1. Open a terminal
Ubuntu terminal
  • Create your STM32MPU workspace directory on your host computer
 cd $HOME/STM32MPU_workspace
2. Check the host computer Internet access
If an 'OK' message is returned, the network is well configured.
Any other likely situation indicates the need for a proxy for http/https protocols.
3. Install the tools
3.1. STM32CubeProgrammer
  • Create your STM32MPU tools directory on your host computer
  • Create a temporary directory in your STM32MPU workspace
  • Download last STM32CubeProgrammer in the following directory
  • Uncompress the archive file to get the STM32CubeProgrammer installers
  • Execute the Linux installer, which guides you through the installation process. Select "$HOME/STM32MPU-Tools/STM32CubeProgrammer-x.y.z" as the installation directory, when it's requested by the installer
Screenshot examples from V2.2.0 :
Splash screen
  • Add the STM32CubeProgrammer binary path to your PATH environment variable
  • Check that the STM32CubeProgrammer tool is properly installed and accessible
 STM32_Programmer_CLI --h
                       STM32CubeProgrammer vx.y.z
3.2. USB serial link
  • Install the libusb on your host computer
  • To allow STM32CubeProgrammer to access the USB port through low-level commands, proceed as follows
4. Download the image
4.1. For ecosystem release v1.2.0
  • Create your STM32MP15 Starter Package directory on your host computer
 mkdir $HOME/STM32MPU_workspace/STM32MP15-Ecosystem-v1.2.0
 mkdir $HOME/STM32MPU_workspace/STM32MP15-Ecosystem-v1.2.0/Starter-Package
 cd $HOME/STM32MPU_workspace/STM32MP15-Ecosystem-v1.2.0/Starter-Package
  • Download the STM32MP15-Ecosystem-v1.2.0 Starter Package to the following directory:
 tar xvf en.FLASH-stm32mp1-openstlinux-20-02-19.tar.xz
4.2. For ecosystem release v1.1.0
4.3. For ecosystem release v1.0.0
