Revision as of 21:45, 31 January 2019 by Registered User
1. Overview[edit source]
This stage will explain you how to get, install and boot the STM32MP15 Discovery kits with the Starter Package.
2. Install the tools[edit source]
2.1. STM32CubeProgrammer[edit source]
STM32CubeProgrammer requires 1.8 version or later of the Java platfrom.
 sudo apt-get install openjdk-8-jre
 sudo update-alternatives --config java
Select the java-8-openjdk configuration.
  • Create your STM32MPU tools directory on your host computer
 mkdir $HOME/STM32MPU-Tools
 cd $HOME/STM32MPU-Tools
 mkdir STM32CubeProgrammer-2.0.0
  • Download the version 2.0.0 of STM32CubeProgrammer archive file in a temporary derectory of your host computer
  • Uncompress the archive file to get the STM32CubeProgrammer installers
  • Execute the Linux installer, which guides you through the installation process. Select "$HOME/STM32MPU-Tools/STM32CubeProgrammer-2.0.0" as the installation directory, when it's requested by the installer
 ./SetupSTM32CubeProgrammer-2.0.0.linux
Splash screen
Welcome page
Installation path
  • Add the STM32CubeProgrammer binary path to your PATH environment variable
export PATH=$HOME/STM32MPU-Tools/STM32CubeProgrammer-2.0.0/bin:$PATH
  • Check that the STM32CubeProgrammer tool is properly installed and accessible
 STM32_Programmer_CLI --h
2.2. USB serial link[edit source]
  • Install the libusb on your host computer
  • To allow STM32CubeProgrammer to access the USB port through low-level commands, proceed as follows
 cd $HOME/STM32MPU-Tools/STM32CubeProgrammer-2.0.0/Drivers/rules
3. Download the image[edit source]
  • Create your STM32MP15 Starter Package directory on your host computer
 mkdir $HOME/STM32MP15-Ecosystem-v1.0.0
 cd $HOME/STM32MP15-Ecosystem-v1.0.0
 mkdir Starter-Package
 cd Starter-Package
  • Download the STM32MP15-Ecosystem-v1.0.0 Starter Package in the Starter-Package directory newly created
 tar xvf FLASH-stm32mp1-boards-revc-openstlinux-4.14-rocko-mp1-18-11-26.tar.xz
4. Populate the SDCard[edit source]
  • Power up the board
 cd $HOME/STM32MP15-Ecosystem-v1.0.0/Starter-Package/stm32mp1-boards-revc-openstlinux-4.14-rocko-mp1-18-11-26/images/stm32mp1-boards-revc
 STM32_Programmer_CLI -l usb
  Device Index           : USB1
  USB Bus Number         : 002
  USB Address Number     : 002
  Serial number          : 000000000000
  Firmware version       : 0x011a
  • Flash the microSD card with the image for the trusted boot chain
This operation takes several minutes (mainly depending of the rootfs size). A successful flashing outputs the following log:
Please note that the logs that you will obtain, might be slightly different, especially if you use a different software release.
USB speed              : High Speed (480MBit/s)
Manufacturer ID        : STMicroelectronics
   AREA NAME          SECT.NBR        PARTITION.ID    SIZE         TYPE
   Partition0           0000          0x00000000      0256 KB      RW
   SECBL                0000          0x00000001      0001 MB      RW
   Partition2           0000          0x00000002      0001 MB      RW
   Partition3           0000          0x00000003      0256 KB      RW
   Partition4           0000          0x00000004      0016 MB      RW
   virtual              0000          0x000000f1      0512 B       R
Device name : STM32MPxxx
Device type : MPU
Device CPU  : Cortex-A7
Start Embedded Flashing service
Memory Programming ...
Opening and parsing file: tf-a-stm32mp157c-dk2-trusted.stm32
  File          : tf-a-stm32mp157c-dk2-trusted.stm32
  Partition ID  : 0x01
Download in Progress:
File download complete
Time elapsed during the download operation is: 00:00:00.561
RUNNING Program ...
  PartID:      :0x01
Start operation done successfully at partition 0x01
Flashlayout Programming ...
Running Flashlayout Partition ...
Flashlayout partition started successfully
Opening and parsing file: u-boot-stm32mp157c-dk2-trusted.stm32
  File          : u-boot-stm32mp157c-dk2-trusted.stm32
  Partition ID  : 0x03
Time elapsed during the download operation is: 00:00:00.665
RUNNING Program ...
  PartID:      :0x03
reconnecting the device ...
Product ID             : USB download gadget@Device ID /0x500, @Revision ID /0x0000
   fsbl1                0000          0x00000001      0256 KB      RW
   fsbl2                0000          0x00000002      0256 KB      RW
   ssbl                 0000          0x00000003      0002 MB      RW
   bootfs               0000          0x00000011      0064 MB      RW
   rootfs               0000          0x00000012      0768 MB      RW
   userfs               0000          0x00000013      6846 MB      RW
   virtual              0000          0x000000f1      0512 B       RW
   OTP                  0000          0x000000f2      0512 B       RW
   PMIC                 0000          0x000000f4      0008 B       RW
Start operation done successfully at partition 0x03
  Partition ID  : 0x01
Time elapsed during the download operation is: 00:00:00.097
RUNNING Program ...
  PartID:      :0x01
  Partition ID  : 0x02
Time elapsed during the download operation is: 00:00:00.107
RUNNING Program ...
  PartID:      :0x02
Start operation done successfully at partition 0x02
  Partition ID  : 0x03
Time elapsed during the download operation is: 00:00:00.326
RUNNING Program ...
  PartID:      :0x03
Opening and parsing file: st-image-bootfs-openstlinux-weston-stm32mp1.ext4
  File          : st-image-bootfs-openstlinux-weston-stm32mp1.ext4
  Partition ID  : 0x11
Time elapsed during the download operation is: 00:00:32.392
RUNNING Program ...
  PartID:      :0x11
Start operation done successfully at partition 0x11
Opening and parsing file: st-image-weston-openstlinux-weston-stm32mp1.ext4
  File          : st-image-weston-openstlinux-weston-stm32mp1.ext4
  Partition ID  : 0x12
Time elapsed during the download operation is: 00:04:06.544
RUNNING Program ...
  PartID:      :0x12
Start operation done successfully at partition 0x12
Opening and parsing file: st-image-userfs-openstlinux-weston-stm32mp1.ext4
  File          : st-image-userfs-openstlinux-weston-stm32mp1.ext4
  Partition ID  : 0x13
Time elapsed during the download operation is: 00:00:32.095
RUNNING Program ...
  PartID:      :0x13
Start operation done successfully at partition 0x13
5. Boot the board[edit source]
  • Set the boot switches (located at the back of the board) to the on position
  • After few seconds, the board starts and automatically go through the following screens
UBoot splash screen
Linux splash screen
Weston desktop
GTK demo launcher
