Revision as of 18:43, 16 November 2022 by Registered User (→‎Printing the amount of disk space available on all mounted file systems)
1. Overview[edit source]
This step explains how to connect your board Linux® terminal to your host computer through the ST-LINK/V2-1.
It then describes how to execute basic commands with the Linux command line interface in order to get familiar with the Linux console.
2. Serial terminal[edit source]
The serial terminal allows communicating with the board through a UART serial interface.
  • Install minicom
 sudo apt-get install minicom
  • Get the ttyACM device instance that needs to be used to access the ST-LINK/V2-1
 ls /dev/ttyACM*
/dev/ttyACM0
 minicom -D /dev/ttyACM0
Welcome to minicom 2.7
OPTIONS: I18n
Port /dev/ttyACM0, 15:56:03
Press CTRL-A Z to get help on special keys
  • Press the reset button to reset the board. The boot log should be displayed on the minicom window:
NOTICE:  CPU: STM32MP157FAC Rev.Z
NOTICE:  Model: STMicroelectronics STM32MP157F-DK2 Discovery Board
NOTICE:  Board: MB1272 Var4.0 Rev.C-02
INFO:    PMIC version = 0x20
INFO:    Reset reason (0x14):
INFO:    FCONF: Reading TB_FW firmware configuration file from: 0x2ffe2000
INFO:    FCONF: Reading firmware configuration information for: stm32mp_io
INFO:    Using SDMMC
INFO:      Instance 1
NOTICE:  BL2: v2.6-stm32mp1-r2.0(debug):v2.6-dirty(a1f02f4f)
NOTICE:  BL2: Built : 13:14:26, Nov 23 2021
INFO:    RAM: DDR3-DDR3L 16bits 533000kHz
INFO:    Memory size = 0x20000000 (512 MB)
INFO:    BL2: Loading image id 1
INFO:    Loading image id=1 at address 0x2ffff000
INFO:    Image id=1 loaded: 0x2ffff000 - 0x2ffff1fa
INFO:    FCONF: Reading FW_CONFIG firmware configuration file from: 0x2ffff000
INFO:    FCONF: Reading firmware configuration information for: dyn_cfg
INFO:    FCONF: Reading firmware configuration information for: stm32mp1_firewall
INFO:    Loading image id=4 at address 0x2ffc0000
INFO:    Image id=4 loaded: 0x2ffc0000 - 0x2ffc002c
INFO:    OPTEE ep=0x2ffc0000
INFO:    OPTEE header info:
INFO:          magic=0x4554504f
INFO:          version=0x2
INFO:          arch=0x0
INFO:          flags=0x0
INFO:          nb_images=0x2
INFO:    BL2: Loading image id 8
INFO:    Loading image id=8 at address 0x2ffc0000
INFO:    Image id=8 loaded: 0x2ffc0000 - 0x2ffda730
INFO:    BL2: Loading image id 9
INFO:    Loading image id=9 at address 0xde200000
INFO:    Image id=9 loaded: 0xde200000 - 0xde253000
INFO:    BL2: Loading image id 2
INFO:    Loading image id=2 at address 0xc0500000
INFO:    Image id=2 loaded: 0xc0500000 - 0xc051d858
INFO:    BL2: Skip loading image id 16
INFO:    Image id=5 loaded: 0xc0100000 - 0xc01ece88
NOTICE:  BL2: Booting BL32
INFO:    Entry point address = 0x2ffc0000
INFO:    SPSR = 0x1d3
I/TC: Early console on UART#4
I/TC:
I/TC: Pager is enabled. Hashes: 2752 bytes
I/TC: Pager pool size: 60kB
I/TC: Non-secure external DT found
I/TC: Embedded DTB found
I/TC: OP-TEE version: 3.16.0-dev (gcc version 11.3.0 (GCC)) #1 Fri 28 Jan 2022 02:28:18 PM UTC arm
I/TC: WARNING: This OP-TEE configuration might be insecure!
I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html
I/TC: Primary CPU initializing
I/TC: DT clock tree configurations were ignored
I/TC: WARNING: All debug access are allowed
I/TC: Platform stm32mp1: flavor PLATFORM_FLAVOR - DT stm32mp157f-dk2.dts
I/TC: DTB enables console (non-secure)
I/TC: Primary CPU switching to normal world boot
optee optee: OP-TEE: revision 3.16 (d0b742d1)
U-Boot 2021.10-stm32mp-r2 (Oct 04 2021 - 15:09:26 +0000)
Board: stm32mp1 in trusted mode (st,stm32mp157f-dk2)
DRAM:  512 MiB
Clocks:
- MPU : 800 MHz
- MCU : 208.878 MHz
- AXI : 266.500 MHz
- PER : 24 MHz
- DDR : 533 MHz
NAND:  0 MiB
In:    serial
Out:   serial
Err:   serial
Boot over mmc0!
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:8...
Found /mmc0_extlinux/stm32mp157f-dk2_extlinux.conf
Retrieving file: /mmc0_extlinux/stm32mp157f-dk2_extlinux.conf
790 bytes read in 119 ms (5.9 KiB/s)
Retrieving file: /splash_portrait.bmp
89462 bytes read in 122 ms (715.8 KiB/s)
Select the boot mode
1:      OpenSTLinux
2:      stm32mp157f-dk2-a7-examples
3:      stm32mp157f-dk2-m4-examples
Retrieving file: /uImage
7903216 bytes read in 452 ms (16.7 MiB/s)
Retrieving file: /st-image-resize-initrd
4059103 bytes read in 290 ms (13.3 MiB/s)
append: root=PARTUUID=e91c4e10-16e6-4c0e-bd0e-77becf4a3582 rootwait rw   console=ttySTM0,115200
Retrieving file: /stm32mp157f-dk2.dtb
118879 bytes read in 124 ms (935.5 KiB/s)
   Image Name:   Linux-5.15.67
   Created:      2022-09-08  10:32:54 UTC
   Data Size:    7903152 Bytes = 7.5 MiB
   Load Address: c2000040
   Entry Point:  c2000040
   Verifying Checksum ... OK
   XIP Kernel Image
   Loading Ramdisk to cfc21000, end cfffffdf ... OK
   Loading Device Tree to cfc00000, end cfc2005e ... OK
Starting kernel ...
I/TC: Secondary CI/TC: Secondary CPU 1 switching to normal world boot
[    0.000000] Linux version 5.15.67 (oe-user@oe-host) (arm-ostl-linux-gnueabi-gcc (GCC) 11.3.0, GNU ld (GNU Binutils) 2.38.20220708) #1 SMP PREEMPT Thu Sep 8 10:32:54 UTC 2022
[    0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[    0.000000] CPU: div instructions available: patching division code
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] OF: fdt: Machine model: STMicroelectronics STM32MP157F-DK2 Discovery Board
[    0.000000] Memory policy: Data cache writealloc
[    0.000000] Reserved memory: created DMA memory pool at 0x10000000, size 0 MiB
[    0.000000] OF: reserved mem: initialized node mcuram2@10000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x10040000, size 0 MiB
[    0.000000] OF: reserved mem: initialized node vdev0vring0@10040000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x10041000, size 0 MiB
[    0.000000] OF: reserved mem: initialized node vdev0vring1@10041000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x10042000, size 0 MiB
[    0.000000] OF: reserved mem: initialized node vdev0buffer@10042000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x10048000, size 0 MiB
[    0.000000] OF: reserved mem: initialized node mcu_rsc_table@10048000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x30000000, size 0 MiB
[    0.000000] OF: reserved mem: initialized node mcuram@30000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x38000000, size 0 MiB
[    0.000000] OF: reserved mem: initialized node retram@38000000, compatible id shared-dma-pool
[    0.000000] cma: Reserved 128 MiB at 0xc7800000
[    0.000000] Zone ranges:
[    0.000000]   Normal   [mem 0x00000000c0000000-0x00000000ddffffff]
[    0.000000]   HighMem  [mem 0x00000000de000000-0x00000000dfffffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x00000000c0000000-0x00000000d3ffffff]
[    0.000000]   node   0: [mem 0x00000000d4000000-0x00000000d7ffffff]
[    0.000000]   node   0: [mem 0x00000000d8000000-0x00000000ddbfffff]
[    0.000000]   node   0: [mem 0x00000000ddc00000-0x00000000ddfeffff]
[    0.000000]   node   0: [mem 0x00000000ddff0000-0x00000000ddffffff]
[    0.000000]   node   0: [mem 0x00000000de000000-0x00000000dfffffff]
[    0.000000] Initmem setup node 0 [mem 0x00000000c0000000-0x00000000dfffffff]
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.0 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] psci: SMC Calling Convention v1.1
[    0.000000] percpu: Embedded 17 pages/cpu s37004 r8192 d24436 u69632
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 129992
[    0.000000] Kernel command line: root=PARTUUID=e91c4e10-16e6-4c0e-bd0e-77becf4a3582 rootwait rw   console=ttySTM0,115200
[    0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] Memory: 262156K/524288K available (12288K kernel code, 1241K rwdata, 3468K rodata, 1024K init, 201K bss, 131060K reserved, 131072K cma-reserved, 0K highmem)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[    0.000000] trace event string verifier disabled
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu:     RCU event tracing is enabled.
[    0.000000]  Trampoline variant of Tasks RCU enabled.
[    0.000000]  Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (virt).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[    0.000002] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.000024] Switching to timer-based delay loop, resolution 41ns
[    0.001777] Console: colour dummy device 80x30
[    0.001858] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[    0.001887] pid_max: default: 32768 minimum: 301
[    0.002168] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    0.002200] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    0.003415] CPU: Testing write buffer coherency: ok
[    0.003887] /cpus/cpu@0 missing clock-frequency property
[    0.003949] /cpus/cpu@1 missing clock-frequency property
[    0.003976] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.005447] Setting up static identity map for 0xc0100000 - 0xc0100060
[    0.005671] rcu: Hierarchical SRCU implementation.
[    0.007237] smp: Bringing up secondary CPUs ...
[    0.013357] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.013573] smp: Brought up 1 node, 2 CPUs
[    0.013606] SMP: Total of 2 processors activated (96.00 BogoMIPS).
[    0.013621] CPU: All CPU(s) started in SVC mode.
[    0.014500] devtmpfs: initialized
[    0.045255] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[    0.045622] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.045659] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
[    0.051669] pinctrl core: initialized pinctrl subsystem
[    0.054102] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.057131] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.058795] thermal_sys: Registered thermal governor 'step_wise'
[    0.059159] cpuidle: using governor menu
[    0.059519] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.059548] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.059994] Serial: AMBA PL011 UART driver
[    0.063668] stm32-pm-domain pm_domain: domain core-ret-power-domain registered
[    0.063721] stm32-pm-domain pm_domain: subdomain core-power-domain registered
[    0.063739] stm32-pm-domain pm_domain: domains probed
[    0.102086] platform 5a000000.dsi: Fixing up cyclic dependency with 5a001000.display-controller
[    0.119182] Kprobes globally optimized
[    0.129232] SCSI subsystem initialized
[    0.130055] usbcore: registered new interface driver usbfs
[    0.130131] usbcore: registered new interface driver hub
[    0.130198] usbcore: registered new device driver usb
[    0.130686] pps_core: LinuxPPS API ver. 1 registered
[    0.130708] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.130741] PTP clock support registered
[    0.130996] EDAC MC: Ver: 3.0.0
[    0.134670] clocksource: Switched to clocksource arch_sys_counter
[    0.216461] NET: Registered PF_INET protocol family
[    0.216797] IP idents hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.218057] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[    0.218125] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.218151] TCP established hash table entries: 4096 (order: 2, 16384 bytes, linear)
[    0.218208] TCP bind hash table entries: 4096 (order: 3, 32768 bytes, linear)
[    0.218294] TCP: Hash tables configured (established 4096 bind 4096)
[    0.218441] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
[    0.218492] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
[    0.218814] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.219766] RPC: Registered named UNIX socket transport module.
[    0.219802] RPC: Registered udp transport module.
[    0.219814] RPC: Registered tcp transport module.
[    0.219824] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.220614] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available
[    0.220977] Trying to unpack rootfs image as initramfs...
[    0.222532] Initialise system trusted keyrings
[    0.234914] workingset: timestamp_bits=14 max_order=17 bucket_order=3
[    0.244842] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.255662] NFS: Registering the id_resolver key type
[    0.255792] Key type id_resolver registered
[    0.255809] Key type id_legacy registered
[    0.255972] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.256005] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    0.256171] ntfs: driver 2.1.32 [Flags: R/O].
[    0.256470] jffs2: version 2.2. (NAND) �© 2001-2006 Red Hat, Inc.
[    0.257334] fuse: init (API version 7.34)
[    0.258687] NET: Registered PF_ALG protocol family
[    0.258730] Key type asymmetric registered
[    0.258743] Asymmetric key parser 'x509' registered
[    0.258906] bounce: pool size: 64 pages
[    0.259009] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[    0.259028] io scheduler mq-deadline registered
[    0.259042] io scheduler kyber registered
[    0.277399] STM32 USART driver initialized
[    0.319726] brd: module loaded
[    0.340951] loop: module loaded
[    0.348826] CAN device driver interface
[    0.351146] pegasus: Pegasus/Pegasus II USB Ethernet driver
[    0.351250] usbcore: registered new interface driver pegasus
[    0.351328] usbcore: registered new interface driver asix
[    0.351401] usbcore: registered new interface driver ax88179_178a
[    0.351459] usbcore: registered new interface driver cdc_ether
[    0.351528] usbcore: registered new interface driver smsc75xx
[    0.351626] usbcore: registered new interface driver smsc95xx
[    0.351684] usbcore: registered new interface driver net1080
[    0.351739] usbcore: registered new interface driver cdc_subset
[    0.351801] usbcore: registered new interface driver zaurus
[    0.351932] usbcore: registered new interface driver cdc_ncm
[    0.353099] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.353164] ehci-platform: EHCI generic platform driver
[    0.353432] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    0.353470] ohci-platform: OHCI generic platform driver
[    0.354182] usbcore: registered new interface driver usb-storage
[    0.376759] i2c_dev: i2c /dev entries driver
[    0.381269] device-mapper: ioctl: 4.45.0-ioctl (2021-03-22) initialised: dm-devel@redhat.com
[    0.383119] sdhci: Secure Digital Host Controller Interface driver
[    0.383151] sdhci: Copyright(c) Pierre Ossman
[    0.383164] Synopsys Designware Multimedia Card Interface Driver
[    0.383675] sdhci-pltfm: SDHCI platform and OF driver helper
[    0.394865] ledtrig-cpu: registered to indicate activity on CPUs
[    0.395608] usbcore: registered new interface driver usbhid
[    0.395637] usbhid: USB HID core driver
[    0.398112] optee: probing for conduit method.
[    0.398155] optee: revision 3.16 (d0b742d1)
[    0.398652] optee: dynamic shared memory is enabled
[    0.438453] optee: initialized driver
[    0.441116] NET: Registered PF_PACKET protocol family
[    0.441189] can: controller area network core
[    0.441313] NET: Registered PF_CAN protocol family
[    0.441334] can: raw protocol
[    0.441349] can: broadcast manager protocol
[    0.441367] can: netlink gateway - max_hops=1
[    0.443646] random: crng init done
[    0.455139] Key type dns_resolver registered
[    0.455266] ThumbEE CPU extension supported.
[    0.455301] Registering SWP/SWPB emulation handler
[    0.455785] registered taskstats version 1
[    0.455825] Loading compiled-in X.509 certificates
[    0.464590] arm-scmi firmware:scmi: SCMI Notifications - Core Enabled.
[    0.476411] arm-scmi firmware:scmi: SCMI Protocol v2.0 'ST:' Firmware version 0x0
[    0.581172] Freeing initrd memory: 3964K
[    0.600468] stm32-mdma 58000000.dma-controller: STM32 MDMA driver registered
[    0.603096] stm32-dma 48000000.dma-controller: STM32 DMA driver registered
[    0.606040] stm32-dma 48001000.dma-controller: STM32 DMA driver registered
[    0.608737] [drm] Initialized simpledrm 1.0.0 20200625 for ddc00000.framebuffer on minor 0
[    0.612627] stm_thermal 50028000.thermal: stm_thermal_probe: Driver initialized successfully
[    0.619325] /soc/interrupt-controller@5000d000: bank0
[    0.619375] /soc/interrupt-controller@5000d000: bank1
[    0.619400] /soc/interrupt-controller@5000d000: bank2
[    0.621836] stm32mp157-pinctrl soc:pinctrl@50002000: GPIOA bank added
[    0.622565] stm32mp157-pinctrl soc:pinctrl@50002000: GPIOB bank added
[    0.623239] stm32mp157-pinctrl soc:pinctrl@50002000: GPIOC bank added
[    0.623872] stm32mp157-pinctrl soc:pinctrl@50002000: GPIOD bank added
[    0.624508] stm32mp157-pinctrl soc:pinctrl@50002000: GPIOE bank added
[    0.625281] stm32mp157-pinctrl soc:pinctrl@50002000: GPIOF bank added
[    0.625991] stm32mp157-pinctrl soc:pinctrl@50002000: GPIOG bank added
[    0.626671] stm32mp157-pinctrl soc:pinctrl@50002000: GPIOH bank added
[    0.627317] stm32mp157-pinctrl soc:pinctrl@50002000: GPIOI bank added
[    0.627650] stm32mp157-pinctrl soc:pinctrl@50002000: Pinctrl STM32 initialized
[    0.630589] stm32mp157-pinctrl soc:pinctrl@54004000: GPIOZ bank added
[    0.630641] stm32mp157-pinctrl soc:pinctrl@54004000: Pinctrl STM32 initialized
[    0.633704] 4000e000.serial: ttySTM3 at MMIO 0x4000e000 (irq = 62, base_baud = 4000000) is a stm32-usart
[    0.634044] serial serial0: tty port ttySTM3 registered
[    0.636138] stm32-usart 40010000.serial: interrupt mode for rx (no dma)
[    0.636175] stm32-usart 40010000.serial: interrupt mode for tx (no dma)
[    0.636209] 40010000.serial: ttySTM0 at MMIO 0x40010000 (irq = 63, base_baud = 4000000) is a stm32-usart
[    1.882000] printk: console [ttySTM0] enabled
[    1.889296] stm32-dwmac 5800a000.ethernet: IRQ eth_lpi not found
[    1.894889] stm32-dwmac 5800a000.ethernet: User ID: 0x40, Synopsys ID: 0x42
[    1.900890] stm32-dwmac 5800a000.ethernet:   DWMAC4/5
[    1.905893] stm32-dwmac 5800a000.ethernet: DMA HW capability register supported
[    1.913067] stm32-dwmac 5800a000.ethernet: RX Checksum Offload Engine supported
[    1.920460] stm32-dwmac 5800a000.ethernet: TX Checksum insertion supported
[    1.927347] stm32-dwmac 5800a000.ethernet: Wake-Up On Lan supported
[    1.933628] stm32-dwmac 5800a000.ethernet: TSO supported
[    1.938920] stm32-dwmac 5800a000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[    1.946721] stm32-dwmac 5800a000.ethernet: Enabled L3L4 Flow TC (entries=2)
[    1.953596] stm32-dwmac 5800a000.ethernet: Enabled RFS Flow TC (entries=8)
[    1.960503] stm32-dwmac 5800a000.ethernet: TSO feature enabled
[    1.966287] stm32-dwmac 5800a000.ethernet: Using 32 bits DMA width
[    1.985798] stm32_rtc 5c004000.rtc: registered as rtc0
[    1.989606] stm32_rtc 5c004000.rtc: setting system clock to 2000-01-01T00:04:28 UTC (946685068)
[    1.999057] stm32_rtc 5c004000.rtc: Date/Time must be initialized
[    2.004342] stm32_rtc 5c004000.rtc: registered rev:1.2
[    2.027449] i2c 0-0039: Fixing up cyclic dependency with 4000b000.audio-controller
[    2.033733] i2c 0-0039: Fixing up cyclic dependency with 5a001000.display-controller
[    2.046253] stm32f7-i2c 40012000.i2c: STM32F7 I2C-0 bus adapter
[    2.074881] stpmic1 1-0033: PMIC Chip Version: 0x20
[    2.083205] vddcore: supplied by vin
[    2.088606] vdd_ddr: supplied by vin
[    2.093708] vdd: supplied by vin
[    2.098680] v3v3: supplied by vin
[    2.103509] v1v8_audio: supplied by v3v3
[    2.110066] v3v3_hdmi: supplied by vin
[    2.115930] vtt_ddr: supplied by vdd_ddr
[    2.121576] vdd_usb: supplied by vin
[    2.124486] vdda: supplied by vin
[    2.130421] v1v2_hdmi: supplied by v3v3
[    2.136061] vref_ddr: supplied by vin
[    2.141537] bst_out: supplied by vin
[    2.144484] vbus_otg: supplied by bst_out
[    2.148621] vbus_sw: supplied by bst_out
[    2.153940] stm32f7-i2c 5c002000.i2c: STM32F7 I2C-1 bus adapter
[    2.162623] mmci-pl18x 58005000.mmc: Got CD GPIO
[    2.166874] mmci-pl18x 58005000.mmc: mmc0: PL180 manf 53 rev2 at 0x58005000 irq 55,0 (pio)
[    2.206290] mmci-pl18x 58007000.mmc: allocated mmc-pwrseq
[    2.212944] mmci-pl18x 58007000.mmc: mmc1: PL180 manf 53 rev2 at 0x58007000 irq 56,0 (pio)
[    2.248807] mmc0: new high speed SDHC card at address aaaa
[    2.254402] stm32-ipcc 4c001000.mailbox: ipcc rev:1.0 enabled, 6 chans, proc 0
[    2.255097] mmcblk0: mmc0:aaaa SS16G 14.8 GiB
[    2.264508] stm32-rproc 10000000.m4: wdg irq registered
[    2.271335] remoteproc remoteproc0: m4 is available
[    2.277204] vref: supplied by vdd
[    2.280531] reg11: supplied by vdd
[    2.282551]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11
[    2.282957] reg18: supplied by vdd
[    2.291919] usb33: supplied by vdd_usb
[    2.354980] i2c i2c-0: Added multiplexed i2c bus 2
[    2.361843] input: pmic_onkey as /devices/platform/soc/5c002000.i2c/i2c-1/1-0033/5c002000.i2c:stpmic@33:onkey/input/input0
[    2.375509] stm32-usbphyc 5a006000.usbphyc: registered rev:1.0
[    2.381601] input: generic ft5x06 (00) as /devices/platform/soc/40012000.i2c/i2c-0/0-0038/input/input1
[    2.392141] [drm] Initialized stm 1.0.0 20170330 for 5a001000.display-controller on minor 0
[    2.404529] ehci-platform 5800d000.usb: EHCI Host Controller
[    2.408943] ehci-platform 5800d000.usb: new USB bus registered, assigned bus number 1
[    2.417298] ehci-platform 5800d000.usb: irq 87, io mem 0x5800d000
[    2.444793] ehci-platform 5800d000.usb: USB 2.0 started, EHCI 1.00
[    2.452928] hub 1-0:1.0: USB hub found
[    2.455694] hub 1-0:1.0: 2 ports detected
[    2.459865] mmc1: new high speed SDIO card at address 0001
[    2.469537] Freeing unused kernel image (initmem) memory: 1024K
[    2.505412] Run /init as init process
[    2.744821] usb 1-1: new high-speed USB device number 2 using ehci-platform
Starting version 250.5+
[    2.956579] hub 1-1:1.0: USB hub found
[    2.959283] hub 1-1:1.0: 4 ports detected
[    4.715105] EXT4-fs (mmcblk0p10): recovery complete
[    4.720787] EXT4-fs (mmcblk0p10): mounted filesystem with ordered data mode. Opts: (null). Quota mode: disabled.
[    5.324474] systemd[1]: System time before build time, advancing clock.
[    5.461664] NET: Registered PF_INET6 protocol family
[    5.501874] Segment Routing with IPv6
[    5.504208] In-situ OAM (IOAM) with IPv6
[    5.566532] systemd[1]: systemd 250.5+ running in system mode (+PAM -AUDIT -SELINUX -APPARMOR +IMA -SMACK -SECCOMP -GCRYPT -GNUTLS -OPENSSL -ACL +BLKID -CURL -ELFUTILS -FIDO2 -IDN2 -IDN +IPTC +KMOD -LIBCRYPTSETUP +LIBFDISK -PCRE2 -PWQUALITY -P11KIT -QRENCODE -BZIP2 -LZ4)
[    5.598256] systemd[1]: Detected architecture arm.
Welcome to ST OpenSTLinux - Weston - (A Yocto Project Based Distro) 4.0.4-openstlinux-5.15-yocto-kirkstone-mp1-v22.11.23 (kirkstone)!
[    5.778805] systemd[1]: Hostname set to <stm32mp1>.
[    5.837331] systemd[1]: Using hardware watchdog 'STM32 Independent Watchdog', version 0, device /dev/watchdog0
[    5.847187] systemd[1]: Watchdog running with a timeout of 32s.
[    6.698678] systemd[1]: /lib/systemd/system/mount-partitions.service:9: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
[    6.738404] systemd[1]: Queued start job for default target Multi-User System.
[    6.802344] systemd[1]: Created slice Slice /system/getty.
[  OK  ] Created slice Slice /system/getty.
[    6.841095] systemd[1]: Created slice Slice /system/modprobe.
[  OK  ] Created slice Slice /system/modprobe.
[    6.881164] systemd[1]: Created slice Slice /system/serial-getty.
[  OK  ] Created slice Slice /system/serial-getty.
[    6.920096] systemd[1]: Created slice User and Session Slice.
[  OK  ] Created slice User and Session Slice.
[    6.956236] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[  OK  ] Started Dispatch Password �…ts to Console Directory Watch.
[    6.995971] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[  OK  ] Started Forward Password R�…uests to Wall Directory Watch.
[    7.036305] systemd[1]: Reached target Path Units.
[  OK  ] Reached target Path Units.
[    7.075338] systemd[1]: Reached target Remote File Systems.
[  OK  ] Reached target Remote File Systems.
[    7.115377] systemd[1]: Reached target Slice Units.
[  OK  ] Reached target Slice Units.
[    7.155462] systemd[1]: Reached target Swaps.
[  OK  ] Reached target Swaps.
[    7.229772] systemd[1]: Listening on RPCbind Server Activation Socket.
[  OK  ] Listening on RPCbind Server Activation Socket.
[    7.265641] systemd[1]: Reached target RPC Port Mapper.
[  OK  ] Reached target RPC Port Mapper.
[    7.307033] systemd[1]: Listening on Syslog Socket.
[  OK  ] Listening on Syslog Socket.
[    7.371237] systemd[1]: Listening on Process Core Dump Socket.
[  OK  ] Listening on Process Core Dump Socket.
[    7.406935] systemd[1]: Listening on initctl Compatibility Named Pipe.
[  OK  ] Listening on initctl Compatibility Named Pipe.
[    7.457398] systemd[1]: Journal Audit Socket was skipped because of a failed condition check (ConditionSecurity=audit).
[    7.468193] systemd[1]: Listening on Journal Socket (/dev/log).
[  OK  ] Listening on Journal Socket (/dev/log).
[    7.507240] systemd[1]: Listening on Journal Socket.
[  OK  ] Listening on Journal Socket.
[    7.547514] systemd[1]: Listening on Network Service Netlink Socket.
[  OK  ] Listening on Network Service Netlink Socket.
[    7.587326] systemd[1]: Listening on udev Control Socket.
[  OK  ] Listening on udev Control Socket.
[    7.626703] systemd[1]: Listening on udev Kernel Socket.
[  OK  ] Listening on udev Kernel Socket.
[    7.666823] systemd[1]: Listening on User Database Manager Socket.
[  OK  ] Listening on User Database Manager Socket.
[    7.707179] systemd[1]: Huge Pages File System was skipped because of a failed condition check (ConditionPathExists=/sys/kernel/mm/hugepages).
[    7.729594] systemd[1]: Mounting POSIX Message Queue File System...
[    7.777113] systemd[1]: Mounting Kernel Debug File System...
[    7.826356] systemd[1]: Mounting Kernel Trace File System...
[    7.875971] systemd[1]: Mounting Temporary Directory /tmp...
[    7.926792] systemd[1]: Starting Create List of Static Device Nodes...
[    7.977911] systemd[1]: Starting Load Kernel Module configfs...
[    8.028160] systemd[1]: Starting Load Kernel Module drm...
[    8.078040] systemd[1]: Starting Load Kernel Module fuse...
[    8.124539] systemd[1]: Starting Mount partitions...
[    8.167182] systemd[1]: Starting RPC Bind...
[    8.197837] systemd[1]: File System Check on Root Device was skipped because of a failed condition check (ConditionPathIsReadWrite=!/).
[    8.236700] systemd[1]: Starting Journal Service...
[    8.280378] systemd[1]: Load Kernel Modules was skipped because all trigger condition checks failed.
[    8.315423] systemd[1]: Starting Generate network units from Kernel command line...
         Starting Generate network �…ts from Kernel command line...
[    8.360123] systemd[1]: Starting Remount Root and Kernel File Systems...
[    8.413712] systemd[1]: Starting Apply Kernel Variables...
[    8.486676] systemd[1]: Starting Coldplug All udev Devices...
[    8.508212] EXT4-fs (mmcblk0p10): re-mounted. Opts: (null). Quota mode: disabled.
[    8.623716] systemd[1]: Started RPC Bind.
[  OK  ] Started RPC Bind.
[    8.650835] systemd[1]: Mounted POSIX Message Queue File System.
[  OK  ] Mounted POSIX Message Queue File System.
[    8.696136] systemd[1]: Mounted Kernel Debug File System.
[  OK  ] Mounted Kernel Debug File System.
[    8.736032] systemd[1]: Mounted Kernel Trace File System.
[  OK  ] Mounted Kernel Trace File System.
[    8.775939] systemd[1]: Started Journal Service.
[  OK  ] Started Journal Service.
[    8.788884] EXT4-fs (mmcblk0p8): recovery complete
[    8.792292] EXT4-fs (mmcblk0p8): mounted filesystem with ordered data mode. Opts: (null). Quota mode: disabled.
[  OK  ] Mounted Temporary Directory /tmp.
[  OK  ] Finished Create List of Static Device Nodes.
[  OK  ] Finished Load Kernel Module configfs.
[  OK  ] Finished Load Kernel Module drm.
[  OK  ] Finished Load Kernel Module fuse.
[  OK  ] Finished Generate network units from Kernel command line.
[  OK  ] Finished Remount Root and Kernel File Systems.
[  OK  ] Finished Apply Kernel Variables.
         Mounting FUSE Control File System...
         Mounting Kernel Configuration File System...
[  OK  ] Started Starts Psplash Boot screen.
         Starting Flush Journal to Persistent Storage...
[    9.252724] systemd-journald[281]: Received client request to flush runtime journal.
[    9.279946] EXT4-fs (mmcblk0p9): recovery complete
[    9.285169] EXT4-fs (mmcblk0p9): mounted filesystem with ordered data mode. Opts: (null). Quota mode: disabled.
         Starting Create Static Device Nodes in /dev...
[  OK  ] Mounted FUSE Control File System.
[  OK  ] Mounted Kernel Configuration File System.
[  OK  ] Finished Flush Journal to Persistent Storage.
[  OK  ] Finished Create Static Device Nodes in /dev.
[  OK  ] Reached target Preparation for Local File Systems.
         Mounting /var/volatile...
[    9.607986] EXT4-fs (mmcblk0p11): recovery complete
         Starting[    9.627499] EXT4-fs (mmcblk0p11): mounted filesystem with ordered data mode. Opts: (null). Quota mode: disabled.
 Rule-based Manage�…for Device Events and Files...
[  OK  ] Finished Mount partitions.
[  OK  ] Mounted /var/volatile.
         Starting Load/Save Random Seed...
[  OK  ] Reached target Local File Systems.
         Starting Create Volatile Files and Directories...
[  OK  ] Finished Load/Save Random Seed.
[  OK  ] Started Rule-based Manager for Device Events and Files.
[  OK  ] Finished Create Volatile Files and Directories.
         Starting Network Time Synchronization...
         Starting Record System Boot/Shutdown in UTMP...
[  OK  ] Finished Record System Boot/Shutdown in UTMP.
[  OK  ] Finished Coldplug All udev Devices.
         Starting Wait for udev To �…plete Device Initialization...
[   11.178197] platform 4400b004.audio-controller: Fixing up cyclic dependency with 0-004a
[   11.209911] platform 4400b024.audio-controller: Fixing up cyclic dependency with 0-004a
[   11.264185] st,stm32-i2s 4000b000.audio-controller: No cache defaults, reading back from HW
[   11.403064] Bluetooth: Core ver 2.22
[   11.415123] stm32-hash 54002000.hash: will run requests pump with realtime priority
[   11.436679] stm32-cryp 54001000.cryp: will run requests pump with realtime priority
[   11.458149] NET: Registered PF_BLUETOOTH protocol family
[   11.467787] stm32-hash 54002000.hash: Init HASH done HW ver 23 DMA mode 1
[   11.473614] Bluetooth: HCI device and connection manager initialized
[  OK  ] Started Netwo[   11.483113] Bluetooth: HCI socket layer initialized
rk Time Synchron[   11.489999] Bluetooth: L2CAP socket layer initialized
ization  11.495275] Bluetooth: SCO socket layer initialized
[0m.
[  OK  ] Reached target System Time Set.
[   11.514215] stm32-cryp 54001000.cryp: Initialized
[   11.521592] Bluetooth: HCI UART driver ver 2.3
[   11.541935] Bluetooth: HCI UART protocol H4 registered
[   11.560821] Bluetooth: HCI UART protocol Broadcom registered
[   11.636795] stm32-crc32 58009000.crc: Initialized
[   11.678864] galcore: loading out-of-tree module taints kernel.
[   11.730638] Galcore version 6.4.9.436021
[   11.965881] Bluetooth: hci0: BCM: chip id 94
[   11.971514] Bluetooth: hci0: BCM: features 0x2e
[   11.976381] Bluetooth: hci0: BCM43430A1
[   11.978859] Bluetooth: hci0: BCM43430A1 (001.002.009) build 0000
[   11.990970] Bluetooth: hci0: BCM43430A1 'brcm/BCM43430A1.hcd' Patch
[   12.165110] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[   12.323379] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[   12.473337] dwc2 49000000.usb-otg: supply vusb_d not found, using dummy regulator
[   12.483748] dwc2 49000000.usb-otg: supply vusb_a not found, using dummy regulator
[   12.523128] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43430-sdio for chip BCM43430/1
[   12.542905] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43430-sdio.st,stm32mp157f-dk2.bin failed with error -2
[   12.637465] Bluetooth: hci0: BCM4343WA1 37.4MHz Murata Type-1DX BT4.2-0093
[   12.642987] Bluetooth: hci0: BCM43430A1 (001.002.009) build 0395
[   12.679386] dwc2 49000000.usb-otg: EPs: 9, dedicated fifos, 952 entries in SPRAM
[   12.723827] dwc2 49000000.usb-otg: DWC OTG Controller
[   12.782842] dwc2 49000000.usb-otg: new USB bus registered, assigned bus number 2
[   12.825305] dwc2 49000000.usb-otg: irq 91, io mem 0x49000000
[   12.836930] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43430-sdio for chip BCM43430/1
[   12.847233] hub 2-0:1.0: USB hub found
[   12.871686] hub 2-0:1.0: 1 port detected
[   12.925210] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM43430/1 wl0: Feb 16 2020 22:39:24 version 7.45.98.97 (r724416 CY) FWID 01-bf41ed64
[   13.451752] cs42l51 0-004a: Cirrus Logic CS42L51, Revision: 01
[  OK  ] Created slice Slice /system/systemd-backlight.
[  OK  ] Listening on Load/Save RF �…itch Status /dev/rfkill Watch.
         Starting Load/Save Screen �…of backlight:5a000000.dsi.0...
[  OK  ] Finished Load/Save Screen �…s of backlight:5a000000.dsi.0.
         Starting Load/Save RF Kill Switch Status...
[  OK  ] Started Load/Save RF Kill Switch Status.
[   14.828665] using random self ethernet address
[   14.831751] using random host ethernet address
[   14.882423] usb0: HOST MAC 28:4c:66:e6:ad:94
[   14.885383] usb0: MAC e6:b6:75:51:70:e0
[   14.889245] dwc2 49000000.usb-otg: bound driver configfs-gadget
[   15.017012] dwc2 49000000.usb-otg: new device is high-speed
[   15.057221] dwc2 49000000.usb-otg: new address 24
[  OK  ] Reached target Hardware activated USB gadget.
[  OK  ] Finished Wait for udev To Complete Device Initialization.
[  OK  ] Started Hardware RNG Entropy Gatherer Daemon.
[   15.323794] dwc2 49000000.usb-otg: new device is high-speed
[  OK  ] Reached target System Initialization.
[   15.373187] dwc2 49000000.usb-otg: new device is high-speed
[  OK  ] Reached target Timer Units.
[   15.412408] dwc2 49000000.usb-otg: new address 24
[  OK  ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[  OK  ] Listening on D-Bus System Message Bus Socket.
[  OK  ] Listening on dropbear.socket.
[  OK  ] Reached target Socket Units.
[  OK  ] Reached target Basic System.
         Starting Save/Restore Sound Card State...
         Starting Bluetooth service...
[   15.743723] IPv6: ADDRCONF(NETDEV_CHANGE): usb0: link becomes ready
[  OK  ] Started Kernel Logging Service.
[  OK  ] Started System Logging Service.
         Starting D-Bus System Message Bus...
         Starting IPv6 Packet Filtering Framework...
         Starting IPv4 Packet Filtering Framework...
         Starting Hold until boot process finishes up...
         Starting Resets System Activity Logs...
         Starting User Login Management...
[  OK  ] Started TEE Supplicant.
[  OK  ] Started D-Bus System Message Bus.
[  OK  ] Finished Save/Restore Sound Card State.
[  OK  ] Finished IPv6 Packet Filtering Framework.
[  OK  ] Finished IPv4 Packet Filtering Framework.
[  OK  ] Finished Hold until boot process finishes up.
[  OK  ] Finished Resets System Activity Logs.
[  OK  ] Reached target Preparation for Network.
[  OK  ] Reached target Sound Card.
         Starting Network Configuration...
         Starting Check if the gpu �…orrect weston configuration...
[  OK  ] Started User Login Management.
[  OK  ] Started Bluetooth service.
[  OK  ] Reached target Bluetooth Support.
         Starting Hostname Service...
[  OK  ] Finished Check if the gpu �… correct weston configuration.
[  OK  ] Started Network Configuration.
         Starting Network Name Resolution...
[   17.314876] stm32-dwmac 5800a000.ethernet eth0: PHY [stmmac-0:00] driver [RTL8211F Gigabit Ethernet] (irq=POLL)
[   17.335498] stm32-dwmac 5800a000.ethernet eth0: Register MEM_TYPE_PAGE_POOL RxQ-0
[   17.352658] dwmac4: Master AXI performs any burst length
[   17.364905] stm32-dwmac 5800a000.ethernet eth0: No Safety Features support found
[   17.370934] stm32-dwmac 5800a000.ethernet eth0: IEEE 1588-2008 Advanced Timestamp supported
[   17.394492] stm32-dwmac 5800a000.ethernet eth0: registered PTP clock
[   17.403357] stm32-dwmac 5800a000.ethernet eth0: configuring for phy/rgmii-id link mode
[  OK  ] Started Hostname Service.
[  OK  ] Started Network Name Resolution.
[  OK  ] Reached target Network.
[  OK  ] Reached target Host and Network Name Lookups.
         Starting Avahi mDNS/DNS-SD Stack...
[  OK  ] Started IIO Daemon.
         Starting Real time performance monitoring...
[  OK  ] Started Respond to IPv6 Node Information Queries.
[  OK  ] Started Network Router Discovery Daemon.
         Starting Permit User Sessions...
         Starting Target Communication Framework agent...
[  OK  ] Finished Permit User Sessions.
[  OK  ] Started Target Communication Framework agent.
[  OK  ] Started Real time performance monitoring.
[  OK  ] Started Avahi mDNS/DNS-SD Stack.
[  OK  ] Started Getty on tty1.
[  OK  ] Started Serial Getty on ttySTM0.
[  OK  ] Reached target Login Prompts.
[  OK  ] Started Weston, a Wayland �…mpositor, as a system service.
[  OK  ] Reached target Multi-User System.
         Starting Record Runlevel Change in UTMP...
         Starting User Database Manager...
[  OK  ] Finished Record Runlevel Change in UTMP.
[  OK  ] Started User Database Manager.
ST OpenSTLinux - Weston - (A Yocto Project Based Distro) 4.0.4-openstlinux-5.15-yocto-kirkstone-mp1-v22.11.23 stm32mp1 ttySTM0
root@stm32mp1:~#
root@stm32mp1:~# cat /etc/build
Build Configuration:  |
BB_VERSION = 2.0.0
BUILD_SYS = x86_64-linux
NATIVELSBSTRING = universal
MACHINE = stm32mp1
DISTRO = openstlinux-weston
DISTRO_VERSION = 4.0.4-openstlinux-5.15-yocto-kirkstone-mp1-v22.11.23
TARGET_FPU = hard
MANIFESTVERSION = ostl-22-11-23-rc5
DISTRO_CODENAME = kirkstone
ACCEPT_EULA_stm32mp1 = 1
GCCVERSION = 11.%
Layer Revisions:      |
meta-python       = v4.1.xml:05dcac98473402d87e0af73bbc2c5a6a840abe93
meta-oe           = v4.1.xml:05dcac98473402d87e0af73bbc2c5a6a840abe93
meta-gnome        = v4.1.xml:05dcac98473402d87e0af73bbc2c5a6a840abe93
meta-initramfs    = v4.1.xml:05dcac98473402d87e0af73bbc2c5a6a840abe93
meta-multimedia   = v4.1.xml:05dcac98473402d87e0af73bbc2c5a6a840abe93
meta-networking   = v4.1.xml:05dcac98473402d87e0af73bbc2c5a6a840abe93
meta-webserver    = v4.1.xml:05dcac98473402d87e0af73bbc2c5a6a840abe93
meta-filesystems  = v4.1.xml:05dcac98473402d87e0af73bbc2c5a6a840abe93
meta-perl         = v4.1.xml:05dcac98473402d87e0af73bbc2c5a6a840abe93
meta-st-stm32mp   = v4.1.xml:acec289f0112d8e7f19e54c2b3cfec1c0196069e
meta-qt5          = v4.1.xml:5b71df60e523423b9df6793de9387f87a149ac42
meta-st-openstlinux = v4.1.xml:046062232c191887a570d8e346012c99db1784c6
meta              = v4.1.xml:f7766da462905ec67bf549d46b8017be36cd5b2a
root@stm32mp1:~# uname -a
Linux stm32mp1 5.15.67 #1 SMP PREEMPT Thu Sep 8 10:32:54 UTC 2022 armv7l armv7l armv7l GNU/Linux
root@stm32mp1:~# cat /proc/version
root@stm32mp1:~# df -h
Filesystem       Size  Used Avail Use% Mounted on
devtmpfs         129M     0  129M   0% /dev
/dev/mmcblk0p10  3.8G  447M  3.2G  13% /
tmpfs            195M  176K  195M   1% /dev/shm
tmpfs             78M  8.8M   70M  12% /run
tmpfs            4.0M     0  4.0M   0% /sys/fs/cgroup
tmpfs            195M   16K  195M   1% /tmp
/dev/mmcblk0p8    55M   14M   37M  28% /boot
/dev/mmcblk0p9    14M  6.0M  6.7M  48% /vendor
tmpfs            195M   96K  195M   1% /var/volatile
/dev/mmcblk0p11   11G   43M  9.5G   1% /usr/local
tmpfs             39M  4.0K   39M   1% /run/user/1000
tmpfs             39M     0   39M   0% /run/user/0
3.5. ssh connection (only if the Ethernet cable connected)[edit source]
 ip addr show eth0
  • On the host computer, connect the terminal to the board using ssh
 ssh root@xx.xx.xx.xx
root@stm32mp1:~#
