1. Overview[edit source]
This step explains how to connect your board Linux® terminal to your host computer through the ST-LINK/V2-1.
It then describes how to execute basic commands with the Linux command line interface in order to get familiar with the Linux console.
2. Serial terminal[edit source]
The serial terminal allows communicating with the board through a UART serial interface.
  • Install minicom
PC $> sudo apt-get install minicom
  • Get the ttyACM device instance that needs to be used to access the ST-LINK/V2-1
PC $> ls /dev/ttyACM*
/dev/ttyACM0
PC $> minicom -D /dev/ttyACM0
Welcome to minicom 2.7
OPTIONS: I18n
Port /dev/ttyACM0, 15:56:03
Press CTRL-A Z to get help on special keys
  • Press the reset button to reset the board. The boot log should be displayed on the minicom window:
For ecosystem release v3.1.0 More info.png :
NOTICE:  CPU: STM32MP157CAC Rev.B
NOTICE:  Model: STMicroelectronics STM32MP157C-DK2 Discovery Board
NOTICE:  Board: MB1272 Var2.0 Rev.C-01
INFO:    Reset reason (0x14):
INFO:    PMIC version = 0x10
INFO:    FCONF: Reading TB_FW firmware configuration file from: 0x2ffe2000
INFO:    FCONF: Reading firmware configuration information for: stm32mp_io
INFO:    Using SDMMC
INFO:      Instance 1
NOTICE:  BL2: v2.4-r2.0(debug):v2.4-dirty
NOTICE:  BL2: Built : 16:43:51, Nov 17 2020
INFO:    RAM: DDR3-DDR3L 16bits 533000kHz
INFO:    Memory size = 0x20000000 (512 MB)
INFO:    BL2: Loading image id 31
INFO:    Loading image id=31 at address 0x2ffff000
INFO:    Image id=31 loaded: 0x2ffff000 - 0x2ffff226
INFO:    FCONF: Reading FW_CONFIG firmware configuration file from: 0x2ffff000
INFO:    FCONF: Reading firmware configuration information for: dyn_cfg
INFO:    FCONF: Reading firmware configuration information for: stm32mp1_firewall
INFO:    Loading image id=4 at address 0x2ffc5000
INFO:    Image id=4 loaded: 0x2ffc5000 - 0x2ffd97ec
WARNING: Not a known TEE, use default loading options.
INFO:    BL2: Skip loading image id 21
INFO:    BL2: Skip loading image id 22
INFO:    BL2: Loading image id 23
INFO:    Loading image id=23 at address 0xc0500000
INFO:    Image id=23 loaded: 0xc0500000 - 0xc051d252
INFO:    BL2: Loading image id 26
INFO:    Loading image id=26 at address 0x2ffc0000
INFO:    Image id=26 loaded: 0x2ffc0000 - 0x2ffc46fd
INFO:    Image id=5 loaded: 0xc0100000 - 0xc01d3ee8
NOTICE:  BL2: Booting BL32
INFO:    Entry point address = 0x2ffc5000
INFO:    SPSR = 0x1d3
NOTICE:  SP_MIN: v2.4-r2.0(debug):v2.4-dirty
NOTICE:  SP_MIN: Built : 16:43:51, Nov 17 2020
INFO:    ARM GICv2 driver initialized
INFO:    Set calibration timer to 60 sec
INFO:    stm32mp1 IWDG1 is secure
INFO:    SP_MIN: Initializing runtime services
INFO:    SP_MIN: Preparing exit to normal world
U-Boot 2020.10-stm32mp-r2 (Oct 05 2020 - 15:15:32 +0000)
Board: stm32mp1 in trusted mode (st,stm32mp157c-dk2)
DRAM:  512 MiB
Clocks:
- MPU : 650 MHz
- MCU : 208.878 MHz
- AXI : 266.500 MHz
- PER : 24 MHz
- DDR : 533 MHz
NAND:  0 MiB
In:    serial
Out:   serial
Err:   serial
Boot over mmc0!
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:4...
Found /mmc0_extlinux/stm32mp157c-dk2_extlinux.conf
Retrieving file: /mmc0_extlinux/stm32mp157c-dk2_extlinux.conf
769 bytes read in 46 ms (15.6 KiB/s)
Retrieving file: /splash_portrait.bmp
89462 bytes read in 49 ms (1.7 MiB/s)
Select the boot mode
1:      OpenSTLinux
2:      stm32mp157c-dk2-a7-examples
3:      stm32mp157c-dk2-m4-examples
Retrieving file: /st-image-resize-initrd
3635706 bytes read in 199 ms (17.4 MiB/s)
Retrieving file: /uImage
7464336 bytes read in 361 ms (19.7 MiB/s)
append: root=PARTUUID=e91c4e10-16e6-4c0e-bd0e-77becf4a3582 rootwait rw    console=ttySTM0,115200
Retrieving file: /stm32mp157c-dk2.dtb
116881 bytes read in 50 ms (2.2 MiB/s)
   Image Name:   Linux-5.10.61
   Created:      2021-08-26  12:51:21 UTC
   Data Size:    7464272 Bytes = 7.1 MiB
   Load Address: c2000040
   Entry Point:  c2000040
   Verifying Checksum ... OK
   XIP Kernel Image
   Loading Ramdisk to cfc88000, end cffff9fa ... OK
   Loading Device Tree to cfc68000, end cfc87890 ... OK
Starting kernel ...
[    0.000000] Linux version 5.10.61 (oe-user@oe-host) (arm-ostl-linux-gnueabi-gcc (GCC) 9.3.0, GNU ld (GNU Binutils) 2.34.0.20200220) #1 SMP PREEMPT Thu Aug 26 12:51:21 UTC 2021
[    0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[    0.000000] CPU: div instructions available: patching division code
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] OF: fdt: Machine model: STMicroelectronics STM32MP157C-DK2 Discovery Board
[    0.000000] Memory policy: Data cache writealloc
[    0.000000] Reserved memory: created DMA memory pool at 0x10000000, size 0 MiB
[    0.000000] OF: reserved mem: initialized node mcuram2@10000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x10040000, size 0 MiB
[    0.000000] OF: reserved mem: initialized node vdev0vring0@10040000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x10041000, size 0 MiB
[    0.000000] OF: reserved mem: initialized node vdev0vring1@10041000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x10042000, size 0 MiB
[    0.000000] OF: reserved mem: initialized node vdev0buffer@10042000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x10048000, size 0 MiB
[    0.000000] OF: reserved mem: initialized node mcu_rsc_table@10048000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x30000000, size 0 MiB
[    0.000000] OF: reserved mem: initialized node mcuram@30000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x38000000, size 0 MiB
[    0.000000] OF: reserved mem: initialized node retram@38000000, compatible id shared-dma-pool
[    0.000000] cma: Reserved 128 MiB at 0xc7800000
[    0.000000] Zone ranges:
[    0.000000]   Normal   [mem 0x00000000c0000000-0x00000000dfffffff]
[    0.000000]   HighMem  empty
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x00000000c0000000-0x00000000d3ffffff]
[    0.000000]   node   0: [mem 0x00000000d4000000-0x00000000d7ffffff]
[    0.000000]   node   0: [mem 0x00000000d8000000-0x00000000dfcfffff]
[    0.000000]   node   0: [mem 0x00000000dfd00000-0x00000000dffeffff]
[    0.000000]   node   0: [mem 0x00000000dfff0000-0x00000000dfffffff]
[    0.000000] Initmem setup node 0 [mem 0x00000000c0000000-0x00000000dfffffff]
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] psci: SMC Calling Convention v1.2
[    0.000000] percpu: Embedded 20 pages/cpu s51788 r8192 d21940 u81920
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 129920
[    0.000000] Kernel command line: root=PARTUUID=e91c4e10-16e6-4c0e-bd0e-77becf4a3582 rootwait rw    console=ttySTM0,115200
[    0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] Memory: 297400K/524288K available (11264K kernel code, 1207K rwdata, 3308K rodata, 1024K init, 239K bss, 95816K reserved, 131072K cma-reserved, 0K highmem)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu:     RCU event tracing is enabled.
[    0.000000]  Trampoline variant of Tasks RCU enabled.
[    0.000000]  Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[    0.000000] random: get_random_bytes called from start_kernel+0x388/0x560 with crng_init=0
[    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (virt).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[    0.000010] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.000031] Switching to timer-based delay loop, resolution 41ns
[    0.001774] Console: colour dummy device 80x30
[    0.001836] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[    0.001867] pid_max: default: 32768 minimum: 301
[    0.002134] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    0.002159] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    0.003520] CPU: Testing write buffer coherency: ok
[    0.003980] /cpus/cpu@0 missing clock-frequency property
[    0.004027] /cpus/cpu@1 missing clock-frequency property
[    0.004049] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.005344] Setting up static identity map for 0xc0100000 - 0xc0100060
[    0.005553] rcu: Hierarchical SRCU implementation.
[    0.007006] smp: Bringing up secondary CPUs ...
[    0.008237] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.008499] smp: Brought up 1 node, 2 CPUs
[    0.008531] SMP: Total of 2 processors activated (96.00 BogoMIPS).
[    0.008545] CPU: All CPU(s) started in SVC mode.
[    0.009408] devtmpfs: initialized
[    0.047138] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[    0.047532] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.047573] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
[    0.055083] pinctrl core: initialized pinctrl subsystem
[    0.057060] NET: Registered protocol family 16
[    0.060540] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.062457] thermal_sys: Registered thermal governor 'step_wise'
[    0.062872] cpuidle: using governor menu
[    0.063294] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.063317] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.063766] Serial: AMBA PL011 UART driver
[    0.119032] stm32-pm-domain pm_domain: domain core-ret-power-domain registered
[    0.119084] stm32-pm-domain pm_domain: subdomain core-power-domain registered
[    0.119104] stm32-pm-domain pm_domain: domains probed
[    0.147707] SCSI subsystem initialized
[    0.148595] usbcore: registered new interface driver usbfs
[    0.148688] usbcore: registered new interface driver hub
[    0.148786] usbcore: registered new device driver usb
[    0.149113] pps_core: LinuxPPS API ver. 1 registered
[    0.149133] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.149173] PTP clock support registered
[    0.150100] arm-scmi firmware:scmi0: SCMI Notifications - Core Enabled.
[    0.150329] arm-scmi firmware:scmi0: SCMI Protocol v2.0 'ST:' Firmware version 0x0
[    0.153834] clocksource: Switched to clocksource arch_sys_counter
[    1.588103] simple-framebuffer dfd00000.framebuffer: framebuffer at 0xdfd00000, 0xbb800 bytes, mapped to 0x(ptrval)
[    1.588142] simple-framebuffer dfd00000.framebuffer: format=r5g6b5, mode=480x800x16, linelength=960
[    1.588594] simple-framebuffer dfd00000.framebuffer: fb0: simplefb registered!
[    1.603245] NET: Registered protocol family 2
[    1.603493] IP idents hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    1.605097] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[    1.605271] TCP established hash table entries: 4096 (order: 2, 16384 bytes, linear)
[    1.605348] TCP bind hash table entries: 4096 (order: 3, 32768 bytes, linear)
[    1.605448] TCP: Hash tables configured (established 4096 bind 4096)
[    1.605628] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
[    1.605683] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
[    1.606333] NET: Registered protocol family 1
[    1.607404] RPC: Registered named UNIX socket transport module.
[    1.607434] RPC: Registered udp transport module.
[    1.607448] RPC: Registered tcp transport module.
[    1.607461] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.607859] Trying to unpack rootfs image as initramfs...
[    1.983690] Freeing initrd memory: 3552K
[    1.985037] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available
[    1.987148] Initialise system trusted keyrings
[    1.987620] workingset: timestamp_bits=14 max_order=17 bucket_order=3
[    1.998736] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    2.000250] NFS: Registering the id_resolver key type
[    2.000312] Key type id_resolver registered
[    2.000326] Key type id_legacy registered
[    2.000522] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    2.000544] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    2.000749] ntfs: driver 2.1.32 [Flags: R/O].
[    2.001086] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[    2.002011] fuse: init (API version 7.32)
[    2.003145] NET: Registered protocol family 38
[    2.003176] Key type asymmetric registered
[    2.003191] Asymmetric key parser 'x509' registered
[    2.003264] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[    2.003283] io scheduler mq-deadline registered
[    2.003297] io scheduler kyber registered
[    2.016958] STM32 USART driver initialized
[    2.040640] brd: module loaded
[    2.041089] random: fast init done
[    2.045787] random: crng init done
[    2.055460] loop: module loaded
[    2.061753] libphy: Fixed MDIO Bus: probed
[    2.064171] CAN device driver interface
[    2.066402] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[    2.066519] usbcore: registered new interface driver pegasus
[    2.066609] usbcore: registered new interface driver asix
[    2.066678] usbcore: registered new interface driver ax88179_178a
[    2.066746] usbcore: registered new interface driver cdc_ether
[    2.066833] usbcore: registered new interface driver smsc75xx
[    2.066919] usbcore: registered new interface driver smsc95xx
[    2.066998] usbcore: registered new interface driver net1080
[    2.067066] usbcore: registered new interface driver cdc_subset
[    2.067130] usbcore: registered new interface driver zaurus
[    2.067227] usbcore: registered new interface driver cdc_ncm
[    2.068856] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    2.068920] ehci-platform: EHCI generic platform driver
[    2.069417] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    2.069463] ohci-platform: OHCI generic platform driver
[    2.070266] usbcore: registered new interface driver usb-storage
[    2.074652] i2c /dev entries driver
[    2.079761] stm32-cpufreq stm32-cpufreq: Failed to get chip info: -517
[    2.081106] sdhci: Secure Digital Host Controller Interface driver
[    2.081128] sdhci: Copyright(c) Pierre Ossman
[    2.081142] Synopsys Designware Multimedia Card Interface Driver
[    2.081653] sdhci-pltfm: SDHCI platform and OF driver helper
[    2.083071] ledtrig-cpu: registered to indicate activity on CPUs
[    2.083337] SMCCC: SOC_ID: ID = jep106:0020:0500 Revision = 0x00002000
[    2.083918] usbcore: registered new interface driver usbhid
[    2.083939] usbhid: USB HID core driver
[    2.085537] remoteproc remoteproc0: releasing m4
[    2.088361] NET: Registered protocol family 17
[    2.088412] can: controller area network core
[    2.088535] NET: Registered protocol family 29
[    2.088552] can: raw protocol
[    2.088571] can: broadcast manager protocol
[    2.088596] can: netlink gateway - max_hops=1
[    2.089464] Key type dns_resolver registered
[    2.089657] ThumbEE CPU extension supported.
[    2.089691] Registering SWP/SWPB emulation handler
[    2.090119] registered taskstats version 1
[    2.090152] Loading compiled-in X.509 certificates
[    2.134694] stm32-mdma 58000000.dma-controller: STM32 MDMA driver registered
[    2.138476] stm32-dma 48000000.dma-controller: STM32 DMA driver registered
[    2.141256] stm32-dma 48001000.dma-controller: STM32 DMA driver registered
[    2.151868] stm_thermal 50028000.thermal: stm_thermal_probe: Driver initialized successfully
[    2.159451] remoteproc remoteproc0: releasing m4
[    2.160420] /soc/interrupt-controller@5000d000: bank0
[    2.160453] /soc/interrupt-controller@5000d000: bank1
[    2.160474] /soc/interrupt-controller@5000d000: bank2
[    2.165248] stm32mp157-pinctrl soc:pin-controller@50002000: GPIOA bank added
[    2.167792] stm32mp157-pinctrl soc:pin-controller@50002000: GPIOB bank added
[    2.170337] stm32mp157-pinctrl soc:pin-controller@50002000: GPIOC bank added
[    2.172806] stm32mp157-pinctrl soc:pin-controller@50002000: GPIOD bank added
[    2.175405] stm32mp157-pinctrl soc:pin-controller@50002000: GPIOE bank added
[    2.177900] stm32mp157-pinctrl soc:pin-controller@50002000: GPIOF bank added
[    2.180435] stm32mp157-pinctrl soc:pin-controller@50002000: GPIOG bank added
[    2.183197] stm32mp157-pinctrl soc:pin-controller@50002000: GPIOH bank added
[    2.185640] stm32mp157-pinctrl soc:pin-controller@50002000: GPIOI bank added
[    2.185996] stm32mp157-pinctrl soc:pin-controller@50002000: Pinctrl STM32 initialized
[    2.189490] stm32mp157-pinctrl soc:pin-controller-z@54004000: GPIOZ bank added
[    2.189538] stm32mp157-pinctrl soc:pin-controller-z@54004000: Pinctrl STM32 initialized
[    2.193157] 4000e000.serial: ttySTM3 at MMIO 0x4000e000 (irq = 61, base_baud = 4000000) is a stm32-usart
[    2.193506] serial serial0: tty port ttySTM3 registered
[    2.195862] stm32-usart 40010000.serial: interrupt mode for rx (no dma)
[    2.195894] stm32-usart 40010000.serial: interrupt mode for tx (no dma)
[    2.195937] 40010000.serial: ttySTM0 at MMIO 0x40010000 (irq = 62, base_baud = 4000000) is a stm32-usart
[    3.440846] printk: console [ttySTM0] enabled
[    3.452937] stm32-dwmac 5800a000.ethernet: IRQ eth_lpi not found
[    3.457931] stm32-dwmac 5800a000.ethernet: no reset control found
[    3.464491] stm32-dwmac 5800a000.ethernet: User ID: 0x40, Synopsys ID: 0x42
[    3.470693] stm32-dwmac 5800a000.ethernet:   DWMAC4/5
[    3.475747] stm32-dwmac 5800a000.ethernet: DMA HW capability register supported
[    3.482935] stm32-dwmac 5800a000.ethernet: RX Checksum Offload Engine supported
[    3.490387] stm32-dwmac 5800a000.ethernet: TX Checksum insertion supported
[    3.497197] stm32-dwmac 5800a000.ethernet: Wake-Up On Lan supported
[    3.503613] stm32-dwmac 5800a000.ethernet: TSO supported
[    3.508816] stm32-dwmac 5800a000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[    3.516642] stm32-dwmac 5800a000.ethernet: Enabled Flow TC (entries=2)
[    3.523222] stm32-dwmac 5800a000.ethernet: TSO feature enabled
[    3.529022] stm32-dwmac 5800a000.ethernet: Using 32 bits DMA width
[    3.537556] libphy: stmmac: probed
[    3.555461] stm32_rtc 5c004000.rtc: registered as rtc0
[    3.559303] stm32_rtc 5c004000.rtc: setting system clock to 2000-01-01T00:52:23 UTC (946687943)
[    3.568835] stm32_rtc 5c004000.rtc: Date/Time must be initialized
[    3.574113] stm32_rtc 5c004000.rtc: registered rev:1.2
[    3.610067] stm32f7-i2c 40012000.i2c: STM32F7 I2C-0 bus adapter
[    3.643941] stpmic1 1-0033: PMIC Chip Version: 0x10
[    3.653335] vddcore: supplied by vin
[    3.658670] vdd_ddr: supplied by vin
[    3.663894] vdd: supplied by vin
[    3.668858] v3v3: supplied by vin
[    3.673866] v1v8_audio: supplied by v3v3
[    3.680403] v3v3_hdmi: supplied by vin
[    3.686331] vtt_ddr: supplied by vdd_ddr
[    3.692147] vdd_usb: supplied by vin
[    3.695135] vdda: supplied by vin
[    3.701004] v1v2_hdmi: supplied by v3v3
[    3.706731] vref_ddr: supplied by vin
[    3.712386] bst_out: supplied by vin
[    3.715528] vbus_otg: supplied by bst_out
[    3.719479] vbus_sw: supplied by bst_out
[    3.726031] input: pmic_onkey as /devices/platform/soc/5c002000.i2c/i2c-1/1-0033/5c002000.i2c:stpmic@33:onkey/input/input0
[    3.736935] stm32f7-i2c 5c002000.i2c: STM32F7 I2C-1 bus adapter
[    3.745950] mmci-pl18x 58005000.sdmmc: Got CD GPIO
[    3.750600] mmci-pl18x 58005000.sdmmc: mmc0: PL180 manf 53 rev2 at 0x58005000 irq 54,0 (pio)
[    3.786876] mmci-pl18x 58007000.sdmmc: allocated mmc-pwrseq
[    3.792041] mmci-pl18x 58007000.sdmmc: mmc1: PL180 manf 53 rev1 at 0x58007000 irq 55,0 (pio)
[    3.831392] stm32-ipcc 4c001000.mailbox: ipcc rev:1.0 enabled, 6 chans, proc 0
[    3.840434] stm32-rproc 10000000.m4: wdg irq registered
[    3.847596] mmc0: new high speed SDHC card at address aaaa
[    3.854106] remoteproc remoteproc0: m4 is available
[    3.857649] mmcblk0: mmc0:aaaa SS16G 14.8 GiB
[    3.862930] reg11: supplied by vdd
[    3.865953] reg18: supplied by vdd
[    3.870743] stm32-usbphyc 5a006000.usbphyc: registered rev:1.0
[    3.883939] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[    3.889546] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[    3.895386] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[    3.902070]  mmcblk0: p1 p2 p3 p4 p5 p6 p7
[    3.905244] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[    3.913412] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[    3.923644] dwc2 49000000.usb-otg: supply vusb_d not found, using dummy regulator
[    3.930300] dwc2 49000000.usb-otg: supply vusb_a not found, using dummy regulator
[    3.939189] mmc1: queuing unknown CIS tuple 0x80 (6 bytes)
[    4.028105] mmc1: new high speed SDIO card at address 0001
[    4.074156] dwc2 49000000.usb-otg: EPs: 9, dedicated fifos, 952 entries in SPRAM
[    4.080866] dwc2 49000000.usb-otg: DWC OTG Controller
[    4.085367] dwc2 49000000.usb-otg: new USB bus registered, assigned bus number 1
[    4.092713] dwc2 49000000.usb-otg: irq 87, io mem 0x49000000
[    4.099721] hub 1-0:1.0: USB hub found
[    4.102154] hub 1-0:1.0: 1 port detected
[    4.108740] ehci-platform 5800d000.usbh-ehci: EHCI Host Controller
[    4.113556] ehci-platform 5800d000.usbh-ehci: new USB bus registered, assigned bus number 2
[    4.122807] ehci-platform 5800d000.usbh-ehci: irq 64, io mem 0x5800d000
[    4.153888] ehci-platform 5800d000.usbh-ehci: USB 2.0 started, EHCI 1.00
[    4.160615] hub 2-0:1.0: USB hub found
[    4.163045] hub 2-0:1.0: 2 ports detected
[    4.174201] i2c i2c-0: Added multiplexed i2c bus 2
[    4.183344] fb0: switching to stmdrmfb from simple
[    4.187614] input: generic ft5x06 (11) as /devices/platform/soc/40012000.i2c/i2c-0/0-002a/input/input1
[    4.194595] [drm] Initialized stm 1.0.0 20170330 for 5a001000.display-controller on minor 0
[    4.210373] Freeing unused kernel memory: 1024K
[    4.254271] Run /init as init process
[    4.464017] usb 2-1: new high-speed USB device number 2 using ehci-platform
Starting version 244.5+
[    4.666279] hub 2-1:1.0: USB hub found
[    4.668900] hub 2-1:1.0: 4 ports detected
[    6.032881] EXT4-fs (mmcblk0p6): recovery complete
[    6.051434] EXT4-fs (mmcblk0p6): mounted filesystem with ordered data mode. Opts: (null)
[    6.596338] systemd[1]: System time before build time, advancing clock.
[    6.732214] NET: Registered protocol family 10
[    6.772361] Segment Routing with IPv6
[    6.833501] systemd[1]: systemd 244.5+ running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR -SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS -ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hierarchy=hybrid)
[    6.860879] systemd[1]: Detected architecture arm.
Welcome to ST OpenSTLinux - Weston - (A Yocto Project Based Distro) 3.1.11-openstlinux-5.10-dunfell-mp1-21-11-17 (dunfell)!
[    6.978306] systemd[1]: Set hostname to <stm32mp1>.
[    6.991891] systemd[1]: Hardware watchdog 'STM32 Independent Watchdog', version 0
[    6.999214] systemd[1]: Set hardware watchdog to 32s.
[    7.945719] systemd[1]: Unnecessary job for /dev/ttySTM0 was removed.
[    7.959034] systemd[1]: Created slice system-getty.slice.
[  OK  ] Created slice system-getty.slice.
[    7.996661] systemd[1]: Created slice system-serial\x2dgetty.slice.
[  OK  ] Created slice system-serial\x2dgetty.slice.
[    8.036312] systemd[1]: Created slice User and Session Slice.
[  OK  ] Created slice User and Session Slice.
[    8.074810] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[  OK  ] Started Dispatch Password …ts to Console Directory Watch.
[    8.114651] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[  OK  ] Started Forward Password R…uests to Wall Directory Watch.
[    8.154491] systemd[1]: Reached target Paths.
[  OK  ] Reached target Paths.
[    8.184196] systemd[1]: Reached target Remote File Systems.
[  OK  ] Reached target Remote File Systems.
[    8.224172] systemd[1]: Reached target Slices.
[  OK  ] Reached target Slices.
[    8.254227] systemd[1]: Reached target Swap.
[  OK  ] Reached target Swap.
[    8.315557] systemd[1]: Listening on RPCbind Server Activation Socket.
[  OK  ] Listening on RPCbind Server Activation Socket.
[    8.354253] systemd[1]: Reached target RPC Port Mapper.
[  OK  ] Reached target RPC Port Mapper.
[    8.395423] systemd[1]: Listening on Syslog Socket.
[  OK  ] Listening on Syslog Socket.
[    8.451033] systemd[1]: Listening on Process Core Dump Socket.
[  OK  ] Listening on Process Core Dump Socket.
[    8.484811] systemd[1]: Listening on initctl Compatibility Named Pipe.
[  OK  ] Listening on initctl Compatibility Named Pipe.
[    8.530894] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
[    8.538771] systemd[1]: Listening on Journal Socket (/dev/log).
[  OK  ] Listening on Journal Socket (/dev/log).
[    8.575359] systemd[1]: Listening on Journal Socket.
[  OK  ] Listening on Journal Socket.
[    8.615652] systemd[1]: Listening on Network Service Netlink Socket.
[  OK  ] Listening on Network Service Netlink Socket.
[    8.655292] systemd[1]: Listening on udev Control Socket.
[  OK  ] Listening on udev Control Socket.
[    8.694907] systemd[1]: Listening on udev Kernel Socket.
[  OK  ] Listening on udev Kernel Socket.
[    8.735331] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
[    8.749795] systemd[1]: Mounting POSIX Message Queue File System...
[    8.791552] systemd[1]: Mounting Kernel Debug File System...
[    8.835978] systemd[1]: Mounting Temporary Directory (/tmp)...
[    8.892332] systemd[1]: Starting Create list of static device nodes for the current kernel...
         Starting Create list of st…odes for the current kernel...
[    8.941554] systemd[1]: Starting Mount partitions...
[    8.990559] systemd[1]: Started Hardware RNG Entropy Gatherer Daemon.
[  OK  ] Started Hardware RNG Entropy Gatherer Daemon.
[    9.033776] systemd[1]: Starting RPC Bind...
[    9.064670] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[    9.086042] systemd[1]: Starting Journal Service...
[    9.110776] systemd[1]: Condition check resulted in Load Kernel Modules being skipped.
[    9.151129] systemd[1]: Mounting FUSE Control File System...
[    9.203038] systemd[1]: Mounting Kernel Configuration File System...
[    9.269144] systemd[1]: Starting Remount Root and Kernel File Systems...
[    9.321857] systemd[1]: Starting Apply Kernel Variables...
[    9.361088] EXT4-fs (mmcblk0p6): re-mounted. Opts: (null)
[    9.418655] systemd[1]: Starting udev Coldplug all Devices...
[    9.475264] systemd[1]: Started RPC Bind.
[  OK  ] Started RPC Bind.
[    9.495852] systemd[1]: Mounted POSIX Message Queue File System.
[  OK  ] Mounted POSIX Message Queue File System.
[    9.515231] systemd[1]: Mounted Kernel Debug File System.
[  OK  ] Mounted Kernel Debug File System.
[    9.565159] systemd[1]: Mounted Temporary Directory (/tmp).
[  OK  ] Mounted Temporary Directory (/tmp).
[    9.595658] systemd[1]: Started Create list of static device nodes for the current kernel.
[  OK  ] Started Create list of sta… nodes for the current kernel.
[    9.619981] systemd[1]: Mounted FUSE Control File System.
[  OK  ] Mounted FUSE Control File System.
[    9.668540] EXT4-fs (mmcblk0p4): recovery complete
[    9.671943] EXT4-fs (mmcblk0p4): mounted filesystem with ordered data mode. Opts: (null)
[    9.705194] systemd[1]: Started Journal Service.
[  OK  ] Started Journal Service.
[  OK  ] Mounted Kernel Configuration File System.
[  OK  ] Started Remount Root and Kernel File Systems.
[  OK  ] Started Apply Kernel Variables.
[  OK  ] Started Starts Psplash Boot screen.
         Starting Flush Journal to Persistent Storage...
         Starting Create Static Device Nodes in /dev...
[   10.102537] systemd-journald[289]: Received client request to flush runtime journal.
[  OK  ] Started Flush Journal to Persistent Storage.
[  OK  ] Started Create Static Device Nodes in /dev.
[  OK  ] Reached target Local File Systems (Pre).
[   10.270906] EXT4-fs (mmcblk0p5): recovery complete
[   10.287007] EXT4-fs (mmcblk0p5): mounted filesystem with ordered data mode. Opts: (null)
         Mounting /var/volatile...
         Starting udev Kernel Device Manager...
[  OK  ] Mounted /var/volatile.
         Starting Load/Save Random Seed...
[  OK  ] Started Load/Save Random Seed.
[  OK  ] Started udev Kernel Device Manager.
[   11.041091] EXT4-fs (mmcblk0p7): recovery complete
[   11.076716] EXT4-fs (mmcblk0p7): mounted filesystem with ordered data mode. Opts: (null)
[  OK  ] Started Mount partitions.
[  OK  ] Reached target Local File Systems.
         Starting Create Volatile Files and Directories...
[  OK  ] Started Create Volatile Files and Directories.
         Starting Network Time Synchronization...
         Starting Update UTMP about System Boot/Shutdown...
[  OK  ] Started Update UTMP about System Boot/Shutdown.
[   12.846472] st,stm32-i2s 4000b000.audio-controller: No cache defaults, reading back from HW
[  OK  ] Reached target Hardware activated USB gadget.
[  OK  ] Started Network Time Synchronization.
[   13.019059] stm32-hash 54002000.hash: will run requests pump with realtime priority
[  OK  ] Reached target    13.038293] stm32-cryp 54001000.cryp: will run requests pump with realtime priority
39mSystem Time Set.
[   13.073591] stm32-hash 54002000.hash: Init HASH done HW ver 23 DMA mode 1
[   13.094995] stm32-cryp 54001000.cryp: Initialized
[  OK  ] Reached target System Time Synchronized.
[  OK  ] Started udev Coldplug all Devices.
[   13.150247] Bluetooth: Core ver 2.22
[   13.176528] NET: Registered protocol family 31
[   13.179605] Bluetooth: HCI device and connection manager initialized
[  OK  ] Reached target System Initialization.
[  OK  ] Started Dail[   13.228094] Bluetooth: HCI socket layer initialized
[   13.232603] Bluetooth: L2CAP socket layer initialized
y apt download activities.
[  OK  ] Started Daily Cleanup of Temporary Directories.
[  OK  ] Reached target Timers.
[  OK  ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[   13.314554] Bluetooth: SCO socket layer initialized
[   13.318475] stm32-crc32 58009000.crc: Initialized
[  OK  ] Listening on D-Bus System Message Bus Socket.
[   13.362752] Bluetooth: HCI UART driver ver 2.3
[   13.386459] galcore: loading out-of-tree module taints kernel.
[   13.438729] Bluetooth: HCI UART protocol H4 registered
[   13.494532] Bluetooth: HCI UART protocol Broadcom registered
[  OK  ] Listening on dropbear.socket.
[   13.581399] Galcore version 6.4.3.279124
[  OK  ] Reached target Sockets.
[  OK  ] Reached target Basic System.
[  OK  ] Started Kernel Logging Service.
[  OK  ] Started System Logging Service.
[   13.925158] Bluetooth: hci0: BCM: chip id 94
[   13.928772] Bluetooth: hci0: BCM: features 0x2e
[   13.934081] Bluetooth: hci0: BCM43430A1
[   13.936561] Bluetooth: hci0: BCM43430A1 (001.002.009) build 0000
[  OK  ] Started D-Bus System Message Bus.
[   13.958684] Bluetooth: hci0: BCM43430A1 'brcm/BCM43430A1.hcd' Patch
[   14.063241] cs42l51 0-004a: Cirrus Logic CS42L51, Revision: 01
[   14.118266] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[   14.299208] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
         Starting IPv6 Packet Filtering Framework...
         Starting IPv4 Packet Filtering Framework...
[   14.626533] Bluetooth: hci0: BCM4343WA1 37.4MHz Murata Type-1DX BT4.2-0093
[   14.632288] Bluetooth: hci0: BCM43430A1 (001.002.009) build 0395
         Starting Netdata, Real-time performance monitoring...
[   14.670339] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43430-sdio for chip BCM43430/1
         Starting Login Service...
[  OK  ] Started TEE Supplicant.
         Starting Enable USB Ethernet gadget...
[   14.894361] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43430-sdio for chip BCM43430/1
[   15.034487] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM43430/1 wl0: Feb 16 2020 22:39:24 version 7.45.98.97 (r724416 CY) FWID 01-bf41ed64
[  OK  ] Started IPv6 Packet Filtering Framework.
[  OK  ] Started IPv4 Packet Filtering Framework.
[   15.460865] using random self ethernet address
[   15.469983] using random host ethernet address
[   15.751976] usb0: HOST MAC 40:4d:17:1e:53:f1
[   15.755103] usb0: MAC 9a:c6:c4:0d:ac:3d
[   15.758730] dwc2 49000000.usb-otg: bound driver configfs-gadget
[  OK  ] Started Enable USB Ethernet gadget.
[  OK  ] Started Netdata, Real-time performance monitoring.
[  OK  ] Started Login Service.
[  OK  ] Created slice system-systemd\x2dbacklight.slice.
[  OK  ] Created slice system-weston.slice.
[  OK  ] Reached target Network (Pre).
[  OK  ] Listening on Load/Save RF …itch Status /dev/rfkill Watch.
         Starting Save/Restore Sound Card State...
         Starting Bluetooth service...
         Starting Load/Save Screen …of backlight:5a000000.dsi.0...
         Starting Network Service...
[  OK  ] Started Save/Restore Sound Card State.
[  OK  ] Started Load/Save Screen B…s of backlight:5a000000.dsi.0.
[  OK  ] Reached target Sound Card.
         Starting Load/Save RF Kill Switch Status...
[  OK  ] Started Bluetooth service.
[  OK  ] Started Load/Save RF Kill Switch Status.
[  OK  ] Reached target Bluetooth.
         Starting Hostname Service...
[  OK  ] Started Network Service.
[   19.074044] stm32-dwmac 5800a000.ethernet eth0: PHY [stmmac-0:00] driver [RTL8211F Gigabit Ethernet] (irq=POLL)
         Starting Network Name Resolution...
[   19.098516] dwmac4: Master AXI performs any burst length
[   19.102443] stm32-dwmac 5800a000.ethernet eth0: No Safety Features support found
[   19.144155] stm32-dwmac 5800a000.ethernet eth0: IEEE 1588-2008 Advanced Timestamp supported
[   19.173371] stm32-dwmac 5800a000.ethernet eth0: registered PTP clock
[   19.201721] stm32-dwmac 5800a000.ethernet eth0: configuring for phy/rgmii-id link mode
[  OK  ] Started Hostname Service.
[  OK  ] Started Network Name Resolution.
[  OK  ] Reached target Network.
[  OK  ] Reached target Host and Network Name Lookups.
         Starting Avahi mDNS/DNS-SD Stack...
[  OK  ] Started IIO Daemon.
[  OK  ] Started Respond to IPv6 Node Information Queries.
         Starting Sound Service...
[  OK  ] Started Network Router Discovery Daemon.
         Starting Permit User Sessions...
         Starting Target Communication Framework agent...
[  OK  ] Started Avahi mDNS/DNS-SD Stack.
[  OK  ] Started Permit User Sessions.
[  OK  ] Started Getty on tty1.
[  OK  ] Started Serial Getty on ttySTM0.
[  OK  ] Reached target Login Prompts.
         Starting Weston Wayland Compositor (on tty7)...
[  OK  ] Started Target Communication Framework agent.
[  OK  ] Started Sound Service.
[  OK  ] Reached target Multi-User System.
         Starting Update UTMP about System Runlevel Changes...
[  OK  ] Started Update UTMP about System Runlevel Changes.
[  OK  ] Started Weston Wayland Compositor (on tty7).
ST OpenSTLinux - Weston - (A Yocto Project Based Distro) 3.1.11-openstlinux-5.10-dunfell-mp1-21-11-17 stm32mp1 ttySTM0
Last login: Sun Sep 20 10:44:13 UTC 2020 on tty7
root@stm32mp1:~#
For ecosystem release v3.0.0 More info.png :
INFO:    FCONF: Reading TB_FW firmware configuration file from: 0x2ffe3000
INFO:    Using SDMMC
INFO:      Instance 1
NOTICE:  BL2: v2.4-r1.0(debug):v2.4-dirty
INFO:    RAM: DDR3-DDR3L 16bits 533000Khz
WARNING: Couldn't find property st,phy-cal in dtb
INFO:    Image id=4 loaded: 0x2ffc5000 - 0x2ffd847c
INFO:    Image id=23 loaded: 0xc0500000 - 0xc051cf56
INFO:    Image id=26 loaded: 0x2ffc0000 - 0x2ffc46e4
INFO:    Image id=5 loaded: 0xc0100000 - 0xc01cf9d8
INFO:    SPSR = 0x1d3
NOTICE:  SP_MIN: v2.4-r1.0(debug):v2.4-dirty
U-Boot 2020.10-stm32mp-r1 (Oct 05 2020 - 15:15:32 +0000)
DRAM:  512 MiB
Clocks:
- MPU : 650 MHz
- MCU : 208.878 MHz
- AXI : 266.500 MHz
- PER : 24 MHz
- DDR : 533 MHz
NAND:  0 MiB
In:    serial
Out:   serial
Err:   serial
Boot over mmc0!
Scanning mmc 0:4...
706 bytes read in 38 ms (17.6 KiB/s)
Retrieving file: /splash.bmp
18244 bytes read in 40 ms (445.3 KiB/s)
1:      OpenSTLinux
Retrieving file: /uInitrd
3634613 bytes read in 193 ms (18 MiB/s)
7457152 bytes read in 354 ms (20.1 MiB/s)
116117 bytes read in 43 ms (2.6 MiB/s)
   Image Name:   Linux-5.10.10
   Created:      2021-01-23  15:04:06 UTC
   Data Size:    7457088 Bytes = 7.1 MiB
   XIP Kernel Image
   Loading Ramdisk to cfc88000, end cffff5b5 ... OK
   Loading Device Tree to cfc68000, end cfc87594 ... OK
Starting kernel ...
[    0.000000] Linux version 5.10.10 (oe-user@oe-host) (arm-ostl-linux-gnueabi-gcc (GCC) 9.3.0, GNU ld (GNU Binutils) 2.34.0.20200220) #1 SMP PREEMPT Sat Jan 23 15:04:06 UTC 2021
[    0.000000] cma: Reserved 128 MiB at 0xd8000000
[    0.000000]   node   0: [mem 0x00000000d8000000-0x00000000dfffffff]
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 113536
[    0.000000] Memory: 300984K/458752K available (11264K kernel code, 1206K rwdata, 3312K rodata, 1024K init, 248K bss, 26696K reserved, 131072K cma-reserved, 0K highmem)
[    0.000000] random: get_random_bytes called from start_kernel+0x390/0x568 with crng_init=0
[    0.000009] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.001749] Console: colour dummy device 80x30
[    0.001808] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[    0.001838] pid_max: default: 32768 minimum: 301
[    0.002100] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    0.002126] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    0.003479] CPU: Testing write buffer coherency: ok
[    0.003929] /cpus/cpu@0 missing clock-frequency property
[    0.003975] /cpus/cpu@1 missing clock-frequency property
[    0.003997] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.005287] Setting up static identity map for 0xc0100000 - 0xc0100060
[    0.005512] rcu: Hierarchical SRCU implementation.
[    0.006971] smp: Bringing up secondary CPUs ...
[    0.008219] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.008477] smp: Brought up 1 node, 2 CPUs
[    0.008507] SMP: Total of 2 processors activated (96.00 BogoMIPS).
[    0.008520] CPU: All CPU(s) started in SVC mode.
[    0.009369] devtmpfs: initialized
[    0.045879] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[    0.046266] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.046304] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
[    0.052603] pinctrl core: initialized pinctrl subsystem
[    0.054576] NET: Registered protocol family 16
[    0.057996] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.059985] thermal_sys: Registered thermal governor 'step_wise'
[    0.060388] cpuidle: using governor menu
[    0.060809] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.060830] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.061274] Serial: AMBA PL011 UART driver
[    0.114186] stm32-pm-domain pm_domain: domain core-ret-power-domain registered
[    0.114237] stm32-pm-domain pm_domain: subdomain core-power-domain registered
[    0.114257] stm32-pm-domain pm_domain: domains probed
[    0.143053] SCSI subsystem initialized
[    0.143948] usbcore: registered new interface driver usbfs
[    0.144039] usbcore: registered new interface driver hub
[    0.144116] usbcore: registered new device driver usb
[    0.144439] pps_core: LinuxPPS API ver. 1 registered
[    0.144457] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.144496] PTP clock support registered
[    0.145431] arm-scmi firmware:scmi0: SCMI Notifications - Core Enabled.
[    0.145521] arm-scmi firmware:scmi0: SCMI Protocol v2.0 'ST:' Firmware version 0x0
[    0.149148] clocksource: Switched to clocksource arch_sys_counter
[    1.595534] NET: Registered protocol family 2
[    1.596801] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[    1.596979] TCP established hash table entries: 4096 (order: 2, 16384 bytes, linear)
[    1.597055] TCP bind hash table entries: 4096 (order: 3, 32768 bytes, linear)
[    1.597154] TCP: Hash tables configured (established 4096 bind 4096)
[    1.597333] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
[    1.597392] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
[    1.597906] NET: Registered protocol family 1
[    1.598919] RPC: Registered named UNIX socket transport module.
[    1.598946] RPC: Registered udp transport module.
[    1.598959] RPC: Registered tcp transport module.
[    1.598971] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.599517] Trying to unpack rootfs image as initramfs...
[    1.976821] Freeing initrd memory: 3552K
[    1.977914] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available
[    1.980222] Initialise system trusted keyrings
[    1.980686] workingset: timestamp_bits=14 max_order=17 bucket_order=3
[    1.991843] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    1.993358] NFS: Registering the id_resolver key type
[    1.993420] Key type id_resolver registered
[    1.993435] Key type id_legacy registered
[    1.993621] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    1.993838] ntfs: driver 2.1.32 [Flags: R/O].
[    1.994169] jffs2: version 2.2. (NAND) �۩ 2001-2006 Red Hat, Inc.
[    1.995113] fuse: init (API version 7.32)
[    1.996219] NET: Registered protocol family 38
[    1.996246] Key type asymmetric registered
[    1.996262] Asymmetric key parser 'x509' registered
[    1.996334] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[    1.996353] io scheduler mq-deadline registered
[    1.996367] io scheduler kyber registered
[    2.010422] STM32 USART driver initialized
[    2.034435] brd: module loaded
[    2.034800] random: fast init done
[    2.039550] random: crng init done
[    2.048711] loop: module loaded
[    2.055184] libphy: Fixed MDIO Bus: probed
[    2.057337] CAN device driver interface
[    2.059718] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[    2.059822] usbcore: registered new interface driver pegasus
[    2.059908] usbcore: registered new interface driver asix
[    2.059973] usbcore: registered new interface driver ax88179_178a
[    2.060055] usbcore: registered new interface driver cdc_ether
[    2.060140] usbcore: registered new interface driver smsc75xx
[    2.060224] usbcore: registered new interface driver smsc95xx
[    2.060288] usbcore: registered new interface driver net1080
[    2.060351] usbcore: registered new interface driver cdc_subset
[    2.060414] usbcore: registered new interface driver zaurus
[    2.060521] usbcore: registered new interface driver cdc_ncm
[    2.062156] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    2.062221] ehci-platform: EHCI generic platform driver
[    2.062708] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    2.062751] ohci-platform: OHCI generic platform driver
[    2.063564] usbcore: registered new interface driver usb-storage
[    2.067582] i2c /dev entries driver
[    2.072630] stm32-cpufreq stm32-cpufreq: Failed to get chip info: -517
[    2.074041] sdhci: Secure Digital Host Controller Interface driver
[    2.074061] sdhci: Copyright(c) Pierre Ossman
[    2.074074] Synopsys Designware Multimedia Card Interface Driver
[    2.074586] sdhci-pltfm: SDHCI platform and OF driver helper
[    2.076073] ledtrig-cpu: registered to indicate activity on CPUs
[    2.076198] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[    2.076693] usbcore: registered new interface driver usbhid
[    2.076710] usbhid: USB HID core driver
[    2.078261] remoteproc remoteproc0: releasing m4
[    2.080749] NET: Registered protocol family 17
[    2.080796] can: controller area network core
[    2.080937] NET: Registered protocol family 29
[    2.080962] can: raw protocol
[    2.080976] can: broadcast manager protocol
[    2.080998] can: netlink gateway - max_hops=1
[    2.081879] Key type dns_resolver registered
[    2.082068] ThumbEE CPU extension supported.
[    2.082099] Registering SWP/SWPB emulation handler
[    2.082521] registered taskstats version 1
[    2.082551] Loading compiled-in X.509 certificates
[    2.126718] stm32-mdma 58000000.dma-controller: STM32 MDMA driver registered
[    2.130584] stm32-dma 48000000.dma-controller: STM32 DMA driver registered
[    2.133305] stm32-dma 48001000.dma-controller: STM32 DMA driver registered
[    2.143036] stm_thermal 50028000.thermal: stm_thermal_probe: Driver initialized successfully
[    2.150338] remoteproc remoteproc0: releasing m4
[    2.151300] /soc/interrupt-controller@5000d000: bank0
[    2.151334] /soc/interrupt-controller@5000d000: bank1
[    2.151355] /soc/interrupt-controller@5000d000: bank2
[    2.153803] stm32mp157-pinctrl soc:pin-controller@50002000: GPIOA bank added
[    2.154306] stm32mp157-pinctrl soc:pin-controller@50002000: GPIOB bank added
[    2.154744] stm32mp157-pinctrl soc:pin-controller@50002000: GPIOC bank added
[    2.155144] stm32mp157-pinctrl soc:pin-controller@50002000: GPIOD bank added
[    2.155544] stm32mp157-pinctrl soc:pin-controller@50002000: GPIOE bank added
[    2.155923] stm32mp157-pinctrl soc:pin-controller@50002000: GPIOF bank added
[    2.156334] stm32mp157-pinctrl soc:pin-controller@50002000: GPIOG bank added
[    2.156711] stm32mp157-pinctrl soc:pin-controller@50002000: GPIOH bank added
[    2.157086] stm32mp157-pinctrl soc:pin-controller@50002000: GPIOI bank added
[    2.157427] stm32mp157-pinctrl soc:pin-controller@50002000: Pinctrl STM32 initialized
[    2.158956] stm32mp157-pinctrl soc:pin-controller-z@54004000: GPIOZ bank added
[    2.159000] stm32mp157-pinctrl soc:pin-controller-z@54004000: Pinctrl STM32 initialized
[    2.162877] 4000e000.serial: ttySTM3 at MMIO 0x4000e000 (irq = 61, base_baud = 4000000) is a stm32-usart
[    2.163218] serial serial0: tty port ttySTM3 registered
[    2.165214] stm32-usart 40010000.serial: interrupt mode for rx (no dma)
[    2.165244] stm32-usart 40010000.serial: interrupt mode for tx (no dma)
[    2.165285] 40010000.serial: ttySTM0 at MMIO 0x40010000 (irq = 62, base_baud = 4000000) is a stm32-usart
[    3.330090] printk: console [ttySTM0] enabled
[    3.341987] stm32-dwmac 5800a000.ethernet: IRQ eth_lpi not found
[    3.346770] stm32-dwmac 5800a000.ethernet: PTP uses main clock
[    3.352565] stm32-dwmac 5800a000.ethernet: no reset control found
[    3.359231] stm32-dwmac 5800a000.ethernet: User ID: 0x40, Synopsys ID: 0x42
[    3.365441] stm32-dwmac 5800a000.ethernet:   DWMAC4/5
[    3.370501] stm32-dwmac 5800a000.ethernet: DMA HW capability register supported
[    3.377704] stm32-dwmac 5800a000.ethernet: RX Checksum Offload Engine supported
[    3.385096] stm32-dwmac 5800a000.ethernet: TX Checksum insertion supported
[    3.391914] stm32-dwmac 5800a000.ethernet: Wake-Up On Lan supported
[    3.398291] stm32-dwmac 5800a000.ethernet: TSO supported
[    3.403497] stm32-dwmac 5800a000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[    3.411327] stm32-dwmac 5800a000.ethernet: Enabled Flow TC (entries=2)
[    3.417824] stm32-dwmac 5800a000.ethernet: TSO feature enabled
[    3.423685] stm32-dwmac 5800a000.ethernet: Using 32 bits DMA width
[    3.432089] libphy: stmmac: probed
[    3.449461] stm32_rtc 5c004000.rtc: registered as rtc0
[    3.453206] stm32_rtc 5c004000.rtc: setting system clock to 2000-01-01T00:29:47 UTC (946686587)
[    3.462750] stm32_rtc 5c004000.rtc: Date/Time must be initialized
[    3.467952] stm32_rtc 5c004000.rtc: registered rev:1.2
[    3.502964] stm32f7-i2c 40012000.i2c: STM32F7 I2C-0 bus adapter
[    3.536014] stpmic1 1-0033: PMIC Chip Version: 0x10
[    3.547815] vddcore: supplied by vin
[    3.553221] vdd_ddr: supplied by vin
[    3.558415] vdd: supplied by vin
[    3.563486] v3v3: supplied by vin
[    3.568296] v1v8_audio: supplied by v3v3
[    3.574804] v3v3_hdmi: supplied by vin
[    3.580790] vtt_ddr: supplied by vdd_ddr
[    3.583820] vdd_usb: supplied by vin
[    3.590248] vdda: supplied by vin
[    3.595516] v1v2_hdmi: supplied by v3v3
[    3.601273] vref_ddr: supplied by vin
[    3.604067] bst_out: supplied by vin
[    3.607932] vbus_otg: supplied by bst_out
[    3.612133] vbus_sw: supplied by bst_out
[    3.618377] input: pmic_onkey as /devices/platform/soc/5c002000.i2c/i2c-1/1-0033/5c002000.i2c:stpmic@33:onkey/input/input0
[    3.629238] stm32f7-i2c 5c002000.i2c: STM32F7 I2C-1 bus adapter
[    3.637902] mmci-pl18x 58005000.sdmmc: Got CD GPIO
[    3.642383] mmci-pl18x 58005000.sdmmc: mmc0: PL180 manf 53 rev2 at 0x58005000 irq 54,0 (pio)
[    3.678639] mmci-pl18x 58007000.sdmmc: allocated mmc-pwrseq
[    3.683959] mmci-pl18x 58007000.sdmmc: mmc1: PL180 manf 53 rev1 at 0x58007000 irq 55,0 (pio)
[    3.723682] stm32-ipcc 4c001000.mailbox: ipcc rev:1.0 enabled, 6 chans, proc 0
[    3.732805] stm32-rproc 10000000.m4: wdg irq registered
[    3.737879] remoteproc remoteproc0: m4 is available
[    3.745066] mmc0: new high speed SDHC card at address 5048
[    3.750017] reg11: supplied by vdd
[    3.753382] reg18: supplied by vdd
[    3.756939] mmcblk0: mmc0:5048 SD32G 29.0 GiB
[    3.762914] stm32-usbphyc 5a006000.usbphyc: registered rev:1.0
[    3.771629] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[    3.778074] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[    3.789919]  mmcblk0: p1 p2 p3 p4 p5 p6 p7
[    3.793212] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[    3.802609] dwc2 49000000.usb-otg: supply vusb_d not found, using dummy regulator
[    3.808923] dwc2 49000000.usb-otg: supply vusb_a not found, using dummy regulator
[    3.820397] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[    3.825930] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[    3.832386] mmc1: queuing unknown CIS tuple 0x80 (6 bytes)
[    3.921270] mmc1: new high speed SDIO card at address 0001
[    3.949448] dwc2 49000000.usb-otg: EPs: 9, dedicated fifos, 952 entries in SPRAM
[    3.956139] dwc2 49000000.usb-otg: DWC OTG Controller
[    3.960563] dwc2 49000000.usb-otg: new USB bus registered, assigned bus number 1
[    3.967897] dwc2 49000000.usb-otg: irq 87, io mem 0x49000000
[    3.974887] hub 1-0:1.0: USB hub found
[    3.977313] hub 1-0:1.0: 1 port detected
[    3.983837] ehci-platform 5800d000.usbh-ehci: EHCI Host Controller
[    3.988618] ehci-platform 5800d000.usbh-ehci: new USB bus registered, assigned bus number 2
[    3.997695] ehci-platform 5800d000.usbh-ehci: irq 64, io mem 0x5800d000
[    4.029176] ehci-platform 5800d000.usbh-ehci: USB 2.0 started, EHCI 1.00
[    4.035832] hub 2-0:1.0: USB hub found
[    4.038232] hub 2-0:1.0: 2 ports detected
[    4.049025] i2c i2c-0: Added multiplexed i2c bus 2
[    4.059648] [drm] Initialized stm 1.0.0 20170330 for 5a001000.display-controller on minor 0
[    4.067848] input: generic ft5x06 (11) as /devices/platform/soc/40012000.i2c/i2c-0/0-002a/input/input1
[    4.079713] Freeing unused kernel memory: 1024K
[    4.089594] Run /init as init process
[    4.409367] usb 2-1: new high-speed USB device number 2 using ehci-platform
[    4.661215] hub 2-1:1.0: USB hub found
[    4.667185] hub 2-1:1.0: 4 ports detected
[    5.804612] EXT4-fs (mmcblk0p6): recovery complete
[    5.809318] EXT4-fs (mmcblk0p6): mounted filesystem with ordered data mode. Opts: (null)
[    6.341405] systemd[1]: System time before build time, advancing clock.
[    6.478449] NET: Registered protocol family 10
[    6.516607] Segment Routing with IPv6
[    6.563409] systemd[1]: systemd 244.5+ running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR -SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS -ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD)
[    6.590482] systemd[1]: Detected architecture arm.
Welcome to ST OpenSTLinux - Weston - (A Yocto Project Based Distro) 3.1-openstlinux-5.10-dunfell-mp1-21-03-31 (dunfell)!
[    6.681764] systemd[1]: Set hostname to <stm32mp1>.
[    6.695597] systemd[1]: Hardware watchdog 'STM32 Independent Watchdog', version 0
[    6.702934] systemd[1]: Set hardware watchdog to 32s.
[    7.628476] systemd[1]: Unnecessary job for /dev/ttySTM0 was removed.
[    7.643347] systemd[1]: Created slice system-getty.slice.
[    7.681787] systemd[1]: Created slice system-serial\x2dgetty.slice.
[    7.721593] systemd[1]: Created slice User and Session Slice.
[    7.760026] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[  OK  ] Started Dispatch Password �…ts to Console Directory Watch.
[    7.799937] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[  OK  ] Started Forward Password R�…uests to Wall Directory Watch.
[    7.839845] systemd[1]: Reached target Paths.
[    7.869513] systemd[1]: Reached target Remote File Systems.
[    7.909486] systemd[1]: Reached target Slices.
[    7.939559] systemd[1]: Reached target Swap.
[    8.001083] systemd[1]: Listening on RPCbind Server Activation Socket.
[    8.039578] systemd[1]: Reached target RPC Port Mapper.
[    8.080694] systemd[1]: Listening on Syslog Socket.
[    8.134474] systemd[1]: Listening on Process Core Dump Socket.
[    8.170055] systemd[1]: Listening on initctl Compatibility Named Pipe.
[    8.216274] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
[    8.224145] systemd[1]: Listening on Journal Socket (/dev/log).
[    8.260603] systemd[1]: Listening on Journal Socket.
[    8.301028] systemd[1]: Listening on Network Service Netlink Socket.
[    8.340532] systemd[1]: Listening on udev Control Socket.
[    8.380190] systemd[1]: Listening on udev Kernel Socket.
[    8.420707] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
[    8.435111] systemd[1]: Mounting POSIX Message Queue File System...
[    8.476871] systemd[1]: Mounting Kernel Debug File System...
[    8.518981] systemd[1]: Mounting Temporary Directory (/tmp)...
[    8.567669] systemd[1]: Starting Create list of static device nodes for the current kernel...
         Starting Create list of st�…odes for the current kernel...
[    8.616500] systemd[1]: Starting Mount partitions...
[    8.664049] systemd[1]: Started Hardware RNG Entropy Gatherer Daemon.
[    8.708129] systemd[1]: Starting RPC Bind...
[    8.749810] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[    8.787372] systemd[1]: Starting Journal Service...
[    8.823072] systemd[1]: Condition check resulted in Load Kernel Modules being skipped.
[    8.872952] systemd[1]: Mounting FUSE Control File System...
[    8.916523] systemd[1]: Mounting Kernel Configuration File System...
[    8.956990] systemd[1]: Starting Remount Root and Kernel File Systems...
[    9.032450] systemd[1]: Starting Apply Kernel Variables...
[    9.087285] EXT4-fs (mmcblk0p6): re-mounted. Opts: (null)
[    9.101645] systemd[1]: Starting udev Coldplug all Devices...
[    9.205793] EXT4-fs (mmcblk0p4): recovery complete
[    9.211335] EXT4-fs (mmcblk0p4): mounted filesystem with ordered data mode. Opts: (null)
[    9.218053] ext4 filesystem being mounted at /boot supports timestamps until 2038 (0x7fffffff)
[    9.246625] systemd[1]: Started RPC Bind.
[    9.310477] systemd[1]: Mounted POSIX Message Queue File System.
[    9.392334] systemd[1]: Mounted Kernel Debug File System.
[    9.440661] systemd[1]: Mounted Temporary Directory (/tmp).
[    9.489584] systemd[1]: Started Create list of static device nodes for the current kernel.
[  OK  ] Started Create list of sta�… nodes for the current kernel.
[    9.543349] systemd[1]: Mounted FUSE Control File System.
[    9.570845] systemd[1]: Mounted Kernel Configuration File System.
[    9.639566] systemd[1]: Started Remount Root and Kernel File Systems.
[    9.662851] systemd[1]: Started Journal Service.
[    9.785320] EXT4-fs (mmcblk0p5): recovery complete
[    9.789599] EXT4-fs (mmcblk0p5): mounted filesystem with ordered data mode. Opts: (null)
[    9.796861] ext4 filesystem being mounted at /vendor supports timestamps until 2038 (0x7fffffff)
[    9.901644] systemd-journald[280]: Received client request to flush runtime journal.
[   10.819473] EXT4-fs (mmcblk0p7): recovery complete
[   10.839373] EXT4-fs (mmcblk0p7): mounted filesystem with ordered data mode. Opts: (null)
[   10.846129] ext4 filesystem being mounted at /usr/local supports timestamps until 2038 (0x7fffffff)
[  OK  ] Reached target System Time Set.
[  OK     13.080581] Bluetooth: Core ver 2.22
[   13.083695] NET: Registered protocol family 31
m] Started Daily apt download activities.
[   13.101779] st,stm32-i2s 4000b000.audio-controller: No cache defaults, reading back from HW
[   13.131173] Bluetooth: HCI device and connection manager initialized
[   13.136120] Bluetooth: HCI socket layer initialized
[   13.199641] Bluetooth: L2CAP socket layer initialized
[   13.203347] Bluetooth: SCO socket layer initialized
[   13.269648] stm32-cryp 54001000.cryp: will run requests pump with realtime priority
[   13.271084] stm32-hash 54002000.hash: will run requests pump with realtime priority
[   13.304665] Bluetooth: HCI UART driver ver 2.3
[   13.307676] Bluetooth: HCI UART protocol H4 registered
[   13.320826] Bluetooth: HCI UART protocol Broadcom registered
[   13.469459] stm32-hash 54002000.hash: Init HASH done HW ver 23 DMA mode 1
[   13.476274] stm32-cryp 54001000.cryp: Initialized
[   13.581819] stm32-crc32 58009000.crc: Initialized
[   13.608683] galcore: loading out-of-tree module taints kernel.
[   13.720835] Bluetooth: hci0: BCM: chip id 94
[   13.724540] Bluetooth: hci0: BCM: features 0x2e
[   13.729808] Bluetooth: hci0: BCM43430A1
[   13.732241] Bluetooth: hci0: BCM43430A1 (001.002.009) build 0000
[   13.744882] Bluetooth: hci0: BCM43430A1 'brcm/BCM43430A1.hcd' Patch
[   13.873636] Galcore version 6.4.3.279124
[   14.161069] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[   14.350356] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[   14.426838] Bluetooth: hci0: BCM4343WA1 37.4MHz Murata Type-1DX BT4.2-0093
[   14.432657] Bluetooth: hci0: BCM43430A1 (001.002.009) build 0395
[   14.521939] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43430-sdio for chip BCM43430/1
[   14.720128] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43430-sdio for chip BCM43430/1
[   14.809974] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM43430/1 wl0: Feb 16 2020 22:39:24 version 7.45.98.97 (r724416 CY) FWID 01-bf41ed64
[   15.400454] using random self ethernet address
[   15.413001] using random host ethernet address
[   15.634991] usb0: HOST MAC 50:0e:22:14:9c:21
[   15.638013] usb0: MAC ae:9c:4a:0b:df:f2
[   15.679451] dwc2 49000000.usb-otg: bound driver configfs-gadget
[   15.940645] cs42l51 0-004a: Cirrus Logic CS42L51, Revision: 01
[  OK  ] Listening on Load/Save RF �…itch Status /dev/rfkill Watch.
         Starting Load/Save Screen �…of backlight:5a000000.dsi.0...
[  OK  ] Started Load/Save Screen B�…s of backlight:5a000000.dsi.0.
[   19.011738] stm32-dwmac 5800a000.ethernet eth0: PHY [stmmac-0:00] driver [RTL8211F Gigabit Ethernet] (irq=POLL)
[   19.058061] dwmac4: Master AXI performs any burst length
[   19.062201] stm32-dwmac 5800a000.ethernet eth0: No Safety Features support found
[   19.089383] stm32-dwmac 5800a000.ethernet eth0: IEEE 1588-2008 Advanced Timestamp supported
[   19.114589] stm32-dwmac 5800a000.ethernet eth0: registered PTP clock
[   19.149445] stm32-dwmac 5800a000.ethernet eth0: configuring for phy/rgmii-id link mode
ST OpenSTLinux - Weston - (A Yocto Project Based Distro) 3.1-openstlinux-5.10-dunfell-mp1-21-03-31 stm32mp1 ttySTM0
root@stm32mp1:~# [   34.409316] usb33: supplied by vdd_usb
[   34.411784] vref: supplied by vdd
[   34.415184] vref: disabling
[   34.417729] vdda: disabling
root@stm32mp1:~#
root@stm32mp1:~# cat /etc/build
Build Configuration:  |
BB_VERSION = 1.46.0
BUILD_SYS = x86_64-linux
NATIVELSBSTRING = universal
MACHINE = stm32mp1
DISTRO = openstlinux-weston
DISTRO_VERSION = 3.1.11-openstlinux-5.10-dunfell-mp1-21-11-17
TARGET_FPU = hard
MANIFESTVERSION = ostl-21-11-17-rc4
DISTRO_CODENAME = dunfell
ACCEPT_EULA_stm32mp1 = 1
GCCVERSION = 9.%
Layer Revisions:      |
meta-python       = default.xml:2e7e98cd0cb82db214b13224c71134b9335a719b
meta-oe           = default.xml:2e7e98cd0cb82db214b13224c71134b9335a719b
meta-gnome        = default.xml:2e7e98cd0cb82db214b13224c71134b9335a719b
meta-initramfs    = default.xml:2e7e98cd0cb82db214b13224c71134b9335a719b
meta-multimedia   = default.xml:2e7e98cd0cb82db214b13224c71134b9335a719b
meta-networking   = default.xml:2e7e98cd0cb82db214b13224c71134b9335a719b
meta-webserver    = default.xml:2e7e98cd0cb82db214b13224c71134b9335a719b
meta-filesystems  = default.xml:2e7e98cd0cb82db214b13224c71134b9335a719b
meta-perl         = default.xml:2e7e98cd0cb82db214b13224c71134b9335a719b
meta-st-stm32mp   = default.xml:3d49b4b37ab3d5b80047e494b3fd459da00ff4ba
meta-qt5          = default.xml:b4d24d70aca75791902df5cd59a4f4a54aa4a125
meta-st-openstlinux = default.xml:9268cd36c765295f1abb8180f08d5502af2d1fd9
meta              = default.xml:c7d2281eb6cda9c1637c20b3540b142073bca235
Board $> cat /etc/build
BB_VERSION = 1.46.0
MACHINE = stm32mp1
DISTRO_VERSION = 3.1-openstlinux-5.10-dunfell-mp1-21-03-31
TARGET_FPU = hard
MANIFESTVERSION = ostl-21-03-31-rc4-2-g7ef7d27
GCCVERSION = 9.%
Layer Revisions:      |
meta-python       = default.xml:5bba79488b7d393d2258d6e917f7bf7b0d7c4073
meta-oe           = default.xml:5bba79488b7d393d2258d6e917f7bf7b0d7c4073
meta-gnome        = default.xml:5bba79488b7d393d2258d6e917f7bf7b0d7c4073
meta-initramfs    = default.xml:5bba79488b7d393d2258d6e917f7bf7b0d7c4073
meta-multimedia   = default.xml:5bba79488b7d393d2258d6e917f7bf7b0d7c4073
meta-networking   = default.xml:5bba79488b7d393d2258d6e917f7bf7b0d7c4073
meta-webserver    = default.xml:5bba79488b7d393d2258d6e917f7bf7b0d7c4073
meta-filesystems  = default.xml:5bba79488b7d393d2258d6e917f7bf7b0d7c4073
meta-perl         = default.xml:5bba79488b7d393d2258d6e917f7bf7b0d7c4073
meta-st-stm32mp   = default.xml:2e80e33539a193c6a8add6131c4c760009c49cea
meta-qt5          = default.xml:0d8eb956015acdea7e77cd6672d08dce18061510
meta-st-openstlinux = default.xml:673d7ee4572e3faadec3e43d5f0fa004465b78d9
meta              = default.xml:72431ee8de5e3a53d259cebf420a7713ac9e1f14
For ecosystem release v3.1.0 More info.png :
root@stm32mp1:~# uname -a
Linux stm32mp1 5.10.61 #1 SMP PREEMPT Thu Aug 26 12:51:21 UTC 2021 armv7l armv7l armv7l GNU/Linux
Board $> uname -a
Linux stm32mp1 5.10.10 #1 SMP PREEMPT Sat Jan 23 15:04:06 UTC 2021 armv7l armv7l armv7l GNU/Linux
root@stm32mp1:~# cat /proc/version
Board $> cat /proc/version
root@stm32mp1:~#  df -h
devtmpfs        146M     0  146M   0% /dev
/dev/mmcblk0p6  683M  471M  164M  75% /
tmpfs           212M   64K  212M   1% /dev/shm
tmpfs           212M  8.8M  203M   5% /run
tmpfs           212M     0  212M   0% /sys/fs/cgroup
tmpfs           212M   20K  212M   1% /tmp
/dev/mmcblk0p4   56M   15M   38M  28% /boot
/dev/mmcblk0p5   14M  6.8M  6.2M  53% /vendor
tmpfs           212M  156K  212M   1% /var/volatile
/dev/mmcblk0p7   14G   39M   13G   1% /usr/local
tmpfs            43M     0   43M   0% /run/user/0
Board $> df -h
devtmpfs        147M     0  147M   0% /dev
/dev/mmcblk0p6  690M  424M  220M  66% /
tmpfs           214M   64K  214M   1% /dev/shm
tmpfs           214M  8.8M  205M   5% /run
tmpfs           214M     0  214M   0% /sys/fs/cgroup
tmpfs           214M   20K  214M   1% /tmp
/dev/mmcblk0p4   58M   14M   40M  27% /boot
/dev/mmcblk0p5   15M  6.8M  6.7M  51% /vendor
tmpfs           214M  144K  214M   1% /var/volatile
/dev/mmcblk0p7   28G   38M   26G   1% /usr/local
3.5. ssh connection (only if the Ethernet cable connected)[edit source]
Board $> ip addr show eth0
  • On the host computer, connect the terminal to the board using ssh
PC $> ssh root@xx.xx.xx.xx
root@stm32mp1:~#
