NoIndex
Revision as of 16:29, 9 March 2021 by Registered User (Merge articles)
1. Usage
The NoIndex template is used to add, in a page, the __NOINDEX__ magic word so that this page is neither indexed by search engines, nor indexed by the internal wiki search. For example, a sub-article whose content is per definition only intended to be included in other articles, should not be indexed. Using this template instead of the magic word directly makes use of the magic word easier to track.
Usage: {{NoIndex}}
2. Maintenance
3. Code
