1. Usage
The Info template is used to draw attention to a particularly important point.
It puts a message box with a "dark blue info" icon in the page.
Usage: {{Info | <message>}}
Where <message> is the optional info message. If this parameter is not set, the default message is "Info".
2. Basic examples
You type | You get | ||
Info without specific info message
{{Info}} |
Info with specific Info message
{{Info | Note that the below actions are optional but recommended}} |
3. More examples
You type | You get | ||||
Info with a long info message
{{Info | The info message is a long sentence. Lorem ipsum: isdem diebus Apollinaris Domitiani gener, paulo ante agens palatii Caesaris curam, ad Mesopotamiam missus a socero per militares numeros immodice scrutabatur, an quaedam altiora meditantis iam Galli.}} |
Check that the spaces before and after the info message
BEFORE{{Info | Check spaces}}AFTER<br> BEFORE {{Info | Check spaces}} AFTER |
BEFORE
BEFORE
AFTER |
4. Maintenance
5. Code
File:Info.png | Info |
