1. Usage[edit source]
The GDB$ template is used to prefix a command that must be executed on GDB, with a GDB-specific prompt.
Thanks to the gdb-prompt
Usage: {{GDB$}}
You type | You get |
info break command executed on GDB
{{GDB$}} show listsize<br>
Number of source lines gdb will list by default is 10.
show listsize |
3. More examples[edit source]
2 commands executed on GDB and preformatted text block (space at the beginning of each line)
{{GDB$}} show listsize Number of source lines gdb will list by default is 10. {{GDB$}} continue |
show listsize Number of source lines gdb will list by default is 10. continue |
Command executed on GDB and preformatted text block (space at the beginning of each line)
show listsize Number of source lines gdb will list by default is 10. |
Long command executed on GDB and preformatted text block (space at the beginning of each line)
{{GDB$}} this is a so long command executed on GDB that a horizontal scrolling bar is needed |
Template used within another public message box template
{{Info |
Message before the command
Message after the command
Template used within another protected message box template
{{InternalInfo |
4. Maintenance[edit source]
5. Code[edit source]
