1. Top Software license agreement (SLA) and third-party licences[edit source]
Contents of Images SPDX License
MACHINE | stm32mp1 |
IMAGE | st-image-weston |
DISTRO | openstlinux-weston |
VERSION | 4.0.4-openstlinux-5.15-yocto-kirkstone-mp1-v22.11.23 |
OE branch | kirkstone |
1.1. Sofware license agreement[edit source]
License |
SLA0048 Rev4/March 2018
1.2. Vivante libraries OpenGL ES, OpenVG and EGL (multi backend), (STM32MP15 only)[edit source]
License |
Vivante End User Software License Terms
1.3. Firmware-cypress-bcm4343[edit source]
License |
CYPRESS WIRELESS CONNECTIVITY DEVICES |
1.4. Firmware-broadcom_bcm43xx[edit source]
License |
BROADCOM BCM43XX |
2. Boot partition:[edit source]
List of packages used during the different boot phases:
Recipe Name | Version | License |
linux-stm32mp | 5.15.67-stm32mp-r2 | GPL-2.0-only |
optee-os-stm32mp | 3.16.0-stm32mp-r2 | BSD-2-Clause & BSD-3-Clause |
st-initrd | 1.0 | MIT |
tf-a-stm32mp | v2.6-stm32mp-r2 | BSD-3-Clause |
u-boot-stm32mp | v2021.10-stm32mp-r2 | GPL-2.0-or-later |
3. Kernel partitions:[edit source]
3.1. bootfs partition:[edit source]
List of packages present on image:
Image | st-image-bootfs-openstlinux-weston-stm32mp1 |
Recipe Name | Package Name | Version | License | Description |
linux-stm32mp | kernel-imagebootfs | 5.15.67-stm32mp-r2 | GPL-2.0-only | Linux STM32MP Kernel |
st-initrd | st-initrd | 1.0 | MIT | ST InitRD installation package for st-image-resize-initrd image(s) |
stm32mp-extlinux | stm32mp-extlinux | 3.1.1 | MIT | Provide 'extlinux.conf' file for U-Boot |
u-boot-stm32mp-splash | u-boot-stm32mp-splash | 2018.11 | No license to ST trademark | Universal Boot Loader Splash Screen for stm32mp embedded devices |
3.2. rootfs partition:[edit source]
Image | st-image-weston-openstlinux-weston-stm32mp1 |
adwaita-icon-theme | adwaita-icon-theme-symbolic | 41.0 | CC-BY-SA-3.0 | GTK+ icon theme |
alsa-lib | alsa-conf | 1.2.6.1 | LGPL-2.1-only & GPL-2.0-or-later | ALSA sound library |
alsa-plugins | alsa-plugins-pulseaudio-conf | 1.2.6 | LGPL-2.1-only & GPL-2.0-or-later | ALSA Plugins |
alsa-state | alsa-state | 0.2.0 | MIT & GPL-2.0-or-later | Alsa scenario files to enable alsa state restoration |
alsa-state-stm32mp1 | alsa-state-stm32mp1 | 1.0 | MIT | Alsa scenario files to enable alsa state restoration |
alsa-state | alsa-states | 0.2.0 | MIT & GPL-2.0-or-later | Alsa scenario files to enable alsa state restoration |
alsa-topology-conf | alsa-topology-conf | 1.2.5.1 | BSD-3-Clause | ALSA topology configuration files |
alsa-ucm-conf | alsa-ucm-conf | 1.2.6.3 | BSD-3-Clause | ALSA Use Case Manager configuration |
alsa-utils | alsa-utils-aconnect | 1.2.6 | GPL-2.0-only | ALSA sequencer connection manager |
alsa-utils | alsa-utils-alsabat | 1.2.6 | GPL-2.0-only | Command-line sound tester for ALSA sound card driver |
alsa-utils | alsa-utils-alsactl | 1.2.6 | GPL-2.0-only | Saves/restores ALSA-settings in /etc/asound.state |
alsa-utils | alsa-utils-alsaloop | 1.2.6 | GPL-2.0-only | ALSA PCM loopback utility |
alsa-utils | alsa-utils-alsamixer | 1.2.6 | GPL-2.0-only | ncurses-based control for ALSA mixer and settings |
alsa-utils | alsa-utils-alsatplg | 1.2.6 | GPL-2.0-only | Converts topology text files into binary format for kernel |
alsa-utils | alsa-utils-alsaucm | 1.2.6 | GPL-2.0-only | ALSA Use Case Manager |
alsa-utils | alsa-utils-amixer | 1.2.6 | GPL-2.0-only | Command-line control for ALSA mixer and settings |
alsa-utils | alsa-utils-aplay | 1.2.6 | GPL-2.0-only | Play (and record) sound files using ALSA |
alsa-utils | alsa-utils-aseqdump | 1.2.6 | GPL-2.0-only | Shows the events received at an ALSA sequencer port |
alsa-utils | alsa-utils-aseqnet | 1.2.6 | GPL-2.0-only | Network client/server for ALSA sequencer |
alsa-utils | alsa-utils-iecset | 1.2.6 | GPL-2.0-only | ALSA utility for setting/showing IEC958 (S/PDIF) status bits |
alsa-utils | alsa-utils-midi | 1.2.6 | GPL-2.0-only | Miscellaneous MIDI utilities for ALSA |
alsa-utils | alsa-utils-speakertest | 1.2.6 | GPL-2.0-only | ALSA surround speaker test utility |
apt | apt | 2.4.5 | GPL-2.0-or-later | Advanced front-end for dpkg |
apt-openstlinux | apt-openstlinux | 4.1 | MIT | Add apt configuration files for OpenSTLinux |
avahi | avahi-daemon | 0.8 | LGPL-2.1-or-later | Avahi IPv4LL network address configuration daemon |
babeltrace | babeltrace | 1.5.8 | MIT & GPL-2.0-only & LGPL-2.1-only | Babeltrace - Trace Format Babel Tower |
babeltrace2 | babeltrace2 | 2.0.4 | MIT & GPL-2.0-only & LGPL-2.1-only & BSD-2-Clause | Babeltrace2 - Trace Format Babel Tower |
base-files | base-files | 3.0.14 | GPL-2.0-only | Miscellaneous files for the base system |
bash | bash | 5.1.16 | GPL-3.0-or-later | An sh-compatible command language interpreter |
bc | bc | 1.07.1 | GPL-3.0-or-later | Arbitrary precision calculator language |
blktool | blktool | 4-7.1 | GPL-2.0-or-later | Tune low-level block device parameters |
blktrace | blktrace | 1.3.0+gitAUTOINC+366d30b9cd | GPL-2.0-only | Generates traces of I/O traffic on block devices |
bluetooth-suspend | bluetooth-suspend | 1.0 | MIT | Systemd service to suspend/resume correctly bluetooth |
bluez5 | bluez5 | 5.65 | GPL-2.0-or-later & LGPL-2.1-or-later | Linux Bluetooth Stack Userland V5 |
bridge-utils | bridge-utils | 1.7.1 | GPL-2.0-only | Tools for ethernet bridging |
build-info-openstlinux | build-info-openstlinux | 1.0 | MIT | Writes build information to target filesystem on /etc/build |
busybox | busybox | 1.35.0 | GPL-2.0-only & bzip2-1.0.4 | Tiny versions of many common UNIX utilities in a single small executable |
busybox | busybox-syslog | 1.35.0 | GPL-2.0-only & bzip2-1.0.4 | Tiny versions of many common UNIX utilities in a single small executable |
busybox | busybox-udhcpc | 1.35.0 | GPL-2.0-only & bzip2-1.0.4 | Tiny versions of many common UNIX utilities in a single small executable |
bzip2 | bzip2 | 1.0.8 | bzip2-1.0.6 | Very high-quality data compression program |
ca-certificates | ca-certificates | 20211016 | GPL-2.0-or-later & MPL-2.0 | Common CA certificates |
can-utils | can-utils | 2021.08.0 | GPL-2.0-only & BSD-3-Clause | Linux CAN network development utilities |
ckermit | ckermit | 302 | BSD-3-Clause | ckermit version 302-r0 |
coreutils | coreutils | 9.0 | GPL-3.0-or-later | The basic file, shell and text manipulation utilities |
coreutils | coreutils-stdbuf | 9.0 | GPL-3.0-or-later | The basic file, shell and text manipulation utilities |
cpufrequtils | cpufrequtils | 008 | GPL-2.0-only | cpufrequtils version 008-r5 |
cracklib | cracklib | 2.9.8 | LGPL-2.1-or-later | Password strength checker library |
curl | curl | 7.82.0 | MIT-open-group | Command line tool and library for client-side URL transfers |
db | db | 5.3.28 | Sleepycat | Berkeley Database v5 |
dbus | dbus-1 | 1.14.0 | GPL-2.0-or-later | D-Bus message bus |
dbus | dbus-common | 1.14.0 | GPL-2.0-or-later | D-Bus message bus |
dbus | dbus-tools | 1.14.0 | GPL-2.0-or-later | D-Bus message bus |
desktop-file-utils | desktop-file-utils | 0.26 | GPL-2.0-or-later | Command line utilities for working with *.desktop files |
dosfstools | dosfstools | 4.2 | GPL-3.0-only | DOS FAT Filesystem Utilities |
dpkg | dpkg | 1.21.4 | GPL-2.0-or-later | Package maintenance system from Debian |
dpkg | dpkg-start-stop | 1.21.4 | GPL-2.0-or-later | Package maintenance system from Debian |
dropbear | dropbear | 2020.81 | MIT & BSD-3-Clause & BSD-2-Clause & PD | A lightweight SSH and SCP implementation |
e2fsprogs | e2fsprogs | 1.46.5 | GPL-2.0-only & LGPL-2.0-only & BSD-3-Clause & MIT | Ext2 Filesystem Utilities |
e2fsprogs | e2fsprogs-badblocks | 1.46.5 | GPL-2.0-only | Ext2 Filesystem Utilities |
e2fsprogs | e2fsprogs-dumpe2fs | 1.46.5 | GPL-2.0-only | Ext2 Filesystem Utilities |
e2fsprogs | e2fsprogs-e2fsck | 1.46.5 | GPL-2.0-only | Ext2 Filesystem Utilities |
e2fsprogs | e2fsprogs-mke2fs | 1.46.5 | GPL-2.0-only | Ext2 Filesystem Utilities |
e2fsprogs | e2fsprogs-resize2fs | 1.46.5 | GPL-2.0-only & LGPL-2.0-only & BSD-3-Clause & MIT | Ext2 Filesystem Utilities |
elfutils | elfutils | 0.186 | GPL-3.0-or-later | Utilities and libraries for handling compiled object files |
ethtool | ethtool | 5.16 | GPL-2.0-or-later | Display or change ethernet card settings |
evtest | evtest | 1.34 | GPL-2.0-only | Simple tool for input event debugging |
fb-test | fb-test | 1.1.0 | GPL-2.0-only | Test suite for Linux framebuffer |
file | file | 5.41 | BSD-2-Clause | File classification tool |
fontconfig | fontconfig-utils | 2.13.1 | MIT & MIT & PD | Generic font configuration library |
gdb | gdbserver | 11.2 | GPL-2.0-only & GPL-3.0-only & LGPL-2.0-only & LGPL-3.0-only | GNU debugger |
glib-networking | glib-networking | 2.72.2 | LGPL-2.1-only | GLib networking extensions |
glibc-locale | glibc-binary-localedata-en-us | 2.35 | GPL-2.0-only & LGPL-2.1-only | binary locale definition for en-us |
glibc-locale | glibc-gconv | 2.35 | GPL-2.0-only & LGPL-2.1-only | Locale data from glibc |
glibc-locale | glibc-gconv-iso8859-1 | 2.35 | GPL-2.0-only & LGPL-2.1-only | gconv module for character set iso8859-1 |
glmark2 | glmark2 | 2021.12 | GPL-3.0-or-later & SGI-1 | OpenGL (ES) 2.0 benchmark |
gnupg | gnupg | 2.3.7 | GPL-3.0-only & LGPL-3.0-only | GNU Privacy Guard - encryption and signing tools (2.x) |
gnupg | gnupg-gpg | 2.3.7 | GPL-3.0-only & LGPL-3.0-only | GNU Privacy Guard - encryption and signing tools (2.x) |
gobject-introspection | gobject-introspection | 1.72.0 | LGPL-2.0-or-later & GPL-2.0-or-later & MIT | Middleware layer between GObject-using C libraries and language bindings |
gpio-udev | gpio-udev | 1.0 | GPL-2.0-only | Add udev rules to set GPIO to dialout group |
gptfdisk | gptfdisk | 1.0.8 | GPL-2.0-only | Utility for modifying GPT disk partitioning |
grep | grep | 3.7 | GPL-3.0-only | GNU grep utility |
gstreamer1.0 | gstreamer1.0 | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 multimedia framework |
gstreamer1.0-libav | gstreamer1.0-libav | 1.20.3 | LGPL-2.1-or-later | Libav-based GStreamer 1.x plugin |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-accurip | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for accurip |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-adpcmdec | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for adpcmdec |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-adpcmenc | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for adpcmenc |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-aes | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for aes |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-aiff | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for aiff |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-apps | 1.20.3 | LGPL-2.1-or-later | gstreamer1.0-plugins-bad version 1.20.3-r0 |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-asfmux | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for asfmux |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-audiobuffersplit | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for audiobuffersplit |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-audiofxbad | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for audiofxbad |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-audiolatency | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for audiolatency |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-audiomixmatrix | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for audiomixmatrix |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-audiovisualizers | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for audiovisualizers |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-autoconvert | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for autoconvert |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-bayer | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for bayer |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-bluez | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for bluez |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-bz2 | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for bz2 |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-camerabin | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for camerabin |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-closedcaption | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for closedcaption |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-codecalpha | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for codecalpha |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-coloreffects | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for coloreffects |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-curl | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for curl |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-dash | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for dash |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-debugutilsbad | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for debugutilsbad |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-decklink | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for decklink |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-dtls | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for dtls |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-dvb | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for dvb |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-dvbsubenc | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for dvbsubenc |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-dvbsuboverlay | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for dvbsuboverlay |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-dvdspu | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for dvdspu |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-faac | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for faac |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-faceoverlay | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for faceoverlay |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-fbdevsink | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for fbdevsink |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-festival | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for festival |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-fieldanalysis | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for fieldanalysis |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-freeverb | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for freeverb |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-frei0r | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for frei0r |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-gaudieffects | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for gaudieffects |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-gdp | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for gdp |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-geometrictransform | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for geometrictransform |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-gtkwayland | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for gtkwayland |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-hls | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for hls |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-id3tag | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for id3tag |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-inter | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for inter |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-interlace | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for interlace |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-ipcpipeline | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for ipcpipeline |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-ivfparse | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for ivfparse |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-ivtc | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for ivtc |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-jp2kdecimator | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for jp2kdecimator |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-jpegformat | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for jpegformat |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-kms | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for kms |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-legacyrawparse | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for legacyrawparse |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-midi | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for midi |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-mpegpsdemux | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for mpegpsdemux |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-mpegpsmux | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for mpegpsmux |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-mpegtsdemux | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for mpegtsdemux |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-mpegtsmux | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for mpegtsmux |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-mxf | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for mxf |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-netsim | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for netsim |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-pcapparse | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for pcapparse |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-pnm | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for pnm |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-proxy | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for proxy |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-removesilence | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for removesilence |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-rfbsrc | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for rfbsrc |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-rist | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for rist |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-rsvg | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for rsvg |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-rtmp2 | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for rtmp2 |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-rtpmanagerbad | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for rtpmanagerbad |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-rtponvif | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for rtponvif |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-sbc | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for sbc |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-sdpelem | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for sdpelem |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-segmentclip | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for segmentclip |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-shm | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for shm |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-siren | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for siren |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-smooth | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for smooth |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-smoothstreaming | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for smoothstreaming |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-sndfile | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for sndfile |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-speed | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for speed |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-subenc | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for subenc |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-switchbin | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for switchbin |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-timecode | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for timecode |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-transcode | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for transcode |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-ttmlsubs | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for ttmlsubs |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-uvch264 | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for uvch264 |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-v4l2codecs | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for v4l2codecs |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-videofiltersbad | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for videofiltersbad |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-videoframe-audiolevel | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for videoframe-audiolevel |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-videoparsersbad | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for videoparsersbad |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-videosignal | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for videosignal |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-vmnc | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for vmnc |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-waylandsink | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for waylandsink |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-webp | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for webp |
gstreamer1.0-plugins-bad | gstreamer1.0-plugins-bad-y4mdec | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for y4mdec |
gstreamer1.0-plugins-base | gstreamer1.0-plugins-base | 1.20.3 | LGPL-2.1-or-later | gstreamer1.0-plugins-base version 1.20.3-r0 |
gstreamer1.0-plugins-base | gstreamer1.0-plugins-base-adder | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for adder |
gstreamer1.0-plugins-base | gstreamer1.0-plugins-base-alsa | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for alsa |
gstreamer1.0-plugins-base | gstreamer1.0-plugins-base-app | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for app |
gstreamer1.0-plugins-base | gstreamer1.0-plugins-base-apps | 1.20.3 | LGPL-2.1-or-later | gstreamer1.0-plugins-base version 1.20.3-r0 |
gstreamer1.0-plugins-base | gstreamer1.0-plugins-base-audioconvert | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for audioconvert |
gstreamer1.0-plugins-base | gstreamer1.0-plugins-base-audiomixer | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for audiomixer |
gstreamer1.0-plugins-base | gstreamer1.0-plugins-base-audiorate | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for audiorate |
gstreamer1.0-plugins-base | gstreamer1.0-plugins-base-audioresample | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for audioresample |
gstreamer1.0-plugins-base | gstreamer1.0-plugins-base-audiotestsrc | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for audiotestsrc |
gstreamer1.0-plugins-base | gstreamer1.0-plugins-base-compositor | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for compositor |
gstreamer1.0-plugins-base | gstreamer1.0-plugins-base-encoding | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for encoding |
gstreamer1.0-plugins-base | gstreamer1.0-plugins-base-gio | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for gio |
gstreamer1.0-plugins-base | gstreamer1.0-plugins-base-ogg | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for ogg |
gstreamer1.0-plugins-base | gstreamer1.0-plugins-base-opengl | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for opengl |
gstreamer1.0-plugins-base | gstreamer1.0-plugins-base-overlaycomposition | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for overlaycomposition |
gstreamer1.0-plugins-base | gstreamer1.0-plugins-base-pango | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for pango |
gstreamer1.0-plugins-base | gstreamer1.0-plugins-base-pbtypes | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for pbtypes |
gstreamer1.0-plugins-base | gstreamer1.0-plugins-base-playback | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for playback |
gstreamer1.0-plugins-base | gstreamer1.0-plugins-base-rawparse | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for rawparse |
gstreamer1.0-plugins-base | gstreamer1.0-plugins-base-subparse | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for subparse |
gstreamer1.0-plugins-base | gstreamer1.0-plugins-base-tcp | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for tcp |
gstreamer1.0-plugins-base | gstreamer1.0-plugins-base-theora | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for theora |
gstreamer1.0-plugins-base | gstreamer1.0-plugins-base-typefindfunctions | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for typefindfunctions |
gstreamer1.0-plugins-base | gstreamer1.0-plugins-base-videoconvert | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for videoconvert |
gstreamer1.0-plugins-base | gstreamer1.0-plugins-base-videorate | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for videorate |
gstreamer1.0-plugins-base | gstreamer1.0-plugins-base-videoscale | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for videoscale |
gstreamer1.0-plugins-base | gstreamer1.0-plugins-base-videotestsrc | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for videotestsrc |
gstreamer1.0-plugins-base | gstreamer1.0-plugins-base-volume | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for volume |
gstreamer1.0-plugins-base | gstreamer1.0-plugins-base-vorbis | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for vorbis |
gstreamer1.0-plugins-good | gstreamer1.0-plugins-good-alaw | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for alaw |
gstreamer1.0-plugins-good | gstreamer1.0-plugins-good-alpha | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for alpha |
gstreamer1.0-plugins-good | gstreamer1.0-plugins-good-alphacolor | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for alphacolor |
gstreamer1.0-plugins-good | gstreamer1.0-plugins-good-apetag | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for apetag |
gstreamer1.0-plugins-good | gstreamer1.0-plugins-good-audiofx | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for audiofx |
gstreamer1.0-plugins-good | gstreamer1.0-plugins-good-audioparsers | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for audioparsers |
gstreamer1.0-plugins-good | gstreamer1.0-plugins-good-auparse | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for auparse |
gstreamer1.0-plugins-good | gstreamer1.0-plugins-good-autodetect | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for autodetect |
gstreamer1.0-plugins-good | gstreamer1.0-plugins-good-avi | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for avi |
gstreamer1.0-plugins-good | gstreamer1.0-plugins-good-cairo | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for cairo |
gstreamer1.0-plugins-good | gstreamer1.0-plugins-good-cutter | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for cutter |
gstreamer1.0-plugins-good | gstreamer1.0-plugins-good-debug | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for debug |
gstreamer1.0-plugins-good | gstreamer1.0-plugins-good-deinterlace | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for deinterlace |
gstreamer1.0-plugins-good | gstreamer1.0-plugins-good-dtmf | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for dtmf |
gstreamer1.0-plugins-good | gstreamer1.0-plugins-good-effectv | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for effectv |
gstreamer1.0-plugins-good | gstreamer1.0-plugins-good-equalizer | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for equalizer |
gstreamer1.0-plugins-good | gstreamer1.0-plugins-good-flac | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for flac |
gstreamer1.0-plugins-good | gstreamer1.0-plugins-good-flv | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for flv |
gstreamer1.0-plugins-good | gstreamer1.0-plugins-good-flxdec | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for flxdec |
gstreamer1.0-plugins-good | gstreamer1.0-plugins-good-gdkpixbuf | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for gdkpixbuf |
gstreamer1.0-plugins-good | gstreamer1.0-plugins-good-goom | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for goom |
gstreamer1.0-plugins-good | gstreamer1.0-plugins-good-goom2k1 | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for goom2k1 |
gstreamer1.0-plugins-good | gstreamer1.0-plugins-good-gtk | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for gtk |
gstreamer1.0-plugins-good | gstreamer1.0-plugins-good-icydemux | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for icydemux |
gstreamer1.0-plugins-good | gstreamer1.0-plugins-good-id3demux | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for id3demux |
gstreamer1.0-plugins-good | gstreamer1.0-plugins-good-imagefreeze | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for imagefreeze |
gstreamer1.0-plugins-good | gstreamer1.0-plugins-good-interleave | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for interleave |
gstreamer1.0-plugins-good | gstreamer1.0-plugins-good-isomp4 | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for isomp4 |
gstreamer1.0-plugins-good | gstreamer1.0-plugins-good-jpeg | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for jpeg |
gstreamer1.0-plugins-good | gstreamer1.0-plugins-good-lame | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for lame |
gstreamer1.0-plugins-good | gstreamer1.0-plugins-good-level | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for level |
gstreamer1.0-plugins-good | gstreamer1.0-plugins-good-matroska | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for matroska |
gstreamer1.0-plugins-good | gstreamer1.0-plugins-good-monoscope | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for monoscope |
gstreamer1.0-plugins-good | gstreamer1.0-plugins-good-mpg123 | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for mpg123 |
gstreamer1.0-plugins-good | gstreamer1.0-plugins-good-mulaw | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for mulaw |
gstreamer1.0-plugins-good | gstreamer1.0-plugins-good-multifile | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for multifile |
gstreamer1.0-plugins-good | gstreamer1.0-plugins-good-multipart | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for multipart |
gstreamer1.0-plugins-good | gstreamer1.0-plugins-good-navigationtest | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for navigationtest |
gstreamer1.0-plugins-good | gstreamer1.0-plugins-good-ossaudio | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for ossaudio |
gstreamer1.0-plugins-good | gstreamer1.0-plugins-good-png | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for png |
gstreamer1.0-plugins-good | gstreamer1.0-plugins-good-pulseaudio | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for pulseaudio |
gstreamer1.0-plugins-good | gstreamer1.0-plugins-good-replaygain | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for replaygain |
gstreamer1.0-plugins-good | gstreamer1.0-plugins-good-rtp | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for rtp |
gstreamer1.0-plugins-good | gstreamer1.0-plugins-good-rtpmanager | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for rtpmanager |
gstreamer1.0-plugins-good | gstreamer1.0-plugins-good-rtsp | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for rtsp |
gstreamer1.0-plugins-good | gstreamer1.0-plugins-good-shapewipe | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for shapewipe |
gstreamer1.0-plugins-good | gstreamer1.0-plugins-good-smpte | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for smpte |
gstreamer1.0-plugins-good | gstreamer1.0-plugins-good-soup | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for soup |
gstreamer1.0-plugins-good | gstreamer1.0-plugins-good-spectrum | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for spectrum |
gstreamer1.0-plugins-good | gstreamer1.0-plugins-good-speex | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for speex |
gstreamer1.0-plugins-good | gstreamer1.0-plugins-good-taglib | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for taglib |
gstreamer1.0-plugins-good | gstreamer1.0-plugins-good-udp | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for udp |
gstreamer1.0-plugins-good | gstreamer1.0-plugins-good-video4linux2 | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for video4linux2 |
gstreamer1.0-plugins-good | gstreamer1.0-plugins-good-videobox | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for videobox |
gstreamer1.0-plugins-good | gstreamer1.0-plugins-good-videocrop | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for videocrop |
gstreamer1.0-plugins-good | gstreamer1.0-plugins-good-videofilter | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for videofilter |
gstreamer1.0-plugins-good | gstreamer1.0-plugins-good-videomixer | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for videomixer |
gstreamer1.0-plugins-good | gstreamer1.0-plugins-good-wavenc | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for wavenc |
gstreamer1.0-plugins-good | gstreamer1.0-plugins-good-wavparse | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for wavparse |
gstreamer1.0-plugins-good | gstreamer1.0-plugins-good-y4menc | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for y4menc |
gstreamer1.0-plugins-ugly | gstreamer1.0-plugins-ugly-a52dec | 1.20.3 | GPL-2.0-or-later | GStreamer 1.0 plugin for a52dec |
gstreamer1.0-plugins-ugly | gstreamer1.0-plugins-ugly-asf | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for asf |
gstreamer1.0-plugins-ugly | gstreamer1.0-plugins-ugly-dvdlpcmdec | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for dvdlpcmdec |
gstreamer1.0-plugins-ugly | gstreamer1.0-plugins-ugly-dvdsub | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for dvdsub |
gstreamer1.0-plugins-ugly | gstreamer1.0-plugins-ugly-mpeg2dec | 1.20.3 | GPL-2.0-or-later | GStreamer 1.0 plugin for mpeg2dec |
gstreamer1.0-plugins-ugly | gstreamer1.0-plugins-ugly-realmedia | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for realmedia |
gstreamer1.0-plugins-ugly | gstreamer1.0-plugins-ugly-xingmux | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for xingmux |
gstreamer1.0-rtsp-server | gstreamer1.0-rtsp-server-rtspclientsink | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 plugin for rtspclientsink |
gtk+3 | gtk+3-demo | 3.24.34 | LGPL-2.0-only & LGPL-2.0-or-later & LGPL-2.1-or-later | Multi-platform toolkit for creating GUIs |
gtk+3 | gtk+3-locale-en | 3.24.34 | LGPL-2.0-only & LGPL-2.0-or-later & LGPL-2.1-or-later | Multi-platform toolkit for creating GUIs - en translations |
hdparm | hdparm | 9.63 | BSD-2-Clause & hdparm | Utility for viewing/manipulating IDE disk drive/driver parameters |
hicolor-icon-theme | hicolor-icon-theme | 0.17 | GPL-2.0-only | Default icon theme that all icon themes automatically inherit from |
hostapd | hostapd | 2.10 | BSD-3-Clause | User space daemon for extended IEEE 802.11 management |
i2c-tools | i2c-tools | 4.3 | GPL-2.0-or-later | Set of i2c tools for linux |
infos-openstlinux | infos-openstlinux | 1.1 | GPL-2.0-or-later | Information for support |
iproute2 | iproute2 | 5.17.0 | GPL-2.0-or-later | TCP / IP networking and traffic control utilities |
iproute2 | iproute2-ip | 5.17.0 | GPL-2.0-or-later | TCP / IP networking and traffic control utilities |
iptables | iptables | 1.8.7 | GPL-2.0-or-later | Tools for managing kernel packet filtering capabilities |
iptables | iptables-module-ip6t-ah | 1.8.7 | GPL-2.0-or-later | iptables module ip6t-ah |
iptables | iptables-module-ip6t-dnat | 1.8.7 | GPL-2.0-or-later | iptables module ip6t-dnat |
iptables | iptables-module-ip6t-dnpt | 1.8.7 | GPL-2.0-or-later | iptables module ip6t-dnpt |
iptables | iptables-module-ip6t-dst | 1.8.7 | GPL-2.0-or-later | iptables module ip6t-dst |
iptables | iptables-module-ip6t-eui64 | 1.8.7 | GPL-2.0-or-later | iptables module ip6t-eui64 |
iptables | iptables-module-ip6t-frag | 1.8.7 | GPL-2.0-or-later | iptables module ip6t-frag |
iptables | iptables-module-ip6t-hbh | 1.8.7 | GPL-2.0-or-later | iptables module ip6t-hbh |
iptables | iptables-module-ip6t-hl | 1.8.7 | GPL-2.0-or-later | iptables module ip6t-hl |
iptables | iptables-module-ip6t-icmp6 | 1.8.7 | GPL-2.0-or-later | iptables module ip6t-icmp6 |
iptables | iptables-module-ip6t-ipv6header | 1.8.7 | GPL-2.0-or-later | iptables module ip6t-ipv6header |
iptables | iptables-module-ip6t-log | 1.8.7 | GPL-2.0-or-later | iptables module ip6t-log |
iptables | iptables-module-ip6t-masquerade | 1.8.7 | GPL-2.0-or-later | iptables module ip6t-masquerade |
iptables | iptables-module-ip6t-mh | 1.8.7 | GPL-2.0-or-later | iptables module ip6t-mh |
iptables | iptables-module-ip6t-netmap | 1.8.7 | GPL-2.0-or-later | iptables module ip6t-netmap |
iptables | iptables-module-ip6t-redirect | 1.8.7 | GPL-2.0-or-later | iptables module ip6t-redirect |
iptables | iptables-module-ip6t-reject | 1.8.7 | GPL-2.0-or-later | iptables module ip6t-reject |
iptables | iptables-module-ip6t-rt | 1.8.7 | GPL-2.0-or-later | iptables module ip6t-rt |
iptables | iptables-module-ip6t-snat | 1.8.7 | GPL-2.0-or-later | iptables module ip6t-snat |
iptables | iptables-module-ip6t-snpt | 1.8.7 | GPL-2.0-or-later | iptables module ip6t-snpt |
iptables | iptables-module-ip6t-srh | 1.8.7 | GPL-2.0-or-later | iptables module ip6t-srh |
iptables | iptables-module-ipt-ah | 1.8.7 | GPL-2.0-or-later | iptables module ipt-ah |
iptables | iptables-module-ipt-clusterip | 1.8.7 | GPL-2.0-or-later | iptables module ipt-clusterip |
iptables | iptables-module-ipt-dnat | 1.8.7 | GPL-2.0-or-later | iptables module ipt-dnat |
iptables | iptables-module-ipt-ecn | 1.8.7 | GPL-2.0-or-later | iptables module ipt-ecn |
iptables | iptables-module-ipt-icmp | 1.8.7 | GPL-2.0-or-later | iptables module ipt-icmp |
iptables | iptables-module-ipt-log | 1.8.7 | GPL-2.0-or-later | iptables module ipt-log |
iptables | iptables-module-ipt-masquerade | 1.8.7 | GPL-2.0-or-later | iptables module ipt-masquerade |
iptables | iptables-module-ipt-netmap | 1.8.7 | GPL-2.0-or-later | iptables module ipt-netmap |
iptables | iptables-module-ipt-realm | 1.8.7 | GPL-2.0-or-later | iptables module ipt-realm |
iptables | iptables-module-ipt-redirect | 1.8.7 | GPL-2.0-or-later | iptables module ipt-redirect |
iptables | iptables-module-ipt-reject | 1.8.7 | GPL-2.0-or-later | iptables module ipt-reject |
iptables | iptables-module-ipt-snat | 1.8.7 | GPL-2.0-or-later | iptables module ipt-snat |
iptables | iptables-module-ipt-ttl | 1.8.7 | GPL-2.0-or-later | iptables module ipt-ttl |
iptables | iptables-module-ipt-ulog | 1.8.7 | GPL-2.0-or-later | iptables module ipt-ulog |
iptables | iptables-module-xt-addrtype | 1.8.7 | GPL-2.0-or-later | iptables module xt-addrtype |
iptables | iptables-module-xt-audit | 1.8.7 | GPL-2.0-or-later | iptables module xt-audit |
iptables | iptables-module-xt-bpf | 1.8.7 | GPL-2.0-or-later | iptables module xt-bpf |
iptables | iptables-module-xt-cgroup | 1.8.7 | GPL-2.0-or-later | iptables module xt-cgroup |
iptables | iptables-module-xt-checksum | 1.8.7 | GPL-2.0-or-later | iptables module xt-checksum |
iptables | iptables-module-xt-classify | 1.8.7 | GPL-2.0-or-later | iptables module xt-classify |
iptables | iptables-module-xt-cluster | 1.8.7 | GPL-2.0-or-later | iptables module xt-cluster |
iptables | iptables-module-xt-comment | 1.8.7 | GPL-2.0-or-later | iptables module xt-comment |
iptables | iptables-module-xt-connbytes | 1.8.7 | GPL-2.0-or-later | iptables module xt-connbytes |
iptables | iptables-module-xt-connlimit | 1.8.7 | GPL-2.0-or-later | iptables module xt-connlimit |
iptables | iptables-module-xt-connmark | 1.8.7 | GPL-2.0-or-later | iptables module xt-connmark |
iptables | iptables-module-xt-connsecmark | 1.8.7 | GPL-2.0-or-later | iptables module xt-connsecmark |
iptables | iptables-module-xt-conntrack | 1.8.7 | GPL-2.0-or-later | iptables module xt-conntrack |
iptables | iptables-module-xt-cpu | 1.8.7 | GPL-2.0-or-later | iptables module xt-cpu |
iptables | iptables-module-xt-ct | 1.8.7 | GPL-2.0-or-later | iptables module xt-ct |
iptables | iptables-module-xt-dccp | 1.8.7 | GPL-2.0-or-later | iptables module xt-dccp |
iptables | iptables-module-xt-devgroup | 1.8.7 | GPL-2.0-or-later | iptables module xt-devgroup |
iptables | iptables-module-xt-dscp | 1.8.7 | GPL-2.0-or-later | iptables module xt-dscp |
iptables | iptables-module-xt-ecn | 1.8.7 | GPL-2.0-or-later | iptables module xt-ecn |
iptables | iptables-module-xt-esp | 1.8.7 | GPL-2.0-or-later | iptables module xt-esp |
iptables | iptables-module-xt-hashlimit | 1.8.7 | GPL-2.0-or-later | iptables module xt-hashlimit |
iptables | iptables-module-xt-helper | 1.8.7 | GPL-2.0-or-later | iptables module xt-helper |
iptables | iptables-module-xt-hmark | 1.8.7 | GPL-2.0-or-later | iptables module xt-hmark |
iptables | iptables-module-xt-idletimer | 1.8.7 | GPL-2.0-or-later | iptables module xt-idletimer |
iptables | iptables-module-xt-ipcomp | 1.8.7 | GPL-2.0-or-later | iptables module xt-ipcomp |
iptables | iptables-module-xt-iprange | 1.8.7 | GPL-2.0-or-later | iptables module xt-iprange |
iptables | iptables-module-xt-ipvs | 1.8.7 | GPL-2.0-or-later | iptables module xt-ipvs |
iptables | iptables-module-xt-led | 1.8.7 | GPL-2.0-or-later | iptables module xt-led |
iptables | iptables-module-xt-length | 1.8.7 | GPL-2.0-or-later | iptables module xt-length |
iptables | iptables-module-xt-limit | 1.8.7 | GPL-2.0-or-later | iptables module xt-limit |
iptables | iptables-module-xt-mac | 1.8.7 | GPL-2.0-or-later | iptables module xt-mac |
iptables | iptables-module-xt-mark | 1.8.7 | GPL-2.0-or-later | iptables module xt-mark |
iptables | iptables-module-xt-multiport | 1.8.7 | GPL-2.0-or-later | iptables module xt-multiport |
iptables | iptables-module-xt-nfacct | 1.8.7 | GPL-2.0-or-later | iptables module xt-nfacct |
iptables | iptables-module-xt-nflog | 1.8.7 | GPL-2.0-or-later | iptables module xt-nflog |
iptables | iptables-module-xt-nfqueue | 1.8.7 | GPL-2.0-or-later | iptables module xt-nfqueue |
iptables | iptables-module-xt-osf | 1.8.7 | GPL-2.0-or-later | iptables module xt-osf |
iptables | iptables-module-xt-owner | 1.8.7 | GPL-2.0-or-later | iptables module xt-owner |
iptables | iptables-module-xt-physdev | 1.8.7 | GPL-2.0-or-later | iptables module xt-physdev |
iptables | iptables-module-xt-pkttype | 1.8.7 | GPL-2.0-or-later | iptables module xt-pkttype |
iptables | iptables-module-xt-policy | 1.8.7 | GPL-2.0-or-later | iptables module xt-policy |
iptables | iptables-module-xt-quota | 1.8.7 | GPL-2.0-or-later | iptables module xt-quota |
iptables | iptables-module-xt-rateest | 1.8.7 | GPL-2.0-or-later | iptables module xt-rateest |
iptables | iptables-module-xt-recent | 1.8.7 | GPL-2.0-or-later | iptables module xt-recent |
iptables | iptables-module-xt-rpfilter | 1.8.7 | GPL-2.0-or-later | iptables module xt-rpfilter |
iptables | iptables-module-xt-sctp | 1.8.7 | GPL-2.0-or-later | iptables module xt-sctp |
iptables | iptables-module-xt-secmark | 1.8.7 | GPL-2.0-or-later | iptables module xt-secmark |
iptables | iptables-module-xt-set | 1.8.7 | GPL-2.0-or-later | iptables module xt-set |
iptables | iptables-module-xt-socket | 1.8.7 | GPL-2.0-or-later | iptables module xt-socket |
iptables | iptables-module-xt-standard | 1.8.7 | GPL-2.0-or-later | iptables module xt-standard |
iptables | iptables-module-xt-statistic | 1.8.7 | GPL-2.0-or-later | iptables module xt-statistic |
iptables | iptables-module-xt-string | 1.8.7 | GPL-2.0-or-later | iptables module xt-string |
iptables | iptables-module-xt-synproxy | 1.8.7 | GPL-2.0-or-later | iptables module xt-synproxy |
iptables | iptables-module-xt-tcp | 1.8.7 | GPL-2.0-or-later | iptables module xt-tcp |
iptables | iptables-module-xt-tcpmss | 1.8.7 | GPL-2.0-or-later | iptables module xt-tcpmss |
iptables | iptables-module-xt-tcpoptstrip | 1.8.7 | GPL-2.0-or-later | iptables module xt-tcpoptstrip |
iptables | iptables-module-xt-tee | 1.8.7 | GPL-2.0-or-later | iptables module xt-tee |
iptables | iptables-module-xt-time | 1.8.7 | GPL-2.0-or-later | iptables module xt-time |
iptables | iptables-module-xt-tos | 1.8.7 | GPL-2.0-or-later | iptables module xt-tos |
iptables | iptables-module-xt-tproxy | 1.8.7 | GPL-2.0-or-later | iptables module xt-tproxy |
iptables | iptables-module-xt-trace | 1.8.7 | GPL-2.0-or-later | iptables module xt-trace |
iptables | iptables-module-xt-u32 | 1.8.7 | GPL-2.0-or-later | iptables module xt-u32 |
iptables | iptables-module-xt-udp | 1.8.7 | GPL-2.0-or-later | iptables module xt-udp |
iputils | iputils-arping | 20211215 | BSD-3-Clause & GPL-2.0-or-later | Network monitoring tools |
iputils | iputils-clockdiff | 20211215 | BSD-3-Clause & GPL-2.0-or-later | Network monitoring tools |
iputils | iputils-ninfod | 20211215 | BSD-3-Clause & GPL-2.0-or-later | Network monitoring tools |
iputils | iputils-ping | 20211215 | BSD-3-Clause & GPL-2.0-or-later | Network monitoring tools |
iputils | iputils-rarpd | 20211215 | BSD-3-Clause & GPL-2.0-or-later | Network monitoring tools |
iputils | iputils-rdisc | 20211215 | BSD-3-Clause & GPL-2.0-or-later | Network monitoring tools |
iputils | iputils-tracepath | 20211215 | BSD-3-Clause & GPL-2.0-or-later | Network monitoring tools |
iw | iw | 5.16 | BSD-2-Clause | nl80211 based CLI configuration utility for wireless devices |
kbd | kbd | 2.4.0 | GPL-2.0-or-later | Keytable files and keyboard utilities |
kbd | kbd-consolefonts | 2.4.0 | GPL-2.0-or-later | Keytable files and keyboard utilities |
kbd | kbd-keymaps | 2.4.0 | GPL-2.0-or-later | Keytable files and keyboard utilities |
linux-stm32mp | kernel-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | Linux STM32MP Kernel |
linux-stm32mp | kernel-module-6lowpan-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | 6lowpan kernel module |
linux-stm32mp | kernel-module-8021q-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | 8021q kernel module |
linux-stm32mp | kernel-module-act-bpf-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | act-bpf kernel module |
linux-stm32mp | kernel-module-act-csum-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | act-csum kernel module |
linux-stm32mp | kernel-module-act-gact-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | act-gact kernel module |
linux-stm32mp | kernel-module-act-ife-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | act-ife kernel module |
linux-stm32mp | kernel-module-act-meta-mark-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | act-meta-mark kernel module |
linux-stm32mp | kernel-module-act-meta-skbprio-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | act-meta-skbprio kernel module |
linux-stm32mp | kernel-module-act-meta-skbtcindex-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | act-meta-skbtcindex kernel module |
linux-stm32mp | kernel-module-act-mirred-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | act-mirred kernel module |
linux-stm32mp | kernel-module-act-nat-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | act-nat kernel module |
linux-stm32mp | kernel-module-act-pedit-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | act-pedit kernel module |
linux-stm32mp | kernel-module-act-police-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | act-police kernel module |
linux-stm32mp | kernel-module-act-sample-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | act-sample kernel module |
linux-stm32mp | kernel-module-act-skbmod-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | act-skbmod kernel module |
linux-stm32mp | kernel-module-act-tunnel-key-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | act-tunnel-key kernel module |
linux-stm32mp | kernel-module-act-vlan-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | act-vlan kernel module |
linux-stm32mp | kernel-module-adv7180-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | adv7180 kernel module |
linux-stm32mp | kernel-module-adv7604-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | adv7604 kernel module |
linux-stm32mp | kernel-module-adxl34x-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | adxl34x kernel module |
linux-stm32mp | kernel-module-adxl34x-i2c-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | adxl34x-i2c kernel module |
linux-stm32mp | kernel-module-adxl34x-spi-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | adxl34x-spi kernel module |
linux-stm32mp | kernel-module-aes-arm-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | aes-arm kernel module |
linux-stm32mp | kernel-module-aes-arm-bs-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | aes-arm-bs kernel module |
linux-stm32mp | kernel-module-aes-arm-ce-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | aes-arm-ce kernel module |
linux-stm32mp | kernel-module-aes-generic-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | aes-generic kernel module |
linux-stm32mp | kernel-module-ah4-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | ah4 kernel module |
linux-stm32mp | kernel-module-ah6-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | ah6 kernel module |
linux-stm32mp | kernel-module-algif-aead-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | algif-aead kernel module |
linux-stm32mp | kernel-module-algif-rng-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | algif-rng kernel module |
linux-stm32mp | kernel-module-algif-skcipher-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | algif-skcipher kernel module |
linux-stm32mp | kernel-module-amlogic-gxl-crypto-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | amlogic-gxl-crypto kernel module |
linux-stm32mp | kernel-module-analogix-dp-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | analogix-dp kernel module |
linux-stm32mp | kernel-module-arp-tables-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | arp-tables kernel module |
linux-stm32mp | kernel-module-arpt-mangle-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | arpt-mangle kernel module |
linux-stm32mp | kernel-module-arptable-filter-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | arptable-filter kernel module |
linux-stm32mp | kernel-module-aspeed-pwm-tacho-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | aspeed-pwm-tacho kernel module |
linux-stm32mp | kernel-module-aspeed-video-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | aspeed-video kernel module |
linux-stm32mp | kernel-module-atmel-hlcdc-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | atmel-hlcdc kernel module |
linux-stm32mp | kernel-module-atmel-hlcdc-dc-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | atmel-hlcdc-dc kernel module |
linux-stm32mp | kernel-module-atmel-mxt-ts-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | atmel-mxt-ts kernel module |
linux-stm32mp | kernel-module-axp20x-pek-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | axp20x-pek kernel module |
linux-stm32mp | kernel-module-axp20x-usb-power-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | axp20x-usb-power kernel module |
linux-stm32mp | kernel-module-b53-common-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | b53-common kernel module |
linux-stm32mp | kernel-module-b53-mdio-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | b53-mdio kernel module |
linux-stm32mp | kernel-module-b53-mmap-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | b53-mmap kernel module |
linux-stm32mp | kernel-module-b53-serdes-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | b53-serdes kernel module |
linux-stm32mp | kernel-module-b53-spi-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | b53-spi kernel module |
linux-stm32mp | kernel-module-b53-srab-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | b53-srab kernel module |
linux-stm32mp | kernel-module-batman-adv-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | batman-adv kernel module |
linux-stm32mp | kernel-module-bcm-sf2-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | bcm-sf2 kernel module |
linux-stm32mp | kernel-module-bcm7xxx-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | bcm7xxx kernel module |
linux-stm32mp | kernel-module-bcmsysport-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | bcmsysport kernel module |
linux-stm32mp | kernel-module-bluetooth-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | bluetooth kernel module |
linux-stm32mp | kernel-module-bluetooth-6lowpan-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | bluetooth-6lowpan kernel module |
linux-stm32mp | kernel-module-bq27xxx-battery-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | bq27xxx-battery kernel module |
linux-stm32mp | kernel-module-bq27xxx-battery-i2c-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | bq27xxx-battery-i2c kernel module |
linux-stm32mp | kernel-module-brcmfmac-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | brcmfmac kernel module |
linux-stm32mp | kernel-module-brcmutil-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | brcmutil kernel module |
linux-stm32mp | kernel-module-bridge-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | bridge kernel module |
linux-stm32mp | kernel-module-btbcm-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | btbcm kernel module |
linux-stm32mp | kernel-module-btmrvl-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | btmrvl kernel module |
linux-stm32mp | kernel-module-btmrvl-sdio-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | btmrvl-sdio kernel module |
linux-stm32mp | kernel-module-ccm-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | ccm kernel module |
linux-stm32mp | kernel-module-cdc-acm-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | cdc-acm kernel module |
linux-stm32mp | kernel-module-cfb-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | cfb kernel module |
linux-stm32mp | kernel-module-cfbcopyarea-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | cfbcopyarea kernel module |
linux-stm32mp | kernel-module-cfbfillrect-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | cfbfillrect kernel module |
linux-stm32mp | kernel-module-cfbimgblt-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | cfbimgblt kernel module |
linux-stm32mp | kernel-module-cfg80211-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | cfg80211 kernel module |
linux-stm32mp | kernel-module-chacha-neon-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | chacha-neon kernel module |
linux-stm32mp | kernel-module-clk-rk808-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | clk-rk808 kernel module |
linux-stm32mp | kernel-module-clk-s2mps11-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | clk-s2mps11 kernel module |
linux-stm32mp | kernel-module-cls-basic-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | cls-basic kernel module |
linux-stm32mp | kernel-module-cls-bpf-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | cls-bpf kernel module |
linux-stm32mp | kernel-module-cls-cgroup-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | cls-cgroup kernel module |
linux-stm32mp | kernel-module-cls-flow-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | cls-flow kernel module |
linux-stm32mp | kernel-module-cls-flower-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | cls-flower kernel module |
linux-stm32mp | kernel-module-cls-fw-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | cls-fw kernel module |
linux-stm32mp | kernel-module-cls-matchall-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | cls-matchall kernel module |
linux-stm32mp | kernel-module-cls-route-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | cls-route kernel module |
linux-stm32mp | kernel-module-cls-rsvp-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | cls-rsvp kernel module |
linux-stm32mp | kernel-module-cls-rsvp6-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | cls-rsvp6 kernel module |
linux-stm32mp | kernel-module-cls-tcindex-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | cls-tcindex kernel module |
linux-stm32mp | kernel-module-cls-u32-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | cls-u32 kernel module |
linux-stm32mp | kernel-module-cm36651-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | cm36651 kernel module |
linux-stm32mp | kernel-module-cmac-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | cmac kernel module |
linux-stm32mp | kernel-module-counter-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | counter kernel module |
linux-stm32mp | kernel-module-cpcap-adc-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | cpcap-adc kernel module |
linux-stm32mp | kernel-module-cpcap-battery-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | cpcap-battery kernel module |
linux-stm32mp | kernel-module-cpcap-pwrbutton-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | cpcap-pwrbutton kernel module |
linux-stm32mp | kernel-module-cpufreq-conservative-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | cpufreq-conservative kernel module |
linux-stm32mp | kernel-module-cpufreq-powersave-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | cpufreq-powersave kernel module |
linux-stm32mp | kernel-module-cpufreq-userspace-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | cpufreq-userspace kernel module |
linux-stm32mp | kernel-module-crc-ccitt-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | crc-ccitt kernel module |
linux-stm32mp | kernel-module-crc-itu-t-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | crc-itu-t kernel module |
linux-stm32mp | kernel-module-crc32-arm-ce-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | crc32-arm-ce kernel module |
linux-stm32mp | kernel-module-crc4-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | crc4 kernel module |
linux-stm32mp | kernel-module-cryptd-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | cryptd kernel module |
linux-stm32mp | kernel-module-crypto-engine-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | crypto-engine kernel module |
linux-stm32mp | kernel-module-crypto-simd-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | crypto-simd kernel module |
linux-stm32mp | kernel-module-crypto-user-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | crypto-user kernel module |
cryptodev-module | kernel-module-cryptodev-5.15.67 | 1.12 | GPL-2.0-only | cryptodev kernel module |
linux-stm32mp | kernel-module-ctr-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | ctr kernel module |
linux-stm32mp | kernel-module-cyapatp-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | cyapatp kernel module |
linux-stm32mp | kernel-module-da9063-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | da9063 kernel module |
linux-stm32mp | kernel-module-da9063-onkey-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | da9063-onkey kernel module |
linux-stm32mp | kernel-module-da9063-wdt-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | da9063-wdt kernel module |
linux-stm32mp | kernel-module-dcmipp-bytecap-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | dcmipp-bytecap kernel module |
linux-stm32mp | kernel-module-dcmipp-byteproc-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | dcmipp-byteproc kernel module |
linux-stm32mp | kernel-module-dcmipp-parallel-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | dcmipp-parallel kernel module |
linux-stm32mp | kernel-module-drbg-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | drbg kernel module |
linux-stm32mp | kernel-module-dsa-core-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | dsa-core kernel module |
linux-stm32mp | kernel-module-dvb-core-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | dvb-core kernel module |
linux-stm32mp | kernel-module-dw-hdmi-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | dw-hdmi kernel module |
linux-stm32mp | kernel-module-dw-hdmi-imx-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | dw-hdmi-imx kernel module |
linux-stm32mp | kernel-module-ebt-802-3-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | ebt-802-3 kernel module |
linux-stm32mp | kernel-module-ebt-among-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | ebt-among kernel module |
linux-stm32mp | kernel-module-ebt-arp-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | ebt-arp kernel module |
linux-stm32mp | kernel-module-ebt-arpreply-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | ebt-arpreply kernel module |
linux-stm32mp | kernel-module-ebt-dnat-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | ebt-dnat kernel module |
linux-stm32mp | kernel-module-ebt-ip-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | ebt-ip kernel module |
linux-stm32mp | kernel-module-ebt-ip6-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | ebt-ip6 kernel module |
linux-stm32mp | kernel-module-ebt-limit-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | ebt-limit kernel module |
linux-stm32mp | kernel-module-ebt-log-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | ebt-log kernel module |
linux-stm32mp | kernel-module-ebt-mark-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | ebt-mark kernel module |
linux-stm32mp | kernel-module-ebt-mark-m-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | ebt-mark-m kernel module |
linux-stm32mp | kernel-module-ebt-nflog-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | ebt-nflog kernel module |
linux-stm32mp | kernel-module-ebt-pkttype-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | ebt-pkttype kernel module |
linux-stm32mp | kernel-module-ebt-redirect-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | ebt-redirect kernel module |
linux-stm32mp | kernel-module-ebt-snat-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | ebt-snat kernel module |
linux-stm32mp | kernel-module-ebt-stp-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | ebt-stp kernel module |
linux-stm32mp | kernel-module-ebt-vlan-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | ebt-vlan kernel module |
linux-stm32mp | kernel-module-ebtable-broute-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | ebtable-broute kernel module |
linux-stm32mp | kernel-module-ebtable-filter-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | ebtable-filter kernel module |
linux-stm32mp | kernel-module-ebtable-nat-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | ebtable-nat kernel module |
linux-stm32mp | kernel-module-ebtables-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | ebtables kernel module |
linux-stm32mp | kernel-module-ecb-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | ecb kernel module |
linux-stm32mp | kernel-module-ecc-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | ecc kernel module |
linux-stm32mp | kernel-module-ecdh-generic-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | ecdh-generic kernel module |
linux-stm32mp | kernel-module-echainiv-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | echainiv kernel module |
linux-stm32mp | kernel-module-elants-i2c-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | elants-i2c kernel module |
linux-stm32mp | kernel-module-em-canid-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | em-canid kernel module |
linux-stm32mp | kernel-module-em-cmp-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | em-cmp kernel module |
linux-stm32mp | kernel-module-em-meta-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | em-meta kernel module |
linux-stm32mp | kernel-module-em-nbyte-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | em-nbyte kernel module |
linux-stm32mp | kernel-module-em-text-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | em-text kernel module |
linux-stm32mp | kernel-module-em-u32-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | em-u32 kernel module |
linux-stm32mp | kernel-module-esp4-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | esp4 kernel module |
linux-stm32mp | kernel-module-esp4-offload-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | esp4-offload kernel module |
linux-stm32mp | kernel-module-esp6-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | esp6 kernel module |
linux-stm32mp | kernel-module-esp6-offload-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | esp6-offload kernel module |
linux-stm32mp | kernel-module-etnaviv-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | etnaviv kernel module |
linux-stm32mp | kernel-module-extcon-max14577-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | extcon-max14577 kernel module |
linux-stm32mp | kernel-module-extcon-max77693-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | extcon-max77693 kernel module |
linux-stm32mp | kernel-module-extcon-max8997-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | extcon-max8997 kernel module |
linux-stm32mp | kernel-module-exynosdrm-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | exynosdrm kernel module |
linux-stm32mp | kernel-module-ff-memless-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | ff-memless kernel module |
linux-stm32mp | kernel-module-flexcan-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | flexcan kernel module |
linux-stm32mp | kernel-module-font-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | font kernel module |
linux-stm32mp | kernel-module-fou-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | fou kernel module |
linux-stm32mp | kernel-module-fou6-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | fou6 kernel module |
linux-stm32mp | kernel-module-fsi-core-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | fsi-core kernel module |
linux-stm32mp | kernel-module-fsi-master-aspeed-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | fsi-master-aspeed kernel module |
linux-stm32mp | kernel-module-fsi-master-gpio-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | fsi-master-gpio kernel module |
linux-stm32mp | kernel-module-fsi-master-hub-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | fsi-master-hub kernel module |
linux-stm32mp | kernel-module-fsi-occ-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | fsi-occ kernel module |
linux-stm32mp | kernel-module-fsi-sbefifo-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | fsi-sbefifo kernel module |
linux-stm32mp | kernel-module-fsi-scom-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | fsi-scom kernel module |
linux-stm32mp | kernel-module-fsl-dcu-drm-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | fsl-dcu-drm kernel module |
linux-stm32mp | kernel-module-ftgmac100-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | ftgmac100 kernel module |
linux-stm32mp | kernel-module-g-ether-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | g-ether kernel module |
gcnano-driver-stm32mp | kernel-module-galcore-5.15.67 | 6.4.9-stm32mp-r2 | GPL-1.0-only & MIT | galcore kernel module |
linux-stm32mp | kernel-module-garp-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | garp kernel module |
linux-stm32mp | kernel-module-gc2145-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | gc2145 kernel module |
linux-stm32mp | kernel-module-gcm-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | gcm kernel module |
linux-stm32mp | kernel-module-genet-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | genet kernel module |
linux-stm32mp | kernel-module-gf128mul-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | gf128mul kernel module |
linux-stm32mp | kernel-module-ghash-arm-ce-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | ghash-arm-ce kernel module |
linux-stm32mp | kernel-module-ghash-generic-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | ghash-generic kernel module |
linux-stm32mp | kernel-module-governor-passive-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | governor-passive kernel module |
linux-stm32mp | kernel-module-gpio-charger-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | gpio-charger kernel module |
linux-stm32mp | kernel-module-gpu-sched-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | gpu-sched kernel module |
linux-stm32mp | kernel-module-gre-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | gre kernel module |
linux-stm32mp | kernel-module-hci-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | hci kernel module |
linux-stm32mp | kernel-module-hci-uart-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | hci-uart kernel module |
linux-stm32mp | kernel-module-hsr-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | hsr kernel module |
linux-stm32mp | kernel-module-i2c-arb-gpio-challenge-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | i2c-arb-gpio-challenge kernel module |
linux-stm32mp | kernel-module-ieee802154-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | ieee802154 kernel module |
linux-stm32mp | kernel-module-ieee802154-socket-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | ieee802154-socket kernel module |
linux-stm32mp | kernel-module-ife-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | ife kernel module |
linux-stm32mp | kernel-module-imx-ipu-v3-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | imx-ipu-v3 kernel module |
linux-stm32mp | kernel-module-imx-ldb-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | imx-ldb kernel module |
linux-stm32mp | kernel-module-imx-tve-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | imx-tve kernel module |
linux-stm32mp | kernel-module-imxdrm-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | imxdrm kernel module |
linux-stm32mp | kernel-module-ina2xx-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | ina2xx kernel module |
linux-stm32mp | kernel-module-industrialio-buffer-cb-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | industrialio-buffer-cb kernel module |
linux-stm32mp | kernel-module-industrialio-hw-consumer-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | industrialio-hw-consumer kernel module |
linux-stm32mp | kernel-module-inet-diag-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | inet-diag kernel module |
linux-stm32mp | kernel-module-ip-gre-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | ip-gre kernel module |
linux-stm32mp | kernel-module-ip-set-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | ip-set kernel module |
linux-stm32mp | kernel-module-ip-tables-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | ip-tables kernel module |
linux-stm32mp | kernel-module-ip-tunnel-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | ip-tunnel kernel module |
linux-stm32mp | kernel-module-ip-vs-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | ip-vs kernel module |
linux-stm32mp | kernel-module-ip-vti-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | ip-vti kernel module |
linux-stm32mp | kernel-module-ip6-gre-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | ip6-gre kernel module |
linux-stm32mp | kernel-module-ip6-tables-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | ip6-tables kernel module |
linux-stm32mp | kernel-module-ip6-tunnel-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | ip6-tunnel kernel module |
linux-stm32mp | kernel-module-ip6-udp-tunnel-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | ip6-udp-tunnel kernel module |
linux-stm32mp | kernel-module-ip6-vti-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | ip6-vti kernel module |
linux-stm32mp | kernel-module-ip6t-ah-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | ip6t-ah kernel module |
linux-stm32mp | kernel-module-ip6t-eui64-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | ip6t-eui64 kernel module |
linux-stm32mp | kernel-module-ip6t-frag-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | ip6t-frag kernel module |
linux-stm32mp | kernel-module-ip6t-hbh-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | ip6t-hbh kernel module |
linux-stm32mp | kernel-module-ip6t-ipv6header-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | ip6t-ipv6header kernel module |
linux-stm32mp | kernel-module-ip6t-mh-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | ip6t-mh kernel module |
linux-stm32mp | kernel-module-ip6t-npt-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | ip6t-npt kernel module |
linux-stm32mp | kernel-module-ip6t-reject-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | ip6t-reject kernel module |
linux-stm32mp | kernel-module-ip6t-rpfilter-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | ip6t-rpfilter kernel module |
linux-stm32mp | kernel-module-ip6t-rt-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | ip6t-rt kernel module |
linux-stm32mp | kernel-module-ip6t-synproxy-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | ip6t-synproxy kernel module |
linux-stm32mp | kernel-module-ip6table-filter-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | ip6table-filter kernel module |
linux-stm32mp | kernel-module-ip6table-mangle-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | ip6table-mangle kernel module |
linux-stm32mp | kernel-module-ip6table-nat-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | ip6table-nat kernel module |
linux-stm32mp | kernel-module-ip6table-raw-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | ip6table-raw kernel module |
linux-stm32mp | kernel-module-ipcomp-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | ipcomp kernel module |
linux-stm32mp | kernel-module-ipcomp6-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | ipcomp6 kernel module |
linux-stm32mp | kernel-module-ipip-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | ipip kernel module |
linux-stm32mp | kernel-module-ipt-ah-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | ipt-ah kernel module |
linux-stm32mp | kernel-module-ipt-clusterip-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | ipt-clusterip kernel module |
linux-stm32mp | kernel-module-ipt-ecn-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | ipt-ecn kernel module |
linux-stm32mp | kernel-module-ipt-reject-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | ipt-reject kernel module |
linux-stm32mp | kernel-module-ipt-rpfilter-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | ipt-rpfilter kernel module |
linux-stm32mp | kernel-module-ipt-synproxy-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | ipt-synproxy kernel module |
linux-stm32mp | kernel-module-iptable-filter-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | iptable-filter kernel module |
linux-stm32mp | kernel-module-iptable-mangle-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | iptable-mangle kernel module |
linux-stm32mp | kernel-module-iptable-nat-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | iptable-nat kernel module |
linux-stm32mp | kernel-module-iptable-raw-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | iptable-raw kernel module |
linux-stm32mp | kernel-module-ipv6-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | ipv6 kernel module |
linux-stm32mp | kernel-module-jitterentropy-rng-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | jitterentropy-rng kernel module |
linux-stm32mp | kernel-module-l2tp-core-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | l2tp-core kernel module |
linux-stm32mp | kernel-module-led-class-flash-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | led-class-flash kernel module |
linux-stm32mp | kernel-module-leds-cpcap-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | leds-cpcap kernel module |
linux-stm32mp | kernel-module-leds-max77693-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | leds-max77693 kernel module |
linux-stm32mp | kernel-module-leds-max8997-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | leds-max8997 kernel module |
linux-stm32mp | kernel-module-ledtrig-audio-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | ledtrig-audio kernel module |
linux-stm32mp | kernel-module-libaes-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | libaes kernel module |
linux-stm32mp | kernel-module-libarc4-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | libarc4 kernel module |
linux-stm32mp | kernel-module-libcomposite-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | libcomposite kernel module |
linux-stm32mp | kernel-module-libcrc32c-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | libcrc32c kernel module |
linux-stm32mp | kernel-module-libdes-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | libdes kernel module |
linux-stm32mp | kernel-module-lima-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | lima kernel module |
linux-stm32mp | kernel-module-llc-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | llc kernel module |
linux-stm32mp | kernel-module-llc2-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | llc2 kernel module |
linux-stm32mp | kernel-module-lrw-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | lrw kernel module |
lttng-modules | kernel-module-lttng-clock-5.15.67 | 2.13.4 | LGPL-2.1-only & GPL-2.0-only & MIT | lttng-clock kernel module |
lttng-modules | kernel-module-lttng-clock-plugin-test-5.15.67 | 2.13.4 | LGPL-2.1-only & GPL-2.0-only & MIT | lttng-clock-plugin-test kernel module |
lttng-modules | kernel-module-lttng-counter-5.15.67 | 2.13.4 | LGPL-2.1-only & GPL-2.0-only & MIT | lttng-counter kernel module |
lttng-modules | kernel-module-lttng-counter-client-percpu-32-modular-5.15.67 | 2.13.4 | LGPL-2.1-only & GPL-2.0-only & MIT | lttng-counter-client-percpu-32-modular kernel module |
lttng-modules | kernel-module-lttng-counter-client-percpu-64-modular-5.15.67 | 2.13.4 | LGPL-2.1-only & GPL-2.0-only & MIT | lttng-counter-client-percpu-64-modular kernel module |
lttng-modules | kernel-module-lttng-kprobes-5.15.67 | 2.13.4 | LGPL-2.1-only & GPL-2.0-only & MIT | lttng-kprobes kernel module |
lttng-modules | kernel-module-lttng-kretprobes-5.15.67 | 2.13.4 | LGPL-2.1-only & GPL-2.0-only & MIT | lttng-kretprobes kernel module |
lttng-modules | kernel-module-lttng-lib-ring-buffer-5.15.67 | 2.13.4 | LGPL-2.1-only & GPL-2.0-only & MIT | lttng-lib-ring-buffer kernel module |
lttng-modules | kernel-module-lttng-probe-asoc-5.15.67 | 2.13.4 | LGPL-2.1-only & GPL-2.0-only & MIT | lttng-probe-asoc kernel module |
lttng-modules | kernel-module-lttng-probe-block-5.15.67 | 2.13.4 | LGPL-2.1-only & GPL-2.0-only & MIT | lttng-probe-block kernel module |
lttng-modules | kernel-module-lttng-probe-compaction-5.15.67 | 2.13.4 | LGPL-2.1-only & GPL-2.0-only & MIT | lttng-probe-compaction kernel module |
lttng-modules | kernel-module-lttng-probe-ext4-5.15.67 | 2.13.4 | LGPL-2.1-only & GPL-2.0-only & MIT | lttng-probe-ext4 kernel module |
lttng-modules | kernel-module-lttng-probe-gpio-5.15.67 | 2.13.4 | LGPL-2.1-only & GPL-2.0-only & MIT | lttng-probe-gpio kernel module |
lttng-modules | kernel-module-lttng-probe-i2c-5.15.67 | 2.13.4 | LGPL-2.1-only & GPL-2.0-only & MIT | lttng-probe-i2c kernel module |
lttng-modules | kernel-module-lttng-probe-irq-5.15.67 | 2.13.4 | LGPL-2.1-only & GPL-2.0-only & MIT | lttng-probe-irq kernel module |
lttng-modules | kernel-module-lttng-probe-jbd2-5.15.67 | 2.13.4 | LGPL-2.1-only & GPL-2.0-only & MIT | lttng-probe-jbd2 kernel module |
lttng-modules | kernel-module-lttng-probe-kmem-5.15.67 | 2.13.4 | LGPL-2.1-only & GPL-2.0-only & MIT | lttng-probe-kmem kernel module |
lttng-modules | kernel-module-lttng-probe-module-5.15.67 | 2.13.4 | LGPL-2.1-only & GPL-2.0-only & MIT | lttng-probe-module kernel module |
lttng-modules | kernel-module-lttng-probe-napi-5.15.67 | 2.13.4 | LGPL-2.1-only & GPL-2.0-only & MIT | lttng-probe-napi kernel module |
lttng-modules | kernel-module-lttng-probe-net-5.15.67 | 2.13.4 | LGPL-2.1-only & GPL-2.0-only & MIT | lttng-probe-net kernel module |
lttng-modules | kernel-module-lttng-probe-power-5.15.67 | 2.13.4 | LGPL-2.1-only & GPL-2.0-only & MIT | lttng-probe-power kernel module |
lttng-modules | kernel-module-lttng-probe-printk-5.15.67 | 2.13.4 | LGPL-2.1-only & GPL-2.0-only & MIT | lttng-probe-printk kernel module |
lttng-modules | kernel-module-lttng-probe-rcu-5.15.67 | 2.13.4 | LGPL-2.1-only & GPL-2.0-only & MIT | lttng-probe-rcu kernel module |
lttng-modules | kernel-module-lttng-probe-regmap-5.15.67 | 2.13.4 | LGPL-2.1-only & GPL-2.0-only & MIT | lttng-probe-regmap kernel module |
lttng-modules | kernel-module-lttng-probe-regulator-5.15.67 | 2.13.4 | LGPL-2.1-only & GPL-2.0-only & MIT | lttng-probe-regulator kernel module |
lttng-modules | kernel-module-lttng-probe-sched-5.15.67 | 2.13.4 | LGPL-2.1-only & GPL-2.0-only & MIT | lttng-probe-sched kernel module |
lttng-modules | kernel-module-lttng-probe-scsi-5.15.67 | 2.13.4 | LGPL-2.1-only & GPL-2.0-only & MIT | lttng-probe-scsi kernel module |
lttng-modules | kernel-module-lttng-probe-signal-5.15.67 | 2.13.4 | LGPL-2.1-only & GPL-2.0-only & MIT | lttng-probe-signal kernel module |
lttng-modules | kernel-module-lttng-probe-skb-5.15.67 | 2.13.4 | LGPL-2.1-only & GPL-2.0-only & MIT | lttng-probe-skb kernel module |
lttng-modules | kernel-module-lttng-probe-sock-5.15.67 | 2.13.4 | LGPL-2.1-only & GPL-2.0-only & MIT | lttng-probe-sock kernel module |
lttng-modules | kernel-module-lttng-probe-statedump-5.15.67 | 2.13.4 | LGPL-2.1-only & GPL-2.0-only & MIT | lttng-probe-statedump kernel module |
lttng-modules | kernel-module-lttng-probe-sunrpc-5.15.67 | 2.13.4 | LGPL-2.1-only & GPL-2.0-only & MIT | lttng-probe-sunrpc kernel module |
lttng-modules | kernel-module-lttng-probe-timer-5.15.67 | 2.13.4 | LGPL-2.1-only & GPL-2.0-only & MIT | lttng-probe-timer kernel module |
lttng-modules | kernel-module-lttng-probe-udp-5.15.67 | 2.13.4 | LGPL-2.1-only & GPL-2.0-only & MIT | lttng-probe-udp kernel module |
lttng-modules | kernel-module-lttng-probe-v4l2-5.15.67 | 2.13.4 | LGPL-2.1-only & GPL-2.0-only & MIT | lttng-probe-v4l2 kernel module |
lttng-modules | kernel-module-lttng-probe-vmscan-5.15.67 | 2.13.4 | LGPL-2.1-only & GPL-2.0-only & MIT | lttng-probe-vmscan kernel module |
lttng-modules | kernel-module-lttng-probe-workqueue-5.15.67 | 2.13.4 | LGPL-2.1-only & GPL-2.0-only & MIT | lttng-probe-workqueue kernel module |
lttng-modules | kernel-module-lttng-ring-buffer-client-discard-5.15.67 | 2.13.4 | LGPL-2.1-only & GPL-2.0-only & MIT | lttng-ring-buffer-client-discard kernel module |
lttng-modules | kernel-module-lttng-ring-buffer-client-mmap-discard-5.15.67 | 2.13.4 | LGPL-2.1-only & GPL-2.0-only & MIT | lttng-ring-buffer-client-mmap-discard kernel module |
lttng-modules | kernel-module-lttng-ring-buffer-client-mmap-overwrite-5.15.67 | 2.13.4 | LGPL-2.1-only & GPL-2.0-only & MIT | lttng-ring-buffer-client-mmap-overwrite kernel module |
lttng-modules | kernel-module-lttng-ring-buffer-client-overwrite-5.15.67 | 2.13.4 | LGPL-2.1-only & GPL-2.0-only & MIT | lttng-ring-buffer-client-overwrite kernel module |
lttng-modules | kernel-module-lttng-ring-buffer-event-notifier-client-5.15.67 | 2.13.4 | LGPL-2.1-only & GPL-2.0-only & MIT | lttng-ring-buffer-event-notifier-client kernel module |
lttng-modules | kernel-module-lttng-ring-buffer-metadata-client-5.15.67 | 2.13.4 | LGPL-2.1-only & GPL-2.0-only & MIT | lttng-ring-buffer-metadata-client kernel module |
lttng-modules | kernel-module-lttng-ring-buffer-metadata-mmap-client-5.15.67 | 2.13.4 | LGPL-2.1-only & GPL-2.0-only & MIT | lttng-ring-buffer-metadata-mmap-client kernel module |
lttng-modules | kernel-module-lttng-statedump-5.15.67 | 2.13.4 | LGPL-2.1-only & GPL-2.0-only & MIT | lttng-statedump kernel module |
lttng-modules | kernel-module-lttng-test-5.15.67 | 2.13.4 | LGPL-2.1-only & GPL-2.0-only & MIT | lttng-test kernel module |
lttng-modules | kernel-module-lttng-tracer-5.15.67 | 2.13.4 | LGPL-2.1-only & GPL-2.0-only & MIT | lttng-tracer kernel module |
lttng-modules | kernel-module-lttng-uprobes-5.15.67 | 2.13.4 | LGPL-2.1-only & GPL-2.0-only & MIT | lttng-uprobes kernel module |
lttng-modules | kernel-module-lttng-wrapper-5.15.67 | 2.13.4 | LGPL-2.1-only & GPL-2.0-only & MIT | lttng-wrapper kernel module |
linux-stm32mp | kernel-module-mac80211-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | mac80211 kernel module |
linux-stm32mp | kernel-module-macvlan-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | macvlan kernel module |
linux-stm32mp | kernel-module-macvtap-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | macvtap kernel module |
linux-stm32mp | kernel-module-max14577-charger-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | max14577-charger kernel module |
linux-stm32mp | kernel-module-max14577-regulator-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | max14577-regulator kernel module |
linux-stm32mp | kernel-module-max17040-battery-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | max17040-battery kernel module |
linux-stm32mp | kernel-module-max17042-battery-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | max17042-battery kernel module |
linux-stm32mp | kernel-module-max77693-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | max77693 kernel module |
linux-stm32mp | kernel-module-max77693-charger-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | max77693-charger kernel module |
linux-stm32mp | kernel-module-max77693-haptic-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | max77693-haptic kernel module |
linux-stm32mp | kernel-module-max77693-regulator-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | max77693-regulator kernel module |
linux-stm32mp | kernel-module-max8952-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | max8952 kernel module |
linux-stm32mp | kernel-module-max8997-charger-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | max8997-charger kernel module |
linux-stm32mp | kernel-module-max8997-haptic-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | max8997-haptic kernel module |
linux-stm32mp | kernel-module-max8997-regulator-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | max8997-regulator kernel module |
linux-stm32mp | kernel-module-max8998-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | max8998 kernel module |
linux-stm32mp | kernel-module-max8998-charger-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | max8998-charger kernel module |
linux-stm32mp | kernel-module-mc-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | mc kernel module |
linux-stm32mp | kernel-module-mchp23k256-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | mchp23k256 kernel module |
linux-stm32mp | kernel-module-mdio-bcm-unimac-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | mdio-bcm-unimac kernel module |
linux-stm32mp | kernel-module-mip6-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | mip6 kernel module |
linux-stm32mp | kernel-module-ml86v7667-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | ml86v7667 kernel module |
linux-stm32mp | kernel-module-mms114-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | mms114 kernel module |
linux-stm32mp | kernel-module-mpls-gso-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | mpls-gso kernel module |
linux-stm32mp | kernel-module-mrp-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | mrp kernel module |
linux-stm32mp | kernel-module-mwifiex-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | mwifiex kernel module |
linux-stm32mp | kernel-module-mwifiex-sdio-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | mwifiex-sdio kernel module |
linux-stm32mp | kernel-module-mxsfb-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | mxsfb kernel module |
linux-stm32mp | kernel-module-nci-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | nci kernel module |
linux-stm32mp | kernel-module-nci-spi-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | nci-spi kernel module |
linux-stm32mp | kernel-module-nci-uart-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | nci-uart kernel module |
linux-stm32mp | kernel-module-netlink-diag-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | netlink-diag kernel module |
linux-stm32mp | kernel-module-nf-conncount-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | nf-conncount kernel module |
linux-stm32mp | kernel-module-nf-conntrack-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | nf-conntrack kernel module |
linux-stm32mp | kernel-module-nf-conntrack-amanda-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | nf-conntrack-amanda kernel module |
linux-stm32mp | kernel-module-nf-conntrack-broadcast-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | nf-conntrack-broadcast kernel module |
linux-stm32mp | kernel-module-nf-conntrack-ftp-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | nf-conntrack-ftp kernel module |
linux-stm32mp | kernel-module-nf-conntrack-h323-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | nf-conntrack-h323 kernel module |
linux-stm32mp | kernel-module-nf-conntrack-irc-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | nf-conntrack-irc kernel module |
linux-stm32mp | kernel-module-nf-conntrack-netbios-ns-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | nf-conntrack-netbios-ns kernel module |
linux-stm32mp | kernel-module-nf-conntrack-netlink-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | nf-conntrack-netlink kernel module |
linux-stm32mp | kernel-module-nf-conntrack-pptp-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | nf-conntrack-pptp kernel module |
linux-stm32mp | kernel-module-nf-conntrack-sip-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | nf-conntrack-sip kernel module |
linux-stm32mp | kernel-module-nf-conntrack-snmp-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | nf-conntrack-snmp kernel module |
linux-stm32mp | kernel-module-nf-conntrack-tftp-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | nf-conntrack-tftp kernel module |
linux-stm32mp | kernel-module-nf-defrag-ipv4-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | nf-defrag-ipv4 kernel module |
linux-stm32mp | kernel-module-nf-defrag-ipv6-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | nf-defrag-ipv6 kernel module |
linux-stm32mp | kernel-module-nf-dup-ipv4-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | nf-dup-ipv4 kernel module |
linux-stm32mp | kernel-module-nf-dup-ipv6-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | nf-dup-ipv6 kernel module |
linux-stm32mp | kernel-module-nf-log-syslog-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | nf-log-syslog kernel module |
linux-stm32mp | kernel-module-nf-nat-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | nf-nat kernel module |
linux-stm32mp | kernel-module-nf-nat-amanda-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | nf-nat-amanda kernel module |
linux-stm32mp | kernel-module-nf-nat-ftp-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | nf-nat-ftp kernel module |
linux-stm32mp | kernel-module-nf-nat-h323-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | nf-nat-h323 kernel module |
linux-stm32mp | kernel-module-nf-nat-irc-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | nf-nat-irc kernel module |
linux-stm32mp | kernel-module-nf-nat-pptp-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | nf-nat-pptp kernel module |
linux-stm32mp | kernel-module-nf-nat-sip-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | nf-nat-sip kernel module |
linux-stm32mp | kernel-module-nf-nat-snmp-basic-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | nf-nat-snmp-basic kernel module |
linux-stm32mp | kernel-module-nf-nat-tftp-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | nf-nat-tftp kernel module |
linux-stm32mp | kernel-module-nf-reject-ipv4-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | nf-reject-ipv4 kernel module |
linux-stm32mp | kernel-module-nf-reject-ipv6-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | nf-reject-ipv6 kernel module |
linux-stm32mp | kernel-module-nf-socket-ipv4-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | nf-socket-ipv4 kernel module |
linux-stm32mp | kernel-module-nf-socket-ipv6-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | nf-socket-ipv6 kernel module |
linux-stm32mp | kernel-module-nf-synproxy-core-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | nf-synproxy-core kernel module |
linux-stm32mp | kernel-module-nf-tables-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | nf-tables kernel module |
linux-stm32mp | kernel-module-nfc-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | nfc kernel module |
linux-stm32mp | kernel-module-nfc-digital-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | nfc-digital kernel module |
linux-stm32mp | kernel-module-nfnetlink-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | nfnetlink kernel module |
linux-stm32mp | kernel-module-nfnetlink-acct-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | nfnetlink-acct kernel module |
linux-stm32mp | kernel-module-nfnetlink-cthelper-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | nfnetlink-cthelper kernel module |
linux-stm32mp | kernel-module-nfnetlink-cttimeout-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | nfnetlink-cttimeout kernel module |
linux-stm32mp | kernel-module-nfnetlink-log-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | nfnetlink-log kernel module |
linux-stm32mp | kernel-module-nfnetlink-osf-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | nfnetlink-osf kernel module |
linux-stm32mp | kernel-module-nfnetlink-queue-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | nfnetlink-queue kernel module |
linux-stm32mp | kernel-module-nft-counter-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | nft-counter kernel module |
linux-stm32mp | kernel-module-nft-ct-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | nft-ct kernel module |
linux-stm32mp | kernel-module-nft-hash-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | nft-hash kernel module |
linux-stm32mp | kernel-module-nft-limit-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | nft-limit kernel module |
linux-stm32mp | kernel-module-nft-log-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | nft-log kernel module |
linux-stm32mp | kernel-module-nft-masq-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | nft-masq kernel module |
linux-stm32mp | kernel-module-nft-meta-bridge-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | nft-meta-bridge kernel module |
linux-stm32mp | kernel-module-nft-numgen-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | nft-numgen kernel module |
linux-stm32mp | kernel-module-nft-objref-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | nft-objref kernel module |
linux-stm32mp | kernel-module-nft-queue-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | nft-queue kernel module |
linux-stm32mp | kernel-module-nft-quota-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | nft-quota kernel module |
linux-stm32mp | kernel-module-nft-redir-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | nft-redir kernel module |
linux-stm32mp | kernel-module-nft-reject-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | nft-reject kernel module |
linux-stm32mp | kernel-module-nft-reject-bridge-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | nft-reject-bridge kernel module |
linux-stm32mp | kernel-module-nhc-dest-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | nhc-dest kernel module |
linux-stm32mp | kernel-module-nhc-fragment-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | nhc-fragment kernel module |
linux-stm32mp | kernel-module-nhc-hop-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | nhc-hop kernel module |
linux-stm32mp | kernel-module-nhc-ipv6-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | nhc-ipv6 kernel module |
linux-stm32mp | kernel-module-nhc-mobility-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | nhc-mobility kernel module |
linux-stm32mp | kernel-module-nhc-routing-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | nhc-routing kernel module |
linux-stm32mp | kernel-module-nhc-udp-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | nhc-udp kernel module |
linux-stm32mp | kernel-module-nsh-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | nsh kernel module |
linux-stm32mp | kernel-module-ntc-thermistor-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | ntc-thermistor kernel module |
linux-stm32mp | kernel-module-nvmem-rmem-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | nvmem-rmem kernel module |
linux-stm32mp | kernel-module-nxp-ptn3460-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | nxp-ptn3460 kernel module |
linux-stm32mp | kernel-module-ofb-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | ofb kernel module |
linux-stm32mp | kernel-module-openvswitch-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | openvswitch kernel module |
linux-stm32mp | kernel-module-ov5640-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | ov5640 kernel module |
linux-stm32mp | kernel-module-ov7670-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | ov7670 kernel module |
linux-stm32mp | kernel-module-p8022-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | p8022 kernel module |
linux-stm32mp | kernel-module-panel-samsung-ld9040-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | panel-samsung-ld9040 kernel module |
linux-stm32mp | kernel-module-panel-samsung-s6e63j0x03-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | panel-samsung-s6e63j0x03 kernel module |
linux-stm32mp | kernel-module-panel-samsung-s6e8aa0-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | panel-samsung-s6e8aa0 kernel module |
linux-stm32mp | kernel-module-panfrost-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | panfrost kernel module |
linux-stm32mp | kernel-module-parade-ps8622-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | parade-ps8622 kernel module |
linux-stm32mp | kernel-module-parallel-display-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | parallel-display kernel module |
linux-stm32mp | kernel-module-phy-am335x-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | phy-am335x kernel module |
linux-stm32mp | kernel-module-phy-am335x-control-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | phy-am335x-control kernel module |
linux-stm32mp | kernel-module-phy-cpcap-usb-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | phy-cpcap-usb kernel module |
linux-stm32mp | kernel-module-phy-exynos-usb2-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | phy-exynos-usb2 kernel module |
linux-stm32mp | kernel-module-pl111-drm-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | pl111-drm kernel module |
linux-stm32mp | kernel-module-psample-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | psample kernel module |
linux-stm32mp | kernel-module-psnap-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | psnap kernel module |
linux-stm32mp | kernel-module-pwm-atmel-hlcdc-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | pwm-atmel-hlcdc kernel module |
linux-stm32mp | kernel-module-pwm-fan-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | pwm-fan kernel module |
linux-stm32mp | kernel-module-pwm-fsl-ftm-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | pwm-fsl-ftm kernel module |
linux-stm32mp | kernel-module-pwm-stm32-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | pwm-stm32 kernel module |
linux-stm32mp | kernel-module-pwm-stm32-lp-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | pwm-stm32-lp kernel module |
linux-stm32mp | kernel-module-qt1070-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | qt1070 kernel module |
linux-stm32mp | kernel-module-r8152-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | r8152 kernel module |
linux-stm32mp | kernel-module-r8153-ecm-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | r8153-ecm kernel module |
linux-stm32mp | kernel-module-r8a66597-hcd-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | r8a66597-hcd kernel module |
linux-stm32mp | kernel-module-raw-diag-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | raw-diag kernel module |
linux-stm32mp | kernel-module-resistive-adc-touch-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | resistive-adc-touch kernel module |
linux-stm32mp | kernel-module-rpmsg-client-sample-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | rpmsg-client-sample kernel module |
linux-stm32mp | kernel-module-rpmsg-tty-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | rpmsg-tty kernel module |
linux-stm32mp | kernel-module-rt2800lib-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | rt2800lib kernel module |
linux-stm32mp | kernel-module-rt2800usb-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | rt2800usb kernel module |
linux-stm32mp | kernel-module-rt2x00lib-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | rt2x00lib kernel module |
linux-stm32mp | kernel-module-rt2x00usb-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | rt2x00usb kernel module |
linux-stm32mp | kernel-module-rtc-bq32k-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | rtc-bq32k kernel module |
linux-stm32mp | kernel-module-rtc-cpcap-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | rtc-cpcap kernel module |
linux-stm32mp | kernel-module-rtc-da9063-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | rtc-da9063 kernel module |
linux-stm32mp | kernel-module-rtc-hym8563-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | rtc-hym8563 kernel module |
linux-stm32mp | kernel-module-rtc-max8997-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | rtc-max8997 kernel module |
linux-stm32mp | kernel-module-rtc-max8998-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | rtc-max8998 kernel module |
linux-stm32mp | kernel-module-rtc-pcf85363-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | rtc-pcf85363 kernel module |
linux-stm32mp | kernel-module-rtc-rk808-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | rtc-rk808 kernel module |
linux-stm32mp | kernel-module-rtc-rs5c372-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | rtc-rs5c372 kernel module |
linux-stm32mp | kernel-module-rtc-rx8581-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | rtc-rx8581 kernel module |
linux-stm32mp | kernel-module-rtc-s35390a-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | rtc-s35390a kernel module |
linux-stm32mp | kernel-module-rtc-s5m-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | rtc-s5m kernel module |
linux-stm32mp | kernel-module-s2mpa01-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | s2mpa01 kernel module |
linux-stm32mp | kernel-module-s3fwrn5-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | s3fwrn5 kernel module |
linux-stm32mp | kernel-module-s3fwrn5-i2c-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | s3fwrn5-i2c kernel module |
linux-stm32mp | kernel-module-samsung-keypad-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | samsung-keypad kernel module |
linux-stm32mp | kernel-module-sch-cbq-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | sch-cbq kernel module |
linux-stm32mp | kernel-module-sch-choke-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | sch-choke kernel module |
linux-stm32mp | kernel-module-sch-codel-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | sch-codel kernel module |
linux-stm32mp | kernel-module-sch-drr-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | sch-drr kernel module |
linux-stm32mp | kernel-module-sch-dsmark-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | sch-dsmark kernel module |
linux-stm32mp | kernel-module-sch-fq-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | sch-fq kernel module |
linux-stm32mp | kernel-module-sch-fq-codel-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | sch-fq-codel kernel module |
linux-stm32mp | kernel-module-sch-gred-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | sch-gred kernel module |
linux-stm32mp | kernel-module-sch-hfsc-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | sch-hfsc kernel module |
linux-stm32mp | kernel-module-sch-hhf-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | sch-hhf kernel module |
linux-stm32mp | kernel-module-sch-htb-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | sch-htb kernel module |
linux-stm32mp | kernel-module-sch-mqprio-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | sch-mqprio kernel module |
linux-stm32mp | kernel-module-sch-multiq-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | sch-multiq kernel module |
linux-stm32mp | kernel-module-sch-netem-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | sch-netem kernel module |
linux-stm32mp | kernel-module-sch-pie-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | sch-pie kernel module |
linux-stm32mp | kernel-module-sch-plug-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | sch-plug kernel module |
linux-stm32mp | kernel-module-sch-prio-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | sch-prio kernel module |
linux-stm32mp | kernel-module-sch-qfq-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | sch-qfq kernel module |
linux-stm32mp | kernel-module-sch-red-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | sch-red kernel module |
linux-stm32mp | kernel-module-sch-sfb-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | sch-sfb kernel module |
linux-stm32mp | kernel-module-sch-sfq-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | sch-sfq kernel module |
linux-stm32mp | kernel-module-sch-tbf-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | sch-tbf kernel module |
linux-stm32mp | kernel-module-sch-teql-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | sch-teql kernel module |
linux-stm32mp | kernel-module-seqiv-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | seqiv kernel module |
linux-stm32mp | kernel-module-sha1-arm-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | sha1-arm kernel module |
linux-stm32mp | kernel-module-sha1-arm-ce-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | sha1-arm-ce kernel module |
linux-stm32mp | kernel-module-sha1-arm-neon-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | sha1-arm-neon kernel module |
linux-stm32mp | kernel-module-sha2-arm-ce-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | sha2-arm-ce kernel module |
linux-stm32mp | kernel-module-sha256-arm-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | sha256-arm kernel module |
linux-stm32mp | kernel-module-sha512-arm-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | sha512-arm kernel module |
linux-stm32mp | kernel-module-sha512-generic-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | sha512-generic kernel module |
linux-stm32mp | kernel-module-sii9234-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | sii9234 kernel module |
linux-stm32mp | kernel-module-simple-bridge-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | simple-bridge kernel module |
linux-stm32mp | kernel-module-sit-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | sit kernel module |
linux-stm32mp | kernel-module-snd-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | snd kernel module |
linux-stm32mp | kernel-module-snd-hwdep-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | snd-hwdep kernel module |
linux-stm32mp | kernel-module-snd-pcm-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | snd-pcm kernel module |
linux-stm32mp | kernel-module-snd-pcm-dmaengine-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | snd-pcm-dmaengine kernel module |
linux-stm32mp | kernel-module-snd-rawmidi-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | snd-rawmidi kernel module |
linux-stm32mp | kernel-module-snd-soc-ak4642-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | snd-soc-ak4642 kernel module |
linux-stm32mp | kernel-module-snd-soc-audio-graph-card-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | snd-soc-audio-graph-card kernel module |
linux-stm32mp | kernel-module-snd-soc-core-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | snd-soc-core kernel module |
linux-stm32mp | kernel-module-snd-soc-cpcap-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | snd-soc-cpcap kernel module |
linux-stm32mp | kernel-module-snd-soc-cs42l51-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | snd-soc-cs42l51 kernel module |
linux-stm32mp | kernel-module-snd-soc-cs42l51-i2c-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | snd-soc-cs42l51-i2c kernel module |
linux-stm32mp | kernel-module-snd-soc-dmic-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | snd-soc-dmic kernel module |
linux-stm32mp | kernel-module-snd-soc-fsl-sai-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | snd-soc-fsl-sai kernel module |
linux-stm32mp | kernel-module-snd-soc-hdmi-codec-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | snd-soc-hdmi-codec kernel module |
linux-stm32mp | kernel-module-snd-soc-rl6231-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | snd-soc-rl6231 kernel module |
linux-stm32mp | kernel-module-snd-soc-rt5631-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | snd-soc-rt5631 kernel module |
linux-stm32mp | kernel-module-snd-soc-rt5640-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | snd-soc-rt5640 kernel module |
linux-stm32mp | kernel-module-snd-soc-sgtl5000-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | snd-soc-sgtl5000 kernel module |
linux-stm32mp | kernel-module-snd-soc-simple-card-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | snd-soc-simple-card kernel module |
linux-stm32mp | kernel-module-snd-soc-simple-card-utils-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | snd-soc-simple-card-utils kernel module |
linux-stm32mp | kernel-module-snd-soc-spdif-rx-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | snd-soc-spdif-rx kernel module |
linux-stm32mp | kernel-module-snd-soc-spdif-tx-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | snd-soc-spdif-tx kernel module |
linux-stm32mp | kernel-module-snd-soc-sti-sas-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | snd-soc-sti-sas kernel module |
linux-stm32mp | kernel-module-snd-soc-stm32-i2s-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | snd-soc-stm32-i2s kernel module |
linux-stm32mp | kernel-module-snd-soc-stm32-sai-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | snd-soc-stm32-sai kernel module |
linux-stm32mp | kernel-module-snd-soc-stm32-sai-sub-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | snd-soc-stm32-sai-sub kernel module |
linux-stm32mp | kernel-module-snd-soc-stm32-spdifrx-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | snd-soc-stm32-spdifrx kernel module |
linux-stm32mp | kernel-module-snd-soc-tlv320aic23-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | snd-soc-tlv320aic23 kernel module |
linux-stm32mp | kernel-module-snd-soc-tlv320aic23-i2c-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | snd-soc-tlv320aic23-i2c kernel module |
linux-stm32mp | kernel-module-snd-soc-ts3a227e-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | snd-soc-ts3a227e kernel module |
linux-stm32mp | kernel-module-snd-soc-wm-hubs-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | snd-soc-wm-hubs kernel module |
linux-stm32mp | kernel-module-snd-soc-wm8753-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | snd-soc-wm8753 kernel module |
linux-stm32mp | kernel-module-snd-soc-wm8903-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | snd-soc-wm8903 kernel module |
linux-stm32mp | kernel-module-snd-soc-wm8904-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | snd-soc-wm8904 kernel module |
linux-stm32mp | kernel-module-snd-soc-wm8978-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | snd-soc-wm8978 kernel module |
linux-stm32mp | kernel-module-snd-soc-wm8994-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | snd-soc-wm8994 kernel module |
linux-stm32mp | kernel-module-snd-timer-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | snd-timer kernel module |
linux-stm32mp | kernel-module-snd-usb-audio-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | snd-usb-audio kernel module |
linux-stm32mp | kernel-module-snd-usbmidi-lib-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | snd-usbmidi-lib kernel module |
linux-stm32mp | kernel-module-soundcore-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | soundcore kernel module |
linux-stm32mp | kernel-module-spi-gpio-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | spi-gpio kernel module |
linux-stm32mp | kernel-module-spi-rockchip-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | spi-rockchip kernel module |
linux-stm32mp | kernel-module-spi-stm32-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | spi-stm32 kernel module |
linux-stm32mp | kernel-module-st-lsm6dsx-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | st-lsm6dsx kernel module |
linux-stm32mp | kernel-module-st-lsm6dsx-i2c-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | st-lsm6dsx-i2c kernel module |
linux-stm32mp | kernel-module-st-lsm6dsx-spi-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | st-lsm6dsx-spi kernel module |
linux-stm32mp | kernel-module-st-mipid02-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | st-mipid02 kernel module |
linux-stm32mp | kernel-module-st-pressure-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | st-pressure kernel module |
linux-stm32mp | kernel-module-st-pressure-i2c-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | st-pressure-i2c kernel module |
linux-stm32mp | kernel-module-st-pressure-spi-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | st-pressure-spi kernel module |
linux-stm32mp | kernel-module-st-sensors-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | st-sensors kernel module |
linux-stm32mp | kernel-module-st-sensors-i2c-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | st-sensors-i2c kernel module |
linux-stm32mp | kernel-module-st-sensors-spi-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | st-sensors-spi kernel module |
linux-stm32mp | kernel-module-st1232-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | st1232 kernel module |
linux-stm32mp | kernel-module-sti-drm-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | sti-drm kernel module |
linux-stm32mp | kernel-module-stm32-adc-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | stm32-adc kernel module |
linux-stm32mp | kernel-module-stm32-adc-core-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | stm32-adc-core kernel module |
linux-stm32mp | kernel-module-stm32-adfsdm-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | stm32-adfsdm kernel module |
linux-stm32mp | kernel-module-stm32-booster-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | stm32-booster kernel module |
linux-stm32mp | kernel-module-stm32-cec-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | stm32-cec kernel module |
linux-stm32mp | kernel-module-stm32-crc32-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | stm32-crc32 kernel module |
linux-stm32mp | kernel-module-stm32-cryp-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | stm32-cryp kernel module |
linux-stm32mp | kernel-module-stm32-dac-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | stm32-dac kernel module |
linux-stm32mp | kernel-module-stm32-dac-core-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | stm32-dac-core kernel module |
linux-stm32mp | kernel-module-stm32-dcmi-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | stm32-dcmi kernel module |
linux-stm32mp | kernel-module-stm32-dcmipp-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | stm32-dcmipp kernel module |
linux-stm32mp | kernel-module-stm32-ddr-pmu-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | stm32-ddr-pmu kernel module |
linux-stm32mp | kernel-module-stm32-dfsdm-adc-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | stm32-dfsdm-adc kernel module |
linux-stm32mp | kernel-module-stm32-dfsdm-core-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | stm32-dfsdm-core kernel module |
linux-stm32mp | kernel-module-stm32-hash-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | stm32-hash kernel module |
linux-stm32mp | kernel-module-stm32-lptimer-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | stm32-lptimer kernel module |
linux-stm32mp | kernel-module-stm32-lptimer-cnt-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | stm32-lptimer-cnt kernel module |
linux-stm32mp | kernel-module-stm32-lptimer-trigger-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | stm32-lptimer-trigger kernel module |
linux-stm32mp | kernel-module-stm32-timer-cnt-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | stm32-timer-cnt kernel module |
linux-stm32mp | kernel-module-stm32-timer-trigger-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | stm32-timer-trigger kernel module |
linux-stm32mp | kernel-module-stm32-timers-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | stm32-timers kernel module |
linux-stm32mp | kernel-module-stmpe-adc-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | stmpe-adc kernel module |
linux-stm32mp | kernel-module-stp-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | stp kernel module |
linux-stm32mp | kernel-module-stusb160x-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | stusb160x kernel module |
linux-stm32mp | kernel-module-tag-brcm-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | tag-brcm kernel module |
linux-stm32mp | kernel-module-tap-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | tap kernel module |
linux-stm32mp | kernel-module-tc358764-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | tc358764 kernel module |
linux-stm32mp | kernel-module-tcp-bic-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | tcp-bic kernel module |
linux-stm32mp | kernel-module-tcp-diag-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | tcp-diag kernel module |
linux-stm32mp | kernel-module-tcp-htcp-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | tcp-htcp kernel module |
linux-stm32mp | kernel-module-tcp-westwood-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | tcp-westwood kernel module |
linux-stm32mp | kernel-module-thermal-generic-adc-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | thermal-generic-adc kernel module |
linux-stm32mp | kernel-module-tls-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | tls kernel module |
linux-stm32mp | kernel-module-tpm-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | tpm kernel module |
linux-stm32mp | kernel-module-tpm-i2c-infineon-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | tpm-i2c-infineon kernel module |
linux-stm32mp | kernel-module-ts-bm-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | ts-bm kernel module |
linux-stm32mp | kernel-module-ts-fsm-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | ts-fsm kernel module |
linux-stm32mp | kernel-module-ts-kmp-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | ts-kmp kernel module |
linux-stm32mp | kernel-module-tun-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | tun kernel module |
linux-stm32mp | kernel-module-tunnel4-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | tunnel4 kernel module |
linux-stm32mp | kernel-module-tunnel6-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | tunnel6 kernel module |
linux-stm32mp | kernel-module-typec-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | typec kernel module |
linux-stm32mp | kernel-module-typec-ucsi-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | typec-ucsi kernel module |
linux-stm32mp | kernel-module-u-audio-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | u-audio kernel module |
linux-stm32mp | kernel-module-u-ether-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | u-ether kernel module |
linux-stm32mp | kernel-module-u-serial-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | u-serial kernel module |
linux-stm32mp | kernel-module-uas-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | uas kernel module |
linux-stm32mp | kernel-module-ucsi-stm32g0-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | ucsi-stm32g0 kernel module |
linux-stm32mp | kernel-module-udp-diag-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | udp-diag kernel module |
linux-stm32mp | kernel-module-udp-tunnel-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | udp-tunnel kernel module |
linux-stm32mp | kernel-module-uinput-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | uinput kernel module |
linux-stm32mp | kernel-module-unix-diag-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | unix-diag kernel module |
linux-stm32mp | kernel-module-usb-f-acm-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | usb-f-acm kernel module |
linux-stm32mp | kernel-module-usb-f-ecm-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | usb-f-ecm kernel module |
linux-stm32mp | kernel-module-usb-f-ecm-subset-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | usb-f-ecm-subset kernel module |
linux-stm32mp | kernel-module-usb-f-eem-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | usb-f-eem kernel module |
linux-stm32mp | kernel-module-usb-f-fs-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | usb-f-fs kernel module |
linux-stm32mp | kernel-module-usb-f-hid-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | usb-f-hid kernel module |
linux-stm32mp | kernel-module-usb-f-mass-storage-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | usb-f-mass-storage kernel module |
linux-stm32mp | kernel-module-usb-f-midi-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | usb-f-midi kernel module |
linux-stm32mp | kernel-module-usb-f-ncm-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | usb-f-ncm kernel module |
linux-stm32mp | kernel-module-usb-f-obex-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | usb-f-obex kernel module |
linux-stm32mp | kernel-module-usb-f-printer-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | usb-f-printer kernel module |
linux-stm32mp | kernel-module-usb-f-rndis-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | usb-f-rndis kernel module |
linux-stm32mp | kernel-module-usb-f-serial-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | usb-f-serial kernel module |
linux-stm32mp | kernel-module-usb-f-ss-lb-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | usb-f-ss-lb kernel module |
linux-stm32mp | kernel-module-usb-f-uac1-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | usb-f-uac1 kernel module |
linux-stm32mp | kernel-module-usb-f-uac1-legacy-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | usb-f-uac1-legacy kernel module |
linux-stm32mp | kernel-module-usb-f-uac2-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | usb-f-uac2 kernel module |
linux-stm32mp | kernel-module-usb-f-uvc-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | usb-f-uvc kernel module |
linux-stm32mp | kernel-module-usbip-core-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | usbip-core kernel module |
linux-stm32mp | kernel-module-usbip-host-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | usbip-host kernel module |
linux-stm32mp | kernel-module-uvcvideo-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | uvcvideo kernel module |
linux-stm32mp | kernel-module-v4l2-async-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | v4l2-async kernel module |
linux-stm32mp | kernel-module-v4l2-dv-timings-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | v4l2-dv-timings kernel module |
linux-stm32mp | kernel-module-v4l2-fwnode-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | v4l2-fwnode kernel module |
linux-stm32mp | kernel-module-v4l2-tpg-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | v4l2-tpg kernel module |
linux-stm32mp | kernel-module-veth-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | veth kernel module |
linux-stm32mp | kernel-module-vf610-adc-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | vf610-adc kernel module |
linux-stm32mp | kernel-module-videobuf2-common-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | videobuf2-common kernel module |
linux-stm32mp | kernel-module-videobuf2-dma-contig-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | videobuf2-dma-contig kernel module |
linux-stm32mp | kernel-module-videobuf2-dma-sg-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | videobuf2-dma-sg kernel module |
linux-stm32mp | kernel-module-videobuf2-memops-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | videobuf2-memops kernel module |
linux-stm32mp | kernel-module-videobuf2-v4l2-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | videobuf2-v4l2 kernel module |
linux-stm32mp | kernel-module-videobuf2-vmalloc-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | videobuf2-vmalloc kernel module |
linux-stm32mp | kernel-module-videodev-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | videodev kernel module |
linux-stm32mp | kernel-module-vivid-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | vivid kernel module |
linux-stm32mp | kernel-module-vmw-vsock-virtio-transport-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | vmw-vsock-virtio-transport kernel module |
linux-stm32mp | kernel-module-vmw-vsock-virtio-transport-common-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | vmw-vsock-virtio-transport-common kernel module |
linux-stm32mp | kernel-module-vport-gre-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | vport-gre kernel module |
linux-stm32mp | kernel-module-vsock-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | vsock kernel module |
linux-stm32mp | kernel-module-vsock-diag-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | vsock-diag kernel module |
linux-stm32mp | kernel-module-vsock-loopback-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | vsock-loopback kernel module |
linux-stm32mp | kernel-module-wm8994-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | wm8994 kernel module |
linux-stm32mp | kernel-module-x-tables-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | x-tables kernel module |
linux-stm32mp | kernel-module-xfrm-algo-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | xfrm-algo kernel module |
linux-stm32mp | kernel-module-xfrm-ipcomp-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | xfrm-ipcomp kernel module |
linux-stm32mp | kernel-module-xfrm4-tunnel-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | xfrm4-tunnel kernel module |
linux-stm32mp | kernel-module-xfrm6-tunnel-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | xfrm6-tunnel kernel module |
linux-stm32mp | kernel-module-xt-addrtype-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | xt-addrtype kernel module |
linux-stm32mp | kernel-module-xt-bpf-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | xt-bpf kernel module |
linux-stm32mp | kernel-module-xt-cgroup-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | xt-cgroup kernel module |
linux-stm32mp | kernel-module-xt-classify-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | xt-classify kernel module |
linux-stm32mp | kernel-module-xt-cluster-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | xt-cluster kernel module |
linux-stm32mp | kernel-module-xt-comment-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | xt-comment kernel module |
linux-stm32mp | kernel-module-xt-connbytes-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | xt-connbytes kernel module |
linux-stm32mp | kernel-module-xt-connlabel-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | xt-connlabel kernel module |
linux-stm32mp | kernel-module-xt-connlimit-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | xt-connlimit kernel module |
linux-stm32mp | kernel-module-xt-connmark-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | xt-connmark kernel module |
linux-stm32mp | kernel-module-xt-connsecmark-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | xt-connsecmark kernel module |
linux-stm32mp | kernel-module-xt-conntrack-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | xt-conntrack kernel module |
linux-stm32mp | kernel-module-xt-cpu-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | xt-cpu kernel module |
linux-stm32mp | kernel-module-xt-dccp-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | xt-dccp kernel module |
linux-stm32mp | kernel-module-xt-devgroup-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | xt-devgroup kernel module |
linux-stm32mp | kernel-module-xt-dscp-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | xt-dscp kernel module |
linux-stm32mp | kernel-module-xt-ecn-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | xt-ecn kernel module |
linux-stm32mp | kernel-module-xt-esp-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | xt-esp kernel module |
linux-stm32mp | kernel-module-xt-hashlimit-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | xt-hashlimit kernel module |
linux-stm32mp | kernel-module-xt-helper-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | xt-helper kernel module |
linux-stm32mp | kernel-module-xt-hl-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | xt-hl kernel module |
linux-stm32mp | kernel-module-xt-hmark-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | xt-hmark kernel module |
linux-stm32mp | kernel-module-xt-idletimer-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | xt-idletimer kernel module |
linux-stm32mp | kernel-module-xt-ipcomp-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | xt-ipcomp kernel module |
linux-stm32mp | kernel-module-xt-iprange-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | xt-iprange kernel module |
linux-stm32mp | kernel-module-xt-l2tp-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | xt-l2tp kernel module |
linux-stm32mp | kernel-module-xt-led-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | xt-led kernel module |
linux-stm32mp | kernel-module-xt-length-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | xt-length kernel module |
linux-stm32mp | kernel-module-xt-limit-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | xt-limit kernel module |
linux-stm32mp | kernel-module-xt-log-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | xt-log kernel module |
linux-stm32mp | kernel-module-xt-mac-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | xt-mac kernel module |
linux-stm32mp | kernel-module-xt-mark-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | xt-mark kernel module |
linux-stm32mp | kernel-module-xt-masquerade-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | xt-masquerade kernel module |
linux-stm32mp | kernel-module-xt-multiport-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | xt-multiport kernel module |
linux-stm32mp | kernel-module-xt-nat-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | xt-nat kernel module |
linux-stm32mp | kernel-module-xt-netmap-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | xt-netmap kernel module |
linux-stm32mp | kernel-module-xt-nfacct-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | xt-nfacct kernel module |
linux-stm32mp | kernel-module-xt-nflog-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | xt-nflog kernel module |
linux-stm32mp | kernel-module-xt-nfqueue-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | xt-nfqueue kernel module |
linux-stm32mp | kernel-module-xt-osf-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | xt-osf kernel module |
linux-stm32mp | kernel-module-xt-owner-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | xt-owner kernel module |
linux-stm32mp | kernel-module-xt-pkttype-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | xt-pkttype kernel module |
linux-stm32mp | kernel-module-xt-policy-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | xt-policy kernel module |
linux-stm32mp | kernel-module-xt-quota-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | xt-quota kernel module |
linux-stm32mp | kernel-module-xt-rateest-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | xt-rateest kernel module |
linux-stm32mp | kernel-module-xt-realm-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | xt-realm kernel module |
linux-stm32mp | kernel-module-xt-recent-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | xt-recent kernel module |
linux-stm32mp | kernel-module-xt-redirect-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | xt-redirect kernel module |
linux-stm32mp | kernel-module-xt-sctp-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | xt-sctp kernel module |
linux-stm32mp | kernel-module-xt-secmark-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | xt-secmark kernel module |
linux-stm32mp | kernel-module-xt-state-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | xt-state kernel module |
linux-stm32mp | kernel-module-xt-statistic-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | xt-statistic kernel module |
linux-stm32mp | kernel-module-xt-string-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | xt-string kernel module |
linux-stm32mp | kernel-module-xt-tcpmss-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | xt-tcpmss kernel module |
linux-stm32mp | kernel-module-xt-tcpudp-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | xt-tcpudp kernel module |
linux-stm32mp | kernel-module-xt-tee-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | xt-tee kernel module |
linux-stm32mp | kernel-module-xt-time-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | xt-time kernel module |
linux-stm32mp | kernel-module-xt-u32-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | xt-u32 kernel module |
linux-stm32mp | kernel-module-xts-5.15.67 | 5.15.67-stm32mp-r2 | GPL-2.0-only | xts kernel module |
linux-stm32mp | kernel-modules | 5.15.67-stm32mp-r2 | GPL-2.0-only | Linux STM32MP Kernel |
kmod | kmod | 29 | GPL-2.0-or-later & LGPL-2.1-or-later | Tools for managing Linux kernel modules |
kmscube | kmscube | git | MIT | Demo application to showcase 3D graphics using kms and gbm |
glibc | ldconfig | 2.35 | GPL-2.0-only & LGPL-2.1-only | GLIBC (GNU C Library) |
liba52 | liba52-0 | 0.7.4 | GPL-2.0-or-later | ATSC A/52 surround sound stream decoder |
libaio | libaio1 | 0.3.112 | LGPL-2.1-or-later | Asynchronous I/O library |
elfutils | libasm1 | 0.186 | LGPL-3.0-or-later | Utilities and libraries for handling compiled object files |
alsa-plugins | libasound-module-conf-pulse | 1.2.6 | LGPL-2.1-only & GPL-2.0-or-later | Alsa plugin for conf-pulse |
alsa-plugins | libasound-module-ctl-arcam-av | 1.2.6 | LGPL-2.1-only & GPL-2.0-or-later | Alsa plugin for ctl-arcam-av |
alsa-plugins | libasound-module-ctl-oss | 1.2.6 | LGPL-2.1-only & GPL-2.0-or-later | Alsa plugin for ctl-oss |
alsa-plugins | libasound-module-ctl-pulse | 1.2.6 | LGPL-2.1-only & GPL-2.0-or-later | Alsa plugin for ctl-pulse |
alsa-plugins | libasound-module-pcm-oss | 1.2.6 | LGPL-2.1-only & GPL-2.0-or-later | Alsa plugin for pcm-oss |
alsa-plugins | libasound-module-pcm-pulse | 1.2.6 | LGPL-2.1-only & GPL-2.0-or-later | Alsa plugin for pcm-pulse |
alsa-plugins | libasound-module-pcm-speex | 1.2.6 | LGPL-2.1-only & GPL-2.0-or-later | Alsa plugin for pcm-speex |
alsa-plugins | libasound-module-pcm-upmix | 1.2.6 | LGPL-2.1-only & GPL-2.0-or-later | Alsa plugin for pcm-upmix |
alsa-plugins | libasound-module-pcm-usb-stream | 1.2.6 | LGPL-2.1-only & GPL-2.0-or-later | Alsa plugin for pcm-usb-stream |
alsa-plugins | libasound-module-pcm-vdownmix | 1.2.6 | LGPL-2.1-only & GPL-2.0-or-later | Alsa plugin for pcm-vdownmix |
alsa-plugins | libasound-module-rate-samplerate | 1.2.6 | LGPL-2.1-only & GPL-2.0-or-later | Alsa plugin for rate-samplerate |
alsa-plugins | libasound-module-rate-speexrate | 1.2.6 | LGPL-2.1-only & GPL-2.0-or-later | Alsa plugin for rate-speexrate |
alsa-lib | libasound2 | 1.2.6.1 | LGPL-2.1-only & GPL-2.0-or-later | ALSA sound library |
libassuan | libassuan0 | 2.5.5 | LGPL-2.1-or-later | IPC library used by GnuPG and GPGME |
atk | libatk-1.0-0 | 2.38.0 | GPL-2.0-or-later & LGPL-2.0-or-later | Accessibility toolkit for GNOME |
gcc-runtime | libatomic1 | 11.3.0 | GPL-3.0-with-GCC-exception | GNU C++11 atomics support library |
alsa-lib | libatopology2 | 1.2.6.1 | LGPL-2.1-only & GPL-2.0-or-later | ALSA sound library |
attr | libattr1 | 2.5.1 | LGPL-2.1-or-later | Utilities for manipulating filesystem extended attributes |
avahi | libavahi-client3 | 0.8 | LGPL-2.1-or-later | Avahi IPv4LL network address configuration daemon |
avahi | libavahi-common3 | 0.8 | LGPL-2.1-or-later | Avahi IPv4LL network address configuration daemon |
avahi | libavahi-core7 | 0.8 | LGPL-2.1-or-later | Avahi IPv4LL network address configuration daemon |
ffmpeg | libavcodec59 | 5.0.1 | LGPL-2.1-or-later | A complete, cross-platform solution to record, convert and stream audio and video. |
ffmpeg | libavfilter8 | 5.0.1 | LGPL-2.1-or-later | A complete, cross-platform solution to record, convert and stream audio and video. |
ffmpeg | libavformat59 | 5.0.1 | LGPL-2.1-or-later | A complete, cross-platform solution to record, convert and stream audio and video. |
ffmpeg | libavutil57 | 5.0.1 | LGPL-2.1-or-later | A complete, cross-platform solution to record, convert and stream audio and video. |
binutils | libbfd | 2.38 | GPL-3.0-only | GNU binary utilities |
util-linux | libblkid1 | 2.37.4 | LGPL-2.1-or-later | util-linux libblkid |
boost | libboost-system1.78.0 | 1.78.0 | BSL-1.0 & MIT & Python-2.0 | Free peer-reviewed portable C++ source libraries |
bzip2 | libbz2-1 | 1.0.8 | bzip2-1.0.6 | Very high-quality data compression program |
glibc | libc6 | 2.35 | GPL-2.0-only & LGPL-2.1-only | GLIBC (GNU C Library) |
glibc | libc6-dbg | 2.35 | GPL-2.0-only & LGPL-2.1-only | GLIBC (GNU C Library) - Debugging files |
glibc | libc6-thread-db | 2.35 | GPL-2.0-only & LGPL-2.1-only | GLIBC (GNU C Library) |
cairo | libcairo-gobject2 | 1.16.0 | LGPL-2.1-only | The Cairo library GObject wrapper library |
cairo | libcairo2 | 1.16.0 | LGPL-2.1-only | The Cairo 2D vector graphics library |
libcap | libcap | 2.65 | GPL-2.0-only | Library for getting/setting POSIX.1e capabilities |
libcap-ng | libcap-ng | 0.8.2 | GPL-2.0-or-later & LGPL-2.1-or-later | An alternate posix capabilities library |
e2fsprogs | libcom-err2 | 1.46.5 | GPL-2.0-only & LGPL-2.0-only & BSD-3-Clause & MIT | Ext2 Filesystem Utilities |
libxcrypt | libcrypt2 | 4.4.28 | LGPL-2.1-only | Extended cryptographic library (from glibc) |
openssl | libcrypto3 | 3.0.5 | Apache-2.0 | Secure Socket Layer |
curl | libcurl4 | 7.82.0 | MIT-open-group | Command line tool and library for client-side URL transfers |
libdaemon | libdaemon0 | 0.14 | LGPL-2.1-or-later | Lightweight C library which eases the writing of UNIX daemons |
libdazzle | libdazzle | 3.44.0 | GPL-3.0-or-later | The libdazzle library is a companion library to GObject and Gtk+. |
dbus | libdbus-1-3 | 1.14.0 | GPL-2.0-or-later | D-Bus message bus |
libdrm | libdrm-tests | 2.4.110 | MIT | Userspace interface to the kernel DRM services |
libdrm | libdrm2 | 2.4.110 | MIT | Userspace interface to the kernel DRM services |
duktape | libduktape207 | 2.7.0 | MIT | Duktape embeddable Javascript engine |
elfutils | libdw1 | 0.186 | LGPL-3.0-or-later | Utilities and libraries for handling compiled object files |
e2fsprogs | libe2p2 | 1.46.5 | GPL-2.0-only & LGPL-2.0-only & BSD-3-Clause & MIT | Ext2 Filesystem Utilities |
elfutils | libelf1 | 0.186 | LGPL-3.0-or-later | Utilities and libraries for handling compiled object files |
libepoxy | libepoxy0 | 1.5.9 | MIT | OpenGL function pointer management library |
liberation-fonts | liberation-fonts | 2.1.5 | OFL-1.1 | Liberation(tm) Fonts |
libevdev | libevdev | 1.12.1 | MIT | Wrapper library for evdev devices |
expat | libexpat1 | 2.4.7 | MIT | A stream-oriented XML parser library |
e2fsprogs | libext2fs2 | 1.46.5 | GPL-2.0-only & LGPL-2.0-only & BSD-3-Clause & MIT | Ext2 Filesystem Utilities |
faac | libfaac0 | 1.29.9.2 | LGPL-2.0-or-later | Freeware Advanced Audio Coder (MPEG2-AAC, MPEG4-AAC) |
util-linux | libfdisk1 | 2.37.4 | LGPL-2.1-or-later | util-linux libfdisk |
libffi | libffi8 | 3.4.2 | MIT | A portable foreign function interface library |
fftw | libfftwf | 3.3.10 | GPL-2.0-only | fftw version 3.3.10-r0 |
flac | libflac8 | 1.3.4 | GFDL-1.2 & GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause | Free Lossless Audio Codec |
fontconfig | libfontconfig1 | 2.13.1 | MIT & MIT & PD | Generic font configuration library |
ncurses | libformw5 | 6.3+20220423 | MIT | ncurses formw library |
freetype | libfreetype6 | 2.11.1 | GPL-2.0-or-later | Freetype font rendering library |
fribidi | libfribidi0 | 1.0.12 | LGPL-2.1-or-later | Free Implementation of the Unicode Bidirectional Algorithm |
libgcc | libgcc1 | 11.3.0 | GPL-3.0-with-GCC-exception | GNU cc and gcc C compilers |
libgcrypt | libgcrypt | 1.9.4 | LGPL-2.1-or-later | General purpose cryptographic library based on the code from GnuPG |
gdk-pixbuf | libgdk-pixbuf-2.0-0 | 2.42.9 | LGPL-2.1-or-later | Image loading library for GTK+ |
gdk-pixbuf | libgdk-pixbuf-2.0-loader-gif | 2.42.9 | LGPL-2.1-or-later | GDK pixbuf loader for gif |
gdk-pixbuf | libgdk-pixbuf-2.0-loader-xpm | 2.42.9 | LGPL-2.1-or-later | GDK pixbuf loader for xpm |
glib-2.0 | libglib-2.0-0 | 2.72.3 | LGPL-2.1-or-later & BSD-3-Clause & PD | A general-purpose utility library |
glib-2.0 | libglib-2.0-utils | 2.72.3 | LGPL-2.1-or-later & BSD-3-Clause & PD | A general-purpose utility library |
gmp | libgmp10 | 6.2.1 | LGPL-3.0-or-later | GNU multiprecision arithmetic library |
gnutls | libgnutls30 | 3.7.4 | LGPL-2.1-or-later | GNU Transport Layer Security Library |
libgpg-error | libgpg-error | 1.44 | GPL-2.0-or-later & LGPL-2.1-or-later | Small library that defines common error values for all GnuPG components |
libgpiod | libgpiod-tools | 1.6.3 | LGPL-2.1-or-later | C library and tools for interacting with the linux GPIO character device |
libgpiod | libgpiod2 | 1.6.3 | LGPL-2.1-or-later | C library and tools for interacting with the linux GPIO character device |
gstreamer1.0-plugins-bad | libgstadaptivedemux-1.0-0 | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 gstadaptivedemux-1.0 library |
gstreamer1.0-plugins-base | libgstallocators-1.0-0 | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 gstallocators-1.0 library |
gstreamer1.0-plugins-base | libgstapp-1.0-0 | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 gstapp-1.0 library |
gstreamer1.0-plugins-base | libgstaudio-1.0-0 | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 gstaudio-1.0 library |
gstreamer1.0-plugins-bad | libgstbadaudio-1.0-0 | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 gstbadaudio-1.0 library |
gstreamer1.0-plugins-bad | libgstbasecamerabinsrc-1.0-0 | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 gstbasecamerabinsrc-1.0 library |
gstreamer1.0-plugins-bad | libgstcodecparsers-1.0-0 | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 gstcodecparsers-1.0 library |
gstreamer1.0-plugins-bad | libgstcodecs-1.0-0 | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 gstcodecs-1.0 library |
gstreamer1.0-plugins-base | libgstfft-1.0-0 | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 gstfft-1.0 library |
gstreamer1.0-plugins-base | libgstgl-1.0-0 | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 gstgl-1.0 library |
gstreamer1.0-plugins-bad | libgstinsertbin-1.0-0 | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 gstinsertbin-1.0 library |
gstreamer1.0-plugins-bad | libgstisoff-1.0-0 | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 gstisoff-1.0 library |
gstreamer1.0-plugins-bad | libgstmpegts-1.0-0 | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 gstmpegts-1.0 library |
gstreamer1.0-plugins-base | libgstpbutils-1.0-0 | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 gstpbutils-1.0 library |
gstreamer1.0-plugins-bad | libgstphotography-1.0-0 | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 gstphotography-1.0 library |
gstreamer1.0-plugins-bad | libgstplay-1.0-0 | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 gstplay-1.0 library |
gstreamer1.0-plugins-bad | libgstplayer-1.0-0 | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 gstplayer-1.0 library |
gstreamer1.0-plugins-base | libgstriff-1.0-0 | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 gstriff-1.0 library |
gstreamer1.0-plugins-base | libgstrtp-1.0-0 | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 gstrtp-1.0 library |
gstreamer1.0-plugins-base | libgstrtsp-1.0-0 | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 gstrtsp-1.0 library |
gstreamer1.0-rtsp-server | libgstrtspserver-1.0-0 | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 gstrtspserver-1.0 library |
gstreamer1.0-plugins-bad | libgstsctp-1.0-0 | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 gstsctp-1.0 library |
gstreamer1.0-plugins-base | libgstsdp-1.0-0 | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 gstsdp-1.0 library |
gstreamer1.0-plugins-base | libgsttag-1.0-0 | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 gsttag-1.0 library |
gstreamer1.0-plugins-bad | libgsttranscoder-1.0-0 | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 gsttranscoder-1.0 library |
gstreamer1.0-plugins-bad | libgsturidownloader-1.0-0 | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 gsturidownloader-1.0 library |
gstreamer1.0-plugins-base | libgstvideo-1.0-0 | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 gstvideo-1.0 library |
gstreamer1.0-plugins-bad | libgstwayland-1.0-0 | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 gstwayland-1.0 library |
gstreamer1.0-plugins-bad | libgstwebrtc-1.0-0 | 1.20.3 | LGPL-2.1-or-later | GStreamer 1.0 gstwebrtc-1.0 library |
gtk+3 | libgtk-3.0 | 3.24.34 | LGPL-2.0-only & LGPL-2.0-or-later & LGPL-2.1-or-later | Multi-platform toolkit for creating GUIs |
libgudev | libgudev-1.0-0 | 237 | LGPL-2.1-only | GObject wrapper for libudev |
harfbuzz | libharfbuzz0 | 4.0.1 | MIT | Text shaping library |
icu | libicudata70 | 70.1 | ICU | International Component for Unicode libraries |
icu | libicuuc70 | 70.1 | ICU | International Component for Unicode libraries |
libidn2 | libidn2-0 | 2.3.2 | LGPL-3.0-only) & Unicode-DFS-2016 | Internationalized Domain Name support library |
libiio | libiio-iiod | 0.23 | LGPL-2.1-or-later | Library for interfacing with IIO devices |
libiio | libiio-tests | 0.23 | LGPL-2.1-or-later | Library for interfacing with IIO devices |
libiio | libiio0 | 0.23 | LGPL-2.1-or-later | Library for interfacing with IIO devices |
libinput | libinput10 | 1.19.4 | MIT | Library to handle input devices in Wayland compositors |
libjpeg-turbo | libjpeg62 | 2.1.4 | BSD-3-Clause | Hardware accelerated JPEG compression/decompression library |
json-c | libjson-c5 | 0.15 | MIT | C bindings for apps which will manipulate JSON data |
json-glib | libjson-glib-1.0-0 | 1.6.6 | LGPL-2.1-only | JSON-GLib implements a full JSON parser using GLib and GObject |
kmod | libkmod2 | 29 | LGPL-2.1-or-later | Tools for managing Linux kernel modules |
libdrm | libkms1 | 2.4.110 | MIT | Userspace interface to the kernel DRM services |
libksba | libksba8 | 1.6.0 | LGPL-3.0-or-later | Easy API to create and parse X.509 and CMS related objects |
libtool | libltdl7 | 2.4.7 | GPL-2.0-only & LGPL-2.1-only | Generic library support script |
xz | liblzma5 | 5.2.6 | PD | Utilities for managing LZMA compressed files |
lzo | liblzo2-2 | 2.10 | GPL-2.0-or-later | Lossless data compression library |
ncurses | libmenuw5 | 6.3+20220423 | MIT | ncurses menuw library |
libmnl | libmnl0 | 1.0.4 | LGPL-2.1-or-later | Minimalistic user-space Netlink utility library |
util-linux | libmount1 | 2.37.4 | LGPL-2.1-or-later | util-linux libmount |
lame | libmp3lame0 | 3.100 | LGPL-2.0-or-later | High quality MP3 audio encoder |
mpeg2dec | libmpeg2-0 | 0.5.1 | GPL-2.0-or-later | Library and test program for decoding MPEG-2 and MPEG-1 video streams |
ncurses | libncurses5 | 6.3+20220423 | MIT | ncurses ncurses library |
ncurses | libncursesw5 | 6.3+20220423 | MIT | ncurses ncursesw library |
libnl | libnl-3-200 | 3.5.0 | LGPL-2.1-only | A library for applications dealing with netlink sockets |
libnl | libnl-genl-3-200 | 3.5.0 | LGPL-2.1-only | A library for applications dealing with netlink sockets |
npth | libnpth0 | 1.6 | LGPL-2.0-or-later | New GNU Portable Threads library |
libnss-mdns | libnss-mdns | 0.15.1 | LGPL-2.1-or-later | Name Service Switch module for Multicast DNS (zeroconf) name resolution |
systemd | libnss-myhostname2 | 250.5 | GPL-2.0-only & LGPL-2.1-only | Systemd nss-myhostname library |
libogg | libogg0 | 1.3.5 | BSD-3-Clause | Ogg bitstream and framing libary |
binutils | libopcodes | 2.38 | GPL-3.0-only | GNU binary utilities |
orc | liborc-0.4-0 | 0.4.32 | BSD-2-Clause & BSD-3-Clause | ORC orc-0.4 library |
libpam | libpam | 1.5.2 | BSD-3-Clause | Linux-PAM (Pluggable Authentication Modules) |
libpam | libpam-runtime | 1.5.2 | BSD-3-Clause | Linux-PAM (Pluggable Authentication Modules) |
ncurses | libpanel5 | 6.3+20220423 | MIT | ncurses panel library |
ncurses | libpanelw5 | 6.3+20220423 | MIT | ncurses panelw library |
libpcap | libpcap1 | 1.10.1 | BSD-3-Clause | Interface for user-level network packet capture |
pciutils | libpci3 | 3.7.0 | GPL-2.0-or-later | PCI utilities |
libpcre | libpcre1 | 8.45 | BSD-3-Clause | Perl Compatible Regular Expressions |
pixman | libpixman-1-0 | 0.40.0 | MIT & MIT & PD | Pixman: Pixel Manipulation library |
libpng | libpng16-16 | 1.6.37 | Libpng | PNG image format decoding library |
popt | libpopt0 | 1.18 | MIT | Library for parsing command line options |
procps | libprocps8 | 3.3.17 | GPL-2.0-or-later & LGPL-2.0-or-later | System and process monitoring utilities |
libpsl | libpsl5 | 0.21.1 | MIT | Public Suffix List library |
pulseaudio | libpulse-simple0 | 15.0 | LGPL-2.1-or-later & MIT & BSD-3-Clause | Sound server for Linux and Unix-like operating systems |
pulseaudio | libpulse0 | 15.0 | LGPL-2.1-or-later & MIT & BSD-3-Clause | Sound server for Linux and Unix-like operating systems |
pulseaudio | libpulsecommon | 15.0 | LGPL-2.1-or-later & MIT & BSD-3-Clause | Sound server for Linux and Unix-like operating systems |
pulseaudio | libpulsecore | 15.0 | LGPL-2.1-or-later & MIT & BSD-3-Clause | Sound server for Linux and Unix-like operating systems |
python3 | libpython3.10-1.0 | 3.10.4 | PSF-2.0 | The Python Programming Language |
qrencode | libqrencode4 | 4.1.1 | LGPL-2.1-only | C library for encoding data in a QR Code symbol |
readline | libreadline8 | 8.1.2 | GPL-3.0-or-later | Library for editing typed command lines |
librsvg | librsvg-2-2 | 2.52.7 | LGPL-2.1-or-later | Library for rendering SVG files |
libsamplerate0 | libsamplerate0 | 0.2.2 | BSD-2-Clause | Audio Sample Rate Conversion library |
sbc | libsbc1 | 1.5 | LGPL-2.1-or-later | SBC Audio Codec |
libsdl2 | libsdl2-2.0-0 | 2.0.20 | Zlib & BSD-2-Clause & MIT | Simple DirectMedia Layer |
lmsensors | libsensors5 | 3.6.0 | GPL-2.0-or-later & LGPL-2.1-or-later | Hardware health monitoring applications |
libserialport | libserialport0 | 0.1.1 | LGPL-3.0-or-later | libserialport version 0.1.1-r0 |
util-linux | libsmartcols1 | 2.37.4 | LGPL-2.1-or-later | util-linux libsmartcols |
libsndfile1 | libsndfile1 | 1.0.31 | LGPL-2.1-only | Audio format Conversion library |
libsoup-2.4 | libsoup-2.4 | 2.74.2 | LGPL-2.0-only | An HTTP library implementation in C |
speex | libspeex1 | 1.2.0 | BSD-3-Clause | Speech Audio Codec |
speexdsp | libspeexdsp1 | 1.2.0 | BSD-3-Clause | A patent-free DSP library |
sqlite3 | libsqlite3-0 | 3.38.5 | PD | Embeddable SQL database engine |
e2fsprogs | libss2 | 1.46.5 | GPL-2.0-only & LGPL-2.0-only & BSD-3-Clause & MIT | Ext2 Filesystem Utilities |
openssl | libssl3 | 3.0.5 | Apache-2.0 | Secure Socket Layer |
gcc-runtime | libstdc++6 | 11.3.0 | GPL-3.0-with-GCC-exception | GNU standard C++ library |
ffmpeg | libswresample4 | 5.0.1 | LGPL-2.1-or-later | A complete, cross-platform solution to record, convert and stream audio and video. |
ffmpeg | libswscale6 | 5.0.1 | LGPL-2.1-or-later | A complete, cross-platform solution to record, convert and stream audio and video. |
sysfsutils | libsysfs2 | 2.1.0 | LGPL-2.1-only | Tools for working with sysfs |
systemd | libsystemd-shared | 250.5 | GPL-2.0-only & LGPL-2.1-only | Systemd shared library |
systemd | libsystemd0 | 250.5 | GPL-2.0-only & LGPL-2.1-only | Systemd systemd library |
taglib | libtag1 | 1.12 | MPL-1.1 | Library for reading and editing the meta-data of popular audio formats |
libtheora | libtheora | 1.1.1 | BSD-3-Clause | Theora Video Codec |
tiff | libtiff5 | 4.3.0 | BSD-2-Clause | Provides support for the Tag Image File Format (TIFF) |
ncurses | libtinfo5 | 6.3+20220423 | MIT | ncurses tinfo library |
libtirpc | libtirpc3 | 1.3.2 | BSD-3-Clause | Transport-Independent RPC library |
libubootenv | libubootenv-bin | 0.3.2 | LGPL-2.1-only | U-Boot libraries and tools to access environment |
libubootenv | libubootenv0 | 0.3.2 | LGPL-2.1-only | U-Boot libraries and tools to access environment |
systemd | libudev1 | 250.5 | GPL-2.0-only & LGPL-2.1-only | Systemd udev library |
libunistring | libunistring2 | 1.0 | GPL-2.0-or-later | Library for manipulating C and Unicode strings |
libunwind | libunwind | 1.6.2 | MIT | Library for obtaining the call-chain of a program |
liburcu | liburcu | 0.13.2 | LGPL-2.1-or-later & MIT | Userspace RCU (read-copy-update) library |
libusb1 | libusb-1.0-0 | 1.0.26 | LGPL-2.1-or-later | Userspace library to access USB (version 1.0) |
util-linux-libuuid | libuuid1 | 2.37.4 | BSD-3-Clause | A suite of basic system administration utilities |
libuv | libuv1 | 1.44.2 | MIT | A multi-platform support library with a focus on asynchronous I/O |
v4l-utils | libv4l | 1.22.1 | GPL-2.0-only & LGPL-2.1-only | v4l2 and IR applications |
libvorbis | libvorbis | 1.3.7 | BSD-3-Clause | Ogg Vorbis Audio Codec |
libwebp | libwebp | 1.2.4 | BSD-3-Clause | WebP is an image format designed for the Web |
weston | libweston-10 | 10.0.2 | MIT | Helper library for implementing 'wayland window managers'. |
tcp-wrappers | libwrap0 | 7.6 | BSD-1-Clause | Security tool that is a wrapper for TCP daemons |
libx11-compose-data | libx11-compose-data | 1.6.8 | MIT & MIT & BSD-1-Clause & HPND & HPND-sell-variant | Xlib: Compose data files for libx11 |
libxkbcommon | libxkbcommon0 | 1.4.1 | MIT & MIT | libxkbcommon library |
libxml2 | libxml2 | 2.9.14 | MIT | XML C Parser Library and Toolkit |
libyaml | libyaml-0-2 | 0.2.5 | MIT | LibYAML is a YAML 1.1 parser and emitter written in C. |
zlib | libz1 | 1.2.11 | Zlib | Zlib Compression Library |
zstd | libzstd1 | 1.5.2 | BSD-3-Clause & GPL-2.0-only | Zstandard - Fast real-time compression algorithm |
linux-firmware | linux-firmware-bcm43430 | 20220708 | Firmware-broadcom_bcm43xx | Firmware files for use with Linux kernel |
linux-firmware-bluetooth-bcm4343 | linux-firmware-bluetooth-bcm4343 | 3.0 | Firmware-cypress-bcm4343 | Bluetooth firmware for BCM4343 |
linux-firmware-bluetooth-bcm4343 | linux-firmware-bluetooth-bcm4343-cypress-license | 3.0 | Firmware-cypress-bcm4343 | Bluetooth firmware for BCM4343 |
lmsensors-config | lmsensors-config-libsensors | 1.0 | MIT | lm_sensors configuration files |
lmsensors | lmsensors-sensors | 3.6.0 | GPL-2.0-or-later & LGPL-2.1-or-later | Hardware health monitoring applications |
lrzsz | lrzsz | 0.12.20 | GPL-2.0-or-later | Tools for zmodem/xmodem/ymodem file transfer |
lttng-tools | lttng-tools | 2.13.4 | GPL-2.0-only & LGPL-2.1-only | Linux Trace Toolkit Control |
lttng-ust | lttng-ust | 2.13.3 | LGPL-2.1-or-later & MIT & GPL-2.0-only | Linux Trace Toolkit Userspace Tracer 2.x |
lz4 | lz4 | 1.9.4 | GPL-2.0-only | Extremely Fast Compression algorithm |
m4fwcoredump | m4fwcoredump | 1.0 | MIT | Script to manage coredump of cortexM4 |
m4projects-stm32mp1 | m4projects-stm32mp1 | 1.6.0 | Apache-2.0 & MIT & BSD-3-Clause | STM32MP1 Firmware examples for CM4 |
v4l-utils | media-ctl | 1.22.1 | GPL-2.0-only & LGPL-2.1-only | v4l2 and IR applications |
memtester | memtester | 4.5.1 | GPL-2.0-only | Utility to test for faulty memory subsystem |
minicom | minicom | 2.8 | GPL-2.0-or-later | Text-based modem control and terminal emulation program |
mmc-utils | mmc-utils | 0.1+gitAUTOINC+b7e4d5a6ae | GPL-2.0-only | Userspace tools for MMC/SD devices |
mpg123 | mpg123 | 1.29.3 | LGPL-2.1-only | Audio decoder for MPEG-1 Layer 1/2/3 |
mtd-utils | mtd-utils | 2.1.4 | GPL-2.0-or-later | Tools for managing memory technology devices |
mtd-utils | mtd-utils-ubifs | 2.1.4 | GPL-2.0-or-later | Tools for managing memory technology devices |
mtdev | mtdev | 1.1.6 | MIT | Multitouch Protocol Translation Library |
ncurses | ncurses-terminfo-base | 6.3+20220423 | MIT | The New Curses library |
netbase | netbase | 6.3 | GPL-2.0-only | Basic TCP/IP networking support |
netdata | netdata | 1.34.1 | GPL-3.0-only | Real-time performance monitoring |
nettle | nettle | 3.7.3 | GPL-2.0-or-later | A low level cryptographic library |
ntp | ntp | 4.2.8p15 | NTP | Network Time Protocol daemon and utilities |
ntp | ntp-tickadj | 4.2.8p15 | NTP | Network Time Protocol daemon and utilities |
numactl | numactl | 2.0.14 | GPL-2.0-only & LGPL-2.1-only | Development package for building Applications that use numa |
openssh | openssh-sftp | 8.9p1 | BSD-2-Clause & BSD-3-Clause & ISC & MIT | A suite of security-related network utilities based on the SSH protocol including the ssh client and sshd server |
openssh | openssh-sftp-server | 8.9p1 | BSD-2-Clause & BSD-3-Clause & ISC & MIT | A suite of security-related network utilities based on the SSH protocol including the ssh client and sshd server |
openssl | openssl | 3.0.5 | Apache-2.0 | Secure Socket Layer |
openssl | openssl-bin | 3.0.5 | Apache-2.0 | Secure Socket Layer |
openssl | openssl-conf | 3.0.5 | Apache-2.0 | Secure Socket Layer |
openssl | openssl-engines | 3.0.5 | Apache-2.0 | Secure Socket Layer |
openssl | openssl-ossl-module-legacy | 3.0.5 | Apache-2.0 | Secure Socket Layer |
optee-client | optee-client | 3.16.0+gitAUTOINC+06db73b3f3 | BSD-2-Clause | OPTEE Client |
optee-stm32mp-addons | optee-stm32mp-addons | 3.16.0.AUTOINC+3c3cb0ed91 | BSD-3-Clause | OP-TEE STM32MP examples |
optee-test | optee-test | 3.16.0+gitAUTOINC+1cf0e6d2bd | BSD-2-Clause & GPL-2.0-only | OP-TEE sanity testsuite |
os-release | os-release | 1.0 | MIT | Operating system identification |
libpam | pam-plugin-deny | 1.5.2 | BSD-3-Clause | PAM plugin for -deny |
libpam | pam-plugin-env | 1.5.2 | BSD-3-Clause | PAM plugin for -env |
libpam | pam-plugin-faildelay | 1.5.2 | BSD-3-Clause | PAM plugin for -faildelay |
libpam | pam-plugin-group | 1.5.2 | BSD-3-Clause | PAM plugin for -group |
libpam | pam-plugin-keyinit | 1.5.2 | BSD-3-Clause | PAM plugin for -keyinit |
libpam | pam-plugin-lastlog | 1.5.2 | BSD-3-Clause | PAM plugin for -lastlog |
libpam | pam-plugin-limits | 1.5.2 | BSD-3-Clause | PAM plugin for -limits |
libpam | pam-plugin-loginuid | 1.5.2 | BSD-3-Clause | PAM plugin for -loginuid |
libpam | pam-plugin-mail | 1.5.2 | BSD-3-Clause | PAM plugin for -mail |
libpam | pam-plugin-motd | 1.5.2 | BSD-3-Clause | PAM plugin for -motd |
libpam | pam-plugin-nologin | 1.5.2 | BSD-3-Clause | PAM plugin for -nologin |
libpam | pam-plugin-permit | 1.5.2 | BSD-3-Clause | PAM plugin for -permit |
libpam | pam-plugin-rootok | 1.5.2 | BSD-3-Clause | PAM plugin for -rootok |
libpam | pam-plugin-securetty | 1.5.2 | BSD-3-Clause | PAM plugin for -securetty |
libpam | pam-plugin-shells | 1.5.2 | BSD-3-Clause | PAM plugin for -shells |
libpam | pam-plugin-unix | 1.5.2 | BSD-3-Clause | PAM plugin for -unix |
libpam | pam-plugin-warn | 1.5.2 | BSD-3-Clause | PAM plugin for -warn |
pango | pango | 1.50.4 | LGPL-2.0-or-later | Framework for layout and rendering of internationalized text |
pciutils | pciutils | 3.7.0 | GPL-2.0-or-later | PCI utilities |
pciutils | pciutils-ids | 3.7.0 | GPL-2.0-or-later | PCI utilities - device ID database |
perf | perf | 1.0 | GPL-2.0-only | Performance analysis tools for Linux |
perl | perl | 5.34.1 | GPL-1.0-or-later | Perl scripting language |
perl | perl-module-config-heavy | 5.34.1 | GPL-1.0-or-later | perl module config-heavy |
pinentry | pinentry | 1.2.0 | GPL-2.0-only | Collection of simple PIN or passphrase entry dialogs |
polkit | polkit | 0.119 | LGPL-2.0-or-later | PolicyKit Authorization Framework |
powertop | powertop | 2.14 | GPL-2.0-only | Power usage tool |
powertop | powertop-locale-en-us | 2.14 | GPL-2.0-only | Power usage tool - en_US translations |
procps | procps | 3.3.17 | GPL-2.0-or-later & LGPL-2.0-or-later | System and process monitoring utilities |
procps | procps-ps | 3.3.17 | GPL-2.0-or-later & LGPL-2.0-or-later | System and process monitoring utilities |
procps | procps-sysctl | 3.3.17 | GPL-2.0-or-later & LGPL-2.0-or-later | System and process monitoring utilities |
psplash-drm | psplash-drm | 1.0 | MIT | Basic splash screen which display a picture on DRM/KMS |
pulseaudio | pulseaudio-lib-alsa-util | 15.0 | LGPL-2.1-or-later & MIT & BSD-3-Clause | PulseAudio library for alsa-util |
pulseaudio | pulseaudio-lib-bluez5-util | 15.0 | LGPL-2.1-or-later & MIT & BSD-3-Clause | PulseAudio library for bluez5-util |
pulseaudio | pulseaudio-lib-cli | 15.0 | LGPL-2.1-or-later & MIT & BSD-3-Clause | PulseAudio library for cli |
pulseaudio | pulseaudio-lib-protocol-cli | 15.0 | LGPL-2.1-or-later & MIT & BSD-3-Clause | PulseAudio library for protocol-cli |
pulseaudio | pulseaudio-lib-protocol-native | 15.0 | LGPL-2.1-or-later & MIT & BSD-3-Clause | PulseAudio library for protocol-native |
pulseaudio | pulseaudio-misc | 15.0 | LGPL-2.1-or-later & MIT & BSD-3-Clause | Sound server for Linux and Unix-like operating systems |
pulseaudio | pulseaudio-module-alsa-card | 15.0 | LGPL-2.1-or-later & MIT & BSD-3-Clause | PulseAudio module for alsa-card |
pulseaudio | pulseaudio-module-alsa-sink | 15.0 | LGPL-2.1-or-later & MIT & BSD-3-Clause | PulseAudio module for alsa-sink |
pulseaudio | pulseaudio-module-alsa-source | 15.0 | LGPL-2.1-or-later & MIT & BSD-3-Clause | PulseAudio module for alsa-source |
pulseaudio | pulseaudio-module-always-sink | 15.0 | LGPL-2.1-or-later & MIT & BSD-3-Clause | PulseAudio module for always-sink |
pulseaudio | pulseaudio-module-augment-properties | 15.0 | LGPL-2.1-or-later & MIT & BSD-3-Clause | PulseAudio module for augment-properties |
pulseaudio | pulseaudio-module-bluetooth-discover | 15.0 | LGPL-2.1-or-later & MIT & BSD-3-Clause | PulseAudio module for bluetooth-discover |
pulseaudio | pulseaudio-module-bluetooth-policy | 15.0 | LGPL-2.1-or-later & MIT & BSD-3-Clause | PulseAudio module for bluetooth-policy |
pulseaudio | pulseaudio-module-bluez5-device | 15.0 | LGPL-2.1-or-later & MIT & BSD-3-Clause | PulseAudio module for bluez5-device |
pulseaudio | pulseaudio-module-bluez5-discover | 15.0 | LGPL-2.1-or-later & MIT & BSD-3-Clause | PulseAudio module for bluez5-discover |
pulseaudio | pulseaudio-module-card-restore | 15.0 | LGPL-2.1-or-later & MIT & BSD-3-Clause | PulseAudio module for card-restore |
pulseaudio | pulseaudio-module-cli-protocol-unix | 15.0 | LGPL-2.1-or-later & MIT & BSD-3-Clause | PulseAudio module for cli-protocol-unix |
pulseaudio | pulseaudio-module-combine-sink | 15.0 | LGPL-2.1-or-later & MIT & BSD-3-Clause | PulseAudio module for combine-sink |
pulseaudio | pulseaudio-module-default-device-restore | 15.0 | LGPL-2.1-or-later & MIT & BSD-3-Clause | PulseAudio module for default-device-restore |
pulseaudio | pulseaudio-module-detect | 15.0 | LGPL-2.1-or-later & MIT & BSD-3-Clause | PulseAudio module for detect |
pulseaudio | pulseaudio-module-device-restore | 15.0 | LGPL-2.1-or-later & MIT & BSD-3-Clause | PulseAudio module for device-restore |
pulseaudio | pulseaudio-module-filter-apply | 15.0 | LGPL-2.1-or-later & MIT & BSD-3-Clause | PulseAudio module for filter-apply |
pulseaudio | pulseaudio-module-filter-heuristics | 15.0 | LGPL-2.1-or-later & MIT & BSD-3-Clause | PulseAudio module for filter-heuristics |
pulseaudio | pulseaudio-module-intended-roles | 15.0 | LGPL-2.1-or-later & MIT & BSD-3-Clause | PulseAudio module for intended-roles |
pulseaudio | pulseaudio-module-native-protocol-unix | 15.0 | LGPL-2.1-or-later & MIT & BSD-3-Clause | PulseAudio module for native-protocol-unix |
pulseaudio | pulseaudio-module-null-sink | 15.0 | LGPL-2.1-or-later & MIT & BSD-3-Clause | PulseAudio module for null-sink |
pulseaudio | pulseaudio-module-position-event-sounds | 15.0 | LGPL-2.1-or-later & MIT & BSD-3-Clause | PulseAudio module for position-event-sounds |
pulseaudio | pulseaudio-module-rescue-streams | 15.0 | LGPL-2.1-or-later & MIT & BSD-3-Clause | PulseAudio module for rescue-streams |
pulseaudio | pulseaudio-module-role-cork | 15.0 | LGPL-2.1-or-later & MIT & BSD-3-Clause | PulseAudio module for role-cork |
pulseaudio | pulseaudio-module-stream-restore | 15.0 | LGPL-2.1-or-later & MIT & BSD-3-Clause | PulseAudio module for stream-restore |
pulseaudio | pulseaudio-module-suspend-on-idle | 15.0 | LGPL-2.1-or-later & MIT & BSD-3-Clause | PulseAudio module for suspend-on-idle |
pulseaudio | pulseaudio-module-switch-on-port-available | 15.0 | LGPL-2.1-or-later & MIT & BSD-3-Clause | PulseAudio module for switch-on-port-available |
pulseaudio | pulseaudio-module-udev-detect | 15.0 | LGPL-2.1-or-later & MIT & BSD-3-Clause | PulseAudio module for udev-detect |
pulseaudio | pulseaudio-server | 15.0 | LGPL-2.1-or-later & MIT & BSD-3-Clause | Sound server for Linux and Unix-like operating systems |
python3 | python3-asyncio | 3.10.4 | PSF-2.0 | Python Asynchronous I/O |
python3 | python3-audio | 3.10.4 | PSF-2.0 | Python Audio Handling |
python3 | python3-codecs | 3.10.4 | PSF-2.0 | Python codec |
python3 | python3-compression | 3.10.4 | PSF-2.0 | Python high-level compression support |
python3 | python3-core | 3.10.4 | PSF-2.0 | Python interpreter and core modules |
python3 | python3-crypt | 3.10.4 | PSF-2.0 | Python basic cryptographic and hashing support |
python3 | python3-ctypes | 3.10.4 | PSF-2.0 | Python C types support |
python3 | python3-datetime | 3.10.4 | PSF-2.0 | Python calendar and time support |
python3-dateutil | python3-dateutil | 2.8.2 | BSD-3-Clause & Apache-2.0 | Extensions to the standard Python datetime module |
python3 | python3-debugger | 3.10.4 | PSF-2.0 | Python debugger |
python3 | python3-difflib | 3.10.4 | PSF-2.0 | Python helpers for computing deltas between objects |
python3 | python3-distutils | 3.10.4 | PSF-2.0 | Python Distribution Utilities |
python3 | python3-email | 3.10.4 | PSF-2.0 | Python email support |
python3-evdev | python3-evdev | 1.5.0 | BSD-3-Clause | Python evdev lib |
python3 | python3-fcntl | 3.10.4 | PSF-2.0 | Python's fcntl interface |
python3 | python3-html | 3.10.4 | PSF-2.0 | Python HTML processing support |
python3 | python3-io | 3.10.4 | PSF-2.0 | Python low-level I/O |
python3 | python3-json | 3.10.4 | PSF-2.0 | Python JSON support |
python3 | python3-logging | 3.10.4 | PSF-2.0 | Python logging support |
python3 | python3-math | 3.10.4 | PSF-2.0 | Python math support |
python3 | python3-mime | 3.10.4 | PSF-2.0 | Python MIME handling APIs |
python3 | python3-misc | 3.10.4 | PSF-2.0 | The Python Programming Language |
python3 | python3-mmap | 3.10.4 | PSF-2.0 | Python memory-mapped file support |
python3 | python3-multiprocessing | 3.10.4 | PSF-2.0 | Python multiprocessing support |
python3 | python3-netclient | 3.10.4 | PSF-2.0 | Python Internet Protocol clients |
python3 | python3-netserver | 3.10.4 | PSF-2.0 | Python Internet Protocol servers |
python3 | python3-numbers | 3.10.4 | PSF-2.0 | Python number APIs |
python3-pexpect | python3-pexpect | 4.8.0 | ISC | A Pure Python Expect like Module for Python |
python3 | python3-pickle | 3.10.4 | PSF-2.0 | Python serialisation/persistence support |
python3 | python3-pprint | 3.10.4 | PSF-2.0 | Python pretty-print support |
python3 | python3-profile | 3.10.4 | PSF-2.0 | Python basic performance profiling support |
python3-ptyprocess | python3-ptyprocess | 0.7.0 | ISC | Run a subprocess in a pseudo terminal |
python3-pycairo | python3-pycairo | 1.21.0 | LGPL-2.1-only & MPL-1.1 | Python bindings for the Cairo canvas library |
python3 | python3-pydoc | 3.10.4 | PSF-2.0 | Python interactive help support |
python3-pygobject | python3-pygobject | 3.42.0 | LGPL-2.1-only | Python GObject bindings |
python3-pyparsing | python3-pyparsing | 3.0.7 | MIT | Python parsing module |
python3-pyyaml | python3-pyyaml | 6.0 | MIT | Python support for YAML |
python3 | python3-resource | 3.10.4 | PSF-2.0 | Python resource control interface |
python3 | python3-shell | 3.10.4 | PSF-2.0 | Python shell-like functionality |
python3-six | python3-six | 1.16.0 | MIT | Python 2 and 3 compatibility library |
python3 | python3-stringold | 3.10.4 | PSF-2.0 | Python string APIs [deprecated] |
python3 | python3-terminal | 3.10.4 | PSF-2.0 | Python terminal controlling support |
python3 | python3-threading | 3.10.4 | PSF-2.0 | Python threading & synchronization support |
python3 | python3-unittest | 3.10.4 | PSF-2.0 | Python unit testing framework |
python3 | python3-xml | 3.10.4 | PSF-2.0 | Python basic XML support |
qrenc | qrenc | 1.0 | LGPL-2.1-only | qrenc which uses libqrencode to generate QR-code |
v4l-utils | rc-keymaps | 1.22.1 | GPL-2.0-only & LGPL-2.1-only | v4l2 and IR applications |
resize-helper | resize-helper | 1.0 | GPL-2.0-or-later | Tools for resizing the file system |
rng-tools | rng-tools | 6.15 | GPL-2.0-only | Random number generator daemon |
rpcbind | rpcbind | 1.2.6 | BSD-3-Clause | Universal Addresses to RPC Program Number Mapper |
rt-tests | rt-tests | 2.3 | GPL-2.0-only & GPL-2.0-or-later | Real-Time preemption testcases |
run-postinsts | run-postinsts | 1.0 | MIT | Runs postinstall scripts on first boot of the target device |
shadow | shadow | 4.11.1 | BSD-3-Clause | Tools to change and administer password and group data |
shadow | shadow-base | 4.11.1 | BSD-3-Clause | Tools to change and administer password and group data |
shadow-securetty | shadow-securetty | 4.6 | MIT | Provider of the machine specific securetty file |
shared-mime-info | shared-mime-info | 2.1 | GPL-2.0-only | Shared MIME type database and specification |
shared-mime-info | shared-mime-info-data | 2.1 | GPL-2.0-only | Shared MIME type database and specification |
slang | slang | 2.3.2 | GPL-2.0-only | The shared library for the S-Lang extension language |
sqlite3 | sqlite3 | 3.38.5 | PD | Embeddable SQL database engine |
stm32-ddr-tools | stm32-ddr-tools | 1.0 | MIT | STM32 tool to convert the 'perf' tool counters into understandable MB/s |
stm32mp-g0 | stm32mp-g0 | v1.0.0 | Apache-2.0 & MIT & BSD-3-Clause & Proprietary | STM32MP Firmware for G0 |
strace | strace | 5.16 | LGPL-2.1-or-later & GPL-2.0-or-later | System call tracing tool |
sysfsutils | sysfsutils | 2.1.0 | GPL-2.0-only | Tools for working with sysfs |
sysprof | sysprof | 3.44.0 | GPL-3.0-or-later | System-wide Performance Profiler for Linux |
sysstat | sysstat | 12.4.5 | GPL-2.0-or-later | System performance tools |
systemd | systemd | 250.5 | GPL-2.0-only & LGPL-2.1-only | A System and service manager |
systemd | systemd-analyze | 250.5 | GPL-2.0-only & LGPL-2.1-only | A System and service manager |
systemd-conf | systemd-conf | 1.0 | MIT | Systemd system configuration |
systemd | systemd-extra-utils | 250.5 | GPL-2.0-only & LGPL-2.1-only | A System and service manager |
systemd-mount-partitions | systemd-mount-partitions | 1.0 | MIT | Mount partitions |
systemd-networkd-configuration | systemd-networkd-configuration | 1.0 | MIT | Basic networkd configuration |
systemd-serialgetty | systemd-serialgetty | 1.0 | GPL-2.0-or-later | Serial terminal support for systemd |
systemd | systemd-udev-rules | 250.5 | GPL-2.0-only & LGPL-2.1-only | A System and service manager |
systemd | systemd-vconsole-setup | 250.5 | GPL-2.0-only & LGPL-2.1-only | A System and service manager |
systemtap | systemtap | 4.6 | GPL-2.0-only | Script-directed dynamic tracing and performance analysis tool for Linux |
systemtap | systemtap-locale-en | 4.6 | GPL-2.0-only | Script-directed dynamic tracing and performance analysis tool for Linux - en translations |
systemtap | systemtap-runtime | 4.6 | GPL-2.0-only | Script-directed dynamic tracing and performance analysis tool for Linux |
tar | tar | 1.34 | GPL-3.0-only | GNU file archiving program |
tcf-agent | tcf-agent | 1.7.0+gitAUTOINC+2735e3d6b7 | EDL-1.0 | Target Communication Framework for the Eclipse IDE |
tcpdump | tcpdump | 4.99.1 | BSD-3-Clause | A sophisticated network protocol analyzer |
tzdata | tzdata-africa | 2022b | PD & BSD-3-Clause | Timezone data |
tzdata | tzdata-americas | 2022b | PD & BSD-3-Clause | Timezone data |
tzdata | tzdata-antarctica | 2022b | PD & BSD-3-Clause | Timezone data |
tzdata | tzdata-arctic | 2022b | PD & BSD-3-Clause | Timezone data |
tzdata | tzdata-asia | 2022b | PD & BSD-3-Clause | Timezone data |
tzdata | tzdata-atlantic | 2022b | PD & BSD-3-Clause | Timezone data |
tzdata | tzdata-australia | 2022b | PD & BSD-3-Clause | Timezone data |
tzdata | tzdata-core | 2022b | PD & BSD-3-Clause | Timezone data |
tzdata | tzdata-europe | 2022b | PD & BSD-3-Clause | Timezone data |
tzdata | tzdata-misc | 2022b | PD & BSD-3-Clause | Timezone data |
tzdata | tzdata-pacific | 2022b | PD & BSD-3-Clause | Timezone data |
tzdata | tzdata-posix | 2022b | PD & BSD-3-Clause | Timezone data |
tzdata | tzdata-right | 2022b | PD & BSD-3-Clause | Timezone data |
u-boot-fw-config-stm32mp | u-boot-fw-config-stm32mp | 2021.10 | MIT | U-Boot bootloader fw_printenv/setenv utilities |
systemd | udev | 250.5 | GPL-2.0-only & LGPL-2.1-only | A System and service manager |
systemd | udev-hwdb | 250.5 | GPL-2.0-only & LGPL-2.1-only | A System and service manager |
uhubctl | uhubctl | 2.4.0 | GPL-2.0-only | USB hub per-port power control |
opkg-utils | update-alternatives-opkg | 0.5.0 | GPL-2.0-or-later | Utility for managing the alternatives system |
update-rc.d | update-rc.d | 0.8 | GPL-2.0-or-later | manage symlinks in /etc/rcN.d |
usbip | usbip | 2.0 | GPL-2.0-only | USB ip tools |
usbotg-gadget-config | usbotg-gadget-config | 1.0 | MIT | The goal is to enable USB gadget configuration |
usbutils | usbutils | 014 | GPL-2.0-or-later | Host side USB console utilities |
userfs-cleanup-package | userfs-cleanup-package | 1.0 | BSD-3-Clause | Tools for cleaning apt databse |
util-linux | util-linux-addpart | 2.37.4 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux addpart |
util-linux | util-linux-agetty | 2.37.4 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux agetty |
util-linux | util-linux-blkdiscard | 2.37.4 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux blkdiscard |
util-linux | util-linux-blkid | 2.37.4 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux blkid |
util-linux | util-linux-blkzone | 2.37.4 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux blkzone |
util-linux | util-linux-blockdev | 2.37.4 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux blockdev |
util-linux | util-linux-cal | 2.37.4 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux cal |
util-linux | util-linux-cfdisk | 2.37.4 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux cfdisk |
util-linux | util-linux-chcpu | 2.37.4 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux chcpu |
util-linux | util-linux-chfn | 2.37.4 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux chfn |
util-linux | util-linux-chmem | 2.37.4 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux chmem |
util-linux | util-linux-choom | 2.37.4 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux choom |
util-linux | util-linux-chrt | 2.37.4 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux chrt |
util-linux | util-linux-chsh | 2.37.4 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux chsh |
util-linux | util-linux-col | 2.37.4 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux col |
util-linux | util-linux-colcrt | 2.37.4 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux colcrt |
util-linux | util-linux-colrm | 2.37.4 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux colrm |
util-linux | util-linux-column | 2.37.4 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux column |
util-linux | util-linux-ctrlaltdel | 2.37.4 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux ctrlaltdel |
util-linux | util-linux-delpart | 2.37.4 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux delpart |
util-linux | util-linux-dmesg | 2.37.4 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux dmesg |
util-linux | util-linux-eject | 2.37.4 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux eject |
util-linux | util-linux-fallocate | 2.37.4 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux fallocate |
util-linux | util-linux-fdisk | 2.37.4 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux fdisk |
util-linux | util-linux-fincore | 2.37.4 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux fincore |
util-linux | util-linux-findfs | 2.37.4 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux findfs |
util-linux | util-linux-findmnt | 2.37.4 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux findmnt |
util-linux | util-linux-flock | 2.37.4 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux flock |
util-linux | util-linux-fsck | 2.37.4 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux fsck |
util-linux | util-linux-fsck.cramfs | 2.37.4 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux fsck.cramfs |
util-linux | util-linux-fsfreeze | 2.37.4 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux fsfreeze |
util-linux | util-linux-fstrim | 2.37.4 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux fstrim |
util-linux | util-linux-getopt | 2.37.4 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux getopt |
util-linux | util-linux-hardlink | 2.37.4 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux hardlink |
util-linux | util-linux-hexdump | 2.37.4 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux hexdump |
util-linux | util-linux-hwclock | 2.37.4 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux hwclock |
util-linux | util-linux-ionice | 2.37.4 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux ionice |
util-linux | util-linux-ipcmk | 2.37.4 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux ipcmk |
util-linux | util-linux-ipcrm | 2.37.4 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux ipcrm |
util-linux | util-linux-ipcs | 2.37.4 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux ipcs |
util-linux | util-linux-irqtop | 2.37.4 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux irqtop |
util-linux | util-linux-isosize | 2.37.4 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux isosize |
util-linux | util-linux-kill | 2.37.4 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux kill |
util-linux | util-linux-last | 2.37.4 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux last |
util-linux | util-linux-ldattach | 2.37.4 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux ldattach |
util-linux | util-linux-logger | 2.37.4 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux logger |
util-linux | util-linux-look | 2.37.4 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux look |
util-linux | util-linux-losetup | 2.37.4 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux losetup |
util-linux | util-linux-lsblk | 2.37.4 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux lsblk |
util-linux | util-linux-lscpu | 2.37.4 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux lscpu |
util-linux | util-linux-lsipc | 2.37.4 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux lsipc |
util-linux | util-linux-lsirq | 2.37.4 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux lsirq |
util-linux | util-linux-lslocks | 2.37.4 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux lslocks |
util-linux | util-linux-lslogins | 2.37.4 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux lslogins |
util-linux | util-linux-lsmem | 2.37.4 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux lsmem |
util-linux | util-linux-lsns | 2.37.4 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux lsns |
util-linux | util-linux-mcookie | 2.37.4 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux mcookie |
util-linux | util-linux-mesg | 2.37.4 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux mesg |
util-linux | util-linux-mkfs | 2.37.4 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux mkfs |
util-linux | util-linux-mkfs.cramfs | 2.37.4 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux mkfs.cramfs |
util-linux | util-linux-mkswap | 2.37.4 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux mkswap |
util-linux | util-linux-more | 2.37.4 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux more |
util-linux | util-linux-mount | 2.37.4 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux mount |
util-linux | util-linux-mountpoint | 2.37.4 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux mountpoint |
util-linux | util-linux-namei | 2.37.4 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux namei |
util-linux | util-linux-nologin | 2.37.4 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux nologin |
util-linux | util-linux-nsenter | 2.37.4 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux nsenter |
util-linux | util-linux-partx | 2.37.4 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux partx |
util-linux | util-linux-pivot-root | 2.37.4 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux pivot-root |
util-linux | util-linux-prlimit | 2.37.4 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux prlimit |
util-linux | util-linux-readprofile | 2.37.4 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux readprofile |
util-linux | util-linux-rename | 2.37.4 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux rename |
util-linux | util-linux-renice | 2.37.4 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux renice |
util-linux | util-linux-resizepart | 2.37.4 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux resizepart |
util-linux | util-linux-rev | 2.37.4 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux rev |
util-linux | util-linux-rfkill | 2.37.4 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux rfkill |
util-linux | util-linux-rtcwake | 2.37.4 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux rtcwake |
util-linux | util-linux-runuser | 2.37.4 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux runuser |
util-linux | util-linux-script | 2.37.4 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux script |
util-linux | util-linux-scriptlive | 2.37.4 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux scriptlive |
util-linux | util-linux-scriptreplay | 2.37.4 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux scriptreplay |
util-linux | util-linux-setarch | 2.37.4 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux setarch |
util-linux | util-linux-setpriv | 2.37.4 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux setpriv |
util-linux | util-linux-setsid | 2.37.4 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux setsid |
util-linux | util-linux-setterm | 2.37.4 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux setterm |
util-linux | util-linux-sfdisk | 2.37.4 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux sfdisk |
util-linux | util-linux-su | 2.37.4 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux su |
util-linux | util-linux-sulogin | 2.37.4 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux sulogin |
util-linux | util-linux-swaplabel | 2.37.4 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux swaplabel |
util-linux | util-linux-swapoff | 2.37.4 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux swapoff |
util-linux | util-linux-swapon | 2.37.4 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux swapon |
util-linux | util-linux-switch-root | 2.37.4 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux switch-root |
util-linux | util-linux-taskset | 2.37.4 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux taskset |
util-linux | util-linux-uclampset | 2.37.4 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux uclampset |
util-linux | util-linux-ul | 2.37.4 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux ul |
util-linux | util-linux-umount | 2.37.4 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux umount |
util-linux | util-linux-unshare | 2.37.4 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux unshare |
util-linux | util-linux-utmpdump | 2.37.4 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux utmpdump |
util-linux | util-linux-uuidd | 2.37.4 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux uuidd |
util-linux | util-linux-uuidgen | 2.37.4 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux uuidgen |
util-linux | util-linux-uuidparse | 2.37.4 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux uuidparse |
util-linux | util-linux-wall | 2.37.4 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux wall |
util-linux | util-linux-wdctl | 2.37.4 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux wdctl |
util-linux | util-linux-whereis | 2.37.4 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux whereis |
util-linux | util-linux-wipefs | 2.37.4 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux wipefs |
util-linux | util-linux-write | 2.37.4 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux write |
util-linux | util-linux-zramctl | 2.37.4 | GPL-2.0-or-later & LGPL-2.1-or-later & BSD-3-Clause & BSD-4-Clause | util-linux zramctl |
v4l-utils | v4l-utils | 1.22.1 | GPL-2.0-only & LGPL-2.1-only | v4l2 and IR applications |
valgrind | valgrind | 3.18.1 | GPL-2.0-only & GPL-2.0-or-later & BSD-3-Clause | Valgrind memory debugger and instrumentation framework |
volatile-binds | volatile-binds | 1.0 | MIT | Volatile bind mount setup and configuration for read-only-rootfs |
wayland | wayland | 1.20.0 | MIT | Wayland, a protocol between a compositor and clients |
weston | weston | 10.0.2 | MIT | Weston, a Wayland compositor |
weston | weston-examples | 10.0.2 | MIT | Weston, a Wayland compositor |
weston-init | weston-init | 1.0 | MIT | Startup script and systemd unit file for the Weston Wayland compositor |
wget | wget | 1.21.3 | GPL-3.0-only | Console URL download utility supporting HTTP, FTP, etc |
wireless-regdb | wireless-regdb-static | 2022.08.12 | ISC | Wireless Central Regulatory Domain Database |
wpa-supplicant | wpa-supplicant | 2.10 | BSD-3-Clause | Client for Wi-Fi Protected Access (WPA) |
wpa-supplicant | wpa-supplicant-cli | 2.10 | BSD-3-Clause | Client for Wi-Fi Protected Access (WPA) |
wpa-supplicant | wpa-supplicant-passphrase | 2.10 | BSD-3-Clause | Client for Wi-Fi Protected Access (WPA) |
xkeyboard-config | xkeyboard-config | 2.35.1 | MIT & MIT | Keyboard configuration database for X Window |
xxhash | xxhash | 0.8.1 | BSD-2-Clause & GPL-2.0-only | Extremely fast non-cryptographic hash algorithm |
xz | xz | 5.2.6 | GPL-2.0-or-later | Utilities for managing LZMA compressed files |
3.3. userfs partition:[edit source]
List of packages present on image:
Image | st-image-userfs-openstlinux-weston-stm32mp1 |
Recipe Name | Package Name | Version | License | Description |
ai-hand-char-reco-launcher | ai-hand-char-reco-launcher | 2.1 | GPL-2.0-only & BSD-3-Clause | Hand writing character recognition launcher based on HCR Neural Network |
demo-application-3d-cube | demo-application-3d-cube | 3.0 | BSD-3-Clause | Add support of 3d Cube application on Demo Launcher |
demo-application-bluetooth | demo-application-bluetooth | 2.1 | BSD-3-Clause | Add support of audio bluetooth speaker on Demo Launcher |
demo-application-camera | demo-application-camera | 2.0 | BSD-3-Clause | Add support of camera preview on Demo Launcher |
demo-application-netdata-hotspot | demo-application-netdata-hotspot | 2.0 | BSD-3-Clause | Add support of netdata/hotspot wifi on Demo Launcher |
demo-application-video | demo-application-video | 2.0 | BSD-3-Clause | Add support of camera preview on Demo Launcher |
demo-hotspot-wifi | demo-hotspot-wifi | 1.0 | MIT | Shell script to enable/disable hotsopt wifi configuration |
demo-launcher | demo-launcher | 2.1 | BSD-3-Clause | Python script which launch several use-cases |
event-gtk-player | event-gtk-player | 4.0+gitAUTOINC+aaba1dcfe5 | GPL-2.0-or-later | GTK player with touch screen management |
linux-examples-stm32mp1 | linux-examples-stm32mp1-userfs | 5.4+AUTOINC+8e1c0b246c | MIT | ST STM32MP1 projects for Linux examples |
m4projects-stm32mp1 | m4projects-stm32mp1-userfs | 1.6.0 | Apache-2.0 & MIT & BSD-3-Clause | STM32MP1 Firmware examples for CM4 |
weston-cube | weston-cube | 4.0+gitAUTOINC+cd44839e95 | MIT | 3D cube for wayland/weston windows |
4. vendorfs partition: (STM32MP15x lines only)[edit source]
Image | st-image-vendorfs-openstlinux-weston-stm32mp1 |
gcnano-userland-multi-binary-stm32mp | libegl-gcnano | 6.4.9+20221020 | Proprietary | Vivante libraries OpenGL ES, OpenVG and EGL (multi backend) |
gcnano-userland-multi-binary-stm32mp | libgal-gcnano | 6.4.9+20221020 | Proprietary | Vivante libraries OpenGL ES, OpenVG and EGL (multi backend) |
gcnano-userland-multi-binary-stm32mp | libgbm-gcnano | 6.4.9+20221020 | Proprietary | Vivante libraries OpenGL ES, OpenVG and EGL (multi backend) |
gcnano-userland-multi-binary-stm32mp | libgles1-gcnano | 6.4.9+20221020 | Proprietary | Vivante libraries OpenGL ES, OpenVG and EGL (multi backend) |
gcnano-userland-multi-binary-stm32mp | libgles2-gcnano | 6.4.9+20221020 | Proprietary | Vivante libraries OpenGL ES, OpenVG and EGL (multi backend) |
gcnano-userland-multi-binary-stm32mp | libopenvg-gcnano | 6.4.9+20221020 | Proprietary | Vivante libraries OpenGL ES, OpenVG and EGL (multi backend) |
5. Full license list including packages from ST package repository[edit source]
This list not only includes the licenses from OpenSTLinux distribution but also the licenses of the packages that could be installed from this distribution thanks to package repository for OpenSTLinux distribution: LICENSES-world-openstlinux-weston-stm32mp1.tar.gz
6. OE SPDX LICENSE[edit source]
Openembedded validate the License with the SPDX license list.
How Openembedded validate an License indicated on a package:
Official licenses used by Openembedded | Link to text of license |
0BSD | [0BSD] |
AAL | [AAL] |
Abstyles | [Abstyles] |
Adobe | [Adobe] |
Adobe-2006 | [Adobe-2006] |
Adobe-Glyph | [Adobe-Glyph] |
ADSL | [ADSL] |
AFL-1.1 | [AFL-1.1] |
AFL-1.2 | [AFL-1.2] |
AFL-2.0 | [AFL-2.0] |
AFL-2.1 | [AFL-2.1] |
AFL-3.0 | [AFL-3.0] |
Afmparse | [Afmparse] |
AGPL-1.0-only | [AGPL-1.0-only] |
AGPL-1.0-or-later | [AGPL-1.0-or-later] |
AGPL-3.0-only | [AGPL-3.0-only] |
AGPL-3.0-or-later | [AGPL-3.0-or-later] |
Aladdin | [Aladdin] |
AMDPLPA | [AMDPLPA] |
AML | [AML] |
AMPAS | [AMPAS] |
ANTLR-PD | [ANTLR-PD] |
ANTLR-PD-fallback | [ANTLR-PD-fallback] |
Apache-1.0 | [Apache-1.0] |
Apache-1.1 | [Apache-1.1] |
Apache-2.0 | [Apache-2.0] |
Apache-2.0-with-LLVM-exception | [Apache-2.0-with-LLVM-exception] |
APAFML | [APAFML] |
APL-1.0 | [APL-1.0] |
APSL-1.0 | [APSL-1.0] |
APSL-1.1 | [APSL-1.1] |
APSL-1.2 | [APSL-1.2] |
APSL-2.0 | [APSL-2.0] |
Artistic-1.0 | [Artistic-1.0] |
Artistic-1.0-cl8 | [Artistic-1.0-cl8] |
Artistic-1.0-Perl | [Artistic-1.0-Perl] |
Artistic-2.0 | [Artistic-2.0] |
Bahyph | [Bahyph] |
Barr | [Barr] |
Beerware | [Beerware] |
BitstreamVera | [BitstreamVera] |
BitTorrent-1.0 | [BitTorrent-1.0] |
BitTorrent-1.1 | [BitTorrent-1.1] |
blessing | [blessing] |
BlueOak-1.0.0 | [BlueOak-1.0.0] |
Borceux | [Borceux] |
BSD-1-Clause | [BSD-1-Clause] |
BSD-2-Clause | [BSD-2-Clause] |
BSD-2-Clause-Patent | [BSD-2-Clause-Patent] |
BSD-2-Clause-Views | [BSD-2-Clause-Views] |
BSD-3-Clause | [BSD-3-Clause] |
BSD-3-Clause-Attribution | [BSD-3-Clause-Attribution] |
BSD-3-Clause-Clear | [BSD-3-Clause-Clear] |
BSD-3-Clause-LBNL | [BSD-3-Clause-LBNL] |
BSD-3-Clause-Modification | [BSD-3-Clause-Modification] |
BSD-3-Clause-No-Military-License | [BSD-3-Clause-No-Military-License] |
BSD-3-Clause-No-Nuclear-License | [BSD-3-Clause-No-Nuclear-License] |
BSD-3-Clause-No-Nuclear-License-2014 | [BSD-3-Clause-No-Nuclear-License-2014] |
BSD-3-Clause-No-Nuclear-Warranty | [BSD-3-Clause-No-Nuclear-Warranty] |
BSD-3-Clause-Open-MPI | [BSD-3-Clause-Open-MPI] |
BSD-4-Clause | [BSD-4-Clause] |
BSD-4-Clause-Shortened | [BSD-4-Clause-Shortened] |
BSD-4-Clause-UC | [BSD-4-Clause-UC] |
BSD-Protection | [BSD-Protection] |
BSD-Source-Code | [BSD-Source-Code] |
BSL-1.0 | [BSL-1.0] |
BUSL-1.1 | [BUSL-1.1] |
bzip2-1.0.4 | [bzip2-1.0.4] |
bzip2-1.0.5 | [bzip2-1.0.5] |
bzip2-1.0.6 | [bzip2-1.0.6] |
CAL-1.0 | [CAL-1.0] |
CAL-1.0-Combined-Work-Exception | [CAL-1.0-Combined-Work-Exception] |
Caldera | [Caldera] |
CATOSL-1.1 | [CATOSL-1.1] |
CC0-1.0 | [CC0-1.0] |
CC-BY-1.0 | [CC-BY-1.0] |
CC-BY-2.0 | [CC-BY-2.0] |
CC-BY-2.5 | [CC-BY-2.5] |
CC-BY-2.5-AU | [CC-BY-2.5-AU] |
CC-BY-3.0 | [CC-BY-3.0] |
CC-BY-3.0-AT | [CC-BY-3.0-AT] |
CC-BY-3.0-DE | [CC-BY-3.0-DE] |
CC-BY-3.0-NL | [CC-BY-3.0-NL] |
CC-BY-3.0-US | [CC-BY-3.0-US] |
CC-BY-4.0 | [CC-BY-4.0] |
CC-BY-NC-1.0 | [CC-BY-NC-1.0] |
CC-BY-NC-2.0 | [CC-BY-NC-2.0] |
CC-BY-NC-2.5 | [CC-BY-NC-2.5] |
CC-BY-NC-3.0 | [CC-BY-NC-3.0] |
CC-BY-NC-3.0-DE | [CC-BY-NC-3.0-DE] |
CC-BY-NC-4.0 | [CC-BY-NC-4.0] |
CC-BY-NC-ND-1.0 | [CC-BY-NC-ND-1.0] |
CC-BY-NC-ND-2.0 | [CC-BY-NC-ND-2.0] |
CC-BY-NC-ND-2.5 | [CC-BY-NC-ND-2.5] |
CC-BY-NC-ND-3.0 | [CC-BY-NC-ND-3.0] |
CC-BY-NC-ND-3.0-DE | [CC-BY-NC-ND-3.0-DE] |
CC-BY-NC-ND-3.0-IGO | [CC-BY-NC-ND-3.0-IGO] |
CC-BY-NC-ND-4.0 | [CC-BY-NC-ND-4.0] |
CC-BY-NC-SA-1.0 | [CC-BY-NC-SA-1.0] |
CC-BY-NC-SA-2.0 | [CC-BY-NC-SA-2.0] |
CC-BY-NC-SA-2.0-FR | [CC-BY-NC-SA-2.0-FR] |
CC-BY-NC-SA-2.0-UK | [CC-BY-NC-SA-2.0-UK] |
CC-BY-NC-SA-2.5 | [CC-BY-NC-SA-2.5] |
CC-BY-NC-SA-3.0 | [CC-BY-NC-SA-3.0] |
CC-BY-NC-SA-3.0-DE | [CC-BY-NC-SA-3.0-DE] |
CC-BY-NC-SA-3.0-IGO | [CC-BY-NC-SA-3.0-IGO] |
CC-BY-NC-SA-4.0 | [CC-BY-NC-SA-4.0] |
CC-BY-ND-1.0 | [CC-BY-ND-1.0] |
CC-BY-ND-2.0 | [CC-BY-ND-2.0] |
CC-BY-ND-2.5 | [CC-BY-ND-2.5] |
CC-BY-ND-3.0 | [CC-BY-ND-3.0] |
CC-BY-ND-3.0-DE | [CC-BY-ND-3.0-DE] |
CC-BY-ND-4.0 | [CC-BY-ND-4.0] |
CC-BY-SA-1.0 | [CC-BY-SA-1.0] |
CC-BY-SA-2.0 | [CC-BY-SA-2.0] |
CC-BY-SA-2.0-UK | [CC-BY-SA-2.0-UK] |
CC-BY-SA-2.1-JP | [CC-BY-SA-2.1-JP] |
CC-BY-SA-2.5 | [CC-BY-SA-2.5] |
CC-BY-SA-3.0 | [CC-BY-SA-3.0] |
CC-BY-SA-3.0-AT | [CC-BY-SA-3.0-AT] |
CC-BY-SA-3.0-DE | [CC-BY-SA-3.0-DE] |
CC-BY-SA-4.0 | [CC-BY-SA-4.0] |
CC-PDDC | [CC-PDDC] |
CDDL-1.0 | [CDDL-1.0] |
CDDL-1.1 | [CDDL-1.1] |
CDL-1.0 | [CDL-1.0] |
CDLA-Permissive-1.0 | [CDLA-Permissive-1.0] |
CDLA-Permissive-2.0 | [CDLA-Permissive-2.0] |
CDLA-Sharing-1.0 | [CDLA-Sharing-1.0] |
CECILL-1.0 | [CECILL-1.0] |
CECILL-1.1 | [CECILL-1.1] |
CECILL-2.0 | [CECILL-2.0] |
CECILL-2.1 | [CECILL-2.1] |
CECILL-B | [CECILL-B] |
CECILL-C | [CECILL-C] |
CERN-OHL-1.1 | [CERN-OHL-1.1] |
CERN-OHL-1.2 | [CERN-OHL-1.2] |
CERN-OHL-P-2.0 | [CERN-OHL-P-2.0] |
CERN-OHL-S-2.0 | [CERN-OHL-S-2.0] |
CERN-OHL-W-2.0 | [CERN-OHL-W-2.0] |
ClArtistic | [ClArtistic] |
CNRI-Jython | [CNRI-Jython] |
CNRI-Python | [CNRI-Python] |
CNRI-Python-GPL-Compatible | [CNRI-Python-GPL-Compatible] |
Condor-1.1 | [Condor-1.1] |
copyleft-next-0.3.0 | [copyleft-next-0.3.0] |
copyleft-next-0.3.1 | [copyleft-next-0.3.1] |
CPAL-1.0 | [CPAL-1.0] |
CPL-1.0 | [CPL-1.0] |
CPOL-1.02 | [CPOL-1.02] |
Crossword | [Crossword] |
CrystalStacker | [CrystalStacker] |
CUA-OPL-1.0 | [CUA-OPL-1.0] |
Cube | [Cube] |
C-UDA-1.0 | [C-UDA-1.0] |
curl | [curl] |
D-FSL-1.0 | [D-FSL-1.0] |
diffmark | [diffmark] |
DOC | [DOC] |
Dotseqn | [Dotseqn] |
DRL-1.0 | [DRL-1.0] |
DSDP | [DSDP] |
DSSSL | [DSSSL] |
dvipdfm | [dvipdfm] |
ECL-1.0 | [ECL-1.0] |
ECL-2.0 | [ECL-2.0] |
eCos-2.0 | [eCos-2.0] |
EDL-1.0 | [EDL-1.0] |
EFL-1.0 | [EFL-1.0] |
EFL-2.0 | [EFL-2.0] |
eGenix | [eGenix] |
Entessa | [Entessa] |
EPICS | [EPICS] |
EPL-1.0 | [EPL-1.0] |
EPL-2.0 | [EPL-2.0] |
ErlPL-1.1 | [ErlPL-1.1] |
etalab-2.0 | [etalab-2.0] |
EUDatagrid | [EUDatagrid] |
EUPL-1.0 | [EUPL-1.0] |
EUPL-1.1 | [EUPL-1.1] |
EUPL-1.2 | [EUPL-1.2] |
Fair | [Fair] |
Frameworx-1.0 | [Frameworx-1.0] |
FreeBSD-DOC | [FreeBSD-DOC] |
FreeImage | [FreeImage] |
FSFAP | [FSFAP] |
FSFUL | [FSFUL] |
FSFULLR | [FSFULLR] |
FSF-Unlimited | [FSF-Unlimited] |
FTL | [FTL] |
GD | [GD] |
GFDL-1.1 | [GFDL-1.1] |
GFDL-1.1-invariants-only | [GFDL-1.1-invariants-only] |
GFDL-1.1-invariants-or-later | [GFDL-1.1-invariants-or-later] |
GFDL-1.1-no-invariants-only | [GFDL-1.1-no-invariants-only] |
GFDL-1.1-no-invariants-or-later | [GFDL-1.1-no-invariants-or-later] |
GFDL-1.1-only | [GFDL-1.1-only] |
GFDL-1.1-or-later | [GFDL-1.1-or-later] |
GFDL-1.2 | [GFDL-1.2] |
GFDL-1.2-invariants-only | [GFDL-1.2-invariants-only] |
GFDL-1.2-invariants-or-later | [GFDL-1.2-invariants-or-later] |
GFDL-1.2-no-invariants-only | [GFDL-1.2-no-invariants-only] |
GFDL-1.2-no-invariants-or-later | [GFDL-1.2-no-invariants-or-later] |
GFDL-1.2-only | [GFDL-1.2-only] |
GFDL-1.2-or-later | [GFDL-1.2-or-later] |
GFDL-1.3 | [GFDL-1.3] |
GFDL-1.3-invariants-only | [GFDL-1.3-invariants-only] |
GFDL-1.3-invariants-or-later | [GFDL-1.3-invariants-or-later] |
GFDL-1.3-no-invariants-only | [GFDL-1.3-no-invariants-only] |
GFDL-1.3-no-invariants-or-later | [GFDL-1.3-no-invariants-or-later] |
GFDL-1.3-only | [GFDL-1.3-only] |
GFDL-1.3-or-later | [GFDL-1.3-or-later] |
Giftware | [Giftware] |
GL2PS | [GL2PS] |
Glide | [Glide] |
Glulxe | [Glulxe] |
GLWTPL | [GLWTPL] |
gnuplot | [gnuplot] |
GPL-1.0-only | [GPL-1.0-only] |
GPL-1.0-or-later | [GPL-1.0-or-later] |
GPL-2.0-only | [GPL-2.0-only] |
GPL-2.0-or-later | [GPL-2.0-or-later] |
GPL-2.0-with-autoconf-exception | [GPL-2.0-with-autoconf-exception] |
GPL-2.0-with-classpath-exception | [GPL-2.0-with-classpath-exception] |
GPL-2.0-with-font-exception | [GPL-2.0-with-font-exception] |
GPL-2.0-with-GCC-exception | [GPL-2.0-with-GCC-exception] |
GPL-2.0-with-OpenSSL-exception | [GPL-2.0-with-OpenSSL-exception] |
GPL-2-with-bison-exception | [GPL-2-with-bison-exception] |
GPL-3.0-only | [GPL-3.0-only] |
GPL-3.0-or-later | [GPL-3.0-or-later] |
GPL-3.0-with-autoconf-exception | [GPL-3.0-with-autoconf-exception] |
GPL-3.0-with-GCC-exception | [GPL-3.0-with-GCC-exception] |
GPL-3-with-bison-exception | [GPL-3-with-bison-exception] |
gSOAP-1 | [gSOAP-1] |
gSOAP-1.3b | [gSOAP-1.3b] |
HaskellReport | [HaskellReport] |
Hippocratic-2.1 | [Hippocratic-2.1] |
HPND | [HPND] |
HPND-sell-variant | [HPND-sell-variant] |
HTMLTIDY | [HTMLTIDY] |
IBM-pibs | [IBM-pibs] |
ICU | [ICU] |
IJG | [IJG] |
ImageMagick | [ImageMagick] |
iMatix | [iMatix] |
Imlib2 | [Imlib2] |
Info-ZIP | [Info-ZIP] |
Intel | [Intel] |
Intel-ACPI | [Intel-ACPI] |
Interbase-1.0 | [Interbase-1.0] |
IPA | [IPA] |
IPL-1.0 | [IPL-1.0] |
ISC | [ISC] |
JasPer-2.0 | [JasPer-2.0] |
JPNIC | [JPNIC] |
JSON | [JSON] |
LAL-1.2 | [LAL-1.2] |
LAL-1.3 | [LAL-1.3] |
Latex2e | [Latex2e] |
Leptonica | [Leptonica] |
LGPL-2.0-only | [LGPL-2.0-only] |
LGPL-2.0-or-later | [LGPL-2.0-or-later] |
LGPL-2.1-only | [LGPL-2.1-only] |
LGPL-2.1-or-later | [LGPL-2.1-or-later] |
LGPL-3.0-only | [LGPL-3.0-only] |
LGPL-3.0-or-later | [LGPL-3.0-or-later] |
LGPLLR | [LGPLLR] |
Libpng | [Libpng] |
libpng-2.0 | [libpng-2.0] |
libselinux-1.0 | [libselinux-1.0] |
libtiff | [libtiff] |
LiLiQ-P-1.1 | [LiLiQ-P-1.1] |
LiLiQ-R-1.1 | [LiLiQ-R-1.1] |
LiLiQ-Rplus-1.1 | [LiLiQ-Rplus-1.1] |
Linux-OpenIB | [Linux-OpenIB] |
LPL-1.0 | [LPL-1.0] |
LPL-1.02 | [LPL-1.02] |
LPPL-1.0 | [LPPL-1.0] |
LPPL-1.1 | [LPPL-1.1] |
LPPL-1.2 | [LPPL-1.2] |
LPPL-1.3a | [LPPL-1.3a] |
LPPL-1.3c | [LPPL-1.3c] |
MakeIndex | [MakeIndex] |
MirOS | [MirOS] |
MIT | [MIT] |
MIT-0 | [MIT-0] |
MIT-advertising | [MIT-advertising] |
MIT-CMU | [MIT-CMU] |
MIT-enna | [MIT-enna] |
MIT-feh | [MIT-feh] |
MIT-Modern-Variant | [MIT-Modern-Variant] |
MITNFA | [MITNFA] |
MIT-open-group | [MIT-open-group] |
Motosoto | [Motosoto] |
mpich2 | [mpich2] |
MPL-1.0 | [MPL-1.0] |
MPL-1.1 | [MPL-1.1] |
MPL-2.0 | [MPL-2.0] |
MPL-2.0-no-copyleft-exception | [MPL-2.0-no-copyleft-exception] |
MS-PL | [MS-PL] |
MS-RL | [MS-RL] |
MTLL | [MTLL] |
MulanPSL-1.0 | [MulanPSL-1.0] |
MulanPSL-2.0 | [MulanPSL-2.0] |
Multics | [Multics] |
Mup | [Mup] |
NAIST-2003 | [NAIST-2003] |
NASA-1.3 | [NASA-1.3] |
Naumen | [Naumen] |
NBPL-1.0 | [NBPL-1.0] |
NCGL-UK-2.0 | [NCGL-UK-2.0] |
NCSA | [NCSA] |
NetCDF | [NetCDF] |
Net-SNMP | [Net-SNMP] |
Newsletr | [Newsletr] |
NGPL | [NGPL] |
NIST-PD | [NIST-PD] |
NIST-PD-fallback | [NIST-PD-fallback] |
NLOD-1.0 | [NLOD-1.0] |
NLOD-2.0 | [NLOD-2.0] |
NLPL | [NLPL] |
Nokia | [Nokia] |
NOSL | [NOSL] |
Noweb | [Noweb] |
NPL-1.0 | [NPL-1.0] |
NPL-1.1 | [NPL-1.1] |
NPOSL-3.0 | [NPOSL-3.0] |
NRL | [NRL] |
NTP | [NTP] |
NTP-0 | [NTP-0] |
OASIS | [OASIS] |
OCCT-PL | [OCCT-PL] |
OCLC-2.0 | [OCLC-2.0] |
ODbL-1.0 | [ODbL-1.0] |
ODC-By-1.0 | [ODC-By-1.0] |
OFL-1.0 | [OFL-1.0] |
OFL-1.0-no-RFN | [OFL-1.0-no-RFN] |
OFL-1.0-RFN | [OFL-1.0-RFN] |
OFL-1.1 | [OFL-1.1] |
OFL-1.1-no-RFN | [OFL-1.1-no-RFN] |
OFL-1.1-RFN | [OFL-1.1-RFN] |
OGC-1.0 | [OGC-1.0] |
OGDL-Taiwan-1.0 | [OGDL-Taiwan-1.0] |
OGL-Canada-2.0 | [OGL-Canada-2.0] |
OGL-UK-1.0 | [OGL-UK-1.0] |
OGL-UK-2.0 | [OGL-UK-2.0] |
OGL-UK-3.0 | [OGL-UK-3.0] |
OGTSL | [OGTSL] |
OLDAP-1.1 | [OLDAP-1.1] |
OLDAP-1.2 | [OLDAP-1.2] |
OLDAP-1.3 | [OLDAP-1.3] |
OLDAP-1.4 | [OLDAP-1.4] |
OLDAP-2.0 | [OLDAP-2.0] |
OLDAP-2.0.1 | [OLDAP-2.0.1] |
OLDAP-2.1 | [OLDAP-2.1] |
OLDAP-2.2 | [OLDAP-2.2] |
OLDAP-2.2.1 | [OLDAP-2.2.1] |
OLDAP-2.2.2 | [OLDAP-2.2.2] |
OLDAP-2.3 | [OLDAP-2.3] |
OLDAP-2.4 | [OLDAP-2.4] |
OLDAP-2.5 | [OLDAP-2.5] |
OLDAP-2.6 | [OLDAP-2.6] |
OLDAP-2.7 | [OLDAP-2.7] |
OLDAP-2.8 | [OLDAP-2.8] |
OML | [OML] |
OpenSSL | [OpenSSL] |
OPL-1.0 | [OPL-1.0] |
OPUBL-1.0 | [OPUBL-1.0] |
OSET-PL-2.1 | [OSET-PL-2.1] |
OSL-1.0 | [OSL-1.0] |
OSL-1.1 | [OSL-1.1] |
OSL-2.0 | [OSL-2.0] |
OSL-2.1 | [OSL-2.1] |
OSL-3.0 | [OSL-3.0] |
O-UDA-1.0 | [O-UDA-1.0] |
ParaTypeFFL-1.3 | [ParaTypeFFL-1.3] |
Parity-6.0.0 | [Parity-6.0.0] |
Parity-7.0.0 | [Parity-7.0.0] |
PD | [PD] |
PDDL-1.0 | [PDDL-1.0] |
PHP-3.0 | [PHP-3.0] |
PHP-3.01 | [PHP-3.01] |
pkgconf | [pkgconf] |
Plexus | [Plexus] |
PolyForm-Noncommercial-1.0.0 | [PolyForm-Noncommercial-1.0.0] |
PolyForm-Small-Business-1.0.0 | [PolyForm-Small-Business-1.0.0] |
PostgreSQL | [PostgreSQL] |
Proprietary | [Proprietary] |
PSF-2.0 | [PSF-2.0] |
psfrag | [psfrag] |
psutils | [psutils] |
Python-2.0 | [Python-2.0] |
Qhull | [Qhull] |
QPL-1.0 | [QPL-1.0] |
Rdisc | [Rdisc] |
RHeCos-1 | [RHeCos-1] |
RHeCos-1.1 | [RHeCos-1.1] |
RPL-1.1 | [RPL-1.1] |
RPL-1.5 | [RPL-1.5] |
RPSL-1.0 | [RPSL-1.0] |
RSA-MD | [RSA-MD] |
RSCPL | [RSCPL] |
Ruby | [Ruby] |
Saxpath | [Saxpath] |
SAX-PD | [SAX-PD] |
SCEA | [SCEA] |
Sendmail | [Sendmail] |
Sendmail-8.23 | [Sendmail-8.23] |
SGI-1 | [SGI-1] |
SGI-B-1.0 | [SGI-B-1.0] |
SGI-B-1.1 | [SGI-B-1.1] |
SGI-B-2.0 | [SGI-B-2.0] |
SHL-0.5 | [SHL-0.5] |
SHL-0.51 | [SHL-0.51] |
SimPL-2.0 | [SimPL-2.0] |
Simple-2.0 | [Simple-2.0] |
SISSL | [SISSL] |
SISSL-1.2 | [SISSL-1.2] |
Sleepycat | [Sleepycat] |
SMAIL_GPL | [SMAIL_GPL] |
SMLNJ | [SMLNJ] |
SMPPL | [SMPPL] |
SNIA | [SNIA] |
Spencer-86 | [Spencer-86] |
Spencer-94 | [Spencer-94] |
Spencer-99 | [Spencer-99] |
SPL-1.0 | [SPL-1.0] |
SSH-OpenSSH | [SSH-OpenSSH] |
SSH-short | [SSH-short] |
SSPL-1.0 | [SSPL-1.0] |
SugarCRM-1 | [SugarCRM-1] |
SugarCRM-1.1.3 | [SugarCRM-1.1.3] |
SWL | [SWL] |
TAPR-OHL-1.0 | [TAPR-OHL-1.0] |
TCL | [TCL] |
TCP-wrappers | [TCP-wrappers] |
TMate | [TMate] |
TORQUE-1.1 | [TORQUE-1.1] |
TOSL | [TOSL] |
TU-Berlin-1.0 | [TU-Berlin-1.0] |
TU-Berlin-2.0 | [TU-Berlin-2.0] |
UCB | [UCB] |
UCL-1.0 | [UCL-1.0] |
unfs3 | [unfs3] |
Unicode-DFS-2015 | [Unicode-DFS-2015] |
Unicode-DFS-2016 | [Unicode-DFS-2016] |
Unicode-TOU | [Unicode-TOU] |
Unlicense | [Unlicense] |
UPL-1.0 | [UPL-1.0] |
Vim | [Vim] |
VOSTROM | [VOSTROM] |
VSL-1.0 | [VSL-1.0] |
W3C | [W3C] |
W3C-19980720 | [W3C-19980720] |
W3C-20150513 | [W3C-20150513] |
Watcom-1.0 | [Watcom-1.0] |
Wsuipa | [Wsuipa] |
WTFPL | [WTFPL] |
WXwindows | [WXwindows] |
X11 | [X11] |
Xerox | [Xerox] |
XFree86-1.0 | [XFree86-1.0] |
xinetd | [xinetd] |
Xnet | [Xnet] |
xpp | [xpp] |
XSkat | [XSkat] |
XSL | [XSL] |
YPL-1.0 | [YPL-1.0] |
YPL-1.1 | [YPL-1.1] |
Zed | [Zed] |
Zend-2.0 | [Zend-2.0] |
Zimbra-1.3 | [Zimbra-1.3] |
Zimbra-1.4 | [Zimbra-1.4] |
Zlib | [Zlib] |
zlib-acknowledgement | [zlib-acknowledgement] |
ZPL-1.1 | [ZPL-1.1] |
ZPL-2.0 | [ZPL-2.0] |
ZPL-2.1 | [ZPL-2.1] |
Information extracted from:
http://git.openembedded.org/openembedded-core/tree/meta/conf/licenses.conf
All Text of License are available:
http://git.openembedded.org/openembedded-core/tree/meta/files/common-licenses
7. Archives [edit source]
STM32MP15 release | OpenSTLinux licenses |
STM32MPU-ecosystem-v4.0.0 | LegalInformation:OpenSTLinux licenses - v4.0.0 |
STM32MP15-ecosystem-v3.1.0 | LegalInformation:OpenSTLinux licenses - v3.1.0 page for the v3 ecosystem releases (in archived wiki) |
STM32MP15-ecosystem-v3.0.0 | LegalInformation:OpenSTLinux licenses - v3.0.0 page for the v3 ecosystem releases (in archived wiki) |
STM32MP15-ecosystem-v2.1.0 | LegalInformation:OpenSTLinux licenses - v2.1.0 page for the v2 ecosystem releases (in archived wiki) |
STM32MP15-ecosystem-v2.0.0 | LegalInformation:OpenSTLinux licenses - v2.0.0 page for the v2 ecosystem releases (in archived wiki) |
STM32MP15-ecosystem-v1.2.0 | LegalInformation:OpenSTLinux licenses - v1.2.0 page for the v1 ecosystem releases (in archived wiki) |
STM32MP15-ecosystem-v1.1.0 | LegalInformation:OpenSTLinux licenses - v1.1.0 page for the v1 ecosystem releases (in archived wiki) |
STM32MP15-ecosystem-v1.0.0 | LegalInformation:OpenSTLinux licenses - v1.0.0 page for the v1 ecosystem releases (in archived wiki) |
