How to create Signed FIT image from Distribution package
The purpose of this article is to explain how to create a signed FIT image containing a kernel image and devicetree.
With the current implementation on Yocto/Openembedded, the creation of a signed FIT image requires that you declare only one devicetree on the machine
2. Creating a signature key[edit source]
Yocto/Openembeded can create a key for signing a FIT image.
To create your own key, follow the commands below to generate a new signing key manually.
  • To generate a new signing key manually:
Create a directory to receive the signing key (uboot-sign-directory for this example)
mkdir uboot-sign-directory/
Generate an RSA private key for signing the fitImage:
 openssl genrsa -F4 \
       -out  uboot-sign-directory/my-uboot-sign-key.key \
       2048
Generate a certificate for signing the fitImage:
 openssl req -batch -new -x509 \
     -key uboot-sign-directory/my-uboot-sign-key.key \
     -out uboot-sign-directory/my-uboot-sign-key.crt
3. Machine configuration on the Distribution Package[edit source]
On the Yocto/Openembedded machine you must specify several parameters:
  • force use of a FIT image
  • request to sign the FIT image
  • specify the path of the signing key
3.1. Use the FIT image[edit source]
# to use the FIT image for kernel and devicetree
 MACHINE_FEATURES += "fit"
3.2. Use the Signing FIT[edit source]
UBOOT_SIGN_ENABLE = "1"
3.3. Signing key[edit source]
if your keys are localized in a specific directory, for example $HOME/uboot-sign-directory (put an absolute path)
 UBOOT_SIGN_KEYDIR = "$HOME/uboot-sign-directory"
or if you use a generic path
 UBOOT_SIGN_KEYDIR = "${DEPLOY_DIR_IMAGE}"
For the signing key, you MUST specify the name of the key (without the extension), my-uboot-sign-key for example
UBOOT_SIGN_KEYNAME = "my-uboot-sign-key"
For the Distribution Package to generate the signing key, you must add the following key in addition to UBOOT_SIGN_ENABLE
FIT_GENERATE_KEYS = "1"
3.4. Summary: Machine contents[edit source]
# to use FIT image for kernel and devicetree
#signing key
# Sign FIT image
# generate new signing key if not exist
# Uboot mkimage option
UBOOT_MKIMAGE_DTCOPTS = "-I dts -O dtb -p 2000"
4. References[edit source]
