This page reports measured performance when using the pure software cryptographic library algorithms with an STM32N6 MCU. In addition to performance figures, the required code footprint and memory are also given.
Measurements are done while executing the code from the external flash memory in execute-in-place mode (XIP).
1. Measurement configuration
1.1. Hardware configuration
| STM32 MCU | STM32N657X0H3Q |
| Device ID | 0x486 |
| Revision ID | 0x200 |
| Board | NUCLEO-N657X0-Q |
1.2. Firmware configuration
| Cryptographic library version | 050000B2[ver. 1] |
- ↑ This value corresponds to the information returned by a call to
cmox_getInfos
1.3. System configuration
| System core clock frequency | 600 MHz |
| Voltage scaling | Range 0 |
| Instruction cache (ART/ICU) | 1 (0: disabled / 1: enabled) |
| Data cache (ART/DCU) | 1 (0: disabled / 1: enabled) |
1.4. Development toolchains and compilers
| IAR Embedded Workbench | IAR ANSI C/C++ Compiler V9.40.1.364/W64 for ARM |
2. Performance values
2.1. AES symmetric key encryption and decryption
This section provides the performance results for AES-CBC using different operation modes:
- Sole buffer: one sole buffer is encrypted or decrypted. The performance time is given in µs.
- Data flow: a big message is encrypted or decrypted in chunks. The bit rate is given in kilobytes per second.
2.1.1. Sole buffer mode
In this mode, the entire encryption or decryption process, for the full message size, is managed through a single API call provided by the CMOX library.
The table below shows the number of clock cycles and time (in µs) needed to perform the described operation in small and fast configurations.
| AES mode | Key size | Buffer size | Cipher operation | Configuration | Cycles | Time |
| AES CBC | 128 bits | 32 bytes | Encryption | Small | 17 280 | 28 µs |
| AES CBC | 128 bits | 32 bytes | Encryption | Fast | 26 056 | 43 µs |
| AES CBC | 128 bits | 64 bytes | Encryption | Small | 19 792 | 32 µs |
| AES CBC | 128 bits | 64 bytes | Encryption | Fast | 27 760 | 46 µs |
| AES CBC | 128 bits | 128 bytes | Encryption | Small | 24 424 | 40 µs |
| AES CBC | 128 bits | 128 bytes | Encryption | Fast | 31 184 | 51 µs |
| AES CBC | 192 bits | 32 bytes | Encryption | Small | 19 032 | 31 µs |
| AES CBC | 192 bits | 32 bytes | Encryption | Fast | 26 936 | 44 µs |
| AES CBC | 192 bits | 64 bytes | Encryption | Small | 21 752 | 36 µs |
| AES CBC | 192 bits | 64 bytes | Encryption | Fast | 28 976 | 48 µs |
| AES CBC | 192 bits | 128 bytes | Encryption | Small | 27 184 | 45 µs |
| AES CBC | 192 bits | 128 bytes | Encryption | Fast | 32 880 | 54 µs |
| AES CBC | 256 bits | 32 bytes | Encryption | Small | 20 056 | 33 µs |
| AES CBC | 256 bits | 32 bytes | Encryption | Fast | 27 984 | 46 µs |
| AES CBC | 256 bits | 64 bytes | Encryption | Small | 23 416 | 39 µs |
| AES CBC | 256 bits | 64 bytes | Encryption | Fast | 30 320 | 50 µs |
| AES CBC | 256 bits | 128 bytes | Encryption | Small | 29 568 | 49 µs |
| AES CBC | 256 bits | 128 bytes | Encryption | Fast | 34 680 | 57 µs |
| AES CBC | 128 bits | 32 bytes | Decryption | Small | 22 608 | 37 µs |
| AES CBC | 128 bits | 32 bytes | Decryption | Fast | 40 216 | 67 µs |
| AES CBC | 128 bits | 64 bytes | Decryption | Small | 26 296 | 43 µs |
| AES CBC | 128 bits | 64 bytes | Decryption | Fast | 42 104 | 70 µs |
| AES CBC | 128 bits | 128 bytes | Decryption | Small | 33 368 | 55 µs |
| AES CBC | 128 bits | 128 bytes | Decryption | Fast | 45 576 | 75 µs |
| AES CBC | 192 bits | 32 bytes | Decryption | Small | 24 304 | 40 µs |
| AES CBC | 192 bits | 32 bytes | Decryption | Fast | 40 784 | 67 µs |
| AES CBC | 192 bits | 64 bytes | Decryption | Small | 28 480 | 47 µs |
| AES CBC | 192 bits | 64 bytes | Decryption | Fast | 42 872 | 71 µs |
| AES CBC | 192 bits | 128 bytes | Decryption | Small | 36 776 | 61 µs |
| AES CBC | 192 bits | 128 bytes | Decryption | Fast | 46 792 | 77 µs |
| AES CBC | 256 bits | 32 bytes | Decryption | Small | 25 600 | 42 µs |
| AES CBC | 256 bits | 32 bytes | Decryption | Fast | 42 576 | 70 µs |
| AES CBC | 256 bits | 64 bytes | Decryption | Small | 30 392 | 50 µs |
| AES CBC | 256 bits | 64 bytes | Decryption | Fast | 44 912 | 74 µs |
| AES CBC | 256 bits | 128 bytes | Decryption | Small | 39 960 | 66 µs |
| AES CBC | 256 bits | 128 bytes | Decryption | Fast | 49 616 | 82 µs |
The table below shows flash memory and RAM usage (in bytes).
| Cipher operation | Configuration | Code | Constant data | Global data | Stack usage |
| Encryption | Small | 2386 bytes | 324 bytes | 0 bytes | 552 bytes |
| Encryption | Fast | 2330 bytes | 1092 bytes | 0 bytes | 552 bytes |
| Decryption | Small | 2746 bytes | 580 bytes | 0 bytes | 568 bytes |
| Decryption | Fast | 2696 bytes | 2372 bytes | 0 bytes | 568 bytes |
2.1.2. Data flow mode
In this mode, the operation is performed in several calls to the CMOX library APIs, as shown below:
cmox_cipher_initcmox_cipher_setKeycmox_cipher_setIVcmox_cipher_append: called several times to encrypt or decrypt the whole message in fixed-size chunks
The table below shows the number of clock cycles and the bit rate (in kilobytes per second) needed to perform the described operation in small and fast configuration.
| AES mode | Key size | Message size | Chunk size | Cipher operation | Configuration | Cycles | Bit rate |
| AES CBC | 128 bits | 8000 bytes | 128 bytes | Encryption | Small | 595 896 | 8055 Kbytes/s |
| AES CBC | 128 bits | 8000 bytes | 128 bytes | Encryption | Fast | 452 664 | 10 603 Kbytes/s |
| AES CBC | 128 bits | 8000 bytes | 512 bytes | Encryption | Small | 590 496 | 8128 Kbytes/s |
| AES CBC | 128 bits | 8000 bytes | 512 bytes | Encryption | Fast | 447 088 | 10 736 Kbytes/s |
| AES CBC | 128 bits | 8000 bytes | 1024 bytes | Encryption | Small | 589 688 | 8139 Kbytes/s |
| AES CBC | 128 bits | 8000 bytes | 1024 bytes | Encryption | Fast | 445 952 | 10 763 Kbytes/s |
| AES CBC | 128 bits | 8000 bytes | 2048 bytes | Encryption | Small | 589 032 | 8148 Kbytes/s |
| AES CBC | 128 bits | 8000 bytes | 2048 bytes | Encryption | Fast | 446 792 | 10 743 Kbytes/s |
| AES CBC | 192 bits | 8000 bytes | 128 bytes | Encryption | Small | 687 856 | 6978 Kbytes/s |
| AES CBC | 192 bits | 8000 bytes | 128 bytes | Encryption | Fast | 512 864 | 9359 Kbytes/s |
| AES CBC | 192 bits | 8000 bytes | 512 bytes | Encryption | Small | 682 360 | 7034 Kbytes/s |
| AES CBC | 192 bits | 8000 bytes | 512 bytes | Encryption | Fast | 507 320 | 9461 Kbytes/s |
| AES CBC | 192 bits | 8000 bytes | 1024 bytes | Encryption | Small | 681 560 | 7042 Kbytes/s |
| AES CBC | 192 bits | 8000 bytes | 1024 bytes | Encryption | Fast | 505 544 | 9494 Kbytes/s |
| AES CBC | 192 bits | 8000 bytes | 2048 bytes | Encryption | Small | 680 776 | 7050 Kbytes/s |
| AES CBC | 192 bits | 8000 bytes | 2048 bytes | Encryption | Fast | 503 816 | 9527 Kbytes/s |
| AES CBC | 256 bits | 8000 bytes | 128 bytes | Encryption | Small | 779 232 | 6159 Kbytes/s |
| AES CBC | 256 bits | 8000 bytes | 128 bytes | Encryption | Fast | 562 936 | 8526 Kbytes/s |
| AES CBC | 256 bits | 8000 bytes | 512 bytes | Encryption | Small | 773 824 | 6202 Kbytes/s |
| AES CBC | 256 bits | 8000 bytes | 512 bytes | Encryption | Fast | 559 400 | 8580 Kbytes/s |
| AES CBC | 256 bits | 8000 bytes | 1024 bytes | Encryption | Small | 773 016 | 6209 Kbytes/s |
| AES CBC | 256 bits | 8000 bytes | 1024 bytes | Encryption | Fast | 557 368 | 8611 Kbytes/s |
| AES CBC | 256 bits | 8000 bytes | 2048 bytes | Encryption | Small | 772 216 | 6215 Kbytes/s |
| AES CBC | 256 bits | 8000 bytes | 2048 bytes | Encryption | Fast | 555 552 | 8640 Kbytes/s |
| AES CBC | 128 bits | 8000 bytes | 128 bytes | Decryption | Small | 943 368 | 5088 Kbytes/s |
| AES CBC | 128 bits | 8000 bytes | 128 bytes | Decryption | Fast | 497 032 | 9657 Kbytes/s |
| AES CBC | 128 bits | 8000 bytes | 512 bytes | Decryption | Small | 915 272 | 5244 Kbytes/s |
| AES CBC | 128 bits | 8000 bytes | 512 bytes | Decryption | Fast | 469 152 | 10 231 Kbytes/s |
| AES CBC | 128 bits | 8000 bytes | 1024 bytes | Decryption | Small | 908 352 | 5284 Kbytes/s |
| AES CBC | 128 bits | 8000 bytes | 1024 bytes | Decryption | Fast | 464 712 | 10 328 Kbytes/s |
| AES CBC | 128 bits | 8000 bytes | 2048 bytes | Decryption | Small | 904 088 | 5309 Kbytes/s |
| AES CBC | 128 bits | 8000 bytes | 2048 bytes | Decryption | Fast | 462 480 | 10 378 Kbytes/s |
| AES CBC | 192 bits | 8000 bytes | 128 bytes | Decryption | Small | 1 100 512 | 4361 Kbytes/s |
| AES CBC | 192 bits | 8000 bytes | 128 bytes | Decryption | Fast | 552 480 | 8688 Kbytes/s |
| AES CBC | 192 bits | 8000 bytes | 512 bytes | Decryption | Small | 1 072 344 | 4476 Kbytes/s |
| AES CBC | 192 bits | 8000 bytes | 512 bytes | Decryption | Fast | 524 888 | 9144 Kbytes/s |
| AES CBC | 192 bits | 8000 bytes | 1024 bytes | Decryption | Small | 1 065 800 | 4503 Kbytes/s |
| AES CBC | 192 bits | 8000 bytes | 1024 bytes | Decryption | Fast | 520 184 | 9227 Kbytes/s |
| AES CBC | 192 bits | 8000 bytes | 2048 bytes | Decryption | Small | 1 061 128 | 4523 Kbytes/s |
| AES CBC | 192 bits | 8000 bytes | 2048 bytes | Decryption | Fast | 517 088 | 9282 Kbytes/s |
| AES CBC | 256 bits | 8000 bytes | 128 bytes | Decryption | Small | 1 255 328 | 3823 Kbytes/s |
| AES CBC | 256 bits | 8000 bytes | 128 bytes | Decryption | Fast | 607 920 | 7895 Kbytes/s |
| AES CBC | 256 bits | 8000 bytes | 512 bytes | Decryption | Small | 1 228 288 | 3907 Kbytes/s |
| AES CBC | 256 bits | 8000 bytes | 512 bytes | Decryption | Fast | 581 824 | 8249 Kbytes/s |
| AES CBC | 256 bits | 8000 bytes | 1024 bytes | Decryption | Small | 1 221 088 | 3930 Kbytes/s |
| AES CBC | 256 bits | 8000 bytes | 1024 bytes | Decryption | Fast | 576 424 | 8327 Kbytes/s |
| AES CBC | 256 bits | 8000 bytes | 2048 bytes | Decryption | Small | 1 216 832 | 3944 Kbytes/s |
| AES CBC | 256 bits | 8000 bytes | 2048 bytes | Decryption | Fast | 575 872 | 8335 Kbytes/s |
| Encryption | Small | 2306 bytes | 316 bytes | 0 bytes | 176 bytes |
| Encryption | Fast | 2250 bytes | 1084 bytes | 0 bytes | 176 bytes |
| Decryption | Small | 2666 bytes | 572 bytes | 0 bytes | 192 bytes |
| Decryption | Fast | 2616 bytes | 2364 bytes | 0 bytes | 192 bytes |
2.2. HASH digest
In this section we provide the performance results for HASH, using different modes of operation:
- Sole buffer: one sole buffer is hashed. The performance time is given in us.
- Data flow: a big message is hashed in chunks. The bit rate is given in bytes per second.
2.2.1. Sole buffer mode
In this mode, the entire message hashing process is managed through a single API call provided by the CMOX library.
The table below shows the number of clock cycles and time (in µs) needed to perform the described operation.
| HASH mode | Buffer size | Cycles | Time |
| SHA256 | 32 bytes | 17 600 | 29 µs |
| SHA256 | 64 bytes | 20 608 | 34 µs |
| SHA256 | 128 bytes | 23 624 | 39 µs |
| SHA384 | 32 bytes | 27 744 | 46 µs |
| SHA384 | 64 bytes | 27 960 | 46 µs |
| SHA384 | 128 bytes | 39 136 | 65 µs |
| HASH mode | Code | Constant data | Global data | Stack usage |
| SHA256 | 1394 | 280 bytes | 0 bytes | 536 bytes |
| SHA384 | 2590 | 728 bytes | 0 bytes | 1076 bytes |
2.2.2. Data flow mode
cmox_hash_initcmox_hash_append: called several times to hash the whole message in fixed-size chunkscmox_hash_generateTag
The table below shows the number of clock cycles and the bit rate (in kilobytes per second) needed to perform the described operation.
| HASH mode | Message size | Chunk size | Cycles | Bit rate |
| SHA256 | 8000 bytes | 128 bytes | 387 016 | 12 402 Kbytes/s |
| SHA256 | 8000 bytes | 512 bytes | 365 256 | 13 141 Kbytes/s |
| SHA256 | 8000 bytes | 1024 bytes | 361 528 | 13 276 Kbytes/s |
| SHA256 | 8000 bytes | 2048 bytes | 359 696 | 13 344 Kbytes/s |
| SHA384 | 8000 bytes | 128 bytes | 728 696 | 6587 Kbytes/s |
| SHA384 | 8000 bytes | 512 bytes | 689 496 | 6961 Kbytes/s |
| SHA384 | 8000 bytes | 1024 bytes | 682 688 | 7031 Kbytes/s |
| SHA384 | 8000 bytes | 2048 bytes | 679 440 | 7064 Kbytes/s |
The table below shows the final tag generation done through the call to cmox_hash_generateTag.
| HASH mode | Cycles | Time |
| SHA256 | 6672 | 11 µs |
| SHA384 | 16 304 | 27 µs |
| SHA256 | 1390 bytes | 272 bytes | 0 bytes | 344 bytes |
| SHA384 | 2586 bytes | 720 bytes | 0 bytes | 780 bytes |
2.3. ECDSA signature and verification
This section provides the performance results for ECDSA signature and verification.
The table below shows the number of clock cycles and time (in ms) needed to perform the described operation in different configurations.
| Curve | Operation | ECC mathematics configuration | Curve definition | Cycles | Time |
| SECP256R1 | Signature | Small | Low | 2 796 080 | 4 ms |
| SECP256R1 | Signature | Small | High | 2 730 464 | 4 ms |
| SECP256R1 | Signature | SuperFast | Low | 1 690 544 | 2 ms |
| SECP256R1 | Signature | SuperFast | High | 1 636 848 | 2 ms |
| SECP256R1 | Verification | Small | Low | 6 640 904 | 11 ms |
| SECP256R1 | Verification | Small | High | 5 936 048 | 9 ms |
| SECP256R1 | Verification | SuperFast | Low | 4 058 896 | 6 ms |
| SECP256R1 | Verification | SuperFast | High | 3 593 968 | 5 ms |
| SECP384R1 | Signature | Small | Low | 8 079 432 | 13 ms |
| SECP384R1 | Signature | Small | High | 7 675 128 | 12 ms |
| SECP384R1 | Signature | Fast | Low | 5 694 160 | 9 ms |
| SECP384R1 | Signature | Fast | High | 5 442 176 | 9 ms |
| SECP384R1 | Verification | Small | Low | 19 598 448 | 32 ms |
| SECP384R1 | Verification | Small | High | 16 598 672 | 27 ms |
| SECP384R1 | Verification | Fast | Low | 13 472 792 | 22 ms |
| SECP384R1 | Verification | Fast | High | 11 715 672 | 19 ms |
The table below shows ECDSA flash memory and RAM usage (in bytes).
| Curve | Operation | ECC mathematics configuration | Curve definition | Code | Constant data | Global data | Stack usage | Working buffer |
| SECP256R1 | Signature | Small | Low | 13 472 bytes | 1212 bytes | 0 bytes | 440 bytes | 628 bytes |
| SECP256R1 | Signature | Small | High | 13 472 bytes | 1596 bytes | 0 bytes | 440 bytes | 696 bytes |
| SECP256R1 | Signature | SuperFast | Low | 14 782 bytes | 1212 bytes | 0 bytes | 444 bytes | 628 bytes |
| SECP256R1 | Signature | SuperFast | High | 14 782 bytes | 1596 bytes | 0 bytes | 444 bytes | 696 bytes |
| SECP256R1 | Verification | Small | Low | 13 460 bytes | 1212 bytes | 0 bytes | 488 bytes | 856 bytes |
| SECP256R1 | Verification | Small | High | 13 460 bytes | 1596 bytes | 0 bytes | 488 bytes | 1648 bytes |
| SECP256R1 | Verification | SuperFast | Low | 14 770 bytes | 1212 bytes | 0 bytes | 492 bytes | 856 bytes |
| SECP256R1 | Verification | SuperFast | High | 14 770 bytes | 1596 bytes | 0 bytes | 492 bytes | 1648 bytes |
| SECP384R1 | Signature | Small | Low | 13 472 bytes | 1692 bytes | 0 bytes | 440 bytes | 884 bytes |
| SECP384R1 | Signature | Small | High | 13 472 bytes | 2268 bytes | 0 bytes | 440 bytes | 984 bytes |
| SECP384R1 | Signature | Fast | Low | 13 842 bytes | 1692 bytes | 0 bytes | 456 bytes | 884 bytes |
| SECP384R1 | Signature | Fast | High | 13 842 bytes | 2268 bytes | 0 bytes | 456 bytes | 984 bytes |
| SECP384R1 | Verification | Small | Low | 13 460 bytes | 1692 bytes | 0 bytes | 488 bytes | 1192 bytes |
| SECP384R1 | Verification | Small | High | 13 460 bytes | 2268 bytes | 0 bytes | 488 bytes | 2272 bytes |
| SECP384R1 | Verification | Fast | Low | 13 830 bytes | 1692 bytes | 0 bytes | 504 bytes | 1192 bytes |
| SECP384R1 | Verification | Fast | High | 13 830 bytes | 2268 bytes | 0 bytes | 504 bytes | 2272 bytes |
2.4. EdDSA signature and verification
This section provides the performance results for EdDSA signature and verification.
| Curve | Message size | Operation | ECC mathematics configuration | Curve definition | Cycles | Time |
| Ed25519 | 1023 bytes | Signature | Small | OptLow | 4 203 528 | 7 ms |
| Ed25519 | 1023 bytes | Signature | Small | OptHigh | 2 461 264 | 4 ms |
| Ed25519 | 1023 bytes | Signature | SuperFast | OptLow | 2 788 800 | 4 ms |
| Ed25519 | 1023 bytes | Signature | SuperFast | OptHigh | 1 677 224 | 2 ms |
| Ed25519 | 1023 bytes | Verification | Small | OptLow | 6 379 832 | 10 ms |
| Ed25519 | 1023 bytes | Verification | Small | OptHigh | 5 587 352 | 9 ms |
| Ed25519 | 1023 bytes | Verification | SuperFast | OptLow | 4 027 000 | 6 ms |
| Ed25519 | 1023 bytes | Verification | SuperFast | OptHigh | 3 545 368 | 5 ms |
The table below shows EdDSA flash memory and RAM usage (in bytes).
| Curve | Message size | Operation | ECC mathematics configuration | Curve definition | Code | Constant data | Global data | Stack usage | Working buffer |
| Ed25519 | 1023 bytes | Signature | Small | OptLow | 14 852 bytes | 1748 bytes | 0 bytes | 1172 bytes | 1672 bytes |
| Ed25519 | 1023 bytes | Signature | Small | OptHigh | 15 272 bytes | 2900 bytes | 0 bytes | 1172 bytes | 1672 bytes |
| Ed25519 | 1023 bytes | Signature | SuperFast | OptLow | 16 162 bytes | 1748 bytes | 0 bytes | 1172 bytes | 1672 bytes |
| Ed25519 | 1023 bytes | Signature | SuperFast | OptHigh | 16 582 bytes | 2900 bytes | 0 bytes | 1172 bytes | 1672 bytes |
| Ed25519 | 1023 bytes | Verification | Small | OptLow | 14 848 bytes | 1748 bytes | 0 bytes | 1172 bytes | 984 bytes |
| Ed25519 | 1023 bytes | Verification | Small | OptHigh | 15 268 bytes | 2900 bytes | 0 bytes | 1172 bytes | 1992 bytes |
| Ed25519 | 1023 bytes | Verification | SuperFast | OptLow | 16 158 bytes | 1748 bytes | 0 bytes | 1172 bytes | 984 bytes |
| Ed25519 | 1023 bytes | Verification | SuperFast | OptHigh | 16 578 bytes | 2900 bytes | 0 bytes | 1172 bytes | 1992 bytes |
2.5. RSA signature and verification
This section provides the performance results for RSA signature and verification.
| PKCS#1 | Priv. key mod. exp. method | Hash method | Modulus size | Operation | RSA mathematics configuration | Priv. key mod. exp. implementation | Cycles | Time |
| v2.2 | CRT | SHA-256 | 3K | Signature | Small | Low | 197 619 160 | 329 ms |
| v2.2 | CRT | SHA-256 | 3K | Signature | Small | Mid | 148 706 336 | 247 ms |
| v2.2 | CRT | SHA-256 | 3K | Signature | Small | High | 124 884 768 | 208 ms |
| v2.2 | CRT | SHA-256 | 3K | Signature | Fast | Low | 120 195 056 | 200 ms |
| v2.2 | CRT | SHA-256 | 3K | Signature | Fast | Mid | 90 544 792 | 150 ms |
| v2.2 | CRT | SHA-256 | 3K | Signature | Fast | High | 76 097 544 | 126 ms |
| v2.2 | No CRT | SHA-256 | 3K | Signature | Small | Low | 762 019 472 | 1270 ms |
| v2.2 | No CRT | SHA-256 | 3K | Signature | Small | Mid | 572 279 400 | 953 ms |
| v2.2 | No CRT | SHA-256 | 3K | Signature | Small | High | 478 690 048 | 797 ms |
| v2.2 | No CRT | SHA-256 | 3K | Signature | Fast | Low | 455 278 128 | 758 ms |
| v2.2 | No CRT | SHA-256 | 3K | Signature | Fast | Mid | 342 001 136 | 570 ms |
| v2.2 | No CRT | SHA-256 | 3K | Signature | Fast | High | 286 093 152 | 476 ms |
| v2.2 | n/a | SHA-256 | 3K | Verification | Small | n/a | 3 716 768 | 6 ms |
| v2.2 | n/a | SHA-256 | 3K | Verification | Fast | n/a | 2 771 616 | 4 ms |
The table below shows RSA flash memory and RAM usage (in bytes).
| PKCS#1 | Priv. key mod. exp. method | Hash method | Modulus size | Operation | RSA mathematics configuration | Priv. key mod. exp. implementation | Code | Constant data | Global data | Stack usage | Working buffer |
| v2.2 | CRT | SHA-256 | 3K | Signature | Small | Low | 6914 bytes | 372 bytes | 0 bytes | 672 bytes | 3704 bytes |
| v2.2 | CRT | SHA-256 | 3K | Signature | Small | Mid | 7150 bytes | 372 bytes | 0 bytes | 672 bytes | 4308 bytes |
| v2.2 | CRT | SHA-256 | 3K | Signature | Small | High | 7150 bytes | 372 bytes | 0 bytes | 672 bytes | 6708 bytes |
| v2.2 | CRT | SHA-256 | 3K | Signature | Fast | Low | 7284 bytes | 372 bytes | 0 bytes | 672 bytes | 3704 bytes |
| v2.2 | CRT | SHA-256 | 3K | Signature | Fast | Mid | 7520 bytes | 372 bytes | 0 bytes | 672 bytes | 4308 bytes |
| v2.2 | CRT | SHA-256 | 3K | Signature | Fast | High | 7520 bytes | 372 bytes | 0 bytes | 672 bytes | 6708 bytes |
| v2.2 | No CRT | SHA-256 | 3K | Signature | Small | Low | 5982 bytes | 364 bytes | 0 bytes | 672 bytes | 3484 bytes |
| v2.2 | No CRT | SHA-256 | 3K | Signature | Small | Mid | 6218 bytes | 364 bytes | 0 bytes | 672 bytes | 4664 bytes |
| v2.2 | No CRT | SHA-256 | 3K | Signature | Small | High | 6218 bytes | 364 bytes | 0 bytes | 672 bytes | 9368 bytes |
| v2.2 | No CRT | SHA-256 | 3K | Signature | Fast | Low | 6352 bytes | 364 bytes | 0 bytes | 672 bytes | 3484 bytes |
| v2.2 | No CRT | SHA-256 | 3K | Signature | Fast | Mid | 6588 bytes | 364 bytes | 0 bytes | 672 bytes | 4664 bytes |
| v2.2 | No CRT | SHA-256 | 3K | Signature | Fast | High | 6588 bytes | 364 bytes | 0 bytes | 672 bytes | 9368 bytes |
| v2.2 | n/a | SHA-256 | 3K | Verification | Small | n/a | 6172 bytes | 368 bytes | 0 bytes | 688 bytes | 3108 bytes |
| v2.2 | n/a | SHA-256 | 3K | Verification | Fast | n/a | 6542 bytes | 368 bytes | 0 bytes | 688 bytes | 3108 bytes |
2.6. Post-Quantum Cryptography ML-DSA key pair generation, Signature and verification
This section provides the performance results for ML-DSA key pair generation, signature and verification.
The table below shows the number of clock cycles and time (in ms) needed to perform the described function in different suites and functions configurations. Note: For signature generation, the number of clock cycles is not bounded in time. The measurement was taken using one predefined private key and one 32-byte message, and the reported value corresponds to the minimum observed time.
| Suite | Function | Cycles | Time (in ms) | Stack usage | Working buffer |
| ML-DSA-44 | keyGen | 1 995 560 | 3 | 476 | 7116 |
| ML-DSA-65 | keyGen | 3 467 696 | 5 | 476 | 8140 |
| ML-DSA-87 | keyGen | 5 794 144 | 9 | 476 | 10 188 |
| ML-DSA-44 | Signature | 3 673 336 | 6 | 772 | 30 796 |
| ML-DSA-44 | Signature Low RAM | 3 689 504 | 6 | 756 | 11 340 |
| ML-DSA-65 | Signature | 5 579 912 | 9 | 772 | 43 084 |
| ML-DSA-65 | Signature Low RAM | 5 705 576 | 9 | 756 | 15 436 |
| ML-DSA-87 | Signature | 8 787 960 | 14 | 772 | 57 420 |
| ML-DSA-87 | Signature Low RAM | 8 885 304 | 14 | 756 | 19 532 |
| ML-DSA-44 | Verification | 2 292 168 | 3 | 700 | 8908 |
| ML-DSA-44 | Verification Low RAM | 2 937 960 | 4 | 700 | 4812 |
| ML-DSA-65 | Verification | 3 788 736 | 6 | 700 | 9948 |
| ML-DSA-65 | Verification Low RAM | 5 171 952 | 8 | 700 | 4828 |
| ML-DSA-87 | Verification | 6 186 984 | 10 | 700 | 12 268 |
| ML-DSA-87 | Verification Low RAM | 8 937 192 | 14 | 700 | 5100 |
2.7. Post-Quantum Cryptography ML-KEM key pair generation, encapsulation, decapsulation
This section provides the performance results for ML-KEM key pair generation, encapsulation and decapsulation.
The table below shows the number of clock cycles and time (in ms) needed to perform the described function in different functions and suites.
| Function | Suites | Cycles | Time (in ms) | Stack usage |
| Key-pair-Generation | ML-KEM-512 | 654 216 | 1 | 3 060 |
| Key-pair-Generation | ML-KEM-768 | 1 050 832 | 2 | 3 572 |
| Key-pair-Generation | ML-KEM-1024 | 1 626 496 | 3 | 4 084 |
| Key-Encapsulation | ML-KEM-512 | 1 916 376 | 3 | 4 588 |
| Key-Encapsulation | ML-KEM-768 | 2 754 800 | 5 | 5 100 |
| Key-Encapsulation | ML-KEM-1024 | 3 741 144 | 6 | 5 612 |
| Key-Decapsulation | ML-KEM-512 | 2 175 120 | 4 | 4 684 |
| Key-Decapsulation | ML-KEM-768 | 3 104 072 | 5 | 5 516 |
| Key-Decapsulation | ML-KEM-1024 | 4 189 560 | 7 | 6 508 |
2.8. Post-Quantum Cryptography HBS-LMS signature verification
This section provides the performance results for ML-LMS signature verification.
The table below shows the number of clock cycles minimum, average and maximum and average time (in ms) needed to perform the described function in different functions and suite. Note: Clock cycles were measured for 10 different generated key and message pairs, and the reported Cycles avg values are averages over these measurements.
| Function | Suite | Cycles min | Cycles avg | Time avg (in ms) | Cycles max | Stack usage |
| LMS-Verify | LMS_N32_H10_W1_SHA256 | 1 003 608 | 1 048 164 | 2 | 1 091 816 | 1 672 |
| LMS-Verify | LMS_N32_H10_W2_SHA256 | 1 013 680 | 1 082 000 | 2 | 1 174 272 | 1 672 |
| LMS-Verify | LMS_N32_H10_W4_SHA256 | 1 728 744 | 2 008 659 | 3 | 2 325 624 | 1 672 |
| LMS-Verify | LMS_N32_H10_W8_SHA256 | 14 903 960 | 17 122 736 | 29 | 19 522 408 | 1 672 |
