U-Boot$
1. Usage[edit source]
The U-Boot$ template is used to prefix a command that must be executed on the U-Boot console, with a U-Boot-specific prompt.
Thanks to the u-boot-prompt class defined in MediaWiki:Common.css, a double (or triple) click to select the command doesn't select the prompt.
Usage:  {{U-Boot$}}
You type You get
help env command executed on the U-Boot console
{{U-Boot$}}help env<br>
env - environment handling commands
help env
3. More examples[edit source]
You type You get
2 commands executed on the U-Boot console and preformatted text block (space at the beginning of each line)
 {{U-Boot$}}help env
 {{U-Boot$}}env default -a
help env
env default -a
Command executed on the U-Boot console and preformatted text block (space at the beginning of each line)
 {{U-Boot$}}help env
help env
Long command executed on the U-Boot console and preformatted text block (space at the beginning of each line)
 {{U-Boot$}}this is a so long command executed on the U-Boot console that a horizontal scrolling bar is needed
Template used within another public message box template
{{Info |
Message before the command
 {{U-Boot$}}help env
Message after the command
Template used within another protected message box template
{{InternalInfo |
 {{U-Boot$}}help env
4. Maintenance[edit source]
5. Code[edit source]
No categories assignedEdit
