Subpart - STM32MP1 - Starter Package
This article gathers the information that applies to any STM32MP1 board.
That's the reason why the steps 2, 3 and 6 referenced in this article depend on the considered board:
2. Checking the boot sequence[edit | edit source]
First information scrolled on the remote Terminal during boot
Last information scrolled on the remote Terminal during boot
In parallel, a U-Boot splash screen picture is displayed on the DSI display (if one is connected to the board).DSI U-Boot splash screen.png
A user space graphical boot splash screen (PSplash) picture is then briefly displayed on the HDMI monitor if one is connected to the board, or otherwise on the DSI display (if one is connected to the board).DSI user splash screen.png
3. Mouse, keyboard and Ethernet hot-plugs[edit | edit source]
[  926.786326] usb 2-1.1: new low-speed USB device number 3 using ehci-platform
[  926.961413] input: Logitech Optical USB Mouse as /devices/platform/soc/5800d000.usbh-ehci/usb2/2-1/2-1.1/2-1.1:1.0/0003:046D:C016.0001/input/input2
[  926.975098] hid-generic 0003:046D:C016.0001: input: USB HID v1.10 Mouse [Logitech Optical USB Mouse] on usb-5800d000.usbh-ehci-1.1/input0
[ 1215.356377] stm32-dwmac 5800a000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[ 1215.363377] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
or on STM32MP13x lines More info.png for the second Ethernet interface
[  117.370989] stm32-dwmac 5800e000.eth2 eth1: Link is Up - 100Mbps/Full - flow control rx/tx
[  117.377950] IPv6: ADDRCONF(NETDEV_CHANGE): eth1: link becomes ready
4. Remote and local Terminal programs[edit | edit source]
Example of command (ifconfig) executed on the remote Terminal program
Icon to launch a local Terminal program
Wayland Terminal program
Example of command (ip addr) executed on the Wayland Terminal program
5. Executing basic commands[edit | edit source]
5.1. Having a look at the OpenSTLinux directory structure[edit | edit source]
5.2. Identifying the software running on board[edit | edit source]
For ecosystem release v4.0.0 More info.png[edit | edit source]
Software How to get its version Output example
TF-A TF-A Version number
NOTICE: BL2: v2.6-stm32mp1-r1.0(debug):v2.6-dirty
U-Boot See the version displayed in the console
2021.10-stm32mp-r1 [...]
Linux kernel
 cat /proc/version
Linux version 5.15.24 (xxxx@yyyy) (arm-ostl-linux-gnueabi-gcc (GCC) 11.2.0 ) [...]
GCC
 cat /proc/version
Linux version 5.15.24 (xxxx@yyyy) (arm-ostl-linux-gnueabi-gcc (GCC) 11.2.0) [...]
Yocto Project
 grep DISTRO_CODENAME /etc/build
DISTRO_CODENAME = kirkstone
Weston
 weston --version
weston 10.0.0
GStreamer
 gst-play-1.0 --version
GStreamer 1.20.1
GPU (only on STM32MP15x lines More info.png)
6.4.7.365873 built [...]
5.3. Configuration tips[edit | edit source]
5.4. Getting board IP address[edit | edit source]
 ip addr show eth0
    inet6 xxxx::xx:xx:xx:xx/xx scope link
  • Get the IP address of your board with the ifconfig Linux command line (a deprecated but well-known command):
 ifconfig eth0
eth0      Link encap:Ethernet  HWaddr xx:xx:xx:xx:xx:xx
          inet addr:xx.xx.xx.xx  Bcast:xx.xx.xx.xx  Mask:255.255.252.0
          inet6 addr: xxxx::xx:xx:xx:xx/xx Scope:Link
          RX packets:2619 errors:0 dropped:0 overruns:0 frame:0
          TX packets:1311 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:353250 (344.9 KiB)  TX bytes:118305 (115.5 KiB)
          Interrupt:247
5.5. Copying a file from your host PC to your board (and reciprocally)[edit | edit source]
5.6. Miscellaneous commands[edit | edit source]
5.6.1. Printing distribution specific information[edit | edit source]
 cat /etc/os-release
ID=openstlinux-weston
NAME="ST OpenSTLinux - Weston - (A Yocto Project Based Distro)"
VERSION="4.0.1-openstlinux-22-06-15 (kirkstone)"
VERSION_ID=4.0.1-openstlinux-22-06-15
PRETTY_NAME="ST OpenSTLinux - Weston - (A Yocto Project Based Distro) 4.0.1-openstlinux-22-06-15 (kirkstone)"
DISTRO_CODENAME="kirkstone"
Where:
5.6.2. Printing system information[edit | edit source]
 uname -a
Linux stm32mp1 5.15.24 #1 SMP PREEMPT Wed Feb 16 11:56:41 UTC 2022 armv7l armv7l armv7l GNU/Linux
Where:
5.6.3. Printing Linux kernel and GCC versions[edit | edit source]
 cat /proc/version
Linux version 5.15.24 (oe-user@oe-host) (arm-ostl-linux-gnueabi-gcc (GCC) 11.2.0, GNU ld (GNU Binutils) 2.38.20220313) #1 SMP PREEMPT Wed Feb 16 11:56:41 UTC 2022
Where:
5.6.4. Printing the amount of disk space available on all mounted file systems[edit | edit source]
 df -h
devtmpfs         116M     0  116M   0% /dev
/dev/mmcblk0p10  684M  453M  184M  72% /
tmpfs            195M  176K  195M   1% /dev/shm
tmpfs             78M  8.8M   70M  12% /run
tmpfs            4.0M     0  4.0M   0% /sys/fs/cgroup
tmpfs            195M   16K  195M   1% /tmp
/dev/mmcblk0p8    55M   39M   12M  77% /boot
/dev/mmcblk0p9    14M  5.9M  6.8M  47% /vendor
tmpfs            195M   96K  195M   1% /var/volatile
/dev/mmcblk0p11   14G   45M   13G   1% /usr/local
tmpfs             39M  4.0K   39M   1% /run/user/1000
tmpfs             39M     0   39M   0% /run/user/0
Where:
