver-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | blocklayoutdriver kernel module |
linux-stm32mp | kernel-module-bluetooth-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | bluetooth kernel module |
linux-stm32mp | kernel-module-bluetooth-6lowpan-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | bluetooth-6lowpan kernel module |
linux-stm32mp | kernel-module-bnx2x-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | bnx2x kernel module |
linux-stm32mp | kernel-module-bq25890-charger-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | bq25890-charger kernel module |
linux-stm32mp | kernel-module-bq25980-charger-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | bq25980-charger kernel module |
linux-stm32mp | kernel-module-br-netfilter-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | br-netfilter kernel module |
linux-stm32mp | kernel-module-brcmfmac-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | brcmfmac kernel module |
linux-stm32mp | kernel-module-brcmnand-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | brcmnand kernel module |
linux-stm32mp | kernel-module-brcmstb-nand-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | brcmstb-nand kernel module |
linux-stm32mp | kernel-module-brcmutil-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | brcmutil kernel module |
linux-stm32mp | kernel-module-bridge-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | bridge kernel module |
linux-stm32mp | kernel-module-broadcom-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | broadcom kernel module |
linux-stm32mp | kernel-module-btbcm-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | btbcm kernel module |
linux-stm32mp | kernel-module-btintel-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | btintel kernel module |
linux-stm32mp | kernel-module-btmrvl-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | btmrvl kernel module |
linux-stm32mp | kernel-module-btmrvl-sdio-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | btmrvl-sdio kernel module |
linux-stm32mp | kernel-module-btqca-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | btqca kernel module |
linux-stm32mp | kernel-module-btrfs-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | btrfs kernel module |
linux-stm32mp | kernel-module-btrtl-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | btrtl kernel module |
linux-stm32mp | kernel-module-btusb-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | btusb kernel module |
linux-stm32mp | kernel-module-can-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | can kernel module |
linux-stm32mp | kernel-module-can-bcm-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | can-bcm kernel module |
linux-stm32mp | kernel-module-can-dev-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | can-dev kernel module |
linux-stm32mp | kernel-module-can-gw-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | can-gw kernel module |
linux-stm32mp | kernel-module-can-raw-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | can-raw kernel module |
linux-stm32mp | kernel-module-cbc-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | cbc kernel module |
linux-stm32mp | kernel-module-ccm-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | ccm kernel module |
linux-stm32mp | kernel-module-ccree-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | ccree kernel module |
linux-stm32mp | kernel-module-cdc-acm-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | cdc-acm kernel module |
linux-stm32mp | kernel-module-cdc-ether-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | cdc-ether kernel module |
linux-stm32mp | kernel-module-cdc-ncm-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | cdc-ncm kernel module |
linux-stm32mp | kernel-module-cdc-subset-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | cdc-subset kernel module |
linux-stm32mp | kernel-module-cdns-mhdp8546-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | cdns-mhdp8546 kernel module |
linux-stm32mp | kernel-module-cdns-usb-common-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | cdns-usb-common kernel module |
linux-stm32mp | kernel-module-cdns3-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | cdns3 kernel module |
linux-stm32mp | kernel-module-cdns3-pci-wrap-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | cdns3-pci-wrap kernel module |
linux-stm32mp | kernel-module-cfg80211-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | cfg80211 kernel module |
linux-stm32mp | kernel-module-ch7006-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | ch7006 kernel module |
linux-stm32mp | kernel-module-chacha-neon-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | chacha-neon kernel module |
linux-stm32mp | kernel-module-clk-bd718x7-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | clk-bd718x7 kernel module |
linux-stm32mp | kernel-module-cls-basic-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | cls-basic kernel module |
linux-stm32mp | kernel-module-cls-bpf-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | cls-bpf kernel module |
linux-stm32mp | kernel-module-cls-cgroup-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | cls-cgroup kernel module |
linux-stm32mp | kernel-module-cls-flow-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | cls-flow kernel module |
linux-stm32mp | kernel-module-cls-flower-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | cls-flower kernel module |
linux-stm32mp | kernel-module-cls-fw-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | cls-fw kernel module |
linux-stm32mp | kernel-module-cls-matchall-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | cls-matchall kernel module |
linux-stm32mp | kernel-module-cls-route-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | cls-route kernel module |
linux-stm32mp | kernel-module-cls-u32-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | cls-u32 kernel module |
linux-stm32mp | kernel-module-cmac-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | cmac kernel module |
linux-stm32mp | kernel-module-cn10k-rng-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | cn10k-rng kernel module |
linux-stm32mp | kernel-module-coresight-catu-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | coresight-catu kernel module |
linux-stm32mp | kernel-module-coresight-etb10-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | coresight-etb10 kernel module |
linux-stm32mp | kernel-module-counter-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | counter kernel module |
linux-stm32mp | kernel-module-cp210x-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | cp210x kernel module |
linux-stm32mp | kernel-module-cppc-cpufreq-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | cppc-cpufreq kernel module |
linux-stm32mp | kernel-module-cpufreq-conservative-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | cpufreq-conservative kernel module |
linux-stm32mp | kernel-module-cpufreq-powersave-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | cpufreq-powersave kernel module |
linux-stm32mp | kernel-module-crct10dif-ce-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | crct10dif-ce kernel module |
linux-stm32mp | kernel-module-cros-ec-baro-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | cros-ec-baro kernel module |
linux-stm32mp | kernel-module-cros-ec-chardev-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | cros-ec-chardev kernel module |
linux-stm32mp | kernel-module-cros-ec-light-prox-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | cros-ec-light-prox kernel module |
linux-stm32mp | kernel-module-cros-ec-sensors-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | cros-ec-sensors kernel module |
linux-stm32mp | kernel-module-cros-ec-sensors-core-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | cros-ec-sensors-core kernel module |
linux-stm32mp | kernel-module-cros-ec-typec-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | cros-ec-typec kernel module |
linux-stm32mp | kernel-module-cros-typec-switch-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | cros-typec-switch kernel module |
linux-stm32mp | kernel-module-crypto-engine-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | crypto-engine kernel module |
linux-stm32mp | kernel-module-crypto-user-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | crypto-user kernel module |
cryptodev-module | kernel-module-cryptodev-6.1.82 | 1.12 | GPL-2.0-only | cryptodev kernel module |
linux-stm32mp | kernel-module-ctr-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | ctr kernel module |
linux-stm32mp | kernel-module-curve25519-generic-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | curve25519-generic kernel module |
linux-stm32mp | kernel-module-cuse-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | cuse kernel module |
linux-stm32mp | kernel-module-des-generic-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | des-generic kernel module |
linux-stm32mp | kernel-module-dh-generic-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | dh-generic kernel module |
linux-stm32mp | kernel-module-dm-crypt-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | dm-crypt kernel module |
linux-stm32mp | kernel-module-dm-log-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | dm-log kernel module |
linux-stm32mp | kernel-module-dm-mirror-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | dm-mirror kernel module |
linux-stm32mp | kernel-module-dm-mod-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | dm-mod kernel module |
linux-stm32mp | kernel-module-dm-region-hash-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | dm-region-hash kernel module |
linux-stm32mp | kernel-module-dm-zero-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | dm-zero kernel module |
linux-stm32mp | kernel-module-dm9601-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | dm9601 kernel module |
linux-stm32mp | kernel-module-drm-display-helper-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | drm-display-helper kernel module |
linux-stm32mp | kernel-module-drm-dp-aux-bus-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | drm-dp-aux-bus kernel module |
linux-stm32mp | kernel-module-drm-ttm-helper-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | drm-ttm-helper kernel module |
linux-stm32mp | kernel-module-drm-vram-helper-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | drm-vram-helper kernel module |
linux-stm32mp | kernel-module-dsa-core-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | dsa-core kernel module |
linux-stm32mp | kernel-module-dw-drm-dsi-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | dw-drm-dsi kernel module |
linux-stm32mp | kernel-module-dw-hdmi-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | dw-hdmi kernel module |
linux-stm32mp | kernel-module-dw-hdmi-ahb-audio-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | dw-hdmi-ahb-audio kernel module |
linux-stm32mp | kernel-module-dw-hdmi-cec-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | dw-hdmi-cec kernel module |
linux-stm32mp | kernel-module-dw-hdmi-i2s-audio-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | dw-hdmi-i2s-audio kernel module |
linux-stm32mp | kernel-module-ebt-802-3-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | ebt-802-3 kernel module |
linux-stm32mp | kernel-module-ebt-among-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | ebt-among kernel module |
linux-stm32mp | kernel-module-ebt-arp-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | ebt-arp kernel module |
linux-stm32mp | kernel-module-ebt-arpreply-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | ebt-arpreply kernel module |
linux-stm32mp | kernel-module-ebt-dnat-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | ebt-dnat kernel module |
linux-stm32mp | kernel-module-ebt-ip-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | ebt-ip kernel module |
linux-stm32mp | kernel-module-ebt-ip6-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | ebt-ip6 kernel module |
linux-stm32mp | kernel-module-ebt-limit-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | ebt-limit kernel module |
linux-stm32mp | kernel-module-ebt-log-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | ebt-log kernel module |
linux-stm32mp | kernel-module-ebt-mark-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | ebt-mark kernel module |
linux-stm32mp | kernel-module-ebt-mark-m-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | ebt-mark-m kernel module |
linux-stm32mp | kernel-module-ebt-nflog-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | ebt-nflog kernel module |
linux-stm32mp | kernel-module-ebt-pkttype-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | ebt-pkttype kernel module |
linux-stm32mp | kernel-module-ebt-redirect-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | ebt-redirect kernel module |
linux-stm32mp | kernel-module-ebt-snat-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | ebt-snat kernel module |
linux-stm32mp | kernel-module-ebt-stp-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | ebt-stp kernel module |
linux-stm32mp | kernel-module-ebt-vlan-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | ebt-vlan kernel module |
linux-stm32mp | kernel-module-ebtable-broute-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | ebtable-broute kernel module |
linux-stm32mp | kernel-module-ebtable-filter-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | ebtable-filter kernel module |
linux-stm32mp | kernel-module-ebtable-nat-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | ebtable-nat kernel module |
linux-stm32mp | kernel-module-ebtables-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | ebtables kernel module |
linux-stm32mp | kernel-module-ecb-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | ecb kernel module |
linux-stm32mp | kernel-module-ecc-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | ecc kernel module |
linux-stm32mp | kernel-module-ecdh-generic-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | ecdh-generic kernel module |
linux-stm32mp | kernel-module-edt-ft5x06-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | edt-ft5x06 kernel module |
linux-stm32mp | kernel-module-em-canid-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | em-canid kernel module |
linux-stm32mp | kernel-module-em-cmp-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | em-cmp kernel module |
linux-stm32mp | kernel-module-em-meta-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | em-meta kernel module |
linux-stm32mp | kernel-module-em-nbyte-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | em-nbyte kernel module |
linux-stm32mp | kernel-module-em-text-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | em-text kernel module |
linux-stm32mp | kernel-module-em-u32-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | em-u32 kernel module |
linux-stm32mp | kernel-module-esp4-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | esp4 kernel module |
linux-stm32mp | kernel-module-esp4-offload-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | esp4-offload kernel module |
linux-stm32mp | kernel-module-essiv-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | essiv kernel module |
linux-stm32mp | kernel-module-etnaviv-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | etnaviv kernel module |
linux-stm32mp | kernel-module-extcon-ptn5150-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | extcon-ptn5150 kernel module |
linux-stm32mp | kernel-module-flexcan-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | flexcan kernel module |
linux-stm32mp | kernel-module-fou-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | fou kernel module |
linux-stm32mp | kernel-module-fou6-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | fou6 kernel module |
linux-stm32mp | kernel-module-fpga-bridge-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | fpga-bridge kernel module |
linux-stm32mp | kernel-module-fpga-region-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | fpga-region kernel module |
linux-stm32mp | kernel-module-ftdi-sio-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | ftdi-sio kernel module |
linux-stm32mp | kernel-module-fusb302-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | fusb302 kernel module |
gcnano-driver-stm32mp | kernel-module-galcore-6.1.82 | 6.4.15-stm32mp2-r1 | GPL-1.0-only & MIT | galcore kernel module |
linux-stm32mp | kernel-module-garp-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | garp kernel module |
linux-stm32mp | kernel-module-gcm-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | gcm kernel module |
linux-stm32mp | kernel-module-genet-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | genet kernel module |
linux-stm32mp | kernel-module-ghash-generic-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | ghash-generic kernel module |
linux-stm32mp | kernel-module-gnss-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | gnss kernel module |
linux-stm32mp | kernel-module-gnss-mtk-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | gnss-mtk kernel module |
linux-stm32mp | kernel-module-gnss-serial-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | gnss-serial kernel module |
linux-stm32mp | kernel-module-governor-userspace-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | governor-userspace kernel module |
linux-stm32mp | kernel-module-gpio-altera-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | gpio-altera kernel module |
linux-stm32mp | kernel-module-gpio-bd9571mwv-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | gpio-bd9571mwv kernel module |
linux-stm32mp | kernel-module-gpio-fan-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | gpio-fan kernel module |
linux-stm32mp | kernel-module-gpio-wcd934x-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | gpio-wcd934x kernel module |
linux-stm32mp | kernel-module-gpu-sched-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | gpu-sched kernel module |
linux-stm32mp | kernel-module-gre-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | gre kernel module |
linux-stm32mp | kernel-module-hantro-vpu-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | hantro-vpu kernel module |
linux-stm32mp | kernel-module-hci-uart-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | hci-uart kernel module |
linux-stm32mp | kernel-module-hd3ss3220-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | hd3ss3220 kernel module |
linux-stm32mp | kernel-module-hdlcd-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | hdlcd kernel module |
linux-stm32mp | kernel-module-hibmc-drm-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | hibmc-drm kernel module |
linux-stm32mp | kernel-module-hid-multitouch-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | hid-multitouch kernel module |
linux-stm32mp | kernel-module-hidp-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | hidp kernel module |
linux-stm32mp | kernel-module-hisi-hpre-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | hisi-hpre kernel module |
linux-stm32mp | kernel-module-hisi-qm-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | hisi-qm kernel module |
linux-stm32mp | kernel-module-hisi-sec2-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | hisi-sec2 kernel module |
linux-stm32mp | kernel-module-hisi-trng-v2-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | hisi-trng-v2 kernel module |
linux-stm32mp | kernel-module-hisi-zip-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | hisi-zip kernel module |
linux-stm32mp | kernel-module-hsr-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | hsr kernel module |
linux-stm32mp | kernel-module-i2c-cadence-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | i2c-cadence kernel module |
linux-stm32mp | kernel-module-i2c-gpio-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | i2c-gpio kernel module |
linux-stm32mp | kernel-module-i2c-hid-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | i2c-hid kernel module |
linux-stm32mp | kernel-module-i2c-hid-acpi-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | i2c-hid-acpi kernel module |
linux-stm32mp | kernel-module-i2c-hid-of-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | i2c-hid-of kernel module |
linux-stm32mp | kernel-module-i2c-rpmsg-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | i2c-rpmsg kernel module |
linux-stm32mp | kernel-module-ieee802154-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | ieee802154 kernel module |
linux-stm32mp | kernel-module-ieee802154-socket-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | ieee802154-socket kernel module |
linux-stm32mp | kernel-module-ife-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | ife kernel module |
linux-stm32mp | kernel-module-igc-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | igc kernel module |
linux-stm32mp | kernel-module-imx219-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | imx219 kernel module |
linux-stm32mp | kernel-module-imx335-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | imx335 kernel module |
linux-stm32mp | kernel-module-ina2xx-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | ina2xx kernel module |
linux-stm32mp | kernel-module-ina3221-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | ina3221 kernel module |
linux-stm32mp | kernel-module-industrialio-buffer-cb-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | industrialio-buffer-cb kernel module |
linux-stm32mp | kernel-module-industrialio-hw-consumer-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | industrialio-hw-consumer kernel module |
linux-stm32mp | kernel-module-inet-diag-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | inet-diag kernel module |
linux-stm32mp | kernel-module-ip-gre-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | ip-gre kernel module |
linux-stm32mp | kernel-module-ip-set-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | ip-set kernel module |
linux-stm32mp | kernel-module-ip-tables-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | ip-tables kernel module |
linux-stm32mp | kernel-module-ip-tunnel-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | ip-tunnel kernel module |
linux-stm32mp | kernel-module-ip-vs-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | ip-vs kernel module |
linux-stm32mp | kernel-module-ip-vti-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | ip-vti kernel module |
linux-stm32mp | kernel-module-ip6-gre-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | ip6-gre kernel module |
linux-stm32mp | kernel-module-ip6-tables-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | ip6-tables kernel module |
linux-stm32mp | kernel-module-ip6-tunnel-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | ip6-tunnel kernel module |
linux-stm32mp | kernel-module-ip6-udp-tunnel-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | ip6-udp-tunnel kernel module |
linux-stm32mp | kernel-module-ip6-vti-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | ip6-vti kernel module |
linux-stm32mp | kernel-module-ip6t-ah-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | ip6t-ah kernel module |
linux-stm32mp | kernel-module-ip6t-eui64-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | ip6t-eui64 kernel module |
linux-stm32mp | kernel-module-ip6t-frag-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | ip6t-frag kernel module |
linux-stm32mp | kernel-module-ip6t-hbh-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | ip6t-hbh kernel module |
linux-stm32mp | kernel-module-ip6t-ipv6header-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | ip6t-ipv6header kernel module |
linux-stm32mp | kernel-module-ip6t-mh-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | ip6t-mh kernel module |
linux-stm32mp | kernel-module-ip6t-npt-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | ip6t-npt kernel module |
linux-stm32mp | kernel-module-ip6t-reject-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | ip6t-reject kernel module |
linux-stm32mp | kernel-module-ip6t-rpfilter-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | ip6t-rpfilter kernel module |
linux-stm32mp | kernel-module-ip6t-rt-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | ip6t-rt kernel module |
linux-stm32mp | kernel-module-ip6t-synproxy-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | ip6t-synproxy kernel module |
linux-stm32mp | kernel-module-ip6table-filter-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | ip6table-filter kernel module |
linux-stm32mp | kernel-module-ip6table-mangle-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | ip6table-mangle kernel module |
linux-stm32mp | kernel-module-ip6table-nat-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | ip6table-nat kernel module |
linux-stm32mp | kernel-module-ip6table-raw-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | ip6table-raw kernel module |
linux-stm32mp | kernel-module-ipcomp-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | ipcomp kernel module |
linux-stm32mp | kernel-module-ipip-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | ipip kernel module |
linux-stm32mp | kernel-module-ipmi-devintf-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | ipmi-devintf kernel module |
linux-stm32mp | kernel-module-ipmi-msghandler-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | ipmi-msghandler kernel module |
linux-stm32mp | kernel-module-ipmi-si-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | ipmi-si kernel module |
linux-stm32mp | kernel-module-iproc-nand-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | iproc-nand kernel module |
linux-stm32mp | kernel-module-ipt-ah-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | ipt-ah kernel module |
linux-stm32mp | kernel-module-ipt-clusterip-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | ipt-clusterip kernel module |
linux-stm32mp | kernel-module-ipt-ecn-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | ipt-ecn kernel module |
linux-stm32mp | kernel-module-ipt-reject-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | ipt-reject kernel module |
linux-stm32mp | kernel-module-ipt-rpfilter-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | ipt-rpfilter kernel module |
linux-stm32mp | kernel-module-ipt-synproxy-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | ipt-synproxy kernel module |
linux-stm32mp | kernel-module-iptable-filter-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | iptable-filter kernel module |
linux-stm32mp | kernel-module-iptable-mangle-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | iptable-mangle kernel module |
linux-stm32mp | kernel-module-iptable-nat-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | iptable-nat kernel module |
linux-stm32mp | kernel-module-iptable-raw-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | iptable-raw kernel module |
linux-stm32mp | kernel-module-ipv6-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | ipv6 kernel module |
linux-stm32mp | kernel-module-ir-kbd-i2c-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | ir-kbd-i2c kernel module |
linux-stm32mp | kernel-module-irq-rpmsg-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | irq-rpmsg kernel module |
linux-stm32mp | kernel-module-isl29018-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | isl29018 kernel module |
linux-stm32mp | kernel-module-jc42-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | jc42 kernel module |
linux-stm32mp | kernel-module-kirin-drm-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | kirin-drm kernel module |
linux-stm32mp | kernel-module-komeda-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | komeda kernel module |
linux-stm32mp | kernel-module-l2tp-core-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | l2tp-core kernel module |
linux-stm32mp | kernel-module-lan78xx-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | lan78xx kernel module |
linux-stm32mp | kernel-module-led-class-multicolor-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | led-class-multicolor kernel module |
linux-stm32mp | kernel-module-leds-lm3692x-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | leds-lm3692x kernel module |
linux-stm32mp | kernel-module-leds-pca9532-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | leds-pca9532 kernel module |
linux-stm32mp | kernel-module-leds-qcom-lpg-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | leds-qcom-lpg kernel module |
linux-stm32mp | kernel-module-libarc4-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | libarc4 kernel module |
linux-stm32mp | kernel-module-libchacha-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | libchacha kernel module |
linux-stm32mp | kernel-module-libcomposite-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | libcomposite kernel module |
linux-stm32mp | kernel-module-libcrc32c-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | libcrc32c kernel module |
linux-stm32mp | kernel-module-libcurve25519-generic-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | libcurve25519-generic kernel module |
linux-stm32mp | kernel-module-libdes-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | libdes kernel module |
linux-stm32mp | kernel-module-lima-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | lima kernel module |
linux-stm32mp | kernel-module-llc-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | llc kernel module |
linux-stm32mp | kernel-module-llc2-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | llc2 kernel module |
linux-stm32mp | kernel-module-lm75-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | lm75 kernel module |
linux-stm32mp | kernel-module-lm90-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | lm90 kernel module |
linux-stm32mp | kernel-module-lontium-lt8912b-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | lontium-lt8912b kernel module |
linux-stm32mp | kernel-module-lontium-lt9611-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | lontium-lt9611 kernel module |
linux-stm32mp | kernel-module-lontium-lt9611uxc-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | lontium-lt9611uxc kernel module |
linux-stm32mp | kernel-module-lp855x-bl-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | lp855x-bl kernel module |
linux-stm32mp | kernel-module-m-can-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | m-can kernel module |
linux-stm32mp | kernel-module-m-can-platform-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | m-can-platform kernel module |
linux-stm32mp | kernel-module-mac80211-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | mac80211 kernel module |
linux-stm32mp | kernel-module-macvlan-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | macvlan kernel module |
linux-stm32mp | kernel-module-macvtap-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | macvtap kernel module |
linux-stm32mp | kernel-module-mali-dp-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | mali-dp kernel module |
linux-stm32mp | kernel-module-marvell-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | marvell kernel module |
linux-stm32mp | kernel-module-marvell10g-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | marvell10g kernel module |
linux-stm32mp | kernel-module-max17042-battery-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | max17042-battery kernel module |
linux-stm32mp | kernel-module-max9611-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | max9611 kernel module |
linux-stm32mp | kernel-module-max96712-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | max96712 kernel module |
linux-stm32mp | kernel-module-mc-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | mc kernel module |
linux-stm32mp | kernel-module-mcp251xfd-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | mcp251xfd kernel module |
linux-stm32mp | kernel-module-mcs7830-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | mcs7830 kernel module |
linux-stm32mp | kernel-module-md-mod-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | md-mod kernel module |
linux-stm32mp | kernel-module-mdio-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | mdio kernel module |
linux-stm32mp | kernel-module-mdio-bcm-unimac-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | mdio-bcm-unimac kernel module |
linux-stm32mp | kernel-module-mhi-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | mhi kernel module |
linux-stm32mp | kernel-module-michael-mic-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | michael-mic kernel module |
linux-stm32mp | kernel-module-microchip-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | microchip kernel module |
linux-stm32mp | kernel-module-mlx4-core-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | mlx4-core kernel module |
linux-stm32mp | kernel-module-mlx4-en-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | mlx4-en kernel module |
linux-stm32mp | kernel-module-mlx5-core-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | mlx5-core kernel module |
linux-stm32mp | kernel-module-mpl3115-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | mpl3115 kernel module |
linux-stm32mp | kernel-module-mpls-gso-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | mpls-gso kernel module |
linux-stm32mp | kernel-module-mpt3sas-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | mpt3sas kernel module |
linux-stm32mp | kernel-module-mrp-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | mrp kernel module |
linux-stm32mp | kernel-module-mt6360-charger-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | mt6360-charger kernel module |
linux-stm32mp | kernel-module-mwifiex-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | mwifiex kernel module |
linux-stm32mp | kernel-module-mwifiex-pcie-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | mwifiex-pcie kernel module |
linux-stm32mp | kernel-module-mwifiex-sdio-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | mwifiex-sdio kernel module |
linux-stm32mp | kernel-module-nbd-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | nbd kernel module |
linux-stm32mp | kernel-module-nci-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | nci kernel module |
linux-stm32mp | kernel-module-net1080-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | net1080 kernel module |
linux-stm32mp | kernel-module-netlink-diag-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | netlink-diag kernel module |
linux-stm32mp | kernel-module-nf-conncount-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | nf-conncount kernel module |
linux-stm32mp | kernel-module-nf-conntrack-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | nf-conntrack kernel module |
linux-stm32mp | kernel-module-nf-conntrack-amanda-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | nf-conntrack-amanda kernel module |
linux-stm32mp | kernel-module-nf-conntrack-broadcast-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | nf-conntrack-broadcast kernel module |
linux-stm32mp | kernel-module-nf-conntrack-ftp-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | nf-conntrack-ftp kernel module |
linux-stm32mp | kernel-module-nf-conntrack-h323-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | nf-conntrack-h323 kernel module |
linux-stm32mp | kernel-module-nf-conntrack-irc-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | nf-conntrack-irc kernel module |
linux-stm32mp | kernel-module-nf-conntrack-netbios-ns-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | nf-conntrack-netbios-ns kernel module |
linux-stm32mp | kernel-module-nf-conntrack-netlink-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | nf-conntrack-netlink kernel module |
linux-stm32mp | kernel-module-nf-conntrack-pptp-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | nf-conntrack-pptp kernel module |
linux-stm32mp | kernel-module-nf-conntrack-sip-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | nf-conntrack-sip kernel module |
linux-stm32mp | kernel-module-nf-conntrack-snmp-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | nf-conntrack-snmp kernel module |
linux-stm32mp | kernel-module-nf-conntrack-tftp-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | nf-conntrack-tftp kernel module |
linux-stm32mp | kernel-module-nf-defrag-ipv4-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | nf-defrag-ipv4 kernel module |
linux-stm32mp | kernel-module-nf-defrag-ipv6-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | nf-defrag-ipv6 kernel module |
linux-stm32mp | kernel-module-nf-dup-ipv4-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | nf-dup-ipv4 kernel module |
linux-stm32mp | kernel-module-nf-dup-ipv6-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | nf-dup-ipv6 kernel module |
linux-stm32mp | kernel-module-nf-log-syslog-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | nf-log-syslog kernel module |
linux-stm32mp | kernel-module-nf-nat-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | nf-nat kernel module |
linux-stm32mp | kernel-module-nf-nat-amanda-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | nf-nat-amanda kernel module |
linux-stm32mp | kernel-module-nf-nat-ftp-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | nf-nat-ftp kernel module |
linux-stm32mp | kernel-module-nf-nat-h323-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | nf-nat-h323 kernel module |
linux-stm32mp | kernel-module-nf-nat-irc-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | nf-nat-irc kernel module |
linux-stm32mp | kernel-module-nf-nat-pptp-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | nf-nat-pptp kernel module |
linux-stm32mp | kernel-module-nf-nat-sip-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | nf-nat-sip kernel module |
linux-stm32mp | kernel-module-nf-nat-snmp-basic-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | nf-nat-snmp-basic kernel module |
linux-stm32mp | kernel-module-nf-nat-tftp-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | nf-nat-tftp kernel module |
linux-stm32mp | kernel-module-nf-reject-ipv4-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | nf-reject-ipv4 kernel module |
linux-stm32mp | kernel-module-nf-reject-ipv6-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | nf-reject-ipv6 kernel module |
linux-stm32mp | kernel-module-nf-socket-ipv4-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | nf-socket-ipv4 kernel module |
linux-stm32mp | kernel-module-nf-socket-ipv6-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | nf-socket-ipv6 kernel module |
linux-stm32mp | kernel-module-nf-synproxy-core-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | nf-synproxy-core kernel module |
linux-stm32mp | kernel-module-nf-tables-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | nf-tables kernel module |
linux-stm32mp | kernel-module-nfc-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | nfc kernel module |
linux-stm32mp | kernel-module-nfnetlink-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | nfnetlink kernel module |
linux-stm32mp | kernel-module-nfnetlink-acct-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | nfnetlink-acct kernel module |
linux-stm32mp | kernel-module-nfnetlink-cthelper-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | nfnetlink-cthelper kernel module |
linux-stm32mp | kernel-module-nfnetlink-cttimeout-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | nfnetlink-cttimeout kernel module |
linux-stm32mp | kernel-module-nfnetlink-log-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | nfnetlink-log kernel module |
linux-stm32mp | kernel-module-nfnetlink-osf-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | nfnetlink-osf kernel module |
linux-stm32mp | kernel-module-nfnetlink-queue-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | nfnetlink-queue kernel module |
linux-stm32mp | kernel-module-nft-ct-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | nft-ct kernel module |
linux-stm32mp | kernel-module-nft-hash-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | nft-hash kernel module |
linux-stm32mp | kernel-module-nft-limit-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | nft-limit kernel module |
linux-stm32mp | kernel-module-nft-log-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | nft-log kernel module |
linux-stm32mp | kernel-module-nft-masq-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | nft-masq kernel module |
linux-stm32mp | kernel-module-nft-meta-bridge-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | nft-meta-bridge kernel module |
linux-stm32mp | kernel-module-nft-numgen-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | nft-numgen kernel module |
linux-stm32mp | kernel-module-nft-objref-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | nft-objref kernel module |
linux-stm32mp | kernel-module-nft-queue-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | nft-queue kernel module |
linux-stm32mp | kernel-module-nft-quota-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | nft-quota kernel module |
linux-stm32mp | kernel-module-nft-redir-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | nft-redir kernel module |
linux-stm32mp | kernel-module-nft-reject-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | nft-reject kernel module |
linux-stm32mp | kernel-module-nft-reject-bridge-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | nft-reject-bridge kernel module |
linux-stm32mp | kernel-module-nhc-dest-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | nhc-dest kernel module |
linux-stm32mp | kernel-module-nhc-fragment-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | nhc-fragment kernel module |
linux-stm32mp | kernel-module-nhc-hop-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | nhc-hop kernel module |
linux-stm32mp | kernel-module-nhc-ipv6-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | nhc-ipv6 kernel module |
linux-stm32mp | kernel-module-nhc-mobility-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | nhc-mobility kernel module |
linux-stm32mp | kernel-module-nhc-routing-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | nhc-routing kernel module |
linux-stm32mp | kernel-module-nhc-udp-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | nhc-udp kernel module |
linux-stm32mp | kernel-module-nouveau-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | nouveau kernel module |
linux-stm32mp | kernel-module-nsh-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | nsh kernel module |
linux-stm32mp | kernel-module-nvme-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | nvme kernel module |
linux-stm32mp | kernel-module-nvme-core-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | nvme-core kernel module |
linux-stm32mp | kernel-module-nvmem-rmem-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | nvmem-rmem kernel module |
linux-stm32mp | kernel-module-nwl-dsi-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | nwl-dsi kernel module |
linux-stm32mp | kernel-module-of-fpga-region-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | of-fpga-region kernel module |
linux-stm32mp | kernel-module-openvswitch-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | openvswitch kernel module |
linux-stm32mp | kernel-module-optee-rng-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | optee-rng kernel module |
linux-stm32mp | kernel-module-option-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | option kernel module |
linux-stm32mp | kernel-module-ov5640-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | ov5640 kernel module |
linux-stm32mp | kernel-module-ov5645-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | ov5645 kernel module |
linux-stm32mp | kernel-module-overlay-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | overlay kernel module |
linux-stm32mp | kernel-module-p8022-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | p8022 kernel module |
linux-stm32mp | kernel-module-panel-boe-tv101wum-nl6-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | panel-boe-tv101wum-nl6 kernel module |
linux-stm32mp | kernel-module-panel-edp-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | panel-edp kernel module |
linux-stm32mp | kernel-module-panel-mantix-mlaf057we51-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | panel-mantix-mlaf057we51 kernel module |
linux-stm32mp | kernel-module-panel-raydium-rm67191-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | panel-raydium-rm67191 kernel module |
linux-stm32mp | kernel-module-panel-sitronix-st7703-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | panel-sitronix-st7703 kernel module |
linux-stm32mp | kernel-module-panel-truly-nt35597-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | panel-truly-nt35597 kernel module |
linux-stm32mp | kernel-module-panfrost-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | panfrost kernel module |
linux-stm32mp | kernel-module-parade-ps8640-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | parade-ps8640 kernel module |
linux-stm32mp | kernel-module-pci-endpoint-test-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | pci-endpoint-test kernel module |
linux-stm32mp | kernel-module-pci-epf-test-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | pci-epf-test kernel module |
linux-stm32mp | kernel-module-pci-meson-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | pci-meson kernel module |
linux-stm32mp | kernel-module-pegasus-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | pegasus kernel module |
linux-stm32mp | kernel-module-phy-cadence-sierra-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | phy-cadence-sierra kernel module |
linux-stm32mp | kernel-module-phy-cadence-torrent-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | phy-cadence-torrent kernel module |
linux-stm32mp | kernel-module-phy-qcom-usb-hs-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | phy-qcom-usb-hs kernel module |
linux-stm32mp | kernel-module-pl111-drm-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | pl111-drm kernel module |
linux-stm32mp | kernel-module-plusb-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | plusb kernel module |
linux-stm32mp | kernel-module-psample-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | psample kernel module |
linux-stm32mp | kernel-module-psnap-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | psnap kernel module |
linux-stm32mp | kernel-module-pwm-beeper-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | pwm-beeper kernel module |
linux-stm32mp | kernel-module-pwm-bl-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | pwm-bl kernel module |
linux-stm32mp | kernel-module-pwm-cros-ec-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | pwm-cros-ec kernel module |
linux-stm32mp | kernel-module-pwm-fan-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | pwm-fan kernel module |
linux-stm32mp | kernel-module-pwm-stm32-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | pwm-stm32 kernel module |
linux-stm32mp | kernel-module-pwm-stm32-lp-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | pwm-stm32-lp kernel module |
linux-stm32mp | kernel-module-pwm-vibra-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | pwm-vibra kernel module |
linux-stm32mp | kernel-module-qcom-emac-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | qcom-emac kernel module |
linux-stm32mp | kernel-module-qcom-spmi-adc5-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | qcom-spmi-adc5 kernel module |
linux-stm32mp | kernel-module-qcom-spmi-vadc-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | qcom-spmi-vadc kernel module |
linux-stm32mp | kernel-module-qcom-vadc-common-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | qcom-vadc-common kernel module |
linux-stm32mp | kernel-module-qmi-helpers-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | qmi-helpers kernel module |
linux-stm32mp | kernel-module-qrtr-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | qrtr kernel module |
linux-stm32mp | kernel-module-qrtr-mhi-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | qrtr-mhi kernel module |
linux-stm32mp | kernel-module-qrtr-smd-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | qrtr-smd kernel module |
linux-stm32mp | kernel-module-qrtr-tun-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | qrtr-tun kernel module |
linux-stm32mp | kernel-module-r8152-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | r8152 kernel module |
linux-stm32mp | kernel-module-r8153-ecm-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | r8153-ecm kernel module |
linux-stm32mp | kernel-module-r8169-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | r8169 kernel module |
linux-stm32mp | kernel-module-raid-class-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | raid-class kernel module |
linux-stm32mp | kernel-module-raid6-pq-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | raid6-pq kernel module |
linux-stm32mp | kernel-module-raw-diag-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | raw-diag kernel module |
linux-stm32mp | kernel-module-rc-adstech-dvb-t-pci-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-adstech-dvb-t-pci kernel module |
linux-stm32mp | kernel-module-rc-alink-dtu-m-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-alink-dtu-m kernel module |
linux-stm32mp | kernel-module-rc-anysee-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-anysee kernel module |
linux-stm32mp | kernel-module-rc-apac-viewcomp-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-apac-viewcomp kernel module |
linux-stm32mp | kernel-module-rc-astrometa-t2hybrid-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-astrometa-t2hybrid kernel module |
linux-stm32mp | kernel-module-rc-asus-pc39-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-asus-pc39 kernel module |
linux-stm32mp | kernel-module-rc-asus-ps3-100-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-asus-ps3-100 kernel module |
linux-stm32mp | kernel-module-rc-ati-tv-wonder-hd-600-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-ati-tv-wonder-hd-600 kernel module |
linux-stm32mp | kernel-module-rc-ati-x10-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-ati-x10 kernel module |
linux-stm32mp | kernel-module-rc-avermedia-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-avermedia kernel module |
linux-stm32mp | kernel-module-rc-avermedia-a16d-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-avermedia-a16d kernel module |
linux-stm32mp | kernel-module-rc-avermedia-cardbus-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-avermedia-cardbus kernel module |
linux-stm32mp | kernel-module-rc-avermedia-dvbt-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-avermedia-dvbt kernel module |
linux-stm32mp | kernel-module-rc-avermedia-m135a-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-avermedia-m135a kernel module |
linux-stm32mp | kernel-module-rc-avermedia-m733a-rm-k6-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-avermedia-m733a-rm-k6 kernel module |
linux-stm32mp | kernel-module-rc-avermedia-rm-ks-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-avermedia-rm-ks kernel module |
linux-stm32mp | kernel-module-rc-avertv-303-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-avertv-303 kernel module |
linux-stm32mp | kernel-module-rc-azurewave-ad-tu700-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-azurewave-ad-tu700 kernel module |
linux-stm32mp | kernel-module-rc-beelink-gs1-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-beelink-gs1 kernel module |
linux-stm32mp | kernel-module-rc-behold-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-behold kernel module |
linux-stm32mp | kernel-module-rc-behold-columbus-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-behold-columbus kernel module |
linux-stm32mp | kernel-module-rc-budget-ci-old-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-budget-ci-old kernel module |
linux-stm32mp | kernel-module-rc-cinergy-1400-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-cinergy-1400 kernel module |
linux-stm32mp | kernel-module-rc-cinergy-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-cinergy kernel module |
linux-stm32mp | kernel-module-rc-core-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-core kernel module |
linux-stm32mp | kernel-module-rc-ct-90405-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-ct-90405 kernel module |
linux-stm32mp | kernel-module-rc-d680-dmb-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-d680-dmb kernel module |
linux-stm32mp | kernel-module-rc-delock-61959-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-delock-61959 kernel module |
linux-stm32mp | kernel-module-rc-dib0700-nec-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-dib0700-nec kernel module |
linux-stm32mp | kernel-module-rc-dib0700-rc5-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-dib0700-rc5 kernel module |
linux-stm32mp | kernel-module-rc-digitalnow-tinytwin-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-digitalnow-tinytwin kernel module |
linux-stm32mp | kernel-module-rc-digittrade-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-digittrade kernel module |
linux-stm32mp | kernel-module-rc-dm1105-nec-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-dm1105-nec kernel module |
linux-stm32mp | kernel-module-rc-dntv-live-dvb-t-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-dntv-live-dvb-t kernel module |
linux-stm32mp | kernel-module-rc-dntv-live-dvbt-pro-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-dntv-live-dvbt-pro kernel module |
linux-stm32mp | kernel-module-rc-dtt200u-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-dtt200u kernel module |
linux-stm32mp | kernel-module-rc-dvbsky-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-dvbsky kernel module |
linux-stm32mp | kernel-module-rc-dvico-mce-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-dvico-mce kernel module |
linux-stm32mp | kernel-module-rc-dvico-portable-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-dvico-portable kernel module |
linux-stm32mp | kernel-module-rc-em-terratec-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-em-terratec kernel module |
linux-stm32mp | kernel-module-rc-encore-enltv-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-encore-enltv kernel module |
linux-stm32mp | kernel-module-rc-encore-enltv-fm53-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-encore-enltv-fm53 kernel module |
linux-stm32mp | kernel-module-rc-encore-enltv2-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-encore-enltv2 kernel module |
linux-stm32mp | kernel-module-rc-evga-indtube-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-evga-indtube kernel module |
linux-stm32mp | kernel-module-rc-eztv-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-eztv kernel module |
linux-stm32mp | kernel-module-rc-flydvb-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-flydvb kernel module |
linux-stm32mp | kernel-module-rc-flyvideo-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-flyvideo kernel module |
linux-stm32mp | kernel-module-rc-fusionhdtv-mce-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-fusionhdtv-mce kernel module |
linux-stm32mp | kernel-module-rc-gadmei-rm008z-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-gadmei-rm008z kernel module |
linux-stm32mp | kernel-module-rc-geekbox-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-geekbox kernel module |
linux-stm32mp | kernel-module-rc-genius-tvgo-a11mce-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-genius-tvgo-a11mce kernel module |
linux-stm32mp | kernel-module-rc-gotview7135-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-gotview7135 kernel module |
linux-stm32mp | kernel-module-rc-hauppauge-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-hauppauge kernel module |
linux-stm32mp | kernel-module-rc-hisi-poplar-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-hisi-poplar kernel module |
linux-stm32mp | kernel-module-rc-hisi-tv-demo-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-hisi-tv-demo kernel module |
linux-stm32mp | kernel-module-rc-imon-mce-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-imon-mce kernel module |
linux-stm32mp | kernel-module-rc-imon-pad-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-imon-pad kernel module |
linux-stm32mp | kernel-module-rc-imon-rsc-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-imon-rsc kernel module |
linux-stm32mp | kernel-module-rc-iodata-bctv7e-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-iodata-bctv7e kernel module |
linux-stm32mp | kernel-module-rc-it913x-v1-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-it913x-v1 kernel module |
linux-stm32mp | kernel-module-rc-it913x-v2-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-it913x-v2 kernel module |
linux-stm32mp | kernel-module-rc-kaiomy-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-kaiomy kernel module |
linux-stm32mp | kernel-module-rc-khadas-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-khadas kernel module |
linux-stm32mp | kernel-module-rc-khamsin-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-khamsin kernel module |
linux-stm32mp | kernel-module-rc-kworld-315u-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-kworld-315u kernel module |
linux-stm32mp | kernel-module-rc-kworld-pc150u-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-kworld-pc150u kernel module |
linux-stm32mp | kernel-module-rc-kworld-plus-tv-analog-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-kworld-plus-tv-analog kernel module |
linux-stm32mp | kernel-module-rc-leadtek-y04g0051-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-leadtek-y04g0051 kernel module |
linux-stm32mp | kernel-module-rc-lme2510-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-lme2510 kernel module |
linux-stm32mp | kernel-module-rc-manli-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-manli kernel module |
linux-stm32mp | kernel-module-rc-mecool-kii-pro-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-mecool-kii-pro kernel module |
linux-stm32mp | kernel-module-rc-mecool-kiii-pro-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-mecool-kiii-pro kernel module |
linux-stm32mp | kernel-module-rc-medion-x10-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-medion-x10 kernel module |
linux-stm32mp | kernel-module-rc-medion-x10-digitainer-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-medion-x10-digitainer kernel module |
linux-stm32mp | kernel-module-rc-medion-x10-or2x-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-medion-x10-or2x kernel module |
linux-stm32mp | kernel-module-rc-minix-neo-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-minix-neo kernel module |
linux-stm32mp | kernel-module-rc-msi-digivox-ii-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-msi-digivox-ii kernel module |
linux-stm32mp | kernel-module-rc-msi-digivox-iii-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-msi-digivox-iii kernel module |
linux-stm32mp | kernel-module-rc-msi-tvanywhere-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-msi-tvanywhere kernel module |
linux-stm32mp | kernel-module-rc-msi-tvanywhere-plus-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-msi-tvanywhere-plus kernel module |
linux-stm32mp | kernel-module-rc-nebula-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-nebula kernel module |
linux-stm32mp | kernel-module-rc-nec-terratec-cinergy-xs-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-nec-terratec-cinergy-xs kernel module |
linux-stm32mp | kernel-module-rc-norwood-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-norwood kernel module |
linux-stm32mp | kernel-module-rc-npgtech-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-npgtech kernel module |
linux-stm32mp | kernel-module-rc-odroid-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-odroid kernel module |
linux-stm32mp | kernel-module-rc-pctv-sedna-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-pctv-sedna kernel module |
linux-stm32mp | kernel-module-rc-pine64-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-pine64 kernel module |
linux-stm32mp | kernel-module-rc-pinnacle-color-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-pinnacle-color kernel module |
linux-stm32mp | kernel-module-rc-pinnacle-grey-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-pinnacle-grey kernel module |
linux-stm32mp | kernel-module-rc-pinnacle-pctv-hd-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-pinnacle-pctv-hd kernel module |
linux-stm32mp | kernel-module-rc-pixelview-002t-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-pixelview-002t kernel module |
linux-stm32mp | kernel-module-rc-pixelview-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-pixelview kernel module |
linux-stm32mp | kernel-module-rc-pixelview-mk12-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-pixelview-mk12 kernel module |
linux-stm32mp | kernel-module-rc-pixelview-new-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-pixelview-new kernel module |
linux-stm32mp | kernel-module-rc-powercolor-real-angel-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-powercolor-real-angel kernel module |
linux-stm32mp | kernel-module-rc-proteus-2309-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-proteus-2309 kernel module |
linux-stm32mp | kernel-module-rc-purpletv-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-purpletv kernel module |
linux-stm32mp | kernel-module-rc-pv951-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-pv951 kernel module |
linux-stm32mp | kernel-module-rc-rc6-mce-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-rc6-mce kernel module |
linux-stm32mp | kernel-module-rc-real-audio-220-32-keys-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-real-audio-220-32-keys kernel module |
linux-stm32mp | kernel-module-rc-reddo-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-reddo kernel module |
linux-stm32mp | kernel-module-rc-snapstream-firefly-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-snapstream-firefly kernel module |
linux-stm32mp | kernel-module-rc-streamzap-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-streamzap kernel module |
linux-stm32mp | kernel-module-rc-su3000-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-su3000 kernel module |
linux-stm32mp | kernel-module-rc-tanix-tx3mini-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-tanix-tx3mini kernel module |
linux-stm32mp | kernel-module-rc-tanix-tx5max-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-tanix-tx5max kernel module |
linux-stm32mp | kernel-module-rc-tbs-nec-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-tbs-nec kernel module |
linux-stm32mp | kernel-module-rc-technisat-ts35-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-technisat-ts35 kernel module |
linux-stm32mp | kernel-module-rc-technisat-usb2-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-technisat-usb2 kernel module |
linux-stm32mp | kernel-module-rc-terratec-cinergy-c-pci-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-terratec-cinergy-c-pci kernel module |
linux-stm32mp | kernel-module-rc-terratec-cinergy-s2-hd-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-terratec-cinergy-s2-hd kernel module |
linux-stm32mp | kernel-module-rc-terratec-cinergy-xs-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-terratec-cinergy-xs kernel module |
linux-stm32mp | kernel-module-rc-terratec-slim-2-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-terratec-slim-2 kernel module |
linux-stm32mp | kernel-module-rc-terratec-slim-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-terratec-slim kernel module |
linux-stm32mp | kernel-module-rc-tevii-nec-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-tevii-nec kernel module |
linux-stm32mp | kernel-module-rc-tivo-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-tivo kernel module |
linux-stm32mp | kernel-module-rc-total-media-in-hand-02-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-total-media-in-hand-02 kernel module |
linux-stm32mp | kernel-module-rc-total-media-in-hand-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-total-media-in-hand kernel module |
linux-stm32mp | kernel-module-rc-trekstor-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-trekstor kernel module |
linux-stm32mp | kernel-module-rc-tt-1500-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-tt-1500 kernel module |
linux-stm32mp | kernel-module-rc-twinhan-dtv-cab-ci-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-twinhan-dtv-cab-ci kernel module |
linux-stm32mp | kernel-module-rc-twinhan1027-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-twinhan1027 kernel module |
linux-stm32mp | kernel-module-rc-vega-s9x-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-vega-s9x kernel module |
linux-stm32mp | kernel-module-rc-videomate-m1f-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-videomate-m1f kernel module |
linux-stm32mp | kernel-module-rc-videomate-s350-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-videomate-s350 kernel module |
linux-stm32mp | kernel-module-rc-videomate-tv-pvr-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-videomate-tv-pvr kernel module |
linux-stm32mp | kernel-module-rc-videostrong-kii-pro-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-videostrong-kii-pro kernel module |
linux-stm32mp | kernel-module-rc-wetek-hub-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-wetek-hub kernel module |
linux-stm32mp | kernel-module-rc-wetek-play2-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-wetek-play2 kernel module |
linux-stm32mp | kernel-module-rc-winfast-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-winfast kernel module |
linux-stm32mp | kernel-module-rc-winfast-usbii-deluxe-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-winfast-usbii-deluxe kernel module |
linux-stm32mp | kernel-module-rc-x96max-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-x96max kernel module |
linux-stm32mp | kernel-module-rc-xbox-360-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-xbox-360 kernel module |
linux-stm32mp | kernel-module-rc-xbox-dvd-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-xbox-dvd kernel module |
linux-stm32mp | kernel-module-rc-zx-irdec-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rc-zx-irdec kernel module |
linux-stm32mp | kernel-module-rcar-dw-hdmi-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rcar-dw-hdmi kernel module |
linux-stm32mp | kernel-module-regmap-i3c-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | regmap-i3c kernel module |
linux-stm32mp | kernel-module-regmap-sdw-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | regmap-sdw kernel module |
linux-stm32mp | kernel-module-regmap-slimbus-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | regmap-slimbus kernel module |
linux-stm32mp | kernel-module-regmap-spmi-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | regmap-spmi kernel module |
linux-stm32mp | kernel-module-rfkill-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rfkill kernel module |
linux-stm32mp | kernel-module-rmnet-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rmnet kernel module |
linux-stm32mp | kernel-module-rng-core-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rng-core kernel module |
linux-stm32mp | kernel-module-rpmsg-char-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rpmsg-char kernel module |
linux-stm32mp | kernel-module-rpmsg-ctrl-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rpmsg-ctrl kernel module |
linux-stm32mp | kernel-module-rtc-ds1307-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rtc-ds1307 kernel module |
linux-stm32mp | kernel-module-rtc-hym8563-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rtc-hym8563 kernel module |
linux-stm32mp | kernel-module-rtc-m41t80-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rtc-m41t80 kernel module |
linux-stm32mp | kernel-module-rtc-mt6397-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rtc-mt6397 kernel module |
linux-stm32mp | kernel-module-rtc-pcf2127-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rtc-pcf2127 kernel module |
linux-stm32mp | kernel-module-rtc-pcf85063-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rtc-pcf85063 kernel module |
linux-stm32mp | kernel-module-rtc-pcf85363-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rtc-pcf85363 kernel module |
linux-stm32mp | kernel-module-rtc-rk808-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rtc-rk808 kernel module |
linux-stm32mp | kernel-module-rtc-rv3028-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rtc-rv3028 kernel module |
linux-stm32mp | kernel-module-rtc-rv8803-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rtc-rv8803 kernel module |
linux-stm32mp | kernel-module-rtc-rx8581-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rtc-rx8581 kernel module |
linux-stm32mp | kernel-module-rtl8150-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | rtl8150 kernel module |
linux-stm32mp | kernel-module-s3fwrn5-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | s3fwrn5 kernel module |
linux-stm32mp | kernel-module-s3fwrn5-i2c-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | s3fwrn5-i2c kernel module |
linux-stm32mp | kernel-module-sbs-battery-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | sbs-battery kernel module |
linux-stm32mp | kernel-module-sch-cbs-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | sch-cbs kernel module |
linux-stm32mp | kernel-module-sch-choke-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | sch-choke kernel module |
linux-stm32mp | kernel-module-sch-codel-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | sch-codel kernel module |
linux-stm32mp | kernel-module-sch-drr-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | sch-drr kernel module |
linux-stm32mp | kernel-module-sch-etf-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | sch-etf kernel module |
linux-stm32mp | kernel-module-sch-fq-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | sch-fq kernel module |
linux-stm32mp | kernel-module-sch-fq-codel-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | sch-fq-codel kernel module |
linux-stm32mp | kernel-module-sch-gred-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | sch-gred kernel module |
linux-stm32mp | kernel-module-sch-hfsc-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | sch-hfsc kernel module |
linux-stm32mp | kernel-module-sch-hhf-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | sch-hhf kernel module |
linux-stm32mp | kernel-module-sch-htb-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | sch-htb kernel module |
linux-stm32mp | kernel-module-sch-ingress-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | sch-ingress kernel module |
linux-stm32mp | kernel-module-sch-mqprio-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | sch-mqprio kernel module |
linux-stm32mp | kernel-module-sch-multiq-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | sch-multiq kernel module |
linux-stm32mp | kernel-module-sch-netem-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | sch-netem kernel module |
linux-stm32mp | kernel-module-sch-pie-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | sch-pie kernel module |
linux-stm32mp | kernel-module-sch-plug-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | sch-plug kernel module |
linux-stm32mp | kernel-module-sch-prio-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | sch-prio kernel module |
linux-stm32mp | kernel-module-sch-qfq-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | sch-qfq kernel module |
linux-stm32mp | kernel-module-sch-red-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | sch-red kernel module |
linux-stm32mp | kernel-module-sch-sfb-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | sch-sfb kernel module |
linux-stm32mp | kernel-module-sch-sfq-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | sch-sfq kernel module |
linux-stm32mp | kernel-module-sch-skbprio-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | sch-skbprio kernel module |
linux-stm32mp | kernel-module-sch-taprio-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | sch-taprio kernel module |
linux-stm32mp | kernel-module-sch-tbf-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | sch-tbf kernel module |
linux-stm32mp | kernel-module-sch-teql-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | sch-teql kernel module |
linux-stm32mp | kernel-module-seqiv-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | seqiv kernel module |
linux-stm32mp | kernel-module-sha3-ce-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | sha3-ce kernel module |
linux-stm32mp | kernel-module-sha3-generic-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | sha3-generic kernel module |
linux-stm32mp | kernel-module-sha512-arm64-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | sha512-arm64 kernel module |
linux-stm32mp | kernel-module-sha512-ce-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | sha512-ce kernel module |
linux-stm32mp | kernel-module-sii902x-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | sii902x kernel module |
linux-stm32mp | kernel-module-sil164-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | sil164 kernel module |
linux-stm32mp | kernel-module-simple-bridge-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | simple-bridge kernel module |
linux-stm32mp | kernel-module-sit-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | sit kernel module |
linux-stm32mp | kernel-module-slim-qcom-ctrl-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | slim-qcom-ctrl kernel module |
linux-stm32mp | kernel-module-slimbus-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | slimbus kernel module |
linux-stm32mp | kernel-module-sm3-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | sm3 kernel module |
linux-stm32mp | kernel-module-sm3-ce-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | sm3-ce kernel module |
linux-stm32mp | kernel-module-sm3-generic-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | sm3-generic kernel module |
linux-stm32mp | kernel-module-sm4-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | sm4 kernel module |
linux-stm32mp | kernel-module-sm4-generic-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | sm4-generic kernel module |
linux-stm32mp | kernel-module-smsc-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | smsc kernel module |
linux-stm32mp | kernel-module-smsc75xx-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | smsc75xx kernel module |
linux-stm32mp | kernel-module-smsc95xx-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | smsc95xx kernel module |
linux-stm32mp | kernel-module-snd-soc-adau7002-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | snd-soc-adau7002 kernel module |
linux-stm32mp | kernel-module-snd-soc-ak4613-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | snd-soc-ak4613 kernel module |
linux-stm32mp | kernel-module-snd-soc-audio-graph-card-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | snd-soc-audio-graph-card kernel module |
linux-stm32mp | kernel-module-snd-soc-audio-graph-card2-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | snd-soc-audio-graph-card2 kernel module |
linux-stm32mp | kernel-module-snd-soc-cros-ec-codec-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | snd-soc-cros-ec-codec kernel module |
linux-stm32mp | kernel-module-snd-soc-cs42l51-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | snd-soc-cs42l51 kernel module |
linux-stm32mp | kernel-module-snd-soc-cs42l51-i2c-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | snd-soc-cs42l51-i2c kernel module |
linux-stm32mp | kernel-module-snd-soc-dmic-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | snd-soc-dmic kernel module |
linux-stm32mp | kernel-module-snd-soc-es7134-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | snd-soc-es7134 kernel module |
linux-stm32mp | kernel-module-snd-soc-es7241-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | snd-soc-es7241 kernel module |
linux-stm32mp | kernel-module-snd-soc-fsl-asrc-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | snd-soc-fsl-asrc kernel module |
linux-stm32mp | kernel-module-snd-soc-fsl-audmix-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | snd-soc-fsl-audmix kernel module |
linux-stm32mp | kernel-module-snd-soc-fsl-easrc-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | snd-soc-fsl-easrc kernel module |
linux-stm32mp | kernel-module-snd-soc-fsl-esai-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | snd-soc-fsl-esai kernel module |
linux-stm32mp | kernel-module-snd-soc-fsl-micfil-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | snd-soc-fsl-micfil kernel module |
linux-stm32mp | kernel-module-snd-soc-fsl-sai-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | snd-soc-fsl-sai kernel module |
linux-stm32mp | kernel-module-snd-soc-fsl-spdif-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | snd-soc-fsl-spdif kernel module |
linux-stm32mp | kernel-module-snd-soc-fsl-ssi-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | snd-soc-fsl-ssi kernel module |
linux-stm32mp | kernel-module-snd-soc-fsl-utils-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | snd-soc-fsl-utils kernel module |
linux-stm32mp | kernel-module-snd-soc-gtm601-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | snd-soc-gtm601 kernel module |
linux-stm32mp | kernel-module-snd-soc-imx-audmux-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | snd-soc-imx-audmux kernel module |
linux-stm32mp | kernel-module-snd-soc-lpass-macro-common-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | snd-soc-lpass-macro-common kernel module |
linux-stm32mp | kernel-module-snd-soc-lpass-rx-macro-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | snd-soc-lpass-rx-macro kernel module |
linux-stm32mp | kernel-module-snd-soc-lpass-tx-macro-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | snd-soc-lpass-tx-macro kernel module |
linux-stm32mp | kernel-module-snd-soc-lpass-va-macro-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | snd-soc-lpass-va-macro kernel module |
linux-stm32mp | kernel-module-snd-soc-lpass-wsa-macro-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | snd-soc-lpass-wsa-macro kernel module |
linux-stm32mp | kernel-module-snd-soc-max98357a-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | snd-soc-max98357a kernel module |
linux-stm32mp | kernel-module-snd-soc-max98927-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | snd-soc-max98927 kernel module |
linux-stm32mp | kernel-module-snd-soc-msm8916-analog-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | snd-soc-msm8916-analog kernel module |
linux-stm32mp | kernel-module-snd-soc-msm8916-digital-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | snd-soc-msm8916-digital kernel module |
linux-stm32mp | kernel-module-snd-soc-nau8822-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | snd-soc-nau8822 kernel module |
linux-stm32mp | kernel-module-snd-soc-pcm3168a-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | snd-soc-pcm3168a kernel module |
linux-stm32mp | kernel-module-snd-soc-pcm3168a-i2c-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | snd-soc-pcm3168a-i2c kernel module |
linux-stm32mp | kernel-module-snd-soc-rl6231-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | snd-soc-rl6231 kernel module |
linux-stm32mp | kernel-module-snd-soc-rt5659-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | snd-soc-rt5659 kernel module |
linux-stm32mp | kernel-module-snd-soc-sgtl5000-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | snd-soc-sgtl5000 kernel module |
linux-stm32mp | kernel-module-snd-soc-simple-amplifier-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | snd-soc-simple-amplifier kernel module |
linux-stm32mp | kernel-module-snd-soc-simple-card-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | snd-soc-simple-card kernel module |
linux-stm32mp | kernel-module-snd-soc-simple-card-utils-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | snd-soc-simple-card-utils kernel module |
linux-stm32mp | kernel-module-snd-soc-simple-mux-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | snd-soc-simple-mux kernel module |
linux-stm32mp | kernel-module-snd-soc-spdif-rx-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | snd-soc-spdif-rx kernel module |
linux-stm32mp | kernel-module-snd-soc-spdif-tx-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | snd-soc-spdif-tx kernel module |
linux-stm32mp | kernel-module-snd-soc-stm32-i2s-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | snd-soc-stm32-i2s kernel module |
linux-stm32mp | kernel-module-snd-soc-stm32-sai-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | snd-soc-stm32-sai kernel module |
linux-stm32mp | kernel-module-snd-soc-stm32-sai-sub-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | snd-soc-stm32-sai-sub kernel module |
linux-stm32mp | kernel-module-snd-soc-stm32-spdifrx-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | snd-soc-stm32-spdifrx kernel module |
linux-stm32mp | kernel-module-snd-soc-tas571x-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | snd-soc-tas571x kernel module |
linux-stm32mp | kernel-module-snd-soc-tlv320aic31xx-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | snd-soc-tlv320aic31xx kernel module |
linux-stm32mp | kernel-module-snd-soc-tlv320aic32x4-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | snd-soc-tlv320aic32x4 kernel module |
linux-stm32mp | kernel-module-snd-soc-tlv320aic32x4-i2c-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | snd-soc-tlv320aic32x4-i2c kernel module |
linux-stm32mp | kernel-module-snd-soc-wcd-mbhc-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | snd-soc-wcd-mbhc kernel module |
linux-stm32mp | kernel-module-snd-soc-wcd9335-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | snd-soc-wcd9335 kernel module |
linux-stm32mp | kernel-module-snd-soc-wcd934x-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | snd-soc-wcd934x kernel module |
linux-stm32mp | kernel-module-snd-soc-wcd938x-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | snd-soc-wcd938x kernel module |
linux-stm32mp | kernel-module-snd-soc-wcd938x-sdw-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | snd-soc-wcd938x-sdw kernel module |
linux-stm32mp | kernel-module-snd-soc-wm-hubs-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | snd-soc-wm-hubs kernel module |
linux-stm32mp | kernel-module-snd-soc-wm8524-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | snd-soc-wm8524 kernel module |
linux-stm32mp | kernel-module-snd-soc-wm8904-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | snd-soc-wm8904 kernel module |
linux-stm32mp | kernel-module-snd-soc-wm8960-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | snd-soc-wm8960 kernel module |
linux-stm32mp | kernel-module-snd-soc-wm8962-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | snd-soc-wm8962 kernel module |
linux-stm32mp | kernel-module-snd-soc-wm8978-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | snd-soc-wm8978 kernel module |
linux-stm32mp | kernel-module-snd-soc-wm8994-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | snd-soc-wm8994 kernel module |
linux-stm32mp | kernel-module-snd-soc-wsa881x-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | snd-soc-wsa881x kernel module |
linux-stm32mp | kernel-module-soundwire-bus-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | soundwire-bus kernel module |
linux-stm32mp | kernel-module-soundwire-qcom-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | soundwire-qcom kernel module |
linux-stm32mp | kernel-module-spi-dw-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | spi-dw kernel module |
linux-stm32mp | kernel-module-spi-dw-mmio-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | spi-dw-mmio kernel module |
linux-stm32mp | kernel-module-spi-stm32-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | spi-stm32 kernel module |
linux-stm32mp | kernel-module-spidev-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | spidev kernel module |
linux-stm32mp | kernel-module-sr9800-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | sr9800 kernel module |
linux-stm32mp | kernel-module-st-lsm6dsx-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | st-lsm6dsx kernel module |
linux-stm32mp | kernel-module-st-lsm6dsx-i2c-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | st-lsm6dsx-i2c kernel module |
linux-stm32mp | kernel-module-st-lsm6dsx-i3c-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | st-lsm6dsx-i3c kernel module |
linux-stm32mp | kernel-module-st-lsm6dsx-spi-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | st-lsm6dsx-spi kernel module |
linux-stm32mp | kernel-module-st-magn-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | st-magn kernel module |
linux-stm32mp | kernel-module-st-magn-i2c-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | st-magn-i2c kernel module |
linux-stm32mp | kernel-module-st-magn-spi-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | st-magn-spi kernel module |
linux-stm32mp | kernel-module-st-pressure-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | st-pressure kernel module |
linux-stm32mp | kernel-module-st-pressure-i2c-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | st-pressure-i2c kernel module |
linux-stm32mp | kernel-module-st-pressure-spi-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | st-pressure-spi kernel module |
linux-stm32mp | kernel-module-st-sensors-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | st-sensors kernel module |
linux-stm32mp | kernel-module-st-sensors-i2c-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | st-sensors-i2c kernel module |
linux-stm32mp | kernel-module-st-sensors-spi-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | st-sensors-spi kernel module |
linux-stm32mp | kernel-module-stm32-adc-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | stm32-adc kernel module |
linux-stm32mp | kernel-module-stm32-adc-core-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | stm32-adc-core kernel module |
linux-stm32mp | kernel-module-stm32-amdf-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | stm32-amdf kernel module |
linux-stm32mp | kernel-module-stm32-crc32-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | stm32-crc32 kernel module |
linux-stm32mp | kernel-module-stm32-cryp-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | stm32-cryp kernel module |
linux-stm32mp | kernel-module-stm32-csi2host-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | stm32-csi2host kernel module |
linux-stm32mp | kernel-module-stm32-dcmi-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | stm32-dcmi kernel module |
linux-stm32mp | kernel-module-stm32-dcmipp-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | stm32-dcmipp kernel module |
linux-stm32mp | kernel-module-stm32-ddr-pmu-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | stm32-ddr-pmu kernel module |
linux-stm32mp | kernel-module-stm32-hash-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | stm32-hash kernel module |
linux-stm32mp | kernel-module-stm32-i3c-master-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | stm32-i3c-master kernel module |
linux-stm32mp | kernel-module-stm32-lptimer-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | stm32-lptimer kernel module |
linux-stm32mp | kernel-module-stm32-lptimer-cnt-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | stm32-lptimer-cnt kernel module |
linux-stm32mp | kernel-module-stm32-lptimer-trigger-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | stm32-lptimer-trigger kernel module |
linux-stm32mp | kernel-module-stm32-mdf-adc-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | stm32-mdf-adc kernel module |
linux-stm32mp | kernel-module-stm32-mdf-core-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | stm32-mdf-core kernel module |
linux-stm32mp | kernel-module-stm32-mdf-serial-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | stm32-mdf-serial kernel module |
linux-stm32mp | kernel-module-stm32-rng-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | stm32-rng kernel module |
linux-stm32mp | kernel-module-stm32-timer-cnt-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | stm32-timer-cnt kernel module |
linux-stm32mp | kernel-module-stm32-timer-trigger-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | stm32-timer-trigger kernel module |
linux-stm32mp | kernel-module-stm32-timers-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | stm32-timers kernel module |
linux-stm32mp | kernel-module-stp-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | stp kernel module |
linux-stm32mp | kernel-module-tag-brcm-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | tag-brcm kernel module |
linux-stm32mp | kernel-module-tag-ocelot-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | tag-ocelot kernel module |
linux-stm32mp | kernel-module-tag-ocelot-8021q-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | tag-ocelot-8021q kernel module |
linux-stm32mp | kernel-module-tap-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | tap kernel module |
linux-stm32mp | kernel-module-tcp-bic-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | tcp-bic kernel module |
linux-stm32mp | kernel-module-tcp-diag-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | tcp-diag kernel module |
linux-stm32mp | kernel-module-tcp-htcp-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | tcp-htcp kernel module |
linux-stm32mp | kernel-module-tcp-westwood-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | tcp-westwood kernel module |
linux-stm32mp | kernel-module-tcpci-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | tcpci kernel module |
linux-stm32mp | kernel-module-tcpm-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | tcpm kernel module |
linux-stm32mp | kernel-module-tda998x-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | tda998x kernel module |
linux-stm32mp | kernel-module-thc63lvd1024-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | thc63lvd1024 kernel module |
linux-stm32mp | kernel-module-ti-ads1015-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | ti-ads1015 kernel module |
linux-stm32mp | kernel-module-ti-sn65dsi86-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | ti-sn65dsi86 kernel module |
linux-stm32mp | kernel-module-tidss-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | tidss kernel module |
linux-stm32mp | kernel-module-tls-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | tls kernel module |
linux-stm32mp | kernel-module-tps65132-regulator-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | tps65132-regulator kernel module |
linux-stm32mp | kernel-module-tps6598x-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | tps6598x kernel module |
linux-stm32mp | kernel-module-ts-bm-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | ts-bm kernel module |
linux-stm32mp | kernel-module-ts-fsm-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | ts-fsm kernel module |
linux-stm32mp | kernel-module-ts-kmp-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | ts-kmp kernel module |
linux-stm32mp | kernel-module-ttm-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | ttm kernel module |
linux-stm32mp | kernel-module-tun-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | tun kernel module |
linux-stm32mp | kernel-module-tunnel4-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | tunnel4 kernel module |
linux-stm32mp | kernel-module-tunnel6-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | tunnel6 kernel module |
linux-stm32mp | kernel-module-typec-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | typec kernel module |
linux-stm32mp | kernel-module-typec-ucsi-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | typec-ucsi kernel module |
linux-stm32mp | kernel-module-u-ether-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | u-ether kernel module |
linux-stm32mp | kernel-module-u-serial-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | u-serial kernel module |
linux-stm32mp | kernel-module-uacce-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | uacce kernel module |
linux-stm32mp | kernel-module-ucsi-stm32g0-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | ucsi-stm32g0 kernel module |
linux-stm32mp | kernel-module-udp-diag-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | udp-diag kernel module |
linux-stm32mp | kernel-module-udp-tunnel-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | udp-tunnel kernel module |
linux-stm32mp | kernel-module-uinput-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | uinput kernel module |
linux-stm32mp | kernel-module-unix-diag-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | unix-diag kernel module |
linux-stm32mp | kernel-module-usb-f-acm-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | usb-f-acm kernel module |
linux-stm32mp | kernel-module-usb-f-ecm-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | usb-f-ecm kernel module |
linux-stm32mp | kernel-module-usb-f-ecm-subset-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | usb-f-ecm-subset kernel module |
linux-stm32mp | kernel-module-usb-f-eem-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | usb-f-eem kernel module |
linux-stm32mp | kernel-module-usb-f-fs-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | usb-f-fs kernel module |
linux-stm32mp | kernel-module-usb-f-mass-storage-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | usb-f-mass-storage kernel module |
linux-stm32mp | kernel-module-usb-f-ncm-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | usb-f-ncm kernel module |
linux-stm32mp | kernel-module-usb-f-obex-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | usb-f-obex kernel module |
linux-stm32mp | kernel-module-usb-f-rndis-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | usb-f-rndis kernel module |
linux-stm32mp | kernel-module-usb-f-serial-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | usb-f-serial kernel module |
linux-stm32mp | kernel-module-usb-wwan-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | usb-wwan kernel module |
linux-stm32mp | kernel-module-usbip-core-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | usbip-core kernel module |
linux-stm32mp | kernel-module-usbip-host-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | usbip-host kernel module |
linux-stm32mp | kernel-module-usbnet-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | usbnet kernel module |
linux-stm32mp | kernel-module-usbserial-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | usbserial kernel module |
linux-stm32mp | kernel-module-uvcvideo-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | uvcvideo kernel module |
linux-stm32mp | kernel-module-v4l2-async-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | v4l2-async kernel module |
linux-stm32mp | kernel-module-v4l2-dv-timings-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | v4l2-dv-timings kernel module |
linux-stm32mp | kernel-module-v4l2-fwnode-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | v4l2-fwnode kernel module |
linux-stm32mp | kernel-module-v4l2-h264-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | v4l2-h264 kernel module |
linux-stm32mp | kernel-module-v4l2-mem2mem-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | v4l2-mem2mem kernel module |
linux-stm32mp | kernel-module-v4l2-tpg-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | v4l2-tpg kernel module |
linux-stm32mp | kernel-module-v4l2-vp9-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | v4l2-vp9 kernel module |
linux-stm32mp | kernel-module-vcnl4000-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | vcnl4000 kernel module |
linux-stm32mp | kernel-module-vctrl-regulator-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | vctrl-regulator kernel module |
linux-stm32mp | kernel-module-veth-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | veth kernel module |
linux-stm32mp | kernel-module-videobuf2-common-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | videobuf2-common kernel module |
linux-stm32mp | kernel-module-videobuf2-dma-contig-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | videobuf2-dma-contig kernel module |
linux-stm32mp | kernel-module-videobuf2-memops-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | videobuf2-memops kernel module |
linux-stm32mp | kernel-module-videobuf2-v4l2-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | videobuf2-v4l2 kernel module |
linux-stm32mp | kernel-module-videobuf2-vmalloc-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | videobuf2-vmalloc kernel module |
linux-stm32mp | kernel-module-videodev-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | videodev kernel module |
linux-stm32mp | kernel-module-vivid-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | vivid kernel module |
linux-stm32mp | kernel-module-vmw-vsock-virtio-transport-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | vmw-vsock-virtio-transport kernel module |
linux-stm32mp | kernel-module-vmw-vsock-virtio-transport-common-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | vmw-vsock-virtio-transport-common kernel module |
linux-stm32mp | kernel-module-vport-gre-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | vport-gre kernel module |
linux-stm32mp | kernel-module-vsock-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | vsock kernel module |
linux-stm32mp | kernel-module-vsock-diag-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | vsock-diag kernel module |
linux-stm32mp | kernel-module-vsock-loopback-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | vsock-loopback kernel module |
linux-stm32mp | kernel-module-wcd934x-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | wcd934x kernel module |
linux-stm32mp | kernel-module-wcn36xx-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | wcn36xx kernel module |
linux-stm32mp | kernel-module-wl18xx-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | wl18xx kernel module |
linux-stm32mp | kernel-module-wlcore-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | wlcore kernel module |
linux-stm32mp | kernel-module-wlcore-sdio-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | wlcore-sdio kernel module |
linux-stm32mp | kernel-module-wm8994-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | wm8994 kernel module |
linux-stm32mp | kernel-module-x-tables-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | x-tables kernel module |
linux-stm32mp | kernel-module-xen-pciback-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | xen-pciback kernel module |
linux-stm32mp | kernel-module-xfrm-algo-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | xfrm-algo kernel module |
linux-stm32mp | kernel-module-xfrm-ipcomp-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | xfrm-ipcomp kernel module |
linux-stm32mp | kernel-module-xfrm4-tunnel-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | xfrm4-tunnel kernel module |
linux-stm32mp | kernel-module-xhci-pci-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | xhci-pci kernel module |
linux-stm32mp | kernel-module-xhci-pci-renesas-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | xhci-pci-renesas kernel module |
linux-stm32mp | kernel-module-xor-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | xor kernel module |
linux-stm32mp | kernel-module-xor-neon-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | xor-neon kernel module |
linux-stm32mp | kernel-module-xt-addrtype-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | xt-addrtype kernel module |
linux-stm32mp | kernel-module-xt-bpf-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | xt-bpf kernel module |
linux-stm32mp | kernel-module-xt-cgroup-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | xt-cgroup kernel module |
linux-stm32mp | kernel-module-xt-checksum-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | xt-checksum kernel module |
linux-stm32mp | kernel-module-xt-classify-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | xt-classify kernel module |
linux-stm32mp | kernel-module-xt-cluster-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | xt-cluster kernel module |
linux-stm32mp | kernel-module-xt-comment-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | xt-comment kernel module |
linux-stm32mp | kernel-module-xt-connbytes-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | xt-connbytes kernel module |
linux-stm32mp | kernel-module-xt-connlabel-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | xt-connlabel kernel module |
linux-stm32mp | kernel-module-xt-connlimit-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | xt-connlimit kernel module |
linux-stm32mp | kernel-module-xt-connmark-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | xt-connmark kernel module |
linux-stm32mp | kernel-module-xt-connsecmark-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | xt-connsecmark kernel module |
linux-stm32mp | kernel-module-xt-conntrack-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | xt-conntrack kernel module |
linux-stm32mp | kernel-module-xt-cpu-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | xt-cpu kernel module |
linux-stm32mp | kernel-module-xt-dccp-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | xt-dccp kernel module |
linux-stm32mp | kernel-module-xt-devgroup-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | xt-devgroup kernel module |
linux-stm32mp | kernel-module-xt-dscp-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | xt-dscp kernel module |
linux-stm32mp | kernel-module-xt-ecn-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | xt-ecn kernel module |
linux-stm32mp | kernel-module-xt-esp-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | xt-esp kernel module |
linux-stm32mp | kernel-module-xt-hashlimit-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | xt-hashlimit kernel module |
linux-stm32mp | kernel-module-xt-helper-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | xt-helper kernel module |
linux-stm32mp | kernel-module-xt-hl-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | xt-hl kernel module |
linux-stm32mp | kernel-module-xt-hmark-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | xt-hmark kernel module |
linux-stm32mp | kernel-module-xt-idletimer-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | xt-idletimer kernel module |
linux-stm32mp | kernel-module-xt-ipcomp-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | xt-ipcomp kernel module |
linux-stm32mp | kernel-module-xt-iprange-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | xt-iprange kernel module |
linux-stm32mp | kernel-module-xt-ipvs-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | xt-ipvs kernel module |
linux-stm32mp | kernel-module-xt-led-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | xt-led kernel module |
linux-stm32mp | kernel-module-xt-length-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | xt-length kernel module |
linux-stm32mp | kernel-module-xt-limit-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | xt-limit kernel module |
linux-stm32mp | kernel-module-xt-log-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | xt-log kernel module |
linux-stm32mp | kernel-module-xt-mac-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | xt-mac kernel module |
linux-stm32mp | kernel-module-xt-mark-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | xt-mark kernel module |
linux-stm32mp | kernel-module-xt-masquerade-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | xt-masquerade kernel module |
linux-stm32mp | kernel-module-xt-multiport-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | xt-multiport kernel module |
linux-stm32mp | kernel-module-xt-nat-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | xt-nat kernel module |
linux-stm32mp | kernel-module-xt-netmap-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | xt-netmap kernel module |
linux-stm32mp | kernel-module-xt-nfacct-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | xt-nfacct kernel module |
linux-stm32mp | kernel-module-xt-nflog-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | xt-nflog kernel module |
linux-stm32mp | kernel-module-xt-nfqueue-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | xt-nfqueue kernel module |
linux-stm32mp | kernel-module-xt-osf-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | xt-osf kernel module |
linux-stm32mp | kernel-module-xt-owner-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | xt-owner kernel module |
linux-stm32mp | kernel-module-xt-physdev-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | xt-physdev kernel module |
linux-stm32mp | kernel-module-xt-pkttype-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | xt-pkttype kernel module |
linux-stm32mp | kernel-module-xt-policy-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | xt-policy kernel module |
linux-stm32mp | kernel-module-xt-quota-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | xt-quota kernel module |
linux-stm32mp | kernel-module-xt-rateest-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | xt-rateest kernel module |
linux-stm32mp | kernel-module-xt-realm-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | xt-realm kernel module |
linux-stm32mp | kernel-module-xt-recent-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | xt-recent kernel module |
linux-stm32mp | kernel-module-xt-redirect-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | xt-redirect kernel module |
linux-stm32mp | kernel-module-xt-sctp-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | xt-sctp kernel module |
linux-stm32mp | kernel-module-xt-secmark-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | xt-secmark kernel module |
linux-stm32mp | kernel-module-xt-state-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | xt-state kernel module |
linux-stm32mp | kernel-module-xt-statistic-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | xt-statistic kernel module |
linux-stm32mp | kernel-module-xt-string-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | xt-string kernel module |
linux-stm32mp | kernel-module-xt-tcpmss-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | xt-tcpmss kernel module |
linux-stm32mp | kernel-module-xt-tcpudp-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | xt-tcpudp kernel module |
linux-stm32mp | kernel-module-xt-tee-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | xt-tee kernel module |
linux-stm32mp | kernel-module-xt-time-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | xt-time kernel module |
linux-stm32mp | kernel-module-xt-u32-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | xt-u32 kernel module |
linux-stm32mp | kernel-module-xts-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | xts kernel module |
linux-stm32mp | kernel-module-xxhash-generic-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | xxhash-generic kernel module |
linux-stm32mp | kernel-module-zaurus-6.1.82 | 6.1.82-stm32mp-r2 | GPL-2.0-only | zaurus kernel module |
linux-stm32mp | kernel-modules | 6.1.82-stm32mp-r2 | GPL-2.0-only | Linux STM32MP Kernel |
kmod | kmod | 30 | GPL-2.0-or-later & LGPL-2.1-or-later | Tools for managing Linux kernel modules |
kmscube | kmscube | git | MIT | Demo application to showcase 3D graphics using kms and gbm |
glibc | ldconfig | 2.37 | GPL-2.0-only & LGPL-2.1-only | GLIBC (GNU C Library) |
liba52 | liba52-0 | 0.7.4 | GPL-2.0-or-later | ATSC A/52 surround sound stream decoder |
libaio | libaio1 | 0.3.113 | LGPL-2.1-or-later | Asynchronous I/O library |
elfutils | libasm1 | 0.188 | LGPL-3.0-or-later | Utilities and libraries for handling compiled object files |
alsa-plugins | libasound-module-conf-pulse | 1.2.7.1 | LGPL-2.1-only & GPL-2.0-or-later | Alsa plugin for conf-pulse |
alsa-plugins | libasound-module-ctl-arcam-av | 1.2.7.1 | LGPL-2.1-only & GPL-2.0-or-later | Alsa plugin for ctl-arcam-av |
alsa-plugins | libasound-module-ctl-oss | 1.2.7.1 | LGPL-2.1-only & GPL-2.0-or-later | Alsa plugin for ctl-oss |
alsa-plugins | libasound-module-ctl-pulse | 1.2.7.1 | LGPL-2.1-only & GPL-2.0-or-later | Alsa plugin for ctl-pulse |
alsa-plugins | libasound-module-pcm-oss | 1.2.7.1 | LGPL-2.1-only & GPL-2.0-or-later | Alsa plugin for pcm-oss |
alsa-plugins | libasound-module-pcm-pulse | 1.2.7.1 | LGPL-2.1-only & GPL-2.0-or-later | Alsa plugin for pcm-pulse |
alsa-plugins | libasound-module-pcm-speex | 1.2.7.1 | LGPL-2.1-only & GPL-2.0-or-later | Alsa plugin for pcm-speex |
alsa-plugins | libasound-module-pcm-upmix | 1.2.7.1 | LGPL-2.1-only & GPL-2.0-or-later | Alsa plugin for pcm-upmix |
alsa-plugins | libasound-module-pcm-usb-stream | 1.2.7.1 | LGPL-2.1-only & GPL-2.0-or-later | Alsa plugin for pcm-usb-stream |
alsa-plugins | libasound-module-pcm-vdownmix | 1.2.7.1 | LGPL-2.1-only & GPL-2.0-or-later | Alsa plugin for pcm-vdownmix |
alsa-plugins | libasound-module-rate-samplerate | 1.2.7.1 | LGPL-2.1-only & GPL-2.0-or-later | Alsa plugin for rate-samplerate |
alsa-plugins | libasound-module-rate-speexrate | 1.2.7.1 | LGPL-2.1-only & GPL-2.0-or-later | Alsa plugin for rate-speexrate |
alsa-lib | libasound2 | 1.2.8 | LGPL-2.1-only & GPL-2.0-or-later | ALSA sound library |
libassuan | libassuan0 | 2.5.6 | LGPL-2.1-or-later | IPC library used by GnuPG and GPGME |
alsa-lib | libatopology2 | 1.2.8 | LGPL-2.1-only & GPL-2.0-or-later | ALSA sound library |
attr | libattr1 | 2.5.1 | LGPL-2.1-or-later | Utilities for manipulating filesystem extended attributes |
avahi | libavahi-client3 | 0.8 | LGPL-2.1-or-later | Avahi IPv4LL network address configuration daemon |
avahi | libavahi-common3 | 0.8 | LGPL-2.1-or-later | Avahi IPv4LL network address configuration daemon |
avahi | libavahi-core7 | 0.8 | LGPL-2.1-or-later | Avahi IPv4LL network address configuration daemon |
ffmpeg | libavcodec59 | 5.1.3 | LGPL-2.1-or-later | A complete, cross-platform solution to record, convert and stream audio and video. |
ffmpeg | libavfilter8 | 5.1.3 | LGPL-2.1-or-later | A complete, cross-platform solution to record, convert and stream audio and video. |
ffmpeg | libavformat59 | 5.1.3 | LGPL-2.1-or-later | A complete, cross-platform solution to record, convert and stream audio and video. |
ffmpeg | libavutil57 | 5.1.3 | LGPL-2.1-or-later | A complete, cross-platform solution to record, convert and stream audio and video. |
util-linux | libblkid1 | 2.38.1 | LGPL-2.1-or-later | util-linux libblkid |
boost | libboost-system1.81.0 | 1.81.0 | BSL-1.0 & MIT & Python-2.0 | Free peer-reviewed portable C++ source libraries |
bzip2 | libbz2-1 | 1.0.8 | bzip2-1.0.6 | Very high-quality data compression program |
glibc | libc6 | 2.37 | GPL-2.0-only & LGPL-2.1-only | GLIBC (GNU C Library) |
glibc | libc6-thread-db | 2.37 | GPL-2.0-only & LGPL-2.1-only | GLIBC (GNU C Library) |
cairo | libcairo-gobject2 | 1.16.0 | LGPL-2.1-only | The Cairo library GObject wrapper library |
cairo | libcairo2 | 1.16.0 | LGPL-2.1-only | The Cairo 2D vector graphics library |
libcamera | libcamera | 0.2.0 | GPL-2.0-or-later & LGPL-2.1-or-later | Linux libcamera framework |
libcamera | libcamera-gst | 0.2.0 | GPL-2.0-or-later & LGPL-2.1-or-later | Linux libcamera framework |
libcap | libcap | 2.67 | GPL-2.0-only | Library for getting/setting POSIX.1e capabilities |
libcap-ng | libcap-ng | 0.8.3 | GPL-2.0-or-later & LGPL-2.1-or-later | An alternate posix capabilities library |
e2fsprogs | libcom-err2 | 1.47.0 | GPL-2.0-only & LGPL-2.0-only & BSD-3-Clause & MIT | Ext2 Filesystem Utilities |
libxcrypt | libcrypt2 | 4.4.33 | LGPL-2.1-only | Extended cryptographic library (from glibc) |
openssl | libcrypto3 | 3.1.4 | Apache-2.0 | Secure Socket Layer |
curl | libcurl4 | 8.0.1 | curl | Command line tool and library for client-side URL transfers |
libdaemon | libdaemon0 | 0.14 | LGPL-2.1-or-later | Lightweight C library which eases the writing of UNIX daemons |
libdazzle | libdazzle | 3.44.0 | GPL-3.0-or-later | The libdazzle library is a companion library to GObject and Gtk+. |
dbus | libdbus-1-3 | 1.14.10 | GPL-2.0-or-later | D-Bus message bus |
libdrm | libdrm-tests | 2.4.115 | MIT | Userspace interface to the kernel DRM services |
libdrm | libdrm2 | 2.4.115 | MIT | Userspace interface to the kernel DRM services |
duktape | libduktape207 | 2.7.0 | MIT | Duktape embeddable Javascript engine |
elfutils | libdw1 | 0.188 | LGPL-3.0-or-later | Utilities and libraries for handling compiled object files |
e2fsprogs | libe2p2 | 1.47.0 | GPL-2.0-only & LGPL-2.0-only & BSD-3-Clause & MIT | Ext2 Filesystem Utilities |
elfutils | libelf1 | 0.188 | LGPL-3.0-or-later | Utilities and libraries for handling compiled object files |
libepoxy | libepoxy0 | 1.5.10 | MIT | OpenGL function pointer management library |
liberation-fonts | liberation-fonts | 2.1.5 | OFL-1.1 | Liberation(tm) Fonts |
libevdev | libevdev | 1.13.0 | MIT | Wrapper library for evdev devices |
libevent | libevent-2.1-7 | 2.1.12 | BSD-3-Clause & MIT | An asynchronous event notification library |
libevent | libevent-pthreads-2.1-7 | 2.1.12 | BSD-3-Clause & MIT | An asynchronous event notification library (pthreads) |
expat | libexpat1 | 2.5.0 | MIT | A stream-oriented XML parser library |
e2fsprogs | libext2fs2 | 1.47.0 | GPL-2.0-only & LGPL-2.0-only & BSD-3-Clause & MIT | Ext2 Filesystem Utilities |
faac | libfaac0 | 1.29.9.2 | LGPL-2.0-or-later | Freeware Advanced Audio Coder (MPEG2-AAC, MPEG4-AAC) |
util-linux | libfdisk1 | 2.38.1 | LGPL-2.1-or-later | util-linux libfdisk |
fdk-aac | libfdk-aac2 | 2.0.1 | Fraunhofer_FDK_AAC_Codec_Library_for_Android | FDK-AAC audio codec |
libffi | libffi8 | 3.4.4 | MIT | A portable foreign function interface library |
fftw | libfftwf | 3.3.10 | GPL-2.0-only | fftw version 3.3.10-r0 |
flac | libflac12 | 1.4.2 | GFDL-1.2 & GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause | Free Lossless Audio Codec |
fontconfig | libfontconfig1 | 2.14.2 | MIT & MIT & PD | Generic font configuration library |
ncurses | libformw5 | 6.4 | MIT | ncurses formw library |
freetype | libfreetype6 | 2.13.1 | GPL-2.0-or-later) & MIT | Freetype font rendering library |
fribidi | libfribidi0 | 1.0.13 | LGPL-2.1-or-later | Free Implementation of the Unicode Bidirectional Algorithm |
libgcc | libgcc1 | 12.3.0 | GPL-3.0-with-GCC-exception | GNU cc and gcc C compilers |
libgcrypt | libgcrypt | 1.10.2 | LGPL-2.1-or-later | General purpose cryptographic library based on the code from GnuPG |
gdk-pixbuf | libgdk-pixbuf-2.0-0 | 2.42.10 | LGPL-2.1-or-later | Image loading library for GTK+ |
gdk-pixbuf | libgdk-pixbuf-2.0-loader-gif | 2.42.10 | LGPL-2.1-or-later | GDK pixbuf loader for gif |
gdk-pixbuf | libgdk-pixbuf-2.0-loader-xpm | 2.42.10 | LGPL-2.1-or-later | GDK pixbuf loader for xpm |
glib-2.0 | libglib-2.0-0 | 2.74.6 | LGPL-2.1-or-later & BSD-3-Clause & PD | A general-purpose utility library |
glib-2.0 | libglib-2.0-utils | 2.74.6 | LGPL-2.1-or-later & BSD-3-Clause & PD | A general-purpose utility library |
gmp | libgmp10 | 6.2.1 | LGPL-3.0-or-later | GNU multiprecision arithmetic library |
gnutls | libgnutls30 | 3.8.0 | LGPL-2.1-or-later | GNU Transport Layer Security Library |
libgpg-error | libgpg-error | 1.46 | GPL-2.0-or-later & LGPL-2.1-or-later | Small library that defines common error values for all GnuPG components |
libgpiod | libgpiod-tools | 2.0 | GPL-2.0-or-later & LGPL-2.1-or-later & CC-BY-SA-4.0 | C library and tools for interacting with the linux GPIO character device |
libgpiod | libgpiod3 | 2.0 | GPL-2.0-or-later & LGPL-2.1-or-later & CC-BY-SA-4.0 | C library and tools for interacting with the linux GPIO character device |
gstreamer1.0-plugins-bad | libgstadaptivedemux-1.0-0 | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 gstadaptivedemux-1.0 library |
gstreamer1.0-plugins-base | libgstallocators-1.0-0 | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 gstallocators-1.0 library |
gstreamer1.0-plugins-base | libgstapp-1.0-0 | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 gstapp-1.0 library |
gstreamer1.0-plugins-base | libgstaudio-1.0-0 | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 gstaudio-1.0 library |
gstreamer1.0-plugins-bad | libgstbadaudio-1.0-0 | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 gstbadaudio-1.0 library |
gstreamer1.0-plugins-bad | libgstbasecamerabinsrc-1.0-0 | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 gstbasecamerabinsrc-1.0 library |
gstreamer1.0-plugins-bad | libgstcodecparsers-1.0-0 | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 gstcodecparsers-1.0 library |
gstreamer1.0-plugins-bad | libgstcodecs-1.0-0 | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 gstcodecs-1.0 library |
gstreamer1.0-plugins-bad | libgstcuda-1.0-0 | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 gstcuda-1.0 library |
gstreamer1.0-plugins-base | libgstfft-1.0-0 | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 gstfft-1.0 library |
gstreamer1.0-plugins-base | libgstgl-1.0-0 | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 gstgl-1.0 library |
gstreamer1.0-plugins-bad | libgstinsertbin-1.0-0 | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 gstinsertbin-1.0 library |
gstreamer1.0-plugins-bad | libgstisoff-1.0-0 | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 gstisoff-1.0 library |
gstreamer1.0-plugins-bad | libgstmpegts-1.0-0 | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 gstmpegts-1.0 library |
gstreamer1.0-plugins-base | libgstpbutils-1.0-0 | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 gstpbutils-1.0 library |
gstreamer1.0-plugins-bad | libgstphotography-1.0-0 | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 gstphotography-1.0 library |
gstreamer1.0-plugins-bad | libgstplay-1.0-0 | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 gstplay-1.0 library |
gstreamer1.0-plugins-bad | libgstplayer-1.0-0 | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 gstplayer-1.0 library |
gstreamer1.0-plugins-base | libgstriff-1.0-0 | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 gstriff-1.0 library |
gstreamer1.0-plugins-base | libgstrtp-1.0-0 | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 gstrtp-1.0 library |
gstreamer1.0-plugins-base | libgstrtsp-1.0-0 | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 gstrtsp-1.0 library |
gstreamer1.0-rtsp-server | libgstrtspserver-1.0-0 | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 gstrtspserver-1.0 library |
gstreamer1.0-plugins-bad | libgstsctp-1.0-0 | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 gstsctp-1.0 library |
gstreamer1.0-plugins-base | libgstsdp-1.0-0 | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 gstsdp-1.0 library |
gstreamer1.0-plugins-base | libgsttag-1.0-0 | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 gsttag-1.0 library |
gstreamer1.0-plugins-bad | libgsttranscoder-1.0-0 | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 gsttranscoder-1.0 library |
gstreamer1.0-plugins-bad | libgsturidownloader-1.0-0 | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 gsturidownloader-1.0 library |
gstreamer1.0-plugins-base | libgstvideo-1.0-0 | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 gstvideo-1.0 library |
gstreamer1.0-plugins-bad | libgstvulkan-1.0-0 | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 gstvulkan-1.0 library |
gstreamer1.0-plugins-bad | libgstwayland-1.0-0 | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 gstwayland-1.0 library |
gstreamer1.0-plugins-bad | libgstwebrtc-1.0-0 | 1.22.6 | LGPL-2.1-or-later | GStreamer 1.0 gstwebrtc-1.0 library |
gtk+3 | libgtk-3.0 | 3.24.36 | LGPL-2.0-only & LGPL-2.0-or-later & LGPL-2.1-or-later | Multi-platform toolkit for creating GUIs |
libgudev | libgudev-1.0-0 | 237 | LGPL-2.1-only | GObject wrapper for libudev |
harfbuzz | libharfbuzz0 | 7.1.0 | MIT | Text shaping library |
icu | libicudata72 | 72-1 | ICU | International Component for Unicode libraries |
icu | libicuuc72 | 72-1 | ICU | International Component for Unicode libraries |
libidn2 | libidn2-0 | 2.3.4 | LGPL-3.0-only) & Unicode-DFS-2016 | Internationalized Domain Name support library |
libiio | libiio-iiod | 0.23 | LGPL-2.1-or-later | Library for interfacing with IIO devices |
libiio | libiio-tests | 0.23 | LGPL-2.1-or-later | Library for interfacing with IIO devices |
libiio | libiio0 | 0.23 | LGPL-2.1-or-later | Library for interfacing with IIO devices |
libinput | libinput10 | 1.22.1 | MIT | Library to handle input devices in Wayland compositors |
jack | libjack | 1.19.22 | GPL-2.0-only & LGPL-2.1-only | jack version 1.19.22-r0 |
libjpeg-turbo | libjpeg62 | 2.1.5.1 | BSD-3-Clause | Hardware accelerated JPEG compression/decompression library |
json-c | libjson-c5 | 0.16 | MIT | C bindings for apps which will manipulate JSON data |
json-glib | libjson-glib-1.0-0 | 1.6.6 | LGPL-2.1-only | JSON-GLib implements a full JSON parser using GLib and GObject |
kmod | libkmod2 | 30 | LGPL-2.1-or-later | Tools for managing Linux kernel modules |
libksba | libksba8 | 1.6.4 | LGPL-3.0-or-later | Easy API to create and parse X.509 and CMS related objects |
xz | liblzma5 | 5.4.4 | PD | Utilities for managing LZMA compressed files |
lzo | liblzo2-2 | 2.10 | GPL-2.0-or-later | Lossless data compression library |
libmd | libmd0 | 1.0.4 | BSD-3-Clause & BSD-2-Clause | Message Digest functions from BSD systems |
ncurses | libmenuw5 | 6.4 | MIT | ncurses menuw library |
libmnl | libmnl0 | 1.0.5 | LGPL-2.1-or-later | Minimalistic user-space Netlink utility library |
util-linux | libmount1 | 2.38.1 | LGPL-2.1-or-later | util-linux libmount |
lame | libmp3lame0 | 3.100 | LGPL-2.0-or-later | High quality MP3 audio encoder |
mpeg2dec | libmpeg2-0 | 0.5.1 | GPL-2.0-or-later | Library and test program for decoding MPEG-2 and MPEG-1 video streams |
ncurses | libncurses5 | 6.4 | MIT | ncurses ncurses library |
ncurses | libncursesw5 | 6.4 | MIT | ncurses ncursesw library |
ne10 | libne10-10 | 1.2.1gitr+AUTOINC+18c4c982a5 | BSD-3-Clause | ne10 version 1.2.1gitr+AUTOINC+18c4c982a5-r0 |
nghttp2 | libnghttp2-14 | 1.52.0 | MIT | HTTP/2 C Library and tools |
libnl | libnl-3-200 | 3.7.0 | LGPL-2.1-only | A library for applications dealing with netlink sockets |
libnl | libnl-genl-3-200 | 3.7.0 | LGPL-2.1-only | A library for applications dealing with netlink sockets |
libnl | libnl-route-3-200 | 3.7.0 | LGPL-2.1-only | A library for applications dealing with netlink sockets |
npth | libnpth0 | 1.6 | LGPL-2.0-or-later | New GNU Portable Threads library |
libnss-mdns | libnss-mdns | 0.15.1 | LGPL-2.1-or-later | Name Service Switch module for Multicast DNS (zeroconf) name resolution |
systemd | libnss-myhostname2 | 253.1 | GPL-2.0-only & LGPL-2.1-only | Systemd nss-myhostname library |
libogg | libogg0 | 1.3.5 | BSD-3-Clause | Ogg bitstream and framing libary |
libopencsd | libopencsd | 1.4.0 | BSD-3-Clause | OpenCSD - An open source CoreSight(tm) Trace Decode library |
libopus | libopus0 | 1.3.1 | BSD-3-Clause | Opus Audio Codec |
orc | liborc-0.4-0 | 0.4.33 | BSD-2-Clause & BSD-3-Clause | ORC orc-0.4 library |
libpam | libpam | 1.5.2 | BSD-3-Clause | Linux-PAM (Pluggable Authentication Modules) |
libpam | libpam-runtime | 1.5.2 | BSD-3-Clause | Linux-PAM (Pluggable Authentication Modules) |
ncurses | libpanel5 | 6.4 | MIT | ncurses panel library |
ncurses | libpanelw5 | 6.4 | MIT | ncurses panelw library |
libpcap | libpcap1 | 1.10.4 | BSD-3-Clause | Interface for user-level network packet capture |
pciutils | libpci3 | 3.9.0 | GPL-2.0-or-later | PCI utilities |
libpcre | libpcre1 | 8.45 | BSD-3-Clause | Perl Compatible Regular Expressions |
libpcre2 | libpcre2 | 10.42 | BSD-3-Clause | Perl Compatible Regular Expressions version 2 |
pipewire | libpipewire-0.3-0 | 1.0.0 | MIT & LGPL-2.1-or-later & GPL-2.0-only | Multimedia processing server for Linux |
pixman | libpixman-1-0 | 0.42.2 | MIT & PD | Pixman: Pixel Manipulation library |
libpng | libpng16-16 | 1.6.39 | Libpng | PNG image format decoding library |
popt | libpopt0 | 1.19 | MIT | Library for parsing command line options |
procps | libproc2-0 | 4.0.3 | GPL-2.0-or-later & LGPL-2.0-or-later | System and process monitoring utilities |
libpsl | libpsl5 | 0.21.2 | MIT | Public Suffix List library |
pulseaudio | libpulse-simple0 | 16.1 | LGPL-2.1-or-later & MIT & BSD-3-Clause | Sound server for Linux and Unix-like operating systems |
pulseaudio | libpulse0 | 16.1 | LGPL-2.1-or-later & MIT & BSD-3-Clause | Sound server for Linux and Unix-like operating systems |
pulseaudio | libpulsecommon | 16.1 | LGPL-2.1-or-later & MIT & BSD-3-Clause | Sound server for Linux and Unix-like operating systems |
python3 | libpython3.11-1.0 | 3.11.5 | PSF-2.0 | The Python Programming Language |
qrencode | libqrencode4 | 4.1.1 | LGPL-2.1-only | C library for encoding data in a QR Code symbol |
readline | libreadline8 | 8.2 | GPL-3.0-or-later | Library for editing typed command lines |
librsvg | librsvg-2-2 | 2.54.6 | LGPL-2.1-or-later | Library for rendering SVG files |
libsamplerate0 | libsamplerate0 | 0.2.2 | BSD-2-Clause | Audio Sample Rate Conversion library |
sbc | libsbc1 | 2.0 | LGPL-2.1-or-later | SBC Audio Codec |
libsdl2 | libsdl2-2.0-0 | 2.26.5 | Zlib & BSD-2-Clause | Simple DirectMedia Layer |
lmsensors | libsensors5 | 3.6.0 | GPL-2.0-or-later & LGPL-2.1-or-later | Hardware health monitoring applications |
libserialport | libserialport0 | 0.1.1 | LGPL-3.0-or-later | libserialport version 0.1.1-r0 |
util-linux | libsmartcols1 | 2.38.1 | LGPL-2.1-or-later | util-linux libsmartcols |
libsndfile1 | libsndfile1 | 1.2.2 | LGPL-2.1-only | Audio format Conversion library |
libsoup | libsoup | 3.2.2 | LGPL-2.0-only | An HTTP library implementation in C |
speex | libspeex1 | 1.2.1 | BSD-3-Clause | Speech Audio Codec |
speexdsp | libspeexdsp1 | 1.2.1 | BSD-3-Clause | A patent-free DSP library |
sqlite3 | libsqlite3-0 | 3.41.0 | PD | Embeddable SQL database engine |
e2fsprogs | libss2 | 1.47.0 | GPL-2.0-only & LGPL-2.0-only & BSD-3-Clause & MIT | Ext2 Filesystem Utilities |
openssl | libssl3 | 3.1.4 | Apache-2.0 | Secure Socket Layer |
gcc-runtime | libstdc++6 | 12.3.0 | GPL-3.0-with-GCC-exception | GNU standard C++ library |
ffmpeg | libswresample4 | 5.1.3 | LGPL-2.1-or-later | A complete, cross-platform solution to record, convert and stream audio and video. |
ffmpeg | libswscale6 | 5.1.3 | LGPL-2.1-or-later | A complete, cross-platform solution to record, convert and stream audio and video. |
sysfsutils | libsysfs2 | 2.1.0 | LGPL-2.1-only | Tools for working with sysfs |
systemd | libsystemd-shared | 253.1 | GPL-2.0-only & LGPL-2.1-only | Systemd shared library |
systemd | libsystemd0 | 253.1 | GPL-2.0-only & LGPL-2.1-only | Systemd systemd library |
taglib | libtag1 | 1.13.1 | MPL-1.1 | Library for reading and editing the meta-data of popular audio formats |
libtheora | libtheora | 1.1.1 | BSD-3-Clause | Theora Video Codec |
tiff | libtiff6 | 4.5.1 | BSD-2-Clause | Provides support for the Tag Image File Format (TIFF) |
ncurses | libtinfo5 | 6.4 | MIT | ncurses tinfo library |
libtirpc | libtirpc3 | 1.3.3 | BSD-3-Clause | Transport-Independent RPC library |
systemd | libudev1 | 253.1 | GPL-2.0-only & LGPL-2.1-only | Systemd udev library |
libunistring | libunistring5 | 1.1 | GPL-2.0-or-later | Library for manipulating C and Unicode strings |
libunwind | libunwind | 1.6.2 | MIT | Library for obtaining the call-chain of a program |
libusb1 | libusb-1.0-0 | 1.0.26 | LGPL-2.1-or-later | Userspace library to access USB (version 1.0) |
util-linux-libuuid | libuuid1 | 2.38.1 | BSD-3-Clause | A suite of basic system administration utilities |
libuv | libuv1 | 1.44.2 | MIT | A multi-platform support library with a focus on asynchronous I/O |
v4l-utils | libv4l | 1.23.0+gitAUTOINC+9431e4b26b | GPL-2.0-only & LGPL-2.1-only | v4l2 and IR applications |
libvorbis | libvorbis | 1.3.7 | BSD-3-Clause | Ogg Vorbis Audio Codec |
vulkan-loader | libvulkan1 | 1.3.239.0 | Apache-2.0 | 3D graphics and compute API common loader |
libwebp | libwebp | 1.3.1 | BSD-3-Clause | WebP is an image format designed for the Web |
webrtc-audio-processing | libwebrtc-audio-processing1 | 0.3.1 | BSD-3-Clause | webrtc-audio-processing version 0.3.1-r0 |
weston | libweston-11-0 | 11.0.1 | MIT | Helper library for implementing 'wayland window managers'. |
wireplumber | libwireplumber-0.4-0 | 0.4.17 | MIT | Session / policy manager implementation for PipeWire |
tcp-wrappers | libwrap0 | 7.6 | BSD-1-Clause | Security tool that is a wrapper for TCP daemons |
libx11-compose-data | libx11-compose-data | 1.8.4 | MIT & BSD-1-Clause & HPND & HPND-sell-variant & ISC | Xlib: Compose data files for libx11 |
libxkbcommon | libxkbcommon0 | 1.5.0 | MIT & MIT | libxkbcommon library |
libxml2 | libxml2 | 2.10.4 | MIT | XML C Parser Library and Toolkit |
libyaml | libyaml-0-2 | 0.2.5 | MIT | LibYAML is a YAML 1.1 parser and emitter written in C. |
zlib | libz1 | 1.2.13 | Zlib | Zlib Compression Library |
zstd | libzstd1 | 1.5.4 | BSD-3-Clause & GPL-2.0-only | Zstandard - Fast real-time compression algorithm |
linux-firmware | linux-firmware-bcm43439 | 20230804 | Firmware-Abilis & Firmware-adsp_sst & Firmware-agere & Firmware-amdgpu & Firmware-amd-ucode & Firmware-amlogic_vdec & Firmware-atheros_firmware & Firmware-atmel & Firmware-broadcom_bcm43xx & Firmware-ca0132 & Firmware-cavium & Firmware-chelsio_firmware & Firmware-cw1200 & Firmware-cypress & Firmware-dib0700 & Firmware-e100 & Firmware-ene_firmware & Firmware-fw_sst_0f28 & Firmware-go7007 & Firmware-GPLv2 & Firmware-hfi1_firmware & Firmware-i915 & Firmware-ibt_firmware & Firmware-ice & Firmware-it913x & Firmware-iwlwifi_firmware & Firmware-IntcSST2 & Firmware-kaweth & Firmware-linaro & Firmware-Lontium & Firmware-Marvell & Firmware-moxa & Firmware-myri10ge_firmware & Firmware-netronome & Firmware-nvidia & Firmware-nxp & Firmware-OLPC & Firmware-ath9k-htc & Firmware-phanfw & Firmware-qat & Firmware-qcom & Firmware-qcom-yamato & Firmware-qla1280 & Firmware-qla2xxx & Firmware-qualcommAthos_ar3k & Firmware-qualcommAthos_ath10k & Firmware-r8a779x_usb3 & Firmware-radeon & Firmware-ralink_a_mediatek_company_firmware & Firmware-ralink-firmware & Firmware-rtlwifi_firmware & Firmware-imx-sdma_firmware & Firmware-siano & Firmware-ti-connectivity & Firmware-ti-keystone & Firmware-ueagle-atm4-firmware & Firmware-via_vt6656 & Firmware-wl1251 & Firmware-xc4000 & Firmware-xc5000 & Firmware-xc5000c & WHENCE | Firmware files for use with Linux kernel |
linux-firmware-bluetooth-bcm4343 | linux-firmware-bluetooth-bcm4343 | 3.1 | Firmware-cypress-bcm4343 | Bluetooth firmware for BCM4343 |
linux-firmware-bluetooth-bcm4343 | linux-firmware-bluetooth-bcm4343-cypress-license | 3.1 | Firmware-cypress-bcm4343 | Bluetooth firmware for BCM4343 |
linux-firmware | linux-firmware-rtl8168 | 20230804 | WHENCE | Firmware files for use with Linux kernel |
linux-firmware | linux-firmware-whence-license | 20230804 | WHENCE | Firmware files for use with Linux kernel |
lmsensors-config | lmsensors-config-libsensors | 1.0 | MIT | lm_sensors configuration files |
lmsensors | lmsensors-sensors | 3.6.0 | GPL-2.0-or-later & LGPL-2.1-or-later | Hardware health monitoring applications |
lrzsz | lrzsz | 0.12.20 | GPL-2.0-or-later | Tools for zmodem/xmodem/ymodem file transfer |
lz4 | lz4 | 1.9.4 | GPL-2.0-only | Extremely Fast Compression algorithm |
m33projects-stm32mp2 | m33projects-stm32mp2 | 1.0.0 | Apache-2.0 & MIT & BSD-3-Clause | STM32MP2 Firmware examples for CM33 |
v4l-utils | media-ctl | 1.23.0+gitAUTOINC+9431e4b26b | GPL-2.0-only & LGPL-2.1-only | v4l2 and IR applications |
memtester | memtester | 4.6.0 | GPL-2.0-only | Utility to test for faulty memory subsystem |
minicom | minicom | 2.8 | GPL-2.0-or-later | Text-based modem control and terminal emulation program |
mmc-utils | mmc-utils | 0.1+gitAUTOINC+d4c2910981 | GPL-2.0-only | Userspace tools for MMC/SD devices |
mpg123 | mpg123 | 1.31.3 | LGPL-2.1-only | Audio decoder for MPEG-1 Layer 1/2/3 |
mtd-utils | mtd-utils | 2.1.5 | GPL-2.0-or-later | Tools for managing memory technology devices |
mtd-utils | mtd-utils-ubifs | 2.1.5 | GPL-2.0-or-later | Tools for managing memory technology devices |
mtdev | mtdev | 1.1.6 | MIT | Multitouch Protocol Translation Library |
ncurses | ncurses-terminfo-base | 6.4 | MIT | The New Curses library |
netbase | netbase | 6.4 | GPL-2.0-only | Basic TCP/IP networking support |
netdata | netdata | 1.36.1 | GPL-3.0-only | Real-time performance monitoring |
nettle | nettle | 3.8.1 | GPL-2.0-or-later | A low level cryptographic library |
ntp | ntp | 4.2.8p15 | NTP | Network Time Protocol daemon and utilities |
ntp | ntp-tickadj | 4.2.8p15 | NTP | Network Time Protocol daemon and utilities |
numactl | numactl | 2.0.16 | GPL-2.0-only & LGPL-2.1-only | Development package for building Applications that use numa |
openssh | openssh-sftp | 9.3p2 | BSD-2-Clause & BSD-3-Clause & ISC & MIT | A suite of security-related network utilities based on the SSH protocol including the ssh client and sshd server |
openssh | openssh-sftp-server | 9.3p2 | BSD-2-Clause & BSD-3-Clause & ISC & MIT | A suite of security-related network utilities based on the SSH protocol including the ssh client and sshd server |
openssl | openssl | 3.1.4 | Apache-2.0 | Secure Socket Layer |
openssl | openssl-bin | 3.1.4 | Apache-2.0 | Secure Socket Layer |
openssl | openssl-conf | 3.1.4 | Apache-2.0 | Secure Socket Layer |
openssl | openssl-engines | 3.1.4 | Apache-2.0 | Secure Socket Layer |
openssl | openssl-ossl-module-legacy | 3.1.4 | Apache-2.0 | Secure Socket Layer |
optee-client | optee-client | 3.19.0+gitAUTOINC+140bf46304 | BSD-2-Clause | OPTEE Client |
optee-stm32mp-addons | optee-stm32mp-addons | 3.16.0.AUTOINC+3c3cb0ed91 | BSD-3-Clause | OP-TEE STM32MP examples |
optee-test | optee-test | 3.19.0+gitAUTOINC+ab9863cc18 | BSD-2-Clause & GPL-2.0-only | OP-TEE sanity testsuite |
os-release | os-release | 1.0 | MIT | Operating system identification |
libpam | pam-plugin-deny | 1.5.2 | BSD-3-Clause | PAM plugin for -deny |
libpam | pam-plugin-env | 1.5.2 | BSD-3-Clause | PAM plugin for -env |
libpam | pam-plugin-faildelay | 1.5.2 | BSD-3-Clause | PAM plugin for -faildelay |
libpam | pam-plugin-group | 1.5.2 | BSD-3-Clause | PAM plugin for -group |
libpam | pam-plugin-keyinit | 1.5.2 | BSD-3-Clause | PAM plugin for -keyinit |
libpam | pam-plugin-lastlog | 1.5.2 | BSD-3-Clause | PAM plugin for -lastlog |
libpam | pam-plugin-limits | 1.5.2 | BSD-3-Clause | PAM plugin for -limits |
libpam | pam-plugin-loginuid | 1.5.2 | BSD-3-Clause | PAM plugin for -loginuid |
libpam | pam-plugin-mail | 1.5.2 | BSD-3-Clause | PAM plugin for -mail |
libpam | pam-plugin-motd | 1.5.2 | BSD-3-Clause | PAM plugin for -motd |
libpam | pam-plugin-namespace | 1.5.2 | BSD-3-Clause | PAM plugin for -namespace |
libpam | pam-plugin-nologin | 1.5.2 | BSD-3-Clause | PAM plugin for -nologin |
libpam | pam-plugin-permit | 1.5.2 | BSD-3-Clause | PAM plugin for -permit |
libpam | pam-plugin-rootok | 1.5.2 | BSD-3-Clause | PAM plugin for -rootok |
libpam | pam-plugin-securetty | 1.5.2 | BSD-3-Clause | PAM plugin for -securetty |
libpam | pam-plugin-shells | 1.5.2 | BSD-3-Clause | PAM plugin for -shells |
libpam | pam-plugin-unix | 1.5.2 | BSD-3-Clause | PAM plugin for -unix |
libpam | pam-plugin-warn | 1.5.2 | BSD-3-Clause | PAM plugin for -warn |
pango | pango | 1.50.14 | LGPL-2.0-or-later | Framework for layout and rendering of internationalized text |
pciutils | pciutils | 3.9.0 | GPL-2.0-or-later | PCI utilities |
pciutils | pciutils-ids | 3.9.0 | GPL-2.0-or-later | PCI utilities - device ID database |
perf | perf | 1.0 | GPL-2.0-only | Performance analysis tools for Linux |
perl | perl | 5.36.0 | GPL-1.0-or-later | Perl scripting language |
perl | perl-module-config-heavy | 5.36.0 | GPL-1.0-or-later | perl module config-heavy |
pinentry | pinentry | 1.2.1 | GPL-2.0-only | Collection of simple PIN or passphrase entry dialogs |
pipewire | pipewire | 1.0.0 | MIT & LGPL-2.1-or-later & GPL-2.0-only | Multimedia processing server for Linux |
pipewire | pipewire-alsa | 1.0.0 | MIT & LGPL-2.1-or-later & GPL-2.0-only | Multimedia processing server for Linux |
pipewire | pipewire-alsa-card-profile | 1.0.0 | MIT & LGPL-2.1-or-later & GPL-2.0-only | Multimedia processing server for Linux |
pipewire | pipewire-modules-access | 1.0.0 | MIT & LGPL-2.1-or-later & GPL-2.0-only | PipeWire access module |
pipewire | pipewire-modules-adapter | 1.0.0 | MIT & LGPL-2.1-or-later & GPL-2.0-only | PipeWire adapter module |
pipewire | pipewire-modules-avb | 1.0.0 | MIT & LGPL-2.1-or-later & GPL-2.0-only | PipeWire avb module |
pipewire | pipewire-modules-client-device | 1.0.0 | MIT & LGPL-2.1-or-later & GPL-2.0-only | PipeWire client-device module |
pipewire | pipewire-modules-client-node | 1.0.0 | MIT & LGPL-2.1-or-later & GPL-2.0-only | PipeWire client-node module |
pipewire | pipewire-modules-combine-stream | 1.0.0 | MIT & LGPL-2.1-or-later & GPL-2.0-only | PipeWire combine-stream module |
pipewire | pipewire-modules-echo-cancel | 1.0.0 | MIT & LGPL-2.1-or-later & GPL-2.0-only | PipeWire echo-cancel module |
pipewire | pipewire-modules-fallback-sink | 1.0.0 | MIT & LGPL-2.1-or-later & GPL-2.0-only | PipeWire fallback-sink module |
pipewire | pipewire-modules-filter-chain | 1.0.0 | MIT & LGPL-2.1-or-later & GPL-2.0-only | PipeWire filter-chain module |
pipewire | pipewire-modules-jack-tunnel | 1.0.0 | MIT & LGPL-2.1-or-later & GPL-2.0-only | PipeWire jack-tunnel module |
pipewire | pipewire-modules-jackdbus-detect | 1.0.0 | MIT & LGPL-2.1-or-later & GPL-2.0-only | PipeWire jackdbus-detect module |
pipewire | pipewire-modules-link-factory | 1.0.0 | MIT & LGPL-2.1-or-later & GPL-2.0-only | PipeWire link-factory module |
pipewire | pipewire-modules-loopback | 1.0.0 | MIT & LGPL-2.1-or-later & GPL-2.0-only | PipeWire loopback module |
pipewire | pipewire-modules-metadata | 1.0.0 | MIT & LGPL-2.1-or-later & GPL-2.0-only | PipeWire metadata module |
pipewire | pipewire-modules-netjack2-driver | 1.0.0 | MIT & LGPL-2.1-or-later & GPL-2.0-only | PipeWire netjack2-driver module |
pipewire | pipewire-modules-netjack2-manager | 1.0.0 | MIT & LGPL-2.1-or-later & GPL-2.0-only | PipeWire netjack2-manager module |
pipewire | pipewire-modules-pipe-tunnel | 1.0.0 | MIT & LGPL-2.1-or-later & GPL-2.0-only | PipeWire pipe-tunnel module |
pipewire | pipewire-modules-portal | 1.0.0 | MIT & LGPL-2.1-or-later & GPL-2.0-only | PipeWire portal module |
pipewire | pipewire-modules-profiler | 1.0.0 | MIT & LGPL-2.1-or-later & GPL-2.0-only | PipeWire profiler module |
pipewire | pipewire-modules-protocol-native | 1.0.0 | MIT & LGPL-2.1-or-later & GPL-2.0-only | PipeWire protocol-native module |
pipewire | pipewire-modules-protocol-pulse | 1.0.0 | MIT & LGPL-2.1-or-later & GPL-2.0-only | PipeWire protocol-pulse module |
pipewire | pipewire-modules-protocol-simple | 1.0.0 | MIT & LGPL-2.1-or-later & GPL-2.0-only | PipeWire protocol-simple module |
pipewire | pipewire-modules-pulse-tunnel | 1.0.0 | MIT & LGPL-2.1-or-later & GPL-2.0-only | PipeWire pulse-tunnel module |
pipewire | pipewire-modules-raop-discover | 1.0.0 | MIT & LGPL-2.1-or-later & GPL-2.0-only | PipeWire raop-discover module |
pipewire | pipewire-modules-raop-sink | 1.0.0 | MIT & LGPL-2.1-or-later & GPL-2.0-only | PipeWire raop-sink module |
pipewire | pipewire-modules-rt | 1.0.0 | MIT & LGPL-2.1-or-later & GPL-2.0-only | PipeWire rt module |
pipewire | pipewire-modules-rtp-sap | 1.0.0 | MIT & LGPL-2.1-or-later & GPL-2.0-only | PipeWire rtp-sap module |
pipewire | pipewire-modules-rtp-session | 1.0.0 | MIT & LGPL-2.1-or-later & GPL-2.0-only | PipeWire rtp-session module |
pipewire | pipewire-modules-rtp-sink | 1.0.0 | MIT & LGPL-2.1-or-later & GPL-2.0-only | PipeWire rtp-sink module |
pipewire | pipewire-modules-rtp-source | 1.0.0 | MIT & LGPL-2.1-or-later & GPL-2.0-only | PipeWire rtp-source module |
pipewire | pipewire-modules-session-manager | 1.0.0 | MIT & LGPL-2.1-or-later & GPL-2.0-only | PipeWire session-manager module |
pipewire | pipewire-modules-spa-device | 1.0.0 | MIT & LGPL-2.1-or-later & GPL-2.0-only | PipeWire spa-device module |
pipewire | pipewire-modules-spa-device-factory | 1.0.0 | MIT & LGPL-2.1-or-later & GPL-2.0-only | PipeWire spa-device-factory module |
pipewire | pipewire-modules-spa-node | 1.0.0 | MIT & LGPL-2.1-or-later & GPL-2.0-only | PipeWire spa-node module |
pipewire | pipewire-modules-spa-node-factory | 1.0.0 | MIT & LGPL-2.1-or-later & GPL-2.0-only | PipeWire spa-node-factory module |
pipewire | pipewire-modules-vban-recv | 1.0.0 | MIT & LGPL-2.1-or-later & GPL-2.0-only | PipeWire vban-recv module |
pipewire | pipewire-modules-vban-send | 1.0.0 | MIT & LGPL-2.1-or-later & GPL-2.0-only | PipeWire vban-send module |
pipewire | pipewire-modules-zeroconf-discover | 1.0.0 | MIT & LGPL-2.1-or-later & GPL-2.0-only | PipeWire zeroconf-discover module |
pipewire | pipewire-pulse | 1.0.0 | MIT & LGPL-2.1-or-later & GPL-2.0-only | Multimedia processing server for Linux |
pipewire | pipewire-spa-plugins-aec-null | 1.0.0 | MIT & LGPL-2.1-or-later & GPL-2.0-only | PipeWire SPA plugin for aec-null |
pipewire | pipewire-spa-plugins-aec-webrtc | 1.0.0 | MIT & LGPL-2.1-or-later & GPL-2.0-only | PipeWire SPA plugin for aec-webrtc |
pipewire | pipewire-spa-plugins-alsa | 1.0.0 | MIT & LGPL-2.1-or-later & GPL-2.0-only | PipeWire SPA plugin for alsa |
pipewire | pipewire-spa-plugins-audioconvert | 1.0.0 | MIT & LGPL-2.1-or-later & GPL-2.0-only | PipeWire SPA plugin for audioconvert |
pipewire | pipewire-spa-plugins-audiomixer | 1.0.0 | MIT & LGPL-2.1-or-later & GPL-2.0-only | PipeWire SPA plugin for audiomixer |
pipewire | pipewire-spa-plugins-audiotestsrc | 1.0.0 | MIT & LGPL-2.1-or-later & GPL-2.0-only | PipeWire SPA plugin for audiotestsrc |
pipewire | pipewire-spa-plugins-avb | 1.0.0 | MIT & LGPL-2.1-or-later & GPL-2.0-only | PipeWire SPA plugin for avb |
pipewire | pipewire-spa-plugins-bluez5 | 1.0.0 | MIT & LGPL-2.1-or-later & GPL-2.0-only | PipeWire SPA plugin for bluez5 |
pipewire | pipewire-spa-plugins-codec-bluez5-aac | 1.0.0 | MIT & LGPL-2.1-or-later & GPL-2.0-only | PipeWire SPA plugin for codec-bluez5-aac |
pipewire | pipewire-spa-plugins-codec-bluez5-faststream | 1.0.0 | MIT & LGPL-2.1-or-later & GPL-2.0-only | PipeWire SPA plugin for codec-bluez5-faststream |
pipewire | pipewire-spa-plugins-codec-bluez5-opus | 1.0.0 | MIT & LGPL-2.1-or-later & GPL-2.0-only | PipeWire SPA plugin for codec-bluez5-opus |
pipewire | pipewire-spa-plugins-codec-bluez5-sbc | 1.0.0 | MIT & LGPL-2.1-or-later & GPL-2.0-only | PipeWire SPA plugin for codec-bluez5-sbc |
pipewire | pipewire-spa-plugins-control | 1.0.0 | MIT & LGPL-2.1-or-later & GPL-2.0-only | PipeWire SPA plugin for control |
pipewire | pipewire-spa-plugins-dbus | 1.0.0 | MIT & LGPL-2.1-or-later & GPL-2.0-only | PipeWire SPA plugin for dbus |
pipewire | pipewire-spa-plugins-ffmpeg | 1.0.0 | MIT & LGPL-2.1-or-later & GPL-2.0-only | PipeWire SPA plugin for ffmpeg |
pipewire | pipewire-spa-plugins-jack | 1.0.0 | MIT & LGPL-2.1-or-later & GPL-2.0-only | PipeWire SPA plugin for jack |
pipewire | pipewire-spa-plugins-journal | 1.0.0 | MIT & LGPL-2.1-or-later & GPL-2.0-only | PipeWire SPA plugin for journal |
pipewire | pipewire-spa-plugins-libcamera | 1.0.0 | MIT & LGPL-2.1-or-later & GPL-2.0-only | PipeWire SPA plugin for libcamera |
pipewire | pipewire-spa-plugins-support | 1.0.0 | MIT & LGPL-2.1-or-later & GPL-2.0-only | PipeWire SPA plugin for support |
pipewire | pipewire-spa-plugins-v4l2 | 1.0.0 | MIT & LGPL-2.1-or-later & GPL-2.0-only | PipeWire SPA plugin for v4l2 |
pipewire | pipewire-spa-plugins-videoconvert | 1.0.0 | MIT & LGPL-2.1-or-later & GPL-2.0-only | PipeWire SPA plugin for videoconvert |
pipewire | pipewire-spa-plugins-videotestsrc | 1.0.0 | MIT & LGPL-2.1-or-later & GPL-2.0-only | PipeWire SPA plugin for videotestsrc |
pipewire | pipewire-spa-plugins-volume | 1.0.0 | MIT & LGPL-2.1-or-later & GPL-2.0-only | PipeWire SPA plugin for volume |
pipewire | pipewire-spa-plugins-vulkan | 1.0.0 | MIT & LGPL-2.1-or-later & GPL-2.0-only | PipeWire SPA plugin for vulkan |
pipewire | pipewire-spa-tools | 1.0.0 | MIT & LGPL-2.1-or-later & GPL-2.0-only | Multimedia processing server for Linux |
pipewire | pipewire-tools | 1.0.0 | MIT & LGPL-2.1-or-later & GPL-2.0-only | Multimedia processing server for Linux |
polkit | polkit | 122 | LGPL-2.0-or-later | PolicyKit Authorization Framework |
powertop | powertop | 2.15 | GPL-2.0-only | Power usage tool |
powertop | powertop-locale-en-us | 2.15 | GPL-2.0-only | Power usage tool - en_US translations |
procps | procps | 4.0.3 | GPL-2.0-or-later & LGPL-2.0-or-later | System and process monitoring utilities |
procps | procps-ps | 4.0.3 | GPL-2.0-or-later & LGPL-2.0-or-later | System and process monitoring utilities |
procps | procps-sysctl | 4.0.3 | GPL-2.0-or-later & LGPL-2.0-or-later | System and process monitoring utilities |
psplash-drm | psplash-drm | 1.0 | MIT | Basic splash screen which display a picture on DRM/KMS |
pulseaudio | pulseaudio-profile | 16.1 | LGPL-2.1-or-later & MIT & BSD-3-Clause | Sound server for Linux and Unix-like operating systems |
pulseaudio | pulseaudio-tools | 16.1 | LGPL-2.1-or-later & MIT & BSD-3-Clause | Sound server for Linux and Unix-like operating systems |
python3 | python3-asyncio | 3.11.5 | PSF-2.0 | Python Asynchronous I/O |
python3 | python3-audio | 3.11.5 | PSF-2.0 | Python Audio Handling |
python3 | python3-codecs | 3.11.5 | PSF-2.0 | Python codec |
python3 | python3-compression | 3.11.5 | PSF-2.0 | Python high-level compression support |
python3 | python3-core | 3.11.5 | PSF-2.0 | Python interpreter and core modules |
python3 | python3-crypt | 3.11.5 | PSF-2.0 | Python basic cryptographic and hashing support |
python3 | python3-ctypes | 3.11.5 | PSF-2.0 | Python C types support |
python3 | python3-datetime | 3.11.5 | PSF-2.0 | Python calendar and time support |
python3-dateutil | python3-dateutil | 2.8.2 | BSD-3-Clause & Apache-2.0 | Extensions to the standard Python datetime module |
python3 | python3-debugger | 3.11.5 | PSF-2.0 | Python debugger |
python3 | python3-difflib | 3.11.5 | PSF-2.0 | Python helpers for computing deltas between objects |
python3 | python3-distutils | 3.11.5 | PSF-2.0 | Python Distribution Utilities |
python3 | python3-email | 3.11.5 | PSF-2.0 | Python email support |
python3-evdev | python3-evdev | 1.6.1 | BSD-3-Clause | Python evdev lib |
python3 | python3-fcntl | 3.11.5 | PSF-2.0 | Python's fcntl interface |
python3 | python3-html | 3.11.5 | PSF-2.0 | Python HTML processing support |
python3 | python3-io | 3.11.5 | PSF-2.0 | Python low-level I/O |
python3 | python3-json | 3.11.5 | PSF-2.0 | Python JSON support |
python3 | python3-logging | 3.11.5 | PSF-2.0 | Python logging support |
python3 | python3-math | 3.11.5 | PSF-2.0 | Python math support |
python3 | python3-mime | 3.11.5 | PSF-2.0 | Python MIME handling APIs |
python3 | python3-misc | 3.11.5 | PSF-2.0 | The Python Programming Language |
python3 | python3-mmap | 3.11.5 | PSF-2.0 | Python memory-mapped file support |
python3 | python3-multiprocessing | 3.11.5 | PSF-2.0 | Python multiprocessing support |
python3 | python3-netclient | 3.11.5 | PSF-2.0 | Python Internet Protocol clients |
python3 | python3-netserver | 3.11.5 | PSF-2.0 | Python Internet Protocol servers |
python3 | python3-numbers | 3.11.5 | PSF-2.0 | Python number APIs |
python3-pexpect | python3-pexpect | 4.8.0 | ISC | A Pure Python Expect like Module for Python |
python3 | python3-pickle | 3.11.5 | PSF-2.0 | Python serialisation/persistence support |
python3 | python3-pprint | 3.11.5 | PSF-2.0 | Python pretty-print support |
python3 | python3-profile | 3.11.5 | PSF-2.0 | Python basic performance profiling support |
python3-ptyprocess | python3-ptyprocess | 0.7.0 | ISC | Run a subprocess in a pseudo terminal |
python3-pycairo | python3-pycairo | 1.23.0 | LGPL-2.1-only & MPL-1.1 | Python bindings for the Cairo canvas library |
python3 | python3-pydoc | 3.11.5 | PSF-2.0 | Python interactive help support |
python3-pygobject | python3-pygobject | 3.42.2 | LGPL-2.1-only | Python GObject bindings |
python3-pyparsing | python3-pyparsing | 3.0.9 | MIT | Python parsing module |
python3-pyyaml | python3-pyyaml | 6.0 | MIT | Python support for YAML |
python3 | python3-resource | 3.11.5 | PSF-2.0 | Python resource control interface |
python3 | python3-shell | 3.11.5 | PSF-2.0 | Python shell-like functionality |
python3-six | python3-six | 1.16.0 | MIT | Python 2 and 3 compatibility library |
python3 | python3-stringold | 3.11.5 | PSF-2.0 | Python string APIs [deprecated] |
python3 | python3-terminal | 3.11.5 | PSF-2.0 | Python terminal controlling support |
python3 | python3-threading | 3.11.5 | PSF-2.0 | Python threading & synchronization support |
python3 | python3-unittest | 3.11.5 | PSF-2.0 | Python unit testing framework |
python3 | python3-xml | 3.11.5 | PSF-2.0 | Python basic XML support |
qrenc | qrenc | 1.0 | LGPL-2.1-only | qrenc which uses libqrencode to generate QR-code |
v4l-utils | rc-keymaps | 1.23.0+gitAUTOINC+9431e4b26b | GPL-2.0-only & LGPL-2.1-only | v4l2 and IR applications |
resize-helper | resize-helper | 1.0 | GPL-2.0-or-later | Tools for resizing the file system |
rng-tools | rng-tools | 6.16 | GPL-2.0-only | Random number generator daemon |
rng-tools | rng-tools-service | 6.16 | GPL-2.0-only | Random number generator daemon |
rpcbind | rpcbind | 1.2.6 | BSD-3-Clause | Universal Addresses to RPC Program Number Mapper |
rt-tests | rt-tests | 2.5 | GPL-2.0-only & GPL-2.0-or-later | Real-Time preemption testcases |
run-postinsts | run-postinsts | 1.0 | MIT | Runs postinstall scripts on first boot of the target device |
seatd | seatd | 0.7.0 | MIT | A minimal seat management daemon, and a universal seat management library. |
shadow | shadow | 4.13 | BSD-3-Clause | Tools to change and administer password and group data |
shadow | shadow-base | 4.13 | BSD-3-Clause | Tools to change and administer password and group data |
shadow-securetty | shadow-securetty | 4.6 | MIT | Provider of the machine specific securetty file |
shared-mime-info | shared-mime-info | 2.2 | GPL-2.0-only | Shared MIME type database and specification |
shared-mime-info | shared-mime-info-data | 2.2 | GPL-2.0-only | Shared MIME type database and specification |
slang | slang | 2.3.3 | GPL-2.0-only | The shared library for the S-Lang extension language |
sqlite3 | sqlite3 | 3.41.0 | PD | Embeddable SQL database engine |
stm32-ddr-tools | stm32-ddr-tools | 1.0 | MIT | STM32 tool to convert the 'perf' tool counters into understandable MB/s |
strace | strace | 6.2 | LGPL-2.1-or-later & GPL-2.0-or-later | System call tracing tool |
sudo | sudo | 1.9.15p2 | ISC & BSD-3-Clause & BSD-2-Clause & Zlib | Provide limited super user privileges to specific users |
sudo | sudo-lib | 1.9.15p2 | ISC & BSD-3-Clause & BSD-2-Clause & Zlib | Provide limited super user privileges to specific users |
sudo | sudo-sudo | 1.9.15p2 | ISC & BSD-3-Clause & BSD-2-Clause & Zlib | Provide limited super user privileges to specific users |
sysfsutils | sysfsutils | 2.1.0 | GPL-2.0-only | Tools for working with sysfs |
sysprof | sysprof | 3.44.0 | GPL-3.0-or-later | System-wide Performance Profiler for Linux |
sysstat | sysstat | 12.6.2 | GPL-2.0-or-later | System performance tools |
systemd | systemd | 253.1 | GPL-2.0-only & LGPL-2.1-only | A System and service manager |
systemd | systemd-analyze | 253.1 | GPL-2.0-only & LGPL-2.1-only | A System and service manager |
systemd-conf | systemd-conf | 1.0 | MIT | Systemd system configuration |
systemd | systemd-extra-utils | 253.1 | GPL-2.0-only & LGPL-2.1-only | A System and service manager |
systemd-mount-partitions | systemd-mount-partitions | 1.0 | MIT | Mount partitions |
systemd-networkd-configuration | systemd-networkd-configuration | 1.0 | MIT | Basic networkd configuration |
systemd-serialgetty | systemd-serialgetty | 1.0 | GPL-2.0-or-later | Serial terminal support for systemd |
systemd | systemd-udev-rules | 253.1 | GPL-2.0-only & LGPL-2.1-only | A System and service manager |
systemd | systemd-vconsole-setup | 253.1 | GPL-2.0-only & LGPL-2.1-only | A System and service manager |
systemtap | systemtap | 4.8 | GPL-2.0-only | Script-directed dynamic tracing and performance analysis tool for Linux |
systemtap | systemtap-locale-en | 4.8 | GPL-2.0-only | Script-directed dynamic tracing and performance analysis tool for Linux - en translations |
systemtap | systemtap-runtime | 4.8 | GPL-2.0-only | Script-directed dynamic tracing and performance analysis tool for Linux |
tar | tar | 1.35 | GPL-3.0-only | GNU file archiving program |
tcf-agent | tcf-agent | 1.8.0+gitAUTOINC+1f11747e83 | EDL-1.0 | Target Communication Framework for the Eclipse IDE |
tcpdump | tcpdump | 4.99.4 | BSD-3-Clause | A sophisticated network protocol analyzer |
tzdata | tzdata-africa | 2023c | PD & BSD-3-Clause | Timezone data |
tzdata | tzdata-americas | 2023c | PD & BSD-3-Clause | Timezone data |
tzdata | tzdata-antarctica | 2023c | PD & BSD-3-Clause | Timezone data |
tzdata | tzdata-arctic | 2023c | PD & BSD-3-Clause | Timezone data |
tzdata | tzdata-asia | 2023c | PD & BSD-3-Clause | Timezone data |
tzdata | tzdata-atlantic | 2023c | PD & BSD-3-Clause | Timezone data |
tzdata | tzdata-australia | 2023c | PD & BSD-3-Clause | Timezone data |
tzdata | tzdata-core | 2023c | PD & BSD-3-Clause | Timezone data |
tzdata | tzdata-europe | 2023c | PD & BSD-3-Clause | Timezone data |
tzdata | tzdata-misc | 2023c | PD & BSD-3-Clause | Timezone data |
tzdata | tzdata-pacific | 2023c | PD & BSD-3-Clause | Timezone data |
tzdata | tzdata-posix | 2023c | PD & BSD-3-Clause | Timezone data |
tzdata | tzdata-right | 2023c | PD & BSD-3-Clause | Timezone data |
systemd | udev | 253.1 | GPL-2.0-only & LGPL-2.1-only | A System and service manager |
systemd | udev-hwdb | 253.1 | GPL-2.0-only & LGPL-2.1-only | A System and service manager |
uhubctl | uhubctl | 2.5.0 | GPL-2.0-only | USB hub per-port power control |
opkg-utils | update-alternatives-opkg | 0.6.2 | GPL-2.0-or-later | Utility for managing the alternatives system |
update-rc.d | update-rc.d | 0.8 | GPL-2.0-or-later | manage symlinks in /etc/rcN.d |
usbip | usbip | 2.0 | GPL-2.0-only | USB ip tools |
usbotg-gadget-config | usbotg-gadget-config | 1.0 | MIT | The goal is to enable USB gadget configuration |
usbutils | usbutils | 015 | GPL-2.0-or-later | Host side USB console utilities |
userfs-cleanup-package | userfs-cleanup-package | 1.0 | BSD-3-Clause | Tools for cleaning apt databse |
util-linux | util-linux-addpart | 2.38.1 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux addpart |
util-linux | util-linux-agetty | 2.38.1 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux agetty |
util-linux | util-linux-blkdiscard | 2.38.1 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux blkdiscard |
util-linux | util-linux-blkid | 2.38.1 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux blkid |
util-linux | util-linux-blkzone | 2.38.1 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux blkzone |
util-linux | util-linux-blockdev | 2.38.1 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux blockdev |
util-linux | util-linux-cal | 2.38.1 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux cal |
util-linux | util-linux-cfdisk | 2.38.1 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux cfdisk |
util-linux | util-linux-chcpu | 2.38.1 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux chcpu |
util-linux | util-linux-chfn | 2.38.1 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux chfn |
util-linux | util-linux-chmem | 2.38.1 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux chmem |
util-linux | util-linux-choom | 2.38.1 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux choom |
util-linux | util-linux-chrt | 2.38.1 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux chrt |
util-linux | util-linux-chsh | 2.38.1 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux chsh |
util-linux | util-linux-col | 2.38.1 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux col |
util-linux | util-linux-colcrt | 2.38.1 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux colcrt |
util-linux | util-linux-colrm | 2.38.1 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux colrm |
util-linux | util-linux-column | 2.38.1 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux column |
util-linux | util-linux-ctrlaltdel | 2.38.1 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux ctrlaltdel |
util-linux | util-linux-delpart | 2.38.1 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux delpart |
util-linux | util-linux-dmesg | 2.38.1 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux dmesg |
util-linux | util-linux-eject | 2.38.1 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux eject |
util-linux | util-linux-fallocate | 2.38.1 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux fallocate |
util-linux | util-linux-fdisk | 2.38.1 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux fdisk |
util-linux | util-linux-fincore | 2.38.1 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux fincore |
util-linux | util-linux-findfs | 2.38.1 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux findfs |
util-linux | util-linux-findmnt | 2.38.1 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux findmnt |
util-linux | util-linux-flock | 2.38.1 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux flock |
util-linux | util-linux-fsck | 2.38.1 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux fsck |
util-linux | util-linux-fsck.cramfs | 2.38.1 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux fsck.cramfs |
util-linux | util-linux-fsfreeze | 2.38.1 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux fsfreeze |
util-linux | util-linux-fstrim | 2.38.1 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux fstrim |
util-linux | util-linux-getopt | 2.38.1 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux getopt |
util-linux | util-linux-hardlink | 2.38.1 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux hardlink |
util-linux | util-linux-hexdump | 2.38.1 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux hexdump |
util-linux | util-linux-hwclock | 2.38.1 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux hwclock |
util-linux | util-linux-ionice | 2.38.1 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux ionice |
util-linux | util-linux-ipcmk | 2.38.1 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux ipcmk |
util-linux | util-linux-ipcrm | 2.38.1 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux ipcrm |
util-linux | util-linux-ipcs | 2.38.1 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux ipcs |
util-linux | util-linux-irqtop | 2.38.1 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux irqtop |
util-linux | util-linux-isosize | 2.38.1 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux isosize |
util-linux | util-linux-kill | 2.38.1 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux kill |
util-linux | util-linux-last | 2.38.1 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux last |
util-linux | util-linux-ldattach | 2.38.1 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux ldattach |
util-linux | util-linux-logger | 2.38.1 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux logger |
util-linux | util-linux-look | 2.38.1 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux look |
util-linux | util-linux-losetup | 2.38.1 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux losetup |
util-linux | util-linux-lsblk | 2.38.1 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux lsblk |
util-linux | util-linux-lscpu | 2.38.1 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux lscpu |
util-linux | util-linux-lsfd | 2.38.1 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux lsfd |
util-linux | util-linux-lsipc | 2.38.1 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux lsipc |
util-linux | util-linux-lsirq | 2.38.1 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux lsirq |
util-linux | util-linux-lslocks | 2.38.1 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux lslocks |
util-linux | util-linux-lslogins | 2.38.1 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux lslogins |
util-linux | util-linux-lsmem | 2.38.1 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux lsmem |
util-linux | util-linux-lsns | 2.38.1 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux lsns |
util-linux | util-linux-mcookie | 2.38.1 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux mcookie |
util-linux | util-linux-mesg | 2.38.1 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux mesg |
util-linux | util-linux-mkfs | 2.38.1 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux mkfs |
util-linux | util-linux-mkfs.cramfs | 2.38.1 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux mkfs.cramfs |
util-linux | util-linux-mkswap | 2.38.1 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux mkswap |
util-linux | util-linux-more | 2.38.1 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux more |
util-linux | util-linux-mount | 2.38.1 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux mount |
util-linux | util-linux-mountpoint | 2.38.1 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux mountpoint |
util-linux | util-linux-namei | 2.38.1 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux namei |
util-linux | util-linux-nologin | 2.38.1 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux nologin |
util-linux | util-linux-nsenter | 2.38.1 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux nsenter |
util-linux | util-linux-partx | 2.38.1 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux partx |
util-linux | util-linux-pivot-root | 2.38.1 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux pivot-root |
util-linux | util-linux-prlimit | 2.38.1 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux prlimit |
util-linux | util-linux-readprofile | 2.38.1 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux readprofile |
util-linux | util-linux-rename | 2.38.1 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux rename |
util-linux | util-linux-renice | 2.38.1 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux renice |
util-linux | util-linux-resizepart | 2.38.1 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux resizepart |
util-linux | util-linux-rev | 2.38.1 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux rev |
util-linux | util-linux-rfkill | 2.38.1 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux rfkill |
util-linux | util-linux-rtcwake | 2.38.1 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux rtcwake |
util-linux | util-linux-runuser | 2.38.1 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux runuser |
util-linux | util-linux-script | 2.38.1 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux script |
util-linux | util-linux-scriptlive | 2.38.1 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux scriptlive |
util-linux | util-linux-scriptreplay | 2.38.1 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux scriptreplay |
util-linux | util-linux-setarch | 2.38.1 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux setarch |
util-linux | util-linux-setpriv | 2.38.1 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux setpriv |
util-linux | util-linux-setsid | 2.38.1 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux setsid |
util-linux | util-linux-setterm | 2.38.1 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux setterm |
util-linux | util-linux-sfdisk | 2.38.1 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux sfdisk |
util-linux | util-linux-su | 2.38.1 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux su |
util-linux | util-linux-sulogin | 2.38.1 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux sulogin |
util-linux | util-linux-swaplabel | 2.38.1 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux swaplabel |
util-linux | util-linux-swapoff | 2.38.1 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux swapoff |
util-linux | util-linux-swapon | 2.38.1 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux swapon |
util-linux | util-linux-switch-root | 2.38.1 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux switch-root |
util-linux | util-linux-taskset | 2.38.1 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux taskset |
util-linux | util-linux-uclampset | 2.38.1 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux uclampset |
util-linux | util-linux-ul | 2.38.1 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux ul |
util-linux | util-linux-umount | 2.38.1 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux umount |
util-linux | util-linux-unshare | 2.38.1 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux unshare |
util-linux | util-linux-utmpdump | 2.38.1 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux utmpdump |
util-linux | util-linux-uuidd | 2.38.1 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux uuidd |
util-linux | util-linux-uuidgen | 2.38.1 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux uuidgen |
util-linux | util-linux-uuidparse | 2.38.1 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux uuidparse |
util-linux | util-linux-wall | 2.38.1 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux wall |
util-linux | util-linux-wdctl | 2.38.1 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux wdctl |
util-linux | util-linux-whereis | 2.38.1 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux whereis |
util-linux | util-linux-wipefs | 2.38.1 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux wipefs |
util-linux | util-linux-write | 2.38.1 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux write |
util-linux | util-linux-zramctl | 2.38.1 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux zramctl |
v4l-utils | v4l-utils | 1.23.0+gitAUTOINC+9431e4b26b | GPL-2.0-only & LGPL-2.1-only | v4l2 and IR applications |
volatile-binds | volatile-binds | 1.0 | MIT | Volatile bind mount setup and configuration for read-only-rootfs |
wayland | wayland | 1.21.0 | MIT | Wayland, a protocol between a compositor and clients |
wayland-utils | wayland-utils | 1.1.0 | MIT | Wayland utilities |
weston | weston | 11.0.1 | MIT | Weston, a Wayland compositor |
weston | weston-examples | 11.0.1 | MIT | Weston, a Wayland compositor |
weston-init | weston-init | 1.0 | MIT | Startup script and systemd unit file for the Weston Wayland compositor |
wget | wget | 1.21.4 | GPL-3.0-only | Console URL download utility supporting HTTP, FTP, etc |
wireless-regdb | wireless-regdb-static | 2023.09.01 | ISC | Wireless Central Regulatory Domain Database |
wireplumber | wireplumber | 0.4.17 | MIT | Session / policy manager implementation for PipeWire |
wireplumber | wireplumber-modules-default-nodes | 0.4.17 | MIT | WirePlumber default-nodes module |
wireplumber | wireplumber-modules-default-nodes-api | 0.4.17 | MIT | WirePlumber default-nodes-api module |
wireplumber | wireplumber-modules-default-profile | 0.4.17 | MIT | WirePlumber default-profile module |
wireplumber | wireplumber-modules-file-monitor-api | 0.4.17 | MIT | WirePlumber file-monitor-api module |
wireplumber | wireplumber-modules-logind | 0.4.17 | MIT | WirePlumber logind module |
wireplumber | wireplumber-modules-lua-scripting | 0.4.17 | MIT | WirePlumber lua-scripting module |
wireplumber | wireplumber-modules-metadata | 0.4.17 | MIT | WirePlumber metadata module |
wireplumber | wireplumber-modules-mixer-api | 0.4.17 | MIT | WirePlumber mixer-api module |
wireplumber | wireplumber-modules-portal-permissionstore | 0.4.17 | MIT | WirePlumber portal-permissionstore module |
wireplumber | wireplumber-modules-reserve-device | 0.4.17 | MIT | WirePlumber reserve-device module |
wireplumber | wireplumber-modules-si-audio-adapter | 0.4.17 | MIT | WirePlumber si-audio-adapter module |
wireplumber | wireplumber-modules-si-audio-endpoint | 0.4.17 | MIT | WirePlumber si-audio-endpoint module |
wireplumber | wireplumber-modules-si-node | 0.4.17 | MIT | WirePlumber si-node module |
wireplumber | wireplumber-modules-si-standard-link | 0.4.17 | MIT | WirePlumber si-standard-link module |
wireplumber | wireplumber-scripts | 0.4.17 | MIT | Session / policy manager implementation for PipeWire |
wpa-supplicant | wpa-supplicant | 2.10 | BSD-3-Clause | Client for Wi-Fi Protected Access (WPA) |
wpa-supplicant | wpa-supplicant-cli | 2.10 | BSD-3-Clause | Client for Wi-Fi Protected Access (WPA) |
wpa-supplicant | wpa-supplicant-passphrase | 2.10 | BSD-3-Clause | Client for Wi-Fi Protected Access (WPA) |
xkeyboard-config | xkeyboard-config | 2.38 | MIT & MIT | Keyboard configuration database for X Window |
xxhash | xxhash | 0.8.1 | BSD-2-Clause & GPL-2.0-only | Extremely fast non-cryptographic hash algorithm |
xz | xz | 5.4.4 | GPL-2.0-or-later | Utilities for managing LZMA compressed files |
3.3. userfs partition:[edit source]
List of packages present on image:
Image | st-image-userfs-openstlinux-weston-stm32mp25 |
Recipe Name | Package Name | Version | License | Description |
dcmipp-isp-ctrl | dcmipp-isp-ctrl | 5.1+gitAUTOINC+a7f953caba | BSD-3-Clause | DMCIPP ISP control tools |
demo-application-3d-cube | demo-application-3d-cube | 3.0 | BSD-3-Clause | Add support of 3d Cube application on Demo Launcher |
demo-application-bluetooth | demo-application-bluetooth | 2.1 | BSD-3-Clause | Add support of audio bluetooth speaker on Demo Launcher |
demo-application-camera | demo-application-camera | 2.0 | BSD-3-Clause | Add support of camera preview on Demo Launcher |
demo-application-netdata-hotspot | demo-application-netdata-hotspot | 2.0 | BSD-3-Clause | Add support of netdata/hotspot wifi on Demo Launcher |
demo-application-video | demo-application-video | 2.0 | BSD-3-Clause | Add support of camera preview on Demo Launcher |
demo-gtk | demo-gtk | 2.2 | BSD-3-Clause | Python script which launch several use-cases |
demo-hotspot-wifi | demo-hotspot-wifi | 1.0 | MIT | Shell script to enable/disable hotsopt wifi configuration |
demo-launcher | demo-launcher | 2.3 | BSD-3-Clause | Script which start a launcher |
event-gtk-player | event-gtk-player | 5.0+gitAUTOINC+b048c2ea12 | GPL-2.0-or-later | GTK player with touch screen management |
installer-apps | installer-apps | 1.0 | BSD-3-Clause | Demos and X-Linux Expansion Packages Individual Installers and Uninstallers |
installer-gtk | installer-gtk | 1.0 | BSD-3-Clause | Demo and X-Linux Expansion Packages Installer and Uninstaller |
linux-examples-stm32mp1 | linux-examples-stm32mp1-userfs | 5.4+AUTOINC+8e1c0b246c | MIT | ST STM32MP1 projects for Linux examples |
m33projects-stm32mp2 | m33projects-stm32mp2-userfs | 1.0.0 | Apache-2.0 & MIT & BSD-3-Clause | STM32MP2 Firmware examples for CM33 |
weston-cube | weston-cube | 5.0+gitAUTOINC+7c46618178 | MIT | 3D cube for wayland/weston windows |
4. vendorfs partition:[edit source]
Image | st-image-vendorfs-openstlinux-weston-stm32mp25 |
gcnano-userland-multi-binary-stm32mp | libclc-gcnano | 6.4.15+20240517 | Proprietary | Vivante libraries OpenGL ES, OpenVG and EGL (multi backend) |
gcnano-userland-multi-binary-stm32mp | libegl-gcnano | 6.4.15+20240517 | Proprietary | Vivante libraries OpenGL ES, OpenVG and EGL (multi backend) |
gcnano-userland-multi-binary-stm32mp | libgal-gcnano | 6.4.15+20240517 | Proprietary | Vivante libraries OpenGL ES, OpenVG and EGL (multi backend) |
gcnano-userland-multi-binary-stm32mp | libgbm-gcnano | 6.4.15+20240517 | Proprietary | Vivante libraries OpenGL ES, OpenVG and EGL (multi backend) |
gcnano-userland-multi-binary-stm32mp | libgles1-gcnano | 6.4.15+20240517 | Proprietary | Vivante libraries OpenGL ES, OpenVG and EGL (multi backend) |
gcnano-userland-multi-binary-stm32mp | libgles2-gcnano | 6.4.15+20240517 | Proprietary | Vivante libraries OpenGL ES, OpenVG and EGL (multi backend) |
gcnano-userland-multi-binary-stm32mp | libglslc-gcnano | 6.4.15+20240517 | Proprietary | Vivante libraries OpenGL ES, OpenVG and EGL (multi backend) |
gcnano-userland-multi-binary-stm32mp | libopencl-gcnano | 6.4.15+20240517 | Proprietary | Vivante libraries OpenGL ES, OpenVG and EGL (multi backend) |
gcnano-userland-multi-binary-stm32mp | libopenvg-gcnano | 6.4.15+20240517 | Proprietary | Vivante libraries OpenGL ES, OpenVG and EGL (multi backend) |
gcnano-userland-multi-binary-stm32mp | libspirv-gcnano | 6.4.15+20240517 | Proprietary | Vivante libraries OpenGL ES, OpenVG and EGL (multi backend) |
gcnano-userland-multi-binary-stm32mp | libvulkan-driver-gcnano | 6.4.15+20240517 | Proprietary | Vivante libraries OpenGL ES, OpenVG and EGL (multi backend) |
5. Full license list including packages from ST package repository[edit source]
This list not only includes the licenses from OpenSTLinux distribution but also the licenses of the packages that could be installed from this distribution thanks to package repository for OpenSTLinux distribution:
stm32mp1 | licenses-world-openstlinux-weston-stm32mp1.tar.gz |
stm32mp2 | licenses-world-openstlinux-weston-stm32mp2.tar.gz |
6. OE SPDX LICENSE[edit source]
Openembedded validate the License with the SPDX license list.
How Openembedded validate an License indicated on a package:
Official licenses used by Openembedded | Link to text of license |
0BSD | [0BSD] |
AAL | [AAL] |
Abstyles | [Abstyles] |
Adobe | [Adobe] |
Adobe-2006 | [Adobe-2006] |
Adobe-Glyph | [Adobe-Glyph] |
ADSL | [ADSL] |
AFL-1.1 | [AFL-1.1] |
AFL-1.2 | [AFL-1.2] |
AFL-2.0 | [AFL-2.0] |
AFL-2.1 | [AFL-2.1] |
AFL-3.0 | [AFL-3.0] |
Afmparse | [Afmparse] |
AGPL-1.0-only | [AGPL-1.0-only] |
AGPL-1.0-or-later | [AGPL-1.0-or-later] |
AGPL-3.0-only | [AGPL-3.0-only] |
AGPL-3.0-or-later | [AGPL-3.0-or-later] |
Aladdin | [Aladdin] |
AMDPLPA | [AMDPLPA] |
AML | [AML] |
AMPAS | [AMPAS] |
ANTLR-PD | [ANTLR-PD] |
ANTLR-PD-fallback | [ANTLR-PD-fallback] |
Apache-1.0 | [Apache-1.0] |
Apache-1.1 | [Apache-1.1] |
Apache-2.0 | [Apache-2.0] |
Apache-2.0-with-LLVM-exception | [Apache-2.0-with-LLVM-exception] |
APAFML | [APAFML] |
APL-1.0 | [APL-1.0] |
APSL-1.0 | [APSL-1.0] |
APSL-1.1 | [APSL-1.1] |
APSL-1.2 | [APSL-1.2] |
APSL-2.0 | [APSL-2.0] |
Artistic-1.0 | [Artistic-1.0] |
Artistic-1.0-cl8 | [Artistic-1.0-cl8] |
Artistic-1.0-Perl | [Artistic-1.0-Perl] |
Artistic-2.0 | [Artistic-2.0] |
Bahyph | [Bahyph] |
Barr | [Barr] |
Beerware | [Beerware] |
BitstreamVera | [BitstreamVera] |
BitTorrent-1.0 | [BitTorrent-1.0] |
BitTorrent-1.1 | [BitTorrent-1.1] |
blessing | [blessing] |
BlueOak-1.0.0 | [BlueOak-1.0.0] |
Borceux | [Borceux] |
BSD-1-Clause | [BSD-1-Clause] |
BSD-2-Clause | [BSD-2-Clause] |
BSD-2-Clause-Patent | [BSD-2-Clause-Patent] |
BSD-2-Clause-Views | [BSD-2-Clause-Views] |
BSD-3-Clause | [BSD-3-Clause] |
BSD-3-Clause-Attribution | [BSD-3-Clause-Attribution] |
BSD-3-Clause-Clear | [BSD-3-Clause-Clear] |
BSD-3-Clause-LBNL | [BSD-3-Clause-LBNL] |
BSD-3-Clause-Modification | [BSD-3-Clause-Modification] |
BSD-3-Clause-No-Military-License | [BSD-3-Clause-No-Military-License] |
BSD-3-Clause-No-Nuclear-License | [BSD-3-Clause-No-Nuclear-License] |
BSD-3-Clause-No-Nuclear-License-2014 | [BSD-3-Clause-No-Nuclear-License-2014] |
BSD-3-Clause-No-Nuclear-Warranty | [BSD-3-Clause-No-Nuclear-Warranty] |
BSD-3-Clause-Open-MPI | [BSD-3-Clause-Open-MPI] |
BSD-4-Clause | [BSD-4-Clause] |
BSD-4-Clause-Shortened | [BSD-4-Clause-Shortened] |
BSD-4-Clause-UC | [BSD-4-Clause-UC] |
BSD-Protection | [BSD-Protection] |
BSD-Source-Code | [BSD-Source-Code] |
BSL-1.0 | [BSL-1.0] |
BUSL-1.1 | [BUSL-1.1] |
bzip2-1.0.4 | [bzip2-1.0.4] |
bzip2-1.0.5 | [bzip2-1.0.5] |
bzip2-1.0.6 | [bzip2-1.0.6] |
CAL-1.0 | [CAL-1.0] |
CAL-1.0-Combined-Work-Exception | [CAL-1.0-Combined-Work-Exception] |
Caldera | [Caldera] |
CATOSL-1.1 | [CATOSL-1.1] |
CC0-1.0 | [CC0-1.0] |
CC-BY-1.0 | [CC-BY-1.0] |
CC-BY-2.0 | [CC-BY-2.0] |
CC-BY-2.5 | [CC-BY-2.5] |
CC-BY-2.5-AU | [CC-BY-2.5-AU] |
CC-BY-3.0 | [CC-BY-3.0] |
CC-BY-3.0-AT | [CC-BY-3.0-AT] |
CC-BY-3.0-DE | [CC-BY-3.0-DE] |
CC-BY-3.0-NL | [CC-BY-3.0-NL] |
CC-BY-3.0-US | [CC-BY-3.0-US] |
CC-BY-4.0 | [CC-BY-4.0] |
CC-BY-NC-1.0 | [CC-BY-NC-1.0] |
CC-BY-NC-2.0 | [CC-BY-NC-2.0] |
CC-BY-NC-2.5 | [CC-BY-NC-2.5] |
CC-BY-NC-3.0 | [CC-BY-NC-3.0] |
CC-BY-NC-3.0-DE | [CC-BY-NC-3.0-DE] |
CC-BY-NC-4.0 | [CC-BY-NC-4.0] |
CC-BY-NC-ND-1.0 | [CC-BY-NC-ND-1.0] |
CC-BY-NC-ND-2.0 | [CC-BY-NC-ND-2.0] |
CC-BY-NC-ND-2.5 | [CC-BY-NC-ND-2.5] |
CC-BY-NC-ND-3.0 | [CC-BY-NC-ND-3.0] |
CC-BY-NC-ND-3.0-DE | [CC-BY-NC-ND-3.0-DE] |
CC-BY-NC-ND-3.0-IGO | [CC-BY-NC-ND-3.0-IGO] |
CC-BY-NC-ND-4.0 | [CC-BY-NC-ND-4.0] |
CC-BY-NC-SA-1.0 | [CC-BY-NC-SA-1.0] |
CC-BY-NC-SA-2.0 | [CC-BY-NC-SA-2.0] |
CC-BY-NC-SA-2.0-FR | [CC-BY-NC-SA-2.0-FR] |
CC-BY-NC-SA-2.0-UK | [CC-BY-NC-SA-2.0-UK] |
CC-BY-NC-SA-2.5 | [CC-BY-NC-SA-2.5] |
CC-BY-NC-SA-3.0 | [CC-BY-NC-SA-3.0] |
CC-BY-NC-SA-3.0-DE | [CC-BY-NC-SA-3.0-DE] |
CC-BY-NC-SA-3.0-IGO | [CC-BY-NC-SA-3.0-IGO] |
CC-BY-NC-SA-4.0 | [CC-BY-NC-SA-4.0] |
CC-BY-ND-1.0 | [CC-BY-ND-1.0] |
CC-BY-ND-2.0 | [CC-BY-ND-2.0] |
CC-BY-ND-2.5 | [CC-BY-ND-2.5] |
CC-BY-ND-3.0 | [CC-BY-ND-3.0] |
CC-BY-ND-3.0-DE | [CC-BY-ND-3.0-DE] |
CC-BY-ND-4.0 | [CC-BY-ND-4.0] |
CC-BY-SA-1.0 | [CC-BY-SA-1.0] |
CC-BY-SA-2.0 | [CC-BY-SA-2.0] |
CC-BY-SA-2.0-UK | [CC-BY-SA-2.0-UK] |
CC-BY-SA-2.1-JP | [CC-BY-SA-2.1-JP] |
CC-BY-SA-2.5 | [CC-BY-SA-2.5] |
CC-BY-SA-3.0 | [CC-BY-SA-3.0] |
CC-BY-SA-3.0-AT | [CC-BY-SA-3.0-AT] |
CC-BY-SA-3.0-DE | [CC-BY-SA-3.0-DE] |
CC-BY-SA-4.0 | [CC-BY-SA-4.0] |
CC-PDDC | [CC-PDDC] |
CDDL-1.0 | [CDDL-1.0] |
CDDL-1.1 | [CDDL-1.1] |
CDL-1.0 | [CDL-1.0] |
CDLA-Permissive-1.0 | [CDLA-Permissive-1.0] |
CDLA-Permissive-2.0 | [CDLA-Permissive-2.0] |
CDLA-Sharing-1.0 | [CDLA-Sharing-1.0] |
CECILL-1.0 | [CECILL-1.0] |
CECILL-1.1 | [CECILL-1.1] |
CECILL-2.0 | [CECILL-2.0] |
CECILL-2.1 | [CECILL-2.1] |
CECILL-B | [CECILL-B] |
CECILL-C | [CECILL-C] |
CERN-OHL-1.1 | [CERN-OHL-1.1] |
CERN-OHL-1.2 | [CERN-OHL-1.2] |
CERN-OHL-P-2.0 | [CERN-OHL-P-2.0] |
CERN-OHL-S-2.0 | [CERN-OHL-S-2.0] |
CERN-OHL-W-2.0 | [CERN-OHL-W-2.0] |
ClArtistic | [ClArtistic] |
CNRI-Jython | [CNRI-Jython] |
CNRI-Python | [CNRI-Python] |
CNRI-Python-GPL-Compatible | [CNRI-Python-GPL-Compatible] |
Condor-1.1 | [Condor-1.1] |
copyleft-next-0.3.0 | [copyleft-next-0.3.0] |
copyleft-next-0.3.1 | [copyleft-next-0.3.1] |
CPAL-1.0 | [CPAL-1.0] |
CPL-1.0 | [CPL-1.0] |
CPOL-1.02 | [CPOL-1.02] |
Crossword | [Crossword] |
CrystalStacker | [CrystalStacker] |
CUA-OPL-1.0 | [CUA-OPL-1.0] |
Cube | [Cube] |
C-UDA-1.0 | [C-UDA-1.0] |
curl | [curl] |
D-FSL-1.0 | [D-FSL-1.0] |
diffmark | [diffmark] |
DOC | [DOC] |
Dotseqn | [Dotseqn] |
DRL-1.0 | [DRL-1.0] |
DSDP | [DSDP] |
DSSSL | [DSSSL] |
dvipdfm | [dvipdfm] |
ECL-1.0 | [ECL-1.0] |
ECL-2.0 | [ECL-2.0] |
eCos-2.0 | [eCos-2.0] |
EDL-1.0 | [EDL-1.0] |
EFL-1.0 | [EFL-1.0] |
EFL-2.0 | [EFL-2.0] |
eGenix | [eGenix] |
Entessa | [Entessa] |
EPICS | [EPICS] |
EPL-1.0 | [EPL-1.0] |
EPL-2.0 | [EPL-2.0] |
ErlPL-1.1 | [ErlPL-1.1] |
etalab-2.0 | [etalab-2.0] |
EUDatagrid | [EUDatagrid] |
EUPL-1.0 | [EUPL-1.0] |
EUPL-1.1 | [EUPL-1.1] |
EUPL-1.2 | [EUPL-1.2] |
urosym | [urosym] |
Fair | [Fair] |
Frameworx-1.0 | [Frameworx-1.0] |
FreeBSD-DOC | [FreeBSD-DOC] |
FreeImage | [FreeImage] |
FSFAP | [FSFAP] |
FSFUL | [FSFUL] |
FSFULLR | [FSFULLR] |
FSF-Unlimited | [FSF-Unlimited] |
FTL | [FTL] |
GD | [GD] |
GFDL-1.1 | [GFDL-1.1] |
GFDL-1.1-invariants-only | [GFDL-1.1-invariants-only] |
GFDL-1.1-invariants-or-later | [GFDL-1.1-invariants-or-later] |
GFDL-1.1-no-invariants-only | [GFDL-1.1-no-invariants-only] |
GFDL-1.1-no-invariants-or-later | [GFDL-1.1-no-invariants-or-later] |
GFDL-1.1-only | [GFDL-1.1-only] |
GFDL-1.1-or-later | [GFDL-1.1-or-later] |
GFDL-1.2 | [GFDL-1.2] |
GFDL-1.2-invariants-only | [GFDL-1.2-invariants-only] |
GFDL-1.2-invariants-or-later | [GFDL-1.2-invariants-or-later] |
GFDL-1.2-no-invariants-only | [GFDL-1.2-no-invariants-only] |
GFDL-1.2-no-invariants-or-later | [GFDL-1.2-no-invariants-or-later] |
GFDL-1.2-only | [GFDL-1.2-only] |
GFDL-1.2-or-later | [GFDL-1.2-or-later] |
GFDL-1.3 | [GFDL-1.3] |
GFDL-1.3-invariants-only | [GFDL-1.3-invariants-only] |
GFDL-1.3-invariants-or-later | [GFDL-1.3-invariants-or-later] |
GFDL-1.3-no-invariants-only | [GFDL-1.3-no-invariants-only] |
GFDL-1.3-no-invariants-or-later | [GFDL-1.3-no-invariants-or-later] |
GFDL-1.3-only | [GFDL-1.3-only] |
GFDL-1.3-or-later | [GFDL-1.3-or-later] |
Giftware | [Giftware] |
GL2PS | [GL2PS] |
Glide | [Glide] |
Glulxe | [Glulxe] |
GLWTPL | [GLWTPL] |
gnuplot | [gnuplot] |
GPL-1.0-only | [GPL-1.0-only] |
GPL-1.0-or-later | [GPL-1.0-or-later] |
GPL-2.0-only | [GPL-2.0-only] |
GPL-2.0-or-later | [GPL-2.0-or-later] |
GPL-2.0-with-autoconf-exception | [GPL-2.0-with-autoconf-exception] |
GPL-2.0-with-classpath-exception | [GPL-2.0-with-classpath-exception] |
GPL-2.0-with-font-exception | [GPL-2.0-with-font-exception] |
GPL-2.0-with-GCC-exception | [GPL-2.0-with-GCC-exception] |
GPL-2.0-with-OpenSSL-exception | [GPL-2.0-with-OpenSSL-exception] |
GPL-2-with-bison-exception | [GPL-2-with-bison-exception] |
GPL-3.0-only | [GPL-3.0-only] |
GPL-3.0-or-later | [GPL-3.0-or-later] |
GPL-3.0-with-autoconf-exception | [GPL-3.0-with-autoconf-exception] |
GPL-3.0-with-GCC-exception | [GPL-3.0-with-GCC-exception] |
GPL-3-with-bison-exception | [GPL-3-with-bison-exception] |
gSOAP-1 | [gSOAP-1] |
gSOAP-1.3b | [gSOAP-1.3b] |
HaskellReport | [HaskellReport] |
Hippocratic-2.1 | [Hippocratic-2.1] |
HPND | [HPND] |
HPND-sell-variant | [HPND-sell-variant] |
HTMLTIDY | [HTMLTIDY] |
IBM-pibs | [IBM-pibs] |
ICU | [ICU] |
IJG | [IJG] |
ImageMagick | [ImageMagick] |
iMatix | [iMatix] |
Imlib2 | [Imlib2] |
Info-ZIP | [Info-ZIP] |
Intel | [Intel] |
Intel-ACPI | [Intel-ACPI] |
Interbase-1.0 | [Interbase-1.0] |
IPA | [IPA] |
IPL-1.0 | [IPL-1.0] |
ISC | [ISC] |
JasPer-2.0 | [JasPer-2.0] |
JPNIC | [JPNIC] |
JSON | [JSON] |
LAL-1.2 | [LAL-1.2] |
LAL-1.3 | [LAL-1.3] |
Latex2e | [Latex2e] |
Leptonica | [Leptonica] |
LGPL-2.0-only | [LGPL-2.0-only] |
LGPL-2.0-or-later | [LGPL-2.0-or-later] |
LGPL-2.1-only | [LGPL-2.1-only] |
LGPL-2.1-or-later | [LGPL-2.1-or-later] |
LGPL-3.0-only | [LGPL-3.0-only] |
LGPL-3.0-or-later | [LGPL-3.0-or-later] |
LGPLLR | [LGPLLR] |
Libpng | [Libpng] |
libpng-2.0 | [libpng-2.0] |
libselinux-1.0 | [libselinux-1.0] |
libtiff | [libtiff] |
LiLiQ-P-1.1 | [LiLiQ-P-1.1] |
LiLiQ-R-1.1 | [LiLiQ-R-1.1] |
LiLiQ-Rplus-1.1 | [LiLiQ-Rplus-1.1] |
Linux-OpenIB | [Linux-OpenIB] |
LPL-1.0 | [LPL-1.0] |
LPL-1.02 | [LPL-1.02] |
LPPL-1.0 | [LPPL-1.0] |
LPPL-1.1 | [LPPL-1.1] |
LPPL-1.2 | [LPPL-1.2] |
LPPL-1.3a | [LPPL-1.3a] |
LPPL-1.3c | [LPPL-1.3c] |
MakeIndex | [MakeIndex] |
MirOS | [MirOS] |
MIT | [MIT] |
MIT-0 | [MIT-0] |
MIT-advertising | [MIT-advertising] |
MIT-CMU | [MIT-CMU] |
MIT-enna | [MIT-enna] |
MIT-feh | [MIT-feh] |
MIT-Modern-Variant | [MIT-Modern-Variant] |
MITNFA | [MITNFA] |
MIT-open-group | [MIT-open-group] |
Motosoto | [Motosoto] |
mpich2 | [mpich2] |
MPL-1.0 | [MPL-1.0] |
MPL-1.1 | [MPL-1.1] |
MPL-2.0 | [MPL-2.0] |
MPL-2.0-no-copyleft-exception | [MPL-2.0-no-copyleft-exception] |
MS-PL | [MS-PL] |
MS-RL | [MS-RL] |
MTLL | [MTLL] |
MulanPSL-1.0 | [MulanPSL-1.0] |
MulanPSL-2.0 | [MulanPSL-2.0] |
Multics | [Multics] |
Mup | [Mup] |
NAIST-2003 | [NAIST-2003] |
NASA-1.3 | [NASA-1.3] |
Naumen | [Naumen] |
NBPL-1.0 | [NBPL-1.0] |
NCGL-UK-2.0 | [NCGL-UK-2.0] |
NCSA | [NCSA] |
NetCDF | [NetCDF] |
Net-SNMP | [Net-SNMP] |
Newsletr | [Newsletr] |
NGPL | [NGPL] |
NIST-PD | [NIST-PD] |
NIST-PD-fallback | [NIST-PD-fallback] |
NLOD-1.0 | [NLOD-1.0] |
NLOD-2.0 | [NLOD-2.0] |
NLPL | [NLPL] |
Nokia | [Nokia] |
NOSL | [NOSL] |
Noweb | [Noweb] |
NPL-1.0 | [NPL-1.0] |
NPL-1.1 | [NPL-1.1] |
NPOSL-3.0 | [NPOSL-3.0] |
NRL | [NRL] |
NTP | [NTP] |
NTP-0 | [NTP-0] |
OASIS | [OASIS] |
OCCT-PL | [OCCT-PL] |
OCLC-2.0 | [OCLC-2.0] |
ODbL-1.0 | [ODbL-1.0] |
ODC-By-1.0 | [ODC-By-1.0] |
OFL-1.0 | [OFL-1.0] |
OFL-1.0-no-RFN | [OFL-1.0-no-RFN] |
OFL-1.0-RFN | [OFL-1.0-RFN] |
OFL-1.1 | [OFL-1.1] |
OFL-1.1-no-RFN | [OFL-1.1-no-RFN] |
OFL-1.1-RFN | [OFL-1.1-RFN] |
OGC-1.0 | [OGC-1.0] |
OGDL-Taiwan-1.0 | [OGDL-Taiwan-1.0] |
OGL-Canada-2.0 | [OGL-Canada-2.0] |
OGL-UK-1.0 | [OGL-UK-1.0] |
OGL-UK-2.0 | [OGL-UK-2.0] |
OGL-UK-3.0 | [OGL-UK-3.0] |
OGTSL | [OGTSL] |
OLDAP-1.1 | [OLDAP-1.1] |
OLDAP-1.2 | [OLDAP-1.2] |
OLDAP-1.3 | [OLDAP-1.3] |
OLDAP-1.4 | [OLDAP-1.4] |
OLDAP-2.0 | [OLDAP-2.0] |
OLDAP-2.0.1 | [OLDAP-2.0.1] |
OLDAP-2.1 | [OLDAP-2.1] |
OLDAP-2.2 | [OLDAP-2.2] |
OLDAP-2.2.1 | [OLDAP-2.2.1] |
OLDAP-2.2.2 | [OLDAP-2.2.2] |
OLDAP-2.3 | [OLDAP-2.3] |
OLDAP-2.4 | [OLDAP-2.4] |
OLDAP-2.5 | [OLDAP-2.5] |
OLDAP-2.6 | [OLDAP-2.6] |
OLDAP-2.7 | [OLDAP-2.7] |
OLDAP-2.8 | [OLDAP-2.8] |
OML | [OML] |
OpenSSL | [OpenSSL] |
OPL-1.0 | [OPL-1.0] |
OPUBL-1.0 | [OPUBL-1.0] |
OSET-PL-2.1 | [OSET-PL-2.1] |
OSL-1.0 | [OSL-1.0] |
OSL-1.1 | [OSL-1.1] |
OSL-2.0 | [OSL-2.0] |
OSL-2.1 | [OSL-2.1] |
OSL-3.0 | [OSL-3.0] |
O-UDA-1.0 | [O-UDA-1.0] |
ParaTypeFFL-1.3 | [ParaTypeFFL-1.3] |
Parity-6.0.0 | [Parity-6.0.0] |
Parity-7.0.0 | [Parity-7.0.0] |
PD | [PD] |
PDDL-1.0 | [PDDL-1.0] |
PHP-3.0 | [PHP-3.0] |
PHP-3.01 | [PHP-3.01] |
pkgconf | [pkgconf] |
Plexus | [Plexus] |
PolyForm-Noncommercial-1.0.0 | [PolyForm-Noncommercial-1.0.0] |
PolyForm-Small-Business-1.0.0 | [PolyForm-Small-Business-1.0.0] |
PostgreSQL | [PostgreSQL] |
Proprietary | [Proprietary] |
PSF-2.0 | [PSF-2.0] |
psfrag | [psfrag] |
psutils | [psutils] |
Python-2.0 | [Python-2.0] |
Qhull | [Qhull] |
QPL-1.0 | [QPL-1.0] |
Rdisc | [Rdisc] |
RHeCos-1 | [RHeCos-1] |
RHeCos-1.1 | [RHeCos-1.1] |
RPL-1.1 | [RPL-1.1] |
RPL-1.5 | [RPL-1.5] |
RPSL-1.0 | [RPSL-1.0] |
RSA-MD | [RSA-MD] |
RSCPL | [RSCPL] |
Ruby | [Ruby] |
Saxpath | [Saxpath] |
SAX-PD | [SAX-PD] |
SCEA | [SCEA] |
Sendmail | [Sendmail] |
Sendmail-8.23 | [Sendmail-8.23] |
SGI-1 | [SGI-1] |
SGI-B-1.0 | [SGI-B-1.0] |
SGI-B-1.1 | [SGI-B-1.1] |
SGI-B-2.0 | [SGI-B-2.0] |
SHL-0.5 | [SHL-0.5] |
SHL-0.51 | [SHL-0.51] |
SimPL-2.0 | [SimPL-2.0] |
Simple-2.0 | [Simple-2.0] |
SISSL | [SISSL] |
SISSL-1.2 | [SISSL-1.2] |
Sleepycat | [Sleepycat] |
SMAIL_GPL | [SMAIL_GPL] |
SMLNJ | [SMLNJ] |
SMPPL | [SMPPL] |
SNIA | [SNIA] |
Spencer-86 | [Spencer-86] |
Spencer-94 | [Spencer-94] |
Spencer-99 | [Spencer-99] |
SPL-1.0 | [SPL-1.0] |
SSH-OpenSSH | [SSH-OpenSSH] |
SSH-short | [SSH-short] |
SSPL-1.0 | [SSPL-1.0] |
SugarCRM-1 | [SugarCRM-1] |
SugarCRM-1.1.3 | [SugarCRM-1.1.3] |
SWL | [SWL] |
TAPR-OHL-1.0 | [TAPR-OHL-1.0] |
TCL | [TCL] |
TCP-wrappers | [TCP-wrappers] |
TMate | [TMate] |
TORQUE-1.1 | [TORQUE-1.1] |
TOSL | [TOSL] |
TU-Berlin-1.0 | [TU-Berlin-1.0] |
TU-Berlin-2.0 | [TU-Berlin-2.0] |
UCB | [UCB] |
UCL-1.0 | [UCL-1.0] |
unfs3 | [unfs3] |
Unicode-DFS-2015 | [Unicode-DFS-2015] |
Unicode-DFS-2016 | [Unicode-DFS-2016] |
Unicode-TOU | [Unicode-TOU] |
Unlicense | [Unlicense] |
UPL-1.0 | [UPL-1.0] |
Vim | [Vim] |
VOSTROM | [VOSTROM] |
VSL-1.0 | [VSL-1.0] |
W3C | [W3C] |
W3C-19980720 | [W3C-19980720] |
W3C-20150513 | [W3C-20150513] |
Watcom-1.0 | [Watcom-1.0] |
Wsuipa | [Wsuipa] |
WTFPL | [WTFPL] |
WXwindows | [WXwindows] |
X11 | [X11] |
Xerox | [Xerox] |
XFree86-1.0 | [XFree86-1.0] |
Free86-1.1 | [Free86-1.1] |
xinetd | [xinetd] |
Xnet | [Xnet] |
xpp | [xpp] |
XSkat | [XSkat] |
XSL | [XSL] |
YPL-1.0 | [YPL-1.0] |
YPL-1.1 | [YPL-1.1] |
Zed | [Zed] |
Zend-2.0 | [Zend-2.0] |
Zimbra-1.3 | [Zimbra-1.3] |
Zimbra-1.4 | [Zimbra-1.4] |
Zlib | [Zlib] |
zlib-acknowledgement | [zlib-acknowledgement] |
ZPL-1.1 | [ZPL-1.1] |
ZPL-2.0 | [ZPL-2.0] |
ZPL-2.1 | [ZPL-2.1] |
SLA0044 | [SLA0044] |
Information extracted from:
http://git.openembedded.org/openembedded-core/tree/meta/conf/licenses.conf
All Text of License are available:
http://git.openembedded.org/openembedded-core/tree/meta/files/common-licenses
7. Archives [edit source]
STM32MP1 release | OpenSTLinux licenses |
STM32MP1-ecosystem-v5.0.0 | LegalInformation:OpenSTLinux licenses - v5.0.0 page for the v5 ecosystem releases (in archived wiki) |
STM32MP1-ecosystem-v4.1.0 | LegalInformation:OpenSTLinux licenses - v4.1.0 page for the v4 ecosystem releases (in archived wiki) |
STM32MP1-ecosystem-v4.0.0 | LegalInformation:OpenSTLinux licenses - v4.0.0 page for the v4 ecosystem releases (in archived wiki) |
STM32MP15-ecosystem-v3.1.0 | LegalInformation:OpenSTLinux licenses - v3.1.0 page for the v3 ecosystem releases (in archived wiki) |
STM32MP15-ecosystem-v3.0.0 | LegalInformation:OpenSTLinux licenses - v3.0.0 page for the v3 ecosystem releases (in archived wiki) |
STM32MP15-ecosystem-v2.1.0 | LegalInformation:OpenSTLinux licenses - v2.1.0 page for the v2 ecosystem releases (in archived wiki) |
STM32MP15-ecosystem-v2.0.0 | LegalInformation:OpenSTLinux licenses - v2.0.0 page for the v2 ecosystem releases (in archived wiki) |
STM32MP15-ecosystem-v1.2.0 | LegalInformation:OpenSTLinux licenses - v1.2.0 page for the v1 ecosystem releases (in archived wiki) |
STM32MP15-ecosystem-v1.1.0 | LegalInformation:OpenSTLinux licenses - v1.1.0 page for the v1 ecosystem releases (in archived wiki) |
STM32MP15-ecosystem-v1.0.0 | LegalInformation:OpenSTLinux licenses - v1.0.0 page for the v1 ecosystem releases (in archived wiki) |
