Subpart - STM32MP1 - Starter Package
This article gathers the information that applies to any STM32MP15 board.
Template:Warning
That's the reason why the steps 2, 3 and 6 referenced in this article depend on the considered board:Template:UpdateNeededForNewBoard
2. Checking the boot sequence[edit source]
Assuming you have performed the optional step 6 above, the information (coming successively from the U-Boot and the Linux operating system that is booting on the board), should be displayed on the host PC Terminal. Template:Info
First information scrolled on the remote Terminal during boot
Last information scrolled on the remote Terminal during boot
In parallel, a U-Boot splash screen picture is displayed on the DSI display (if one is connected to the board).DSI U-Boot splash screen.png
A user space graphical boot splash screen (PSplash) picture is then briefly displayed on the HDMI monitor if one is connected to the board, or otherwise on the DSI display (if one is connected to the board).DSI user splash screen.png
When the boot process is complete, the Wayland background layer is shown on the HDMI monitor if one is connected to the board, or otherwise on the DSI display (if one is connected to the board).
File:STM32MP15 wayland background layer.png
Wayland background layer shown on the HDMI monitor or on the DSI display
3. Mouse, keyboard and Ethernet hot-plugs[edit source]
[  926.786326] usb 2-1.1: new low-speed USB device number 3 using ehci-platform
[  926.961413] input: Logitech Optical USB Mouse as /devices/platform/soc/5800d000.usbh-ehci/usb2/2-1/2-1.1/2-1.1:1.0/0003:046D:C016.0001/input/input2
[  926.975098] hid-generic 0003:046D:C016.0001: input: USB HID v1.10 Mouse [Logitech Optical USB Mouse] on usb-5800d000.usbh-ehci-1.1/input0
[ 1215.356377] stm32-dwmac 5800a000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[ 1215.363377] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
4. Remote and local Terminal programs[edit source]
Example of command (ifconfig) executed on the remote Terminal program
Icon to launch a local Terminal program
Wayland Terminal program
Then the on-board Wayland Terminal can be used to directly enter command lines as shown below, still with the ifconfig command to query the network interface parameters:
Example of command (ifconfig) executed on the Wayland Terminal program
Note: in this article, any command executed on the board (through the remote Terminal or the Wayland Terminal) starts with Template:Board$, while any command executed on the host PC starts with Template:PC$.
5. Executing basic commands[edit source]
Template:Info
5.1. Having a look at the OpenSTLinux directory structure[edit source]
5.2. Identifying the software running on board[edit source]
Template:Info Template:UpdateNeededForNewRelease
Software How to get its version Output example
TF-A TF-A Version number
NOTICE: BL2: v2.0(debug):Template:Highlight
U-Boot See the version displayed in the console
Template:Highlight [...]
Linux kernel
Template:Board$ cat /proc/version
Template:Highlight (xxxx@yyyy) (gcc version 7.3.0 (GCC)) [...]
GCC
Linux version 4.14.48 (xxxx@yyyy) (Template:Highlight) [...]
Yocto Project
Template:Board$ lsb_release -c
Codename: Template:Highlight
Weston
Template:Board$ weston --version
Template:Highlight
GStreamer
Template:Board$ gst-play-1.0 --version
Template:Highlight
GPU
Template:Board$ cat /sys/kernel/debug/gc/version
Template:Highlight built [...]
5.3. Configuration tips[edit source]
5.4. Getting board IP address[edit source]
Template:Board$ ip addr show eth0
    link/ether 00:xx:xx:xx:xx:xx brd ff:ff:ff:ff:ff:ff
    inet Template:Highlight/22 brd 10.xx.xx.xx scope global dynamic eth0
    inet6 fe80::xx:xx:xx:xx/64 scope link
  • Get the IP address of your board with the ifconfig Linux command line (a deprecated but well-known command):
Template:Board$ ifconfig eth0
eth0      Link encap:Ethernet  HWaddr 00:xx:xx:xx:xx:xx
          inet addr:Template:Highlight  Bcast:10.xx.xx.xx  Mask:255.255.252.0
          inet6 addr: fe80::xx:xx:xx:xx/64 Scope:Link
          RX packets:2619 errors:0 dropped:0 overruns:0 frame:0
          TX packets:1311 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:353250 (344.9 KiB)  TX bytes:118305 (115.5 KiB)
          Interrupt:247
5.5. Copying a file from your host PC to your board (and reciprocally)[edit source]
5.6. Miscellaneous commands[edit source]
Template:InfoTemplate:UpdateNeededForNewRelease
5.6.1. Printing distribution specific information[edit source]
Template:Board$ lsb_release -a
LSB Version:    core-4.1-noarch:core-4.1-arm
Distributor ID: openstlinux-weston
Description:    ST OpenSTLinux - Weston - (A Yocto Project Based Distro) 2.4+openstlinux-4.14-rocko-mp1-18-11-26
Release:        2.4+openstlinux-4.14-rocko-mp1-18-11-26
Codename:       rocko
Where:
LSB Version Version of LSB (Linux Standard Base) against which distribution is compliant
Distributor ID String identifier of distributor
Description Single line text description of distribution
Release Release number of distribution
Codename Codename according to distribution release
5.6.2. Printing system information[edit source]
Template:Board$ uname -a
Linux stm32mp1-boards-rev[b/c] 4.14.48 #1 SMP PREEMPT Tue Nov 27 14:41:52 UTC 2018 armv7l armv7l armv7l GNU/Linux
Where:
Linux Kernel name
stm32mp1-boards-rev[b/c] Network node hostname
4.14.48 Kernel release
#1 SMP PREEMPT Tue Nov 27 14:41:52 UTC 2018 Kernel version
armv7l Machine hardware name
GNU/Linux Operating system
5.6.3. Printing Linux kernel and GCC versions[edit source]
Linux version 4.14.48 (xxxx@yyyy) (gcc version 7.3.0 (GCC)) #1 SMP PREEMPT Tue Nov 27 14:41:52 UTC 2018
Where:
Linux Kernel name
version 4.14.48 Kernel release
(xxxx@yyyy) Person (xxxx) who compiled the kernel, and machine (yyyy) where it happened
(gcc version 7.3.0 (GCC) ) Version of the GCC compiler used to compile the kernel
#1 SMP PREEMPT Tue Nov 27 14:41:52 UTC 2018 Kernel version; type of kernel (SMP) and date and time of the kernel compilation
5.6.4. Printing the amount of disk space available on all mounted file systems[edit source]
Template:Board$ df -h
/dev/root       719M  347M  334M  52% /
devtmpfs        372M     0  372M   0% /dev
tmpfs           436M     0  436M   0% /dev/shm
tmpfs           436M   14M  423M   4% /run
tmpfs           436M     0  436M   0% /sys/fs/cgroup
tmpfs           436M  4.0K  436M   1% /tmp
/dev/mmcblk0p4   58M  7.7M   46M  15% /boot
tmpfs           436M  160K  436M   1% /var/volatile
/dev/mmcblk0p7   15G   14G     0 100% /usr/local
/dev/mmcblk0p5   15M  8.7M  4.7M  65% /vendor
tmpfs            88M     0   88M   0% /run/user/0
Where:
Filesystem Source of the mount point, usually a device
Size Total size in human readable format (e.g. 1K, 234M, 2G)
Used Used size in human readable format
Available Available size in human readable format
Use% Percentage of used size divided by the total size
Mounted on Mount point
