1. Usage
The Board$ template is used to prefix a command that must be executed on a board, with a board-specific prompt.
Thanks to the board-prompt
Usage: {{Board$}}
2. Basic examples
You type | You get |
ls test command executed on the board
{{Board$}} ls test<br>
test1.txt test2.txt
ls test |
3. More examples
2 commands executed on the board and preformatted text block (space at the beginning of each line)
{{Board$}} ls test
test1.txt test2.txt
{{Board$}} cat test/test1.txt
This is a test
ls test
test1.txt test2.txt
cat test/test1.txt
This is a test
Command executed on the board and preformatted text block (space at the beginning of each line)
{{Board$}} ls test
test1.txt test2.txt
ls test
test1.txt test2.txt
Long command executed on the board and preformatted text block (space at the beginning of each line)
{{Board$}} this is a so long command executed on the board that a horizontal scrolling bar is needed
4. Maintenance
5. Code
