EcosystemRelease
Revision as of 14:10, 12 September 2019 by Registered User
1. Usage[edit source]
The EcosystemRelease template is used to indicate for which ecosystem release revision(s), an article part (chapter, paragraph, table...) is valid. Per default (i.e. if this template is not used), any part of an article is valid for all ecosystem release revisions for which the entire article is valid.
Usage: {{EcosystemRelease | revision=<revision> | range =<range> | revision2=<revision2>}}
Where:
  • <revision> is the mandatory ecosystem release revision for which the article part is valid.
    • The possible values for this parameter are available in the EcosystemRelease/Revision template.
    • The optional <range> and <revision2> parameters allow to define a range of revisions.
  • <range> is the optional range of the ecosystem release revisions for which the article part is valid. The possible values are:
    • and before: the article part is valid only for the revision(s) less than or equal to <revision>
    • and after: the article part is valid only for the revision(s) greater than or equal to <revision>
    • to: the article part is only valid from <revision> to <revision2>
  • <revision2> is the optional ecosystem release upper revision for which the article part is valid. If this parameter is set, <range> must be set to "to", and <revision> becomes the lower revision for which the article part is valid.
    • If this parameter is not set, and <range> is set to "to", the article part is valid from <revision> to the latest revision.
If the mouse is left over a revision, a popup window shows, for that revision:
  • the versions of the Linux kernel, U-Boot, TF-A and OP-TEE
  • the version of the STM32Cube MPU Package
  • the version of OpenEmbedded
  • the version of Android
You type You get
A specific revision
{{EcosystemRelease | revision=1.0.0}}
Revisions that are lower than or equal to a revision
{{EcosystemRelease | revision=1.1.0 | range=and before}}
{{EcosystemRelease | revision=1.1.0 | range=and after}}
Range of revisions
{{EcosystemRelease | revision=1.0.0 | range=to | revision2=1.1.0}}
3. More examples[edit source]
You type You get
Another specific revision
{{EcosystemRelease | revision=1.1.0}}
Unspecified revision
{{EcosystemRelease}}
ecosystem release unknown revision
Unknown revision
{{EcosystemRelease | revision=0.0.1}}
Any revision2
{{EcosystemRelease | revision=1.1.0 | range=to}}
ecosystem release 1.1.0Info.png to <span title="Main software components: unknown revision unknown revision unknown revision unknown revision unknown revision unknown revision unknown revision">latestInfo.png
Unknown revision2
{{EcosystemRelease | revision=1.1.0 | range=to | revision2=10.20.30}}
ecosystem release 1.1.0Info.png to unknown revision
Unknown range
{{EcosystemRelease | revision=1.1.0 | range=error}}
ecosystem release 1.1.0Info.png unknown range
4. Code[edit source]
No categories assignedEdit
