1. Overview[edit source]
This article gives information about the Demo Launcher application. The Demo Launcher starts by default in the Starter Package. This application is written in python3 and uses GTK to display the user interface. A touchscreen is required to control the application.
2. STM32MP13x lines More info.png main menu[edit source]
The main menu is composed of four demonstrations:
Main menu
2.1. Netdata perf monitor[edit source]
2.2. Camera preview[edit source]
A USB webcam can be used.
2.3. Video playback[edit source]
Video Playback
2.4. Bluetooth® speaker[edit source]
Bluetooth speaker
First use:
2.5. Info menu[edit source]
Info menu
