1. Overview[edit source]
This stage explains how to connect the Linux terminal of your board to your host computer through the ST-LINK/V2-1.
Then you can see how to execute basic commands with the Linux command line interface in order to be familiarized with the Linux console.
2. The serial terminal[edit source]
The serial terminal allows you to communicate with the board trough an UART serial interface.
  • Install minicom
 sudo apt-get install minicom
  • Get the ttyACM device instance that needs to be used to access the ST-LINK/V2-1
 ls /dev/ttyACM*
/dev/ttyACM0
 minicom -D /dev/ttyACM0
Welcome to minicom 2.7
OPTIONS: I18n
Port /dev/ttyACM0, 15:56:03
Press CTRL-A Z for help on special keys
  • Press the reset button to reset the board. You should see logs displayed in the minicom window
For ecosystem release v1.2.0 More info.png:
NOTICE:  Board: MB1263 Var1 Rev.C-01
INFO:    Reset reason (0x14):
INFO:    PMIC version = 0x10
INFO:    Using SDMMC
INFO:      Instance 1
NOTICE:  BL2: v2.0-r3.0(debug):
NOTICE:  BL2: Built : 13:13:37, Oct  2 2018
INFO:    RAM: DDR3-1066/888 bin G 2x4Gb 533MHz v1.45
INFO:    Memory size = 0x40000000 (1024 MB)
INFO:    BL2 runs SP_MIN setup
INFO:    Loading image id=4 at address 0x2ffef000
INFO:    Image id=4 loaded: 0x2ffef000 - 0x30000000
INFO:    STM32 Image size : 815145
WARNING: Skip signature check (header option)
INFO:    Image id=5 loaded: 0xc0100000 - 0xc01c7029
NOTICE:  BL2: Booting BL32
INFO:    Entry point address = 0x2ffef000
INFO:    SPSR = 0x1d3
NOTICE:  SP_MIN: v2.0-r3.0(debug):
NOTICE:  SP_MIN: Built : 13:13:37, Oct  2 2018
INFO:    ARM GICv2 driver initialized
INFO:    stm32mp HSI (18): Secure only
INFO:    stm32mp HSE (20): Secure only
INFO:    stm32mp PLL2 (27): Secure only
INFO:    stm32mp PLL2_R (30): Secure only
INFO:    SP_MIN: Initializing runtime services
INFO:    SP_MIN: Preparing exit to normal world
U-Boot 2018.11-stm32mp-r4 (Nov 14 2018 - 16:10:06 +0000)
CPU: STM32MP157CAA Rev.B
Board: stm32mp1 in trusted mode (st,stm32mp157c-ev1)
DRAM:  1 GiB
Clocks:
- MPU : 650 MHz
- MCU : 208.878 MHz
- AXI : 266.500 MHz
- PER : 24 MHz
- DDR : 533 MHz
NAND:  1024 MiB
MMC:   STM32 SDMMC2: 0, STM32 SDMMC2: 1
Loading Environment from EXT4... OK
In:    serial
Out:   serial
Err:   serial
Boot over mmc0!
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:4...
Found U-Boot script /boot.scr.uimg
1628 bytes read in 1 ms (1.6 MiB/s)
## Executing script at c4100000
Scanning mmc 0:4...
Found /mmc0_stm32mp157c-ev1_extlinux/extlinux.conf
Retrieving file: /mmc0_stm32mp157c-ev1_extlinux/extlinux.conf
614 bytes read in 0 ms
Retrieving file: /splash.bmp
46180 bytes read in 3 ms (14.7 MiB/s)
Select the boot mode
1:      stm32mp157c-ev1-sdcard
2:      stm32mp157c-ev1-a7-examples-sdcard
3:      stm32mp157c-ev1-m4-examples-sdcard
Enter choice: 1:        stm32mp157c-ev1-sdcard
Retrieving file: /uImage
6722112 bytes read in 305 ms (21 MiB/s)
append: root=/dev/mmcblk0p6 rootwait rw console=ttySTM0,115200
Retrieving file: /stm32mp157c-ev1.dtb
78033 bytes read in 4 ms (18.6 MiB/s)
   Image Name:   Linux-4.19.94
   Created:      2020-01-09   9:19:10 UTC
   Data Size:    6722048 Bytes = 6.4 MiB
   Load Address: c2000040
   Entry Point:  c2000040
   Verifying Checksum ... OK
   XIP Kernel Image ... OK
   Using Device Tree in place at c4000000, end c40160d0
SF: Detected mx25l51235f with page size 256 Bytes, erase size 64 KiB, total 64 MiB
Starting kernel ...
[    0.000000] Linux version 4.19.94 (oe-user@oe-host) (gcc version 8.2.0 (GCC)) #1 SMP PREEMPT Thu Jan 9 09:19:10 UTC 2020
[    0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[    0.000000] CPU: div instructions available: patching division code
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] OF: fdt: Machine model: STMicroelectronics STM32MP157C eval daughter on eval mother
[    0.000000] Memory policy: Data cache writealloc
[    4.017152] systemd[1]: Detected architecture arm.
Welcome to ST OpenSTLinux - Weston - (A Yocto Project Based Distro) 2.6-openstlinux-20-02-19 (thud)!
[    4.074383] systemd[1]: Set hostname to <stm32mp1>.
[    4.083708] systemd[1]: Hardware watchdog 'STM32 Independent Watchdog', version 0
[    4.090842] systemd[1]: Set hardware watchdog to 30s.
[  OK  ] Started Update UTMP about System Runlevel Changes.
ST OpenSTLinux - Weston - (A Yocto Project Based Distro) 2.6-openstlinux-20-02-19 stm32mp1 ttySTM0
root@stm32mp1:~#
For ecosystem release v1.1.0 More info.png:
NOTICE:  CPU: STM32MP157CAA Rev.B
INFO:    Reset reason (0x54):
INFO:      System reset generated by MPU (MPSYSRST)
INFO:    Using SDMMC
INFO:      Instance 1
NOTICE:  BL2: v2.0-r1.5(debug):
INFO:    Loading image id=4 at address 0x2fff0000
INFO:    Image id=4 loaded: 0x2fff0000 - 0x30000000
INFO:    STM32 Image size : 810110
INFO:    Image id=5 loaded: 0xc0100000 - 0xc01c5c7e
INFO:    read version 0 current version 0
INFO:    Entry point address = 0x2fff0000
INFO:    SPSR = 0x1d3
NOTICE:  SP_MIN: v2.0-r1.5(debug):
U-Boot 2018.11-stm32mp-r3 (Nov 14 2018 - 16:10:06 +0000)
DRAM:  1 GiB
Clocks:
- MPU : 650 MHz
- MCU : 208.878 MHz
- AXI : 266.500 MHz
- PER : 24 MHz
- DDR : 533 MHz
NAND:  1024 MiB
In:    serial
Out:   serial
Err:   serial
Boot over mmc0!
Scanning mmc 0:4...
1553 bytes read in 1 ms (1.5 MiB/s)
Scanning mmc 0:4...
614 bytes read in 1 ms (599.6 KiB/s)
46180 bytes read in 4 ms (11 MiB/s)
6652480 bytes read in 294 ms (21.6 MiB/s)
73259 bytes read in 4 ms (17.5 MiB/s)
   Image Name:   Linux-4.19.49
   Created:      2019-06-09   7:17:25 UTC
   Data Size:    6652416 Bytes = 6.3 MiB
   Using Device Tree in place at c4000000, end c4014e2a
SF: Detected mx25l51235f with page size 256 Bytes, erase size 64 KiB, total 64 B
Starting kernel ...
[    0.000000] Linux version 4.19.49 (oe-user@oe-host) (gcc version 8.2.0 (GCC)9
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instructie
[    0.000000] OF: fdt: Machine model: STMicroelectronics STM32MP157C eval daugr
[    0.000000] efi: Getting EFI parameters from FDT:
[    0.000000] efi: UEFI not found.
[    0.000000] Reserved memory: created DMA memory pool at 0x10000000, size 0 MB
[    0.000000] OF: reserved mem: initialized node mcuram2@0x10000000, compatibll
[    0.000000] Reserved memory: created DMA memory pool at 0x10040000, size 0 MB
[    0.000000] OF: reserved mem: initialized node vdev0vring0@10040000, compatil
[    0.000000] Reserved memory: created DMA memory pool at 0x10042000, size 0 MB
[    3.370352] stm32_rtc 5c004000.rtc: setting system clock to 2000-01-01 00:16)
[    3.379410] ALSA device list:
[    3.381354]   #0: STM32MP1-EV
[    3.401085] EXT4-fs (mmcblk0p6): mounted filesystem with ordered data mode. )
[    3.407812] VFS: Mounted root (ext4 filesystem) on device 179:38.
[    3.420459] devtmpfs: mounted
[    3.423774] Freeing unused kernel memory: 1024K
[    3.427170] Run /sbin/init as init process
[    3.601251] systemd[1]: System time before build time, advancing clock.
[    3.680903] NET: Registered protocol family 10
[    3.717093] Segment Routing with IPv6
[    3.740417] systemd[1]: systemd 239 running in system mode. (+PAM -AUDIT -SE)
[    3.761124] systemd[1]: Detected architecture arm.
Welcome to ST OpenSTLinux - Weston - (A Yocto Project Based Distro) 2.6-openstl!
[    3.813855] systemd[1]: Set hostname to <stm32mp1>.
[    3.824369] systemd[1]: Hardware watchdog 'STM32 Independent Watchdog', vers0
[    3.831548] systemd[1]: Set hardware watchdog to 30s.
[    4.436713] systemd[1]: Unnecessary job for dev-ttySTM0.device was removed.
[    4.445218] systemd[1]: Listening on Journal Socket (/dev/log).
[  OK  ] Listening on Journal Socket (/dev/log).
[    4.480281] systemd[1]: Listening on initctl Compatibility Named Pipe.
[  OK  ] Listening on initctl Compatibility Named Pipe.
[    4.524206] systemd[1]: Created slice system-serial\x2dgetty.slice.
[  OK  ] Created slice system-serial\x2dgetty.slice.
[    4.560712] systemd[1]: Listening on udev Control Socket.
[  OK  ] Listening on udev Control Socket.
[  OK  ] Created slice User and Session Slice.
[  OK  ] Reached target Slices.
[  OK  ] Reached target Remote File Systems.
[  OK  ] Listening on Network Service Netlink Socket.
[  OK  ] Reached target Swap.
[  OK  ] Listening on Process Core Dump Socket.
[  OK  ] Listening on udev Kernel Socket.
[  OK  ] Started Dispatch Password Requests to Console Directory Watch.
[  OK  ] Started Forward Password Requests to Wall Directory Watch.
[  OK  ] Started Save/Restore Sound Card State.
[  OK  ] Started Weston Wayland Compositor.
[  OK  ] Reached target Sound Card.
[  OK  ] Started Serial Getty on ttySTM0.
[  OK  ] Started Getty on tty1.
[  OK  ] Reached target Login Prompts.
[  OK  ] Started Login Service.
[  OK  ] Started Avahi mDNS/DNS-SD Stack.
[  OK  ] Started Netdata, Real-time performance monitoring.
[  OK  ] Started Sound Service.
[  OK  ] Reached target Multi-User System.
         Starting Update UTMP about System Runlevel Changes...
[   23.011003] cfg80211: Loading compiled-in X.509 certificates for regulatory e
[   23.051458] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
ST OpenSTLinux - Weston - (A Yocto Project Based Distro) 2.6-openstlinux-4.19-t0
root@stm32mp1:~#
For ecosystem release v1.0.0 More info.png:
NOTICE:  CPU: STM32MP157AAA Rev.B
INFO:    Using SDMMC
INFO:      Instance 1
INFO:    Product_below_2v5=1: HSLVEN update is
INFO:      destructive, no update as VDD>2.7V
NOTICE:  BL2: v2.0(debug):
INFO:    RAM: DDR3-1066/888 bin G 2x4Gb 533MHz v1.41
INFO:    STM32 Image size : 753913
INFO:    Image id=5 loaded: 0xc0100000 - 0xc01b80f9
INFO:    SPSR = 0x1d3
NOTICE:  SP_MIN: v2.0(debug):
U-Boot 2018.11-stm32mp-r2 (Nov 14 2018 - 16:10:06 +0000)
       Watchdog enabled
DRAM:  1 GiB
Clocks:
- MPU : 650 MHz
- MCU : 208.878 MHz
- AXI : 266.500 MHz
- PER : 24 MHz
- DDR : 533 MHz
NAND:  1024 MiB
In:    serial
Out:   serial
Err:   serial
Boot over mmc0!
Scanning mmc 0:4...
Scanning mmc 0:4...
616 bytes read in 0 ms
Retrieving file: /mmc0_stm32mp157c-ev1_extlinux/../splash.bmp
6569464 bytes read in 289 ms (21.7 MiB/s)
74445 bytes read in 5 ms (14.2 MiB/s)
   Data Size:    6569400 Bytes = 6.3 MiB
   Using Device Tree in place at c4000000, end c40152cc
Starting kernel ...
[    0.000000] Linux version 4.19.9 (oe-user@oe-host) (gcc version 8.2.0 (GCC)) #1 SMP PREEMPT Thu Dec 13 08:16:23 UTC 2018
[    0.000000] Reserved memory: created DMA memory pool at 0x10000000, size 0 MiB
[    0.000000] OF: reserved mem: initialized node mcuram2@0x10000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x10040000, size 0 MiB
[    0.000000] OF: reserved mem: initialized node vdev0vring0@10040000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x10042000, size 0 MiB
[    0.000000] OF: reserved mem: initialized node vdev0vring1@10042000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x10044000, size 0 MiB
[    0.000000] OF: reserved mem: initialized node vdev0buffer@10044000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x30000000, size 0 MiB
[    0.000000] OF: reserved mem: initialized node mcuram@0x30000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x38000000, size 0 MiB
[    0.000000] OF: reserved mem: initialized node retram@0x38000000, compatible id shared-dma-pool
[    0.000000] cma: Reserved 128 MiB at 0xf0000000
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] psci: SMC Calling Convention v1.0
[   23.210644] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[   23.263375] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
ST OpenSTLinux - Weston - (A Yocto Project Based Distro) 2.6-openstlinux-4.19-thud-mp1-19-02-20 stm32mp1 ttySTM0
root@stm32mp1:~#
 lsb_release -a
LSB Version:    core-5.0-noarch:core-5.0-arm
Distributor ID: openstlinux-weston
Description:    ST OpenSTLinux - Weston - (A Yocto Project Based Distro) 2.6-openstlinux-20-02-19
Release:        2.6-openstlinux-20-02-19
Codename:       thud
 lsb_release -a
Description:    ST OpenSTLinux - Weston - (A Yocto Project Based Distro) 2.6-openstlinux-4.19-thud-mp1-19-10-09
Release:        2.6-openstlinux-4.19-thud-mp1-19-10-09
Codename:       thud
 lsb_release -a
Description:    ST OpenSTLinux - Weston - (A Yocto Project Based Distro) 2.6-openstlinux-4.19-thud-mp1-19-02-20
Release:        2.6-openstlinux-4.19-thud-mp1-19-02-20
Codename:       thud
 uname -a
Linux stm32mp1 4.19.94 #1 SMP PREEMPT Thu Jan 9 09:19:10 UTC 2020 armv7l armv7l armv7l GNU/Linux
 uname -a
Linux stm32mp1 4.19.49 #1 SMP PREEMPT Sun Jun 9 07:17:25 UTC 2019 armv7l armv7l armv7l GNU/Linux
 uname -a
Linux stm32mp1 4.19.9 #2 SMP PREEMPT Wed Feb 6 19:24:47 CET 2019 armv7l armv7l armv7l GNU/Linux
 cat /proc/version
 cat /proc/version
Linux version 4.19.49 (oe-user@oe-host) (gcc version 8.2.0 (GCC)) #1 SMP PREEMPT Sun Jun 9 07:17:25 UTC 2019
 cat /proc/version
 df -h
/dev/root       719M  360M  321M  53% /
devtmpfs        150M     0  150M   0% /dev
tmpfs           214M     0  214M   0% /dev/shm
tmpfs           214M   12M  203M   6% /run
tmpfs           214M     0  214M   0% /sys/fs/cgroup
tmpfs           214M  4.0K  214M   1% /tmp
/dev/mmcblk0p4   58M  8.2M   46M  16% /boot
tmpfs           214M   92K  214M   1% /var/volatile
/dev/mmcblk0p7  6.4G   68M  6.1G   2% /usr/local
/dev/mmcblk0p5   15M  8.2M  5.3M  61% /vendor
tmpfs            43M     0   43M   0% /run/user/0
3.5. ssh connection (only if Ethernet cable is connected)[edit source]
 ip addr show eth0
  • On the host computer connect the terminal to the board using ssh
 ssh root@xx.xx.xx.xx
root@stm32mp1:~#
