STDarkGreen
Revision as of 13:39, 8 October 2021 by Registered User (Merge articles)
1. Usage
The STDarkGreen template is used to color text in pages, with the STMicroelectronics corporate primary color shade of dark green (█).
Where:
Usage:  {{STDarkGreen|<text to color>|tint=<tint>}}
  • <text to color> is the text to format in dark green. If this template is called with no text, the hexadecimal code of the color is returned.
  • <tint> is the tint of the color expressed in percentage. If tint is not set then the original color is used (tint = 100%). The possible value are:
    • 75: 75% of the original color tint
    • 50: 50% of the original color tint
    • 25: 25% of the original color tint
2. Basic examples
You type You get
Coloring text in dark green
This is a {{STDarkGreen|STMicroelectronics corporate color: shade of dark green: █}}
This is a STMicroelectronics corporate color: shade of dark green: █
Coloring text in 75% tint of dark green
This is a {{STDarkGreen|STMicroelectronics corporate color: 75% tint of dark green: █ | tint=75}}
This is a STMicroelectronics corporate color: 75% tint of dark green: █
Coloring text in 50% tint of dark green
This is a {{STDarkGreen|STMicroelectronics corporate color: 50% tint of dark green: █ | tint=50}}
This is a STMicroelectronics corporate color: 50% tint of dark green: █
Coloring text in 25% tint of dark green
This is a {{STDarkGreen|STMicroelectronics corporate color: 25% tint of dark green: █ | tint=25}}
This is a STMicroelectronics corporate color: 25% tint of dark green: █
Getting the hexadecimal code of the color
{{STDarkGreen}} is the hexadecimal code of STMicroelectronics dark green.
#04572F is the hexadecimal code of STMicroelectronics dark green.
Getting the hexadecimal code of the 75% tint of the color
{{STDarkGreen | tint=75}} is the hexadecimal code of STMicroelectronics 75% tint of dark green.
#438163 is the hexadecimal code of STMicroelectronics 75% tint of dark green.
Getting the hexadecimal code of the 50% tint of the color
{{STDarkGreen | tint=50}} is the hexadecimal code of STMicroelectronics 50% tint of dark green.
#81AB97 is the hexadecimal code of STMicroelectronics 50% tint of dark green.
Getting the hexadecimal code of the 25% tint of the color
{{STDarkGreen | tint=25}} is the hexadecimal code of STMicroelectronics 25% tint of dark green.
#BDD3C8 is the hexadecimal code of STMicroelectronics 25% tint of dark green.
3. More examples
You type You get
dark green and bold
This is a {{STDarkGreen|'''STMicroelectronics'''}} corporate color: '''{{STDarkGreen|shade of dark green: █}}'''
dark green and italic
This is a {{STDarkGreen|''STMicroelectronics''}} corporate color: ''{{STDarkGreen|shade of dark green: █}}''
4. Maintenance
5. Code
#04572F
No categories assignedEdit
