Important
Revision as of 11:03, 17 October 2023 by Registered User (Merge articles)
1. Usage
The Important template is used to delivered important messages.
It puts a message in a green box with a "white warning" icon.
Usage:  {{Important | <message>}}
Where <message> is the optional important message. If this parameter is not set, the default message is "Please read carefully".
2. Basic examples
You type You get
Warning without specific warning message
{{Important}}
Warning DB.png Important
Warning with specific warning message
{{Important | Please respect the order of the below actions}}
3. More examples
You type You get
Warning with a long warning message
{{Important| The warning message is a long sentence. Lorem ipsum: isdem diebus Apollinaris Domitiani gener, paulo ante agens palatii Caesaris curam, ad Mesopotamiam missus a socero per militares numeros immodice scrutabatur, an quaedam altiora meditantis iam Galli.}}
Check that the spaces before and after the info message
BEFORE{{Imortant test1| Check spaces}}AFTER<br>
BEFORE
{{Important | Check spaces}}
AFTER
BEFORE
Check spaces
AFTER
BEFORE
Check spaces
AFTER
4. Maintenance
5. Code
No categories assignedEdit
