Board$
1. Usage
The Board$ template is used to prefix a command that must be executed on a board, with a board-specific prompt.
Thanks to the board-prompt class defined in MediaWiki:Common.css, a double (or triple) click to select the command doesn't select the prompt.
Usage:  {{Board$}}
Warning DB.png Important
Do not insert any space between "{{Board$}}" and the command.
2. Basic examples
You type You get
ls test command executed on the board
{{Board$}}ls test<br>
test1.txt test2.txt
ls test
test1.txt test2.txt
3. More examples
You type You get
2 commands executed on the board and preformatted text block (space at the beginning of each line)
 {{Board$}}ls test
 test1.txt test2.txt
 {{Board$}}cat test/test1.txt
 This is a test
ls test
test1.txt test2.txt
cat test/test1.txt
This is a test
Command executed on the board and preformatted text block (space at the beginning of each line)
 {{Board$}}ls test
 test1.txt test2.txt
ls test
test1.txt test2.txt
Long command executed on the board and preformatted text block (space at the beginning of each line)
 {{Board$}}this is a so long command executed on the board that a horizontal scrolling bar is needed
Template used within another public message box template
{{Info |
Message before the command
 {{Board$}}ls test
 test1.txt test2.txt
Message after the command
ls test
test1.txt test2.txt
Template used within another protected message box template
{{InternalInfo |
 {{Board$}}ls test
 test1.txt test2.txt
4. Maintenance
5. Code
No categories assignedEdit
