PC$
1. Usage
Thanks to the pc-prompt class defined in MediaWiki:Common.css, a double (or triple) click to select the command doesn't select the prompt.
Usage:  {{PC$}}
2. Basic examples
You type You get
{{PC$}} ls test<br>
test1.txt test2.txt
ls test
test1.txt test2.txt
3. More examples
You type You get
2 commands executed on the host PC and preformatted text block (space at the beginning of each line)
 {{PC$}} ls test
 test1.txt test2.txt
 {{PC$}} cat test/test1.txt
 This is a test
 ls test
test1.txt test2.txt
 cat test/test1.txt
This is a test
Command executed on the host PC and preformatted text block (space at the beginning of each line)
 {{PC$}} ls test
 test1.txt test2.txt
 ls test
test1.txt test2.txt
Long command executed on the host PC and preformatted text block (space at the beginning of each line)
 {{PC$}} this is a so long command executed on the host PC that a horizontal scrolling bar is needed
Template used within another public message box template
{{Info |
Message before the command
 {{PC$}} ls test
 test1.txt test2.txt
Message after the command
Template used within another protected message box template
{{InternalInfo |
 {{PC$}} ls test
 test1.txt test2.txt
4. Maintenance
5. Code
No categories assignedEdit
