1. Usage[edit source]
The GDB$ template is used to prefix a command that must be executed on GDB, with a GDB-specific prompt.
Thanks to the gdb-prompt
Usage: {{GDB$}}
You type | You get |
info break command executed on GDB
{{GDB$}}show listsize<br> Number of source lines gdb will list by default is 10. |
show listsize |
3. More examples[edit source]
2 commands executed on GDB and preformatted text block (space at the beginning of each line)
{{GDB$}}show listsize Number of source lines gdb will list by default is 10. {{GDB$}}continue |
show listsize Number of source lines gdb will list by default is 10. continue |
Command executed on GDB and preformatted text block (space at the beginning of each line)
{{GDB$}}show listsize Number of source lines gdb will list by default is 10. |
Long command executed on GDB and preformatted text block (space at the beginning of each line)
{{GDB$}}this is a so long command executed on GDB that a horizontal scrolling bar is needed |
Template used within another public message box template
{{Info | Message before the command {{GDB$}}show listsize Number of source lines gdb will list by default is 10. Message after the command }} |
Template used within another protected message box template
{{InternalInfo | Message before the command {{GDB$}}show listsize Number of source lines gdb will list by default is 10. Message after the command }} |
4. Maintenance[edit source]
5. Code[edit source]
