1. Usage[edit source]
The U-Boot$ template is used to prefix a command that must be executed on the U-Boot console, with a U-Boot-specific prompt.
Thanks to the u-boot-prompt
Usage: {{U-Boot$}}
You type | You get |
help env command executed on the U-Boot console
{{U-Boot$}}help env<br>
env - environment handling commands
help env |
3. More examples[edit source]
2 commands executed on the U-Boot console and preformatted text block (space at the beginning of each line)
{{U-Boot$}}help env env - environment handling commands {{U-Boot$}}env default -a |
help env env - environment handling commands env default -a |
Command executed on the U-Boot console and preformatted text block (space at the beginning of each line)
{{U-Boot$}}help env
help env env - environment handling commands |
Long command executed on the U-Boot console and preformatted text block (space at the beginning of each line)
{{U-Boot$}}this is a so long command executed on the U-Boot console that a horizontal scrolling bar is needed |
Template used within another public message box template
{{Info |
Message before the command
{{U-Boot$}}help env
Message after the command
Template used within another protected message box template
{{InternalInfo |
{{U-Boot$}}help env
4. Maintenance[edit source]
5. Code[edit source]
