Revision as of 14:01, 11 March 2019 by Registered User (→‎Boot the board)
Template:ArticleMainWriter
1. Overview[edit source]
Ubuntu terminal
  • Create your STM32MPU workspace directory on your host computer
 cd $HOME/STM32MPU_workspace
If an 'OK' message is returned, the network is well configured.
Any other likely situation indicates the need for a proxy for http/https protocols.
  • STM32CubeProgrammer requires 1.8 version of the Java platform.
sudo apt-get install openjdk-8-jre-headless
sudo update-alternatives --config java
Select the java-8-openjdk configuration.
  • Install OpenJFX for Ubuntu®18.04
sudo apt purge openjfx
sudo apt install openjfx=8u161-b12-1ubuntu2 libopenjfx-jni=8u161-b12-1ubuntu2 libopenjfx-java=8u161-b12-1ubuntu2
sudo apt-mark hold openjfx libopenjfx-jni libopenjfx-java
  • Create your STM32MPU tools directory on your host computer
  • Create a temporary directory in your STM32MPU workspace
  • Download last STM32CubeProgrammer in the following directory
  • Uncompress the archive file to get the STM32CubeProgrammer installers
  • Execute the Linux installer, which guides you through the installation process. Select "$HOME/STM32MPU-Tools/STM32CubeProgrammer-x.y.z" as the installation directory, when it's requested by the installer
Screenshots, done with STM32CubeProgrammer V2.2.0, are given as examples below:
Splash screen
Welcome page
Installation path
  • Add the STM32CubeProgrammer binary path to your PATH environment variable
  • Check that the STM32CubeProgrammer tool is properly installed and accessible
 STM32_Programmer_CLI --h
                       STM32CubeProgrammer vx.y.z
  • Install the libusb on your host computer
  • To allow STM32CubeProgrammer to access the USB port through low-level commands, proceed as follows
For ecosystem release v1.2.0 More info.png[edit source]
  • Create your STM32MP15 Starter Package directory on your host computer
 mkdir $HOME/STM32MPU_workspace/STM32MP15-Ecosystem-v1.2.0
 mkdir $HOME/STM32MPU_workspace/STM32MP15-Ecosystem-v1.2.0/Starter-Package
 cd $HOME/STM32MPU_workspace/STM32MP15-Ecosystem-v1.2.0/Starter-Package
  • Download the STM32MP15-Ecosystem-v1.2.0 Starter Package to the following directory:
 tar xvf en.FLASH-stm32mp1-openstlinux-20-02-19.tar.xz
For ecosystem release v1.1.0 More info.png[edit source]
 mkdir $HOME/STM32MPU_workspace/STM32MP15-Ecosystem-v1.1.0
 mkdir $HOME/STM32MPU_workspace/STM32MP15-Ecosystem-v1.1.0/Starter-Package
 cd $HOME/STM32MPU_workspace/STM32MP15-Ecosystem-v1.1.0/Starter-Package
  • Download the STM32MP15-Ecosystem-v1.1.0 Starter Package to the following directory:
 tar xvf en.FLASH-stm32mp1-openstlinux-4.19-thud-mp1-19-10-09.tar.xz
For ecosystem release v1.0.0 More info.png[edit source]
 mkdir $HOME/STM32MPU_workspace/STM32MP15-Ecosystem-v1.0.0
 mkdir $HOME/STM32MPU_workspace/STM32MP15-Ecosystem-v1.0.0/Starter-Package
 cd $HOME/STM32MPU_workspace/STM32MP15-Ecosystem-v1.0.0/Starter-Package
  • Download the STM32MP15-Ecosystem-v1.0.0 Starter Package to the following directory:
 tar xvf en.FLASH-stm32mp1-openstlinux-4.19-thud-mp1-19-02-20.tar.xz
  • Power up the board
 cd $HOME/STM32MPU_workspace/STM32MP15-Ecosystem-v1.0.0/Starter-Package/stm32mp1-openstlinux-4.19-thud-mp1-19-02-20/images/stm32mp1
 STM32_Programmer_CLI -l usb
                        STM32CubeProgrammer v2.0.0
=====  DFU Interface   =====
  Device Index           : USB1
  USB Bus Number         : 003
  USB Address Number     : 002
  Serial number          : 004800233338511634383330
  • Flash the microSD card with the image for the trusted boot chain
This operation takes several minutes (mainly depending of the rootfs size). A successful flashing should be terminated by this following log information
  • Set the boot switches (located at the back of the board) to the on position
  • If the board power supply doesn't supply enougth current (3 Amps), the red LED indicates the issue following the rules below:
blink console message boot process
2 times WARNING 500mA power supply detected
Current too low, use a 3A power supply!
continue and red LED stays ON
3 times WARNING 1500mA power supply detected
forever ERROR USB TYPE-C connection in unattached mode
Check that USB TYPE-C cable is correctly plugged
stop
  • After few seconds, the board starts and automatically go through the following screens
UBoot splash screen
Linux splash screen
Weston desktop
GTK demo launcher
