EcosystemRelease
1. Usage[edit source]
The EcosystemRelease template is used to indicate for which ecosystem release revision(s) of the flow associated with this wiki (e.g. v1.y.z ,or v2.y.z, or...), an article part (chapter, paragraph, table...) is valid. Per default (i.e. if this template is not used), any part of an article is valid for all ecosystem release revisions for which the entire article is valid.
Usage: {{EcosystemRelease | revision=<revision> | range =<range> | revision2=<revision2>}}
Where:
  • <revision> is the mandatory ecosystem release revision for which the article part is valid.
    • The possible values for this parameter are available in the EcosystemRelease/Revision template.
    • The optional <range> and <revision2> parameters allow to define a range of revisions.
  • <range> is the optional range of the ecosystem release revisions for which the article part is valid. The possible values are:
    • and before: the article part is valid only for the revision(s) less than or equal to <revision>
    • and after: the article part is valid only for the revision(s) greater than or equal to <revision>
    • to: the article part is only valid from <revision> to <revision2>
  • <revision2> is the mandatory ecosystem release upper revision for which the article part is valid, when <range> is set to "to"; in this case, <revision> becomes the lower revision for which the article part is valid.
    • This parameter is ignored if <range> is either not set, or set to another value than "to".
Warning DB.png Important
Use the value latest for <revision> or <revision2> with caution: be aware that the returned string will vary depending on the latest ecosystem release.
If the mouse is left over a revision (or the More info.png icon), a popup window shows, for that revision:
  • the versions of the Linux kernel, U-Boot, TF-A and OP-TEE
  • the version of the STM32Cube MPU Package
  • the version of OpenEmbedded
  • the version of Android
You type You get
A specific revision (revision 4.1.0): the latest one
{{EcosystemRelease | revision=4.1.0}}
A specific revision (revision 4.0.0)
{{EcosystemRelease | revision=4.0.0}}
The latest revision
{{EcosystemRelease | revision=latest}}
A specific revision (revision 3.1.0): a former one
{{EcosystemRelease | revision=3.1.0}}
ecosystem release v3.1.0
A specific revision (revision 3.0.0): a former one
{{EcosystemRelease | revision=3.0.0}}
ecosystem release v3.0.0
A specific revision (revision 2.1.0): a former one
{{EcosystemRelease | revision=2.1.0}}
ecosystem release v2.1.0
A specific revision (revision 2.0.0): a former one
{{EcosystemRelease | revision=2.0.0}}
ecosystem release v2.0.0
Revisions that are lower than or equal to a revision
{{EcosystemRelease | revision=x.1.0 | range=and before}}
{{EcosystemRelease | revision=x.1.0 | range=and after}}
Range of revisions
{{EcosystemRelease | revision=x.0.0 | range=to | revision2=x.1.0}}
Revisions that are lower than or equal to the latest one
{{EcosystemRelease | revision=latest | range=and before}}
Revisions that are greater than or equal to the latest one
{{EcosystemRelease | revision=latest | range=and after}}
Range of revisions
{{EcosystemRelease | revision=x.0.0 | range=to | revision2=latest}}
3. More examples[edit source]
You type You get
Revision x.1.0
{{EcosystemRelease | revision=x.1.0}}
Revision x.0.0
{{EcosystemRelease | revision=x.0.0}}
Former revision that is part of a flow that is not the one associated with this wiki.
{{EcosystemRelease | revision=0.y.0}}<br>
{{EcosystemRelease | revision=0.y.0 | range=and before}}<br>
{{EcosystemRelease | revision=0.y.0 | range=and after}}
ecosystem release v0.y.0
ecosystem release ≤ v0.y.0
ecosystem release ≥ v0.y.0
Unspecified revision
{{EcosystemRelease}}
Unknown revision
{{EcosystemRelease | revision=10.20.30}}
Unspecified revision2
{{EcosystemRelease | revision=x.1.0 | range=to}}
Unknown revision2
{{EcosystemRelease | revision=x.1.0 | range=to | revision2=10.20.30}}
ecosystem release vx.1.0 More info.png to unknown revision 10.20.30 Warning.png
Former revision2 that is part of a flow that is not the one associated with this wiki.
{{EcosystemRelease | revision=x.0.0 | range=to | revision2=0.y.0}}<br>
{{EcosystemRelease | revision=0.y.0 | range=to | revision2=0.y.0}}
ecosystem release vx.0.0 More info.png to v0.y.0
ecosystem release v0.y.0 to v0.y.0
Ignored revision2
{{EcosystemRelease | revision=x.0.0 | range=and after  | revision2=x.1.0}}
Unknown range
{{EcosystemRelease | revision=x.1.0 | range=error}}
BEFORE{{EcosystemRelease | revision=x.0.0}}AFTER<br>
BEFORE{{EcosystemRelease | revision=x.1.0 | range=and before}}AFTER<br>
BEFORE{{EcosystemRelease | revision=x.1.0 | range=and after}}AFTER<br>
BEFORE{{EcosystemRelease | revision=x.0.0 | range=to | revision2=x.1.0}}AFTER
BEFOREecosystem release vx.0.0 More info.png AFTER
BEFOREecosystem release ≤ vx.1.0 More info.png AFTER
BEFOREecosystem release ≥ vx.1.0 More info.png AFTER
BEFOREecosystem release vx.0.0 More info.png to vx.1.0 More info.pngAFTER
4. Code[edit source]
No categories assignedEdit
